Imprimante ML-2510
Bonjour mon imprimante Samsung Ml-2510 n est pas dans la iste d instalation le pilote proposer est pour ML-2550
ca ne fonctione pas avec ce pilote
amd 64 i386 version 6.04
avec ubuntu 10.04l imprimante a ete reconu d 'office
j ai fichiers que je ne peut pas installer
iscan_2.28.1-3-amd64.deb
iscan dat…deb
iscan plugin…deb
que faire
debutant en mode terminal pas bon en englais
merci de votre aide
Michel
[quote]j ai fichiers que je ne peut pas installer
iscan dat…deb
iscan plugin…deb
que faire [/quote]
pour installer un paquet machin.deb:
Pour plus d’infos sur dpkg:
ou:
olivier@debian:~$ apt-cache show printer-driver-splix
Package: printer-driver-splix
Source: splix
Version: 2.0.0+svn300-1.1
Installed-Size: 2776
Maintainer: Luca Niccoli <lultimouomo@gmail.com>
Architecture: amd64
Replaces: splix (<< 2.0.0+svn299-1)
Depends: libc6 (>= 2.3.2), libcups2 (>= 1.4.0), libcupsimage2 (>= 1.4.0), libgcc1 (>= 1:4.1.1), libstdc++6 (>= 4.1.1), cups (>= 1.5.0-3~), cups-client, ghostscript-cups
Breaks: splix (<< 2.0.0+svn299-1)
Description-en: Driver for Samsung and Xerox SPL2 and SPLc laser printers
 Support for printing to SPL2- and SPLc-based printers. These are most
 of the cheaper Samsung laser printers which do not understand standard
 languages like PostScript or PCL. Both monochrome (ML-15xx, ML-16xx,
 ML-17xx, ML-2xxx) and color (CLP-5xx, CLP-6xx) models are supported.
 Also some rebranded Samsungs like the Xerox Phaser 6100 work with this
 driver.
 Note that older SPL1-based models (ML-12xx, ML-14xx) do not work. Use
 these printers with the older "gdi" driver which is built into
 GhostScript.
Homepage: http://splix.ap2c.org/
Description-md5: bf769a48f0ca1c009ba9795570744dc3
Section: text
Priority: optional
Filename: pool/main/s/splix/printer-driver-splix_2.0.0+svn300-1.1_amd64.deb
MD5sum: 69e51e347c0d01cf224369535891173e
SHA1: aaecdfba67f49de7cafe0276d9cef263070f2871
SHA256: d10ba2e818f7c8cbf6ac6b1ed84dc8e95efce36520a815bed57bf7fcdc5e13d3
:whistle:
De michel819
probleme regler imprimante ML-2510 laser (monochrome)
dans google j ai chercher les cartouches laser pour mon imprimanteML 2510
cela done:ML1610 ,2010, 2010R, 2510,2570,2571n,scx4321
j ai tester 2570 pas bon,2010 tout fontione bien
merci de votre aide
Michel
