donne le retour de:
donne le retour de:
voici le résultat de la commande que vous avez demandé :
00:00.0 Host bridge: VIA Technologies, Inc. PT880 Ultra/PT894 Host Bridge
00:00.1 Host bridge: VIA Technologies, Inc. PT894 Host Bridge
00:00.2 Host bridge: VIA Technologies, Inc. PT894 Host Bridge
00:00.3 Host bridge: VIA Technologies, Inc. PT890 Host Bridge
00:00.4 Host bridge: VIA Technologies, Inc. PT894 Host Bridge
00:00.5 PIC: VIA Technologies, Inc. PT894 I/O APIC Interrupt Controller
00:00.7 Host bridge: VIA Technologies, Inc. PT894 Host Bridge
00:01.0 PCI bridge: VIA Technologies, Inc. VT8237/VX700 PCI Bridge
00:02.0 PCI bridge: VIA Technologies, Inc. PT890 PCI to PCI Bridge Controller
00:0f.0 IDE interface: VIA Technologies, Inc. VT8237A SATA 2-Port Controller (rev 80)
00:0f.1 IDE interface: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE (rev 07)
00:10.0 USB controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev a0)
00:10.1 USB controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev a0)
00:10.2 USB controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev a0)
00:10.3 USB controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev a0)
00:10.4 USB controller: VIA Technologies, Inc. USB 2.0 (rev 86)
00:11.0 ISA bridge: VIA Technologies, Inc. VT8237A PCI to ISA Bridge
00:11.7 Host bridge: VIA Technologies, Inc. VT8237/8251 Ultra VLINK Controller
00:12.0 Ethernet controller: VIA Technologies, Inc. VT6102 [Rhine-II] (rev 7c)
00:13.0 Host bridge: VIA Technologies, Inc. VT8237A Host Bridge
02:00.0 VGA compatible controller: NVIDIA Corporation G86 [Quadro NVS 290] (rev a1)
80:01.0 Audio device: VIA Technologies, Inc. VT8237A/VT8251 HDA Controller (rev 10)
Bonne soirée
va sur la page nvidia correspondant à ta carte:
http://www.nvidia.fr/Download/Find.aspx?lang=fr
tu as la liste des pilotes pour ta carte Quadro NVS 290,carte indiquée par la commande “lspci”
ensuite tu lances la commande:
qui te donnera la liste des pilotes installables par sgfxi correspondants à ta quadro NVS 290.
tu choisis le plus récent et tu l’installes par la commande:
et tu remontes les infos
sur le site de nvidia, le driver recommandé (le plus récent) est 173.1438.
Si je fais
je trouve dans la liste des autres drivers supportés 173.14.38, je suppose que c’est celui-là.
Hier j’ai essayé de l’installer mais le rendu graphique était pitoyable.
Ensuite j’ai voulu en essayer d’autres, j’ai fait
pour tout nettoyer mais impossible d’installer d’autres drivers via sgfxi.
Le message d’erreur parle d’une librairie libc manquante.
J’ai donc fais :
aptitude install xserver-xorg-video-nvidia nvidia-kernel-dkms
aptitude install nvidia-xconfig
dpkg-reconfigure xserver-xorg
nvidia-xconfig
service kdm restart
aptitude install mesa-utils
J’ai ensuite essayé d’installer :
– 173.14.37 --> erreur du script (driver non supporté par le script)
– 173.14.38 --> erreur du script (idem)
– 304.88 --> erreur du script (driver non compatible avec la version de fglrx installée)
– 319.49 installation ok, accélération matérielle activée mais présence des problèmes que j’ai évoqué dans mon précédent message.
Le driver 319.49 date du 20/08/2013, il est en troisième position, le deuxième n’étant pas disponible dans la liste du script sgfxi.
Pour info, voici la liste fournie par sgfxi :
'supported-drivers:' choices require -o <see -o for correct syntax> to install>.
Fglrx: default: 13.9
Other supported-drivers: 13.9 13-4 13.1 13.9 13-4 13.1 12.10 12-7 12-6 12-4 12-3 12-2
12-1 11-12 11-11 11-10 11-9 11-8 11-7 11-6 11-5 11-4 11-3 11-2 11-1
Nvidia: defaults (current + legacy - 3 2 1): 325.15 304.108 173.14.38 96.43.23 71.86.15
Other supported-drivers: 319.49 313.30 313.26 310.44 310.40 304.88 304.84
295.71 290.10 285.05.09 280.13 275.43 270.41.19 260.19.44 256.53 195.36.31 190.53
185.18.36 180.60 177.82 173.14.37 173.14.36 169.12 100.14.19 96.43.20 71.86.14
et la liste des drivers de ma carte obtenue sur le site nvidia :
173.1438 1.10.2013
319.60 1.10.2013
319.49 20.8.2013
319.32 25.6.2013
319.23 23.5.2013
319.17 2.5.2013
173.1437 5.4.2013
304.88 2.4.2013
310.44 2.4.2013
310.40 8.3.2013
304.84 4.3.2013
310.32 21.1.2013
310.19 16.11.2012
304.64 6.11.2012
304.60 18.10.2012
173.1436 4.10.2012
304.51 24.9.2012
96.4323 14.9.2012
295.75 31.8.2012
304.43 27.8.2012
Quelle est la meilleure méthode pour installer le driver nvidia?
Suis-je obligé de réinstaller debian à chaque fois ou bien le script sgfxi suffit-il?
Dois-je exécuté la commande sgfxi -! 32 pour supprimer tous les drivers entre deux installations de drivers et comment faire si j’ai encore le message d’erreur que le script ne veut pas fonctionner car la librairie lbc est absente?
Le script sgfxi parle de Fglrx, pourtant à aucun moment, je n’ai choisi de version pour ce programme. Faut-il installer une version précise de ce programme?
Bonne journée.
je ne comprends plus rien dans cette histoire,reprenons depuis le début:
comment as tu installé ta debian? avec quelle iso? pour quel bureau?gnome?kde?xfce?Et pourquoi est il fait mention de fglrx?ou de l’absence de libc?Pas normal tout ça
Réponds à toutes ces questions pour envisager une réinstallation de debian sur de bonnes bases parce que je n’ai jamais rencontré tous ces problèmes pour installer un pilote nvidia.
désolé d’avoir été confus.
J’ai fait une installation de debian à partir du cd netinstall.
J’ai utilisé l’iso pour installer le bureau kde (debian-7.1.0-i386-kde-CD-1.iso).
J’ai fait une installation standard. Une fois celle-ci terminée, j’ai ajouté les dépôts contrib et non-free dans le fichier sources.list. J’ai aussi commenté la ligne concernant le cd servant à l’installation.
fglrx apparaît quand je lance la commande sfgxi -h. Voici une partie des informations qui apparaissent lors que j’exécute cette commande :
The following beta drivers are available:
nvidia: 331.13
fgrlx: 13.10
Le message d’erreur sur l’absence de libc apparaît lorsque je désinstalle le driver nvidia et que j’essaye d’en installer un autre :
sgfxi -! 32
sgfxi -o xxx
Si j’ai bien compris la doc l’option -! 32 de sgfxi permet de se remettre dans la configuration par défaut au niveau des drivers :
[quote]J’ai fait une installation de debian à partir du cd netinstall.
J’ai utilisé l’iso pour installer le bureau kde (debian-7.1.0-i386-kde-CD-1.iso).[/quote]
deux sources différentes pour installer une debian et des emmerdements par la suite.Pourquoi ne pas avoir installé debian simplement avec le cd debian-7.1.0-i386-kde-CD-1.iso,tu aurais évité tous ces embrouilles.Je serais toi je ne persévérerais pas dans le bricolage et je réinstallerais une debian propre avec le cd kde.Mais ça n’engage que moi.
Je pense qu’on s’est mal compris.
J’ai bien utilisé l’iso debian-7.1.0-i386-kde-CD-1.iso, et ensuite j’ai essayé d’installer le driver nvidia propriétaire.
Pour moi le cd netinstall, c’est celui qui, au contraire du dvd, télécharge des données sur le net pour faire son installation.
Pour moi, le cd iso avec kde est un cd netinstall, celui avec gnome aussi, etc…
Je pense que je 'ai pas utilisé le bon terme, désolé.
Au tout début j’ai fait une installation de debian qui propose le bureau gnome par défaut. j’ai ensuite installé le bureau kde, xfce et lxde pour choisir un bureau, via aptitude.
J’ai ensuite choisi le bureau qui me convenait, c’est-à-dire kde.
A partir de ce stade-là, j’ai pris l’iso avec kde et j’ai fait une nouvelle installation en prenant soin de formater toutes les partitions. Par la suite, suite aux problèmes que j’avais pour installer le driver nvidia propriétaire, toutes les installations que j’ai faite, je les ai faite avec l’iso.
Que faut-il que je fasse? Une réinstallation avec l’iso pour kde (ce que j’ai fait déjà plusieurs fois)?
Faut-il que j’efface les données des partitions?
Bonne soirée
recharge l’iso de wheezy en vérifiant bien le md5sum du téléchargement et vérifie aussi la gravure pour éviter toutes sources d’erreurs sinon on ne sait plus où on met les pieds,et ensuite tu reinstalles une debian propre.
http://cdimage.debian.org/debian-cd/7.2.0/i386/iso-cd/debian-7.2.0-i386-kde-CD-1.iso
j’ai téléchargé la version de debian que vous m’aviez indiqué.
J’ai testé le md5, sh1 et sh256, tout était ok.
Je l’ai gravé sur cd en testant si il y avait des erreurs. Tout était ok.
Pour la réinstallation de debian, je formatte seulement les partitions existantes ou bien il faut que j’efface les données?
Bonne soirée
tu sauvegardes tes données sur une partition ou sur support amovible genre clé usb ou cd ou disque externe et tu réinstalles debian sur la même partition avec le nouveau cd d’installation que tu viens de graver,une fois la réinstallation effectuée tu retrouveras ton win dans le grub.Pas besoin d’effacer les données qui sont écrites sur la partition debian,elles seront effacées au moment de la nouvelle installation.
Une remarque tu trouveras ce qu’il faut pour wheezy/nvidia version 325 sur
deb boisson.homeip.net/depot wheezy nvidia
Je l’ai fait pour clefagreg. Cela fonctionne pour des noyaux jusqu’au 3.10
merci fran.b pour l’info mais le driver nvidia version 325 n’est pas supporté par ma carte graphique.
Marcastro, pour l’installation du driver nvidia, je procède manuellement via aptitude
nvidia-xconfig
ou bien j’utilise le script sgfxi?
Si j’utilise le script sgfxi, dois-je forcer une version du driver ou bien le laisser faire?
En ce qui concerne la configuration des dépôts dans le fichier sources.list, précédemment, j’avais commenté la ligne du cd et ajouté les dépôts contrib et non-free avant de procéder à l’installation du driver. Dois-je refaire pareil?
Bonne soirée.
[quote]Si j’utilise le script sgfxi, dois-je forcer une version du driver ou bien le laisser faire?
commencer par laisser le script faire son boulot,sans aucune option(-o)il doit t’installer le pilote idoine le plus récent.
Ok et pour les dépôts dans le fichier sources.list, je commente le cd et j’ajoute les dépôts contrib et non-free avant d’installer le driver nvidia?
commenter les lignes relatives au cd et rajouter contrib et non-free et ne pas oublier:
apt-get update ou l’équivalent pour aptitude et ensuite tu passes en mode console pour lancer sgfxi
je viens d’installer debian et d’utiliser le script sgfxi pour installer le driver nvidia.
La version du driver nvidia installé par le script est le 325.15.
L’affichage est horrible, cela crante de partout, par contre il n’y a plus l’air d’avoir des erreurs quand je scrole sur un navigateur web.
Je pense qu’il faudrait changer de version de driver.
Comment je fait?
Je réinstalle debian ou bien je lance directement le script sfgxi avec la version du driver?
Dois-je exécuter la commande
sgfxi -! 32
avant d’installer un nouveau driver?
Bonne soirée.
le 325.15 n’est pas listé comme pilote de ta carte,d’après le site nvidia:
par contre le 319.49 est listé chez nvidia et également par le script sgfxi, donc tu vas essayer la manip suivant après être passé en mode console et devenu root:
et tu ne fais rien d’autre.
Certaines cartes nvidia peuvent être réticentes concernant l’installation des pilotes linux,la tienne est un exemple
je viens d’exécuter (en root et après avoir fait CTRL + ALT + F1) la commande
sgfxi -o 319.49
j’ai eu une erreur lors de l’installation du driver :
En examinant les logs, j’ai vu ceci :
Voulez-vous que je poste le fichier de log en entier?
PS : je n’ai fait qu’exécuter la commande, rien d’autre.
Bonne soirée.
il doit te manquer les headers,pour être sûr d’avoir tous les outils de compilation tu fais:
et relance sgfxi comme indiqué;Ctrl+Alt+F1 etc…
