Merci pour votre aide !
En faite comme je dois remcompiler le noyau pour faire fonctionner ma carte son en mettant le module intel_hda, je comptais aussi ajouter le module mac80211 en dur. Mais bon, puisque vous me conseiller de compiler puis d’installer le noyau, je vais d’abord le compiler.
Sinon le module que je veux (voulais) inclure n’est pas le pilote en lui même. J’ai lu sur le site d’intel, qu’il fallait que le module mac80211 soit installé afin que je puisse installer le driver lui même: iwlwifi.
Et voici le README du module:
[quote]README for external mac80211 subsystem package
Copyright © 2007, Intel Corporation
version: mac80211-10.0.0
date : Thu Aug 23 17:12:04 CST 2007
This archive provides a package for the mac80211 subsystem,
installable into most kernels with a version of 2.6.18 or
later. You can determine your kernel version by running:
% uname -r
NOTE: The mac80211 subsystem is being developed by a group of
community developers. Intel put together this packaging system
in order to better facilitate the widespread availability and
adoption of the subsystem.
This file provides an overview of why the mac80211 package exists,
what it does, and how it does it.
Index
Quick steps
Why?
What?
How?
What is in a release?
Makefile targets
Updating compatiblity
Version numbering
Quick steps
If you’re a user that just wants to try and get up and running
as quickly as possible, here are the simplest steps we have so
far:
% make patch_kernel
The above, if it succeeds, should patch your current running
kernel source tree to contain the mac80211 subsystem sources. Now
you need to configure your kernel build to build the mac80211
modules:
% cd /lib/modules/$(uname -r)/build
% make menuconfig
You will want to set the following to :
CONFIG_MAC80211=m
Networking --->
Generic IEEE 802.11 Networking Stack (dscape)
You can turn on the sub-options for that subsystem if you want.
Select ‘Exit’ until it prompts to save your kernel configuration
and select ‘Yes’. Now you can build the module:
% make modules
% make modules_install
NOTE: As of mac80211-2.0.0 you must also enable CONFIG_CFG80211 and
rebuild your main kernel image. This is because the latest mac80211
changes re-implement the kernel built-in from net/core/wireless.c as
part of the net/wireless/ sources.
% make all
% make install
You will then need to reboot into the new kernel (vs. just loading the
new 80211 modules)
Why?
The network community for the Linux kernel typically has an
approach of focusing purely on the ‘tip’. To the average
user that means that bug fixes, patches, and enhancements will
only be available to you if you can upgrade to the latest
development kernel. For some, this is acceptable. For others,
it is not.
This package is created in order to try and provide the user (you)
with fixes and enhancements that affect just the wireless
subsystem required for use with your hardware.
As with any software, new changes may introduce new bugs.
Upgrading from one version of the mac80211 subsystem to the
next might regress a problem, or even introduce a new one –
if it does, and you find it, please file a bug at
bughost.org under the project ‘mac80211’.
What?
So what does this package contain? It represents the latest
version of the mac80211 as available via the GIT repository
hosted at:
git://git.kernel.org/pub/scm/linux/kern … ss-dev.git
In addition to the above, any patches submitted by the mac80211 subsystem
developers which are deemed to be bug fixes or improve existing
functionality which have not been made available in the GIT repository.
When you run make on your system, the build scripts will examine your
target kernel to determine which backward compatibility changes are
required to compile on your system. A side effect of the mac80211
developers using the latest kernel tip as their baseline is that the
subsystem itself emerges to use whichever new features or APIs may have
been made available in the rest of the kernel. This will typically
break building and running on kernels released prior to those changes.
The build system for this package attempts to correct that behavior.
How?
When you run the build, it runs a series of scripts against the
target kernel. The target is specified via KSRC=/patch/to/kernel.
If no KSRC is provided, it will default to looking in:
Each of the scripts attempts to determine if a given set of
kernel functionality is present. In the good old days, a module
could do something simple like:
#if LINUX_VERSION_CODE < KERNEL_VERSION(2,6,19)
/* some code */
#else
/* some other code */
#endif
Over the last few years, however, this approach has broken due
to a number of reasons. The two most prominent causes are:
* Kernel API and structure changes occurring within
an -rc update (which can not be checked with the
KERNEL_VERSION macro)
* Distributions backporting new kernel features into
older kernels such that the older vanilla kernel
(as originally provided by Linus) does not have the
feature but the distributor does.
An example of what a script might do is perform a grep operation
on a particular header file to determine if the parameters
passed to a function have changed, or if a particular definition
exists.
The details of how a typical release cycle is as follows:
Latest files are obtained from Jiri’s GIT
repository into a local GIT tree (eg., /repos/jbenc)
mac80211 subsystem files are copied from the GIT tree into
the ‘origin’ directory via:
% make BASE=/repos/jbenc origin
The patches in the ‘pending’ directory are applied to the
’origin’ in numerical sequence to build a new tree stored
in the ‘modified’ directory.
Miscellaneous testing is performed (build iwlwifi, associate,
etc.)
The files in ‘stubs’ are sourced with the following
environment variables defined:
MAC80211_VERSION=versionstring
with the output of that sourcing going into the base
directory as a file with the same name (eg., stubs/README
creates README). This is used to update the documentation
to contain the latest version fields.
The package is tarballed up with a version stamp named:
mac80211-${MAC80211_VERSION}.tgz
7*. A test system performs a tinderbox build of the package
against:
* Linus’ vanilla kernels > 2.6.18
* Latest kernel sources version available as a 'stable’
package from the following distributions (alphabetical):
Fedora Core
Gentoo
OpenSuse
Ubuntu
- This is not yet done. Currently I have to do the smoke test
build by hand, which means I’m only building against the latest
Gentoo kernel and a couple other random kernel images I have on
my system.
Makefile targets
The build supports multiple targets depending on what you
are trying to do. This section provides an overview of each
of those targets.
clean
Removes *.ko, *.o, and *.mod.c from the tree. This
also deletes the compat directory (built with the
source target)
See Makefile
origin
Updates the tip sources. Specify the source repository
via BASE= on the make command line.
NOTE: The script will not perform any GIT fetching
from the Internet and will only copy the mac80211 related
files from the directory specified. If you want to
update to the latest GIT version you would need to
first obtain Jiri Benc's GIT repository and then direct
the make to that directory via BASE. By default,
the script will look in /home/repos/mac80211/
Once the tip files are copied, the patches in 'pending'
are applied in sequential order.
See scripts/generate_origin
modified
Creates a modified ‘tip’ applying all of the patches
from the ‘pending’ directory.
See scripts/generate_modified
source
Examines if the target kernel can be used without
any changes to the modified mac80211 sources provided in the
tip directory and creates a compatible version of the
sources from ‘modified’ in the ‘compatitble’ directory.
See scripts/generate_source
unmodified
sources from ‘origin’ in the ‘compatitble’ directory.
You would typically use this if you want a "pure" version
of mac80211 compatible with your kernel.
patch_kernel
Transfers the generated or tip sources into the target
kernel. This will also patch the required kernel
build files (Makefile, Kconfig, etc.) as needed in order
to add the mac80211 subsystem to the build.
See scripts/patch_kernel
dist
Builds a distribution tarball and places it in the
distros directory. The filename for the tarball is
mac80211-${MAC80211_VERSION}.tgz.
NOTE: MAC80211_VERSION defaults to 'test'.
See Makefile
Updating compatibility
Ok – you’re developing, or you just moved to a new kernel and
WHAM the kernel build breaks. Once the root cause of the
build failure is determined, a patch is required in order
to support making that kernel ‘just work’ for everyone else.
The following are the typical steps performed:
% make source
% mv compatible old
% make source
Now, edit the sources in the compatible/ directory. You can test
your sources by running:
% make patch_kernel
% make menuconfig <-- If you haven't already enabled mac80211
% make modules
Once you are satisfied the build problems are fixed, create
the patch:
% diff -Nupr old compatible > compatible-$(uname -r).patch
The work to this point is a huge help to others in the community
so go ahead and send the patch to the mac80211-devel mailing list.
If you want to figure out how to modify the mac80211 package so
that it will automatically apply your patch if needed, look
in the following scripts:
scripts/determine_compat
scripts/generate_compatible
Version numbering
The mac80211 package uses a three field versioning scheme:
mac80211-x.y.z.tgz
X will increase whenever a new base/tip is taken from the kernel.
You can see tip/GIT for the commit ID head cached when the
’make update’ target was used.
Y will increase as snapshots are made available in the external
package that may contain code which has not yet been merged into
the kernel itself.
Z will increase only as bug or compatibility patches are made
available against a given snapshot. Z increases will not contain
new functionality and are intended to only provide stability
fixes.
Donc quand je fais le “make patch_kernel”, je recois cette erreur:
Fabogranqi:/home/fabogranqi/Desktop/mac80211-10.0.0# make
Kernel Makefile not found at '/lib/modules/2.6.18-5-686/source/'
If patch or script failed, check pre/ and post/ for current stage.
make: *** [compatible/modified] Erreur 1
