Info sure le log: I/O error, dev sr0
hello.
Depuis quelque temps j’ai un message de ce type dans le kernel.log
Dec 12 02:22:10 pcfix kernel: sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
Dec 12 02:22:10 pcfix kernel: Uniform CD-ROM driver Revision: 3.20
Dec 12 02:22:10 pcfix kernel: sr 0:0:0:0: Attached scsi CD-ROM sr0
Dec 12 02:22:10 pcfix kernel: sd 5:0:0:0: [sda] 625142448 512-byte hardware sectors (320073 MB)
Dec 12 02:22:10 pcfix kernel: sd 5:0:0:0: [sda] Write Protect is off
Dec 12 02:22:10 pcfix kernel: sd 5:0:0:0: [sda] Mode Sense: 00 3a 00 00
Dec 12 02:22:10 pcfix kernel: sd 5:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Dec 12 02:22:10 pcfix kernel: sr 0:0:0:0: Attached scsi generic sg0 type 5
Dec 12 02:22:10 pcfix kernel: sd 5:0:0:0: Attached scsi generic sg1 type 0
Dec 12 02:22:10 pcfix kernel:  sda: sda1 sda2 < sda5 sda6 sda7 sda8 sda9 sda10 >
Dec 12 02:22:10 pcfix kernel: sd 5:0:0:0: [sda] Attached SCSI disk
Dec 12 02:22:10 pcfix kernel: end_request: I/O error, dev sr0, sector 1146752
Dec 12 02:22:10 pcfix kernel: Buffer I/O error on device sr0, logical block 143344
Dec 12 02:22:10 pcfix kernel: end_request: I/O error, dev sr0, sector 1146944
Dec 12 02:22:10 pcfix kernel: Buffer I/O error on device sr0, logical block 143368
Dec 12 02:22:10 pcfix kernel: end_request: I/O error, dev sr0, sector 1146952
Dec 12 02:22:10 pcfix kernel: Buffer I/O error on device sr0, logical block 143369
Dec 12 02:22:10 pcfix kernel: end_request: I/O error, dev sr0, sector 1146896
Dec 12 02:22:10 pcfix kernel: PM: Starting manual resume from disk
On dirait que c’est lier aux lecteur dvd, mai est-ce que je me trompe et que cela serait le disque dure ?
merci d’avance :smt006
