Imprimer avec Epson Stylus DX5050 (multifonctions)
Donc, impossible d’imprimer avec la DX5050 (qui a fonctionné un moment, et puis … plus du tout).
Le scanneur fonctionne, mtink aussi.
En ce qui concerne l’impression, le gestionnaire de tâches (gnome) s’ouvre, l’imprimante ne réagit pas, et passe à l’état “stoped” au bout d’un moment.
Les messages d’erreurs sont différents à chaque fois et ne m’aident pas … par exemple, voici (la fin seulement) du fichier d’erreurs généré par cups :
E [02/Mar/2008:15:36:32 +0100] CUPS-Reject-Jobs: Unauthorized E [02/Mar/2008:15:36:40 +0100] CUPS-Reject-Jobs: Unauthorized E [02/Mar/2008:15:36:45 +0100] Purge-Jobs: Unauthorized E [02/Mar/2008:15:36:49 +0100] CUPS-Accept-Jobs: Unauthorized E [02/Mar/2008:15:36:52 +0100] Resume-Printer: Unauthorized E [02/Mar/2008:15:37:34 +0100] [Job 9] Unable to open parallel port device file: Permission denied E [02/Mar/2008:15:37:34 +0100] PID 7080 (/usr/lib/cups/backend/epson) stopped with status 1! E [02/Mar/2008:15:37:41 +0100] Purge-Jobs: Unauthorized E [02/Mar/2008:15:37:49 +0100] Resume-Printer: Unauthorized E [02/Mar/2008:15:37:49 +0100] Resume-Printer: Unauthorized E [02/Mar/2008:15:39:04 +0100] Purge-Jobs: Unauthorized E [02/Mar/2008:15:39:23 +0100] [CGI] Unable to scan "@LOCAL"! E [02/Mar/2008:15:39:30 +0100] [cups-driverd] Unable to open PPD directory "/opt/share/ppd": No such file or directory E [02/Mar/2008:15:39:35 +0100] [cups-driverd] Unable to open PPD directory "/opt/share/ppd": No such file or directory E [02/Mar/2008:15:39:54 +0100] CUPS-Add-Modify-Printer: Unauthorized E [02/Mar/2008:15:39:55 +0100] CUPS-Add-Modify-Printer: Unauthorized E [02/Mar/2008:15:40:46 +0100] CUPS-Delete-Printer: Unauthorized E [02/Mar/2008:15:42:16 +0100] [cups-driverd] Unable to open PPD directory "/opt/share/ppd": No such file or directory E [02/Mar/2008:15:42:20 +0100] CUPS-Add-Modify-Printer: Unauthorized E [02/Mar/2008:15:51:57 +0100] Pause-Printer: Unauthorized E [02/Mar/2008:15:52:15 +0100] Resume-Printer: Unauthorized E [02/Mar/2008:15:52:35 +0100] CUPS-Set-Default: Unauthorized E [02/Mar/2008:15:53:03 +0100] [cups-driverd] Unable to open PPD directory "/opt/share/ppd": No such file or directory E [02/Mar/2008:15:55:01 +0100] CUPS-Set-Default: Unauthorized E [02/Mar/2008:15:55:08 +0100] CUPS-Set-Default: Unauthorized E [02/Mar/2008:15:55:17 +0100] [Job 11] /undefined in #CUPS-COMMAND E [02/Mar/2008:15:55:17 +0100] PID 5529 (/usr/lib/cups/filter/pstoraster) stopped with status 1! E [02/Mar/2008:16:01:11 +0100] Purge-Jobs: Unauthorized E [02/Mar/2008:16:01:42 +0100] CUPS-Delete-Printer: Unauthorized E [02/Mar/2008:16:01:47 +0100] CUPS-Delete-Printer: Unauthorized E [02/Mar/2008:16:03:16 +0100] [cups-driverd] Unable to open PPD directory "/opt/share/ppd": No such file or directory E [02/Mar/2008:16:03:20 +0100] CUPS-Add-Modify-Printer: Unauthorized
Ou ce que me renvoie le terminal après une tentative d’impression avec gedit :
code: GnomePrint-WARNING **: Could not create filter from description ‘GnomePrintFilterSelect’: filter ‘GnomePrintFilterSelect’ is unknown
(gedit:6271): GLib-GObject-WARNING **: invalid (NULL) pointer instance
(gedit:6271): GLib-GObject-CRITICAL **: g_signal_connect_data: assertion G_TYPE_CHECK_INSTANCE (instance)' failed (gedit:6271): GnomePrint-WARNING **: Could not create filter from description 'GnomePrintFilterClip [ GnomePrintFilterMultipage ]': filter 'GnomePrintFilterClip' is unknown (gedit:6271): GLib-GObject-CRITICAL **: g_object_unref: assertionG_IS_OBJECT (object)’ failed
(gedit:6271): libgnomeprintui-CRITICAL **: gnome_print_layout_selector_load_filter: assertion GNOME_IS_PRINT_FILTER (f)' failed (gedit:6271): GLib-GObject-CRITICAL **: g_object_set: assertionG_IS_OBJECT (object)’ failed
(gedit:6271): GLib-GObject-CRITICAL **: g_object_set: assertion G_IS_OBJECT (object)' failed (gedit:6271): GLib-GObject-CRITICAL **: g_object_set: assertionG_IS_OBJECT (object)’ failed
(gedit:6271): GnomePrint-CRITICAL **: gnome_print_filter_reset: assertion GNOME_IS_PRINT_FILTER (f)' failed (gedit:6271): GnomePrint-CRITICAL **: gnome_print_filter_flush: assertionGNOME_IS_PRINT_FILTER (f)’ failed
** (gedit:6271): WARNING **: could not set the value of Settings.Document.Filter, node not found
Je donne également la liste des paquets installés en rapport avec l’impression. En effet, je souhaite utiliser XFCE4 comme gestionnaire de session, mais n’arrivant pas à imprimer, je suis revenue sous Gnome que j’ai partiellement désinstallé et réinstallé à plusieurs reprises…
cupsys, cupsys-bse, cupsys-client, cupsys-common, cupsys-driver-gutenprint et libcupsys2 foomatic-db-gutenprint, gimp-gutenprint gutenprint-locales, ijsgutenprint, libgutenprint2 et libgutenprintui2-1 fommatic-db, foomatic-db-engine, foomatic-db-hpijs, foomatic-filters et foomatic-filters-pppds
Autres précisions :
  • ajouter mon “user” au groupe “lp” ne change apparemment rien (et il me semble que l’impression fonctionnait sans recourir à cette manipulation)
  • j’ai tenté en vain différentes installations, incluant les pilotes d’Avasy “pipslite” et différents pilotes proposé par gutenprint (DX4800 étant celui que j’utilisais et qui fonctionnait jusq’à présent) et changeant le port de connexion, etc.
  • j’ai également installé le paquet “hal-cups” (dépôt Ubuntu Gusty) qui permet l’installation automatique de cette imprimante. L’imprimante et bien été ajoutée au démarrage, mais n’imprime toujours pas …
En bref : au secours !
s’il-vous-plait :wink:
openprinting.org/show_printer.cg … lus_DX5050
Et oui, la DX5050 fonctionne correctement (“Mostly”) avec le pilote de la DX4800 …
Stylus_DX5000 ( imprimante par défaut ) Description : EPSON Stylus DX5000 Lieu : Marque et modèle : Epson Stylus DX4800 - CUPS+Gutenprint v5.0.1 État de l'imprimante : ne fait rien, accepte les tâches, publique. URI du matériel : epson:/dev/usb/lp0
… sauf qu’elle n’imprime pas.
Il y a donc quelque chose d’autre qui m’échappe.
Une idée ?
Hummm j’ai exactement le même pb mais avec une Epson DX4050
As-tu finalement résolu le pb ?
En fait oui et non …
Mon imprimante fonctionne actuellement, mais je suis sous Xubuntu Gusty et elle a été reconnue automatiquement… et correctement du premier coup.
Une chose sure, c’est que ce problème apparait “des fois” sans que je puisse le lier à une distribution en particulier ni au mode d’installation, automatisé ou non.
Une piste pour t’aider peut-être :
j’ai l’impression que c’est au niveau de la sélection du pilote que les choses peuvent mal se passer.
En clair, il me semble que le pilote n’est pas vraiment “activé” …
Désolée de ne pouvoir t’aider d’avantage …
Bon courage
