Je cherche a créer un deamon sur un Debian wheezy,j’ai suivis l’example suivant : http://www.commentcamarche.net/faq/6858-demarrer-un-programme-en-tant-que-service-demon
mais lorsque j’arrive a l’étape du update-rc monscript defaults j’ai l’erreur suivante :
update-rc.d: using dependency based boot sequencing
insserv: script testprint: service skeleton already provided!
insserv: exiting now!
update-rc.d: error: insserv rejected the script header
Une petite idée ?
voila mon skeleton
[code]#! /bin/sh
BEGIN INIT INFO
Provides: skeleton
Required-Start: $remote_fs $syslog
Required-Stop: $remote_fs $syslog
Default-Start: 2 3 4 5
Default-Stop: 0 1 6
Short-Description: Example initscript
Description: This file should be used to construct scripts to be
placed in /etc/init.d.
END INIT INFO
Author: Foo Bar foobar@baz.org
Please remove the “Author” lines above and replace them
with your own name if you copy and modify this script.
Do NOT “set -e”
PATH should only include /usr/* if it runs after the mountnfs.sh script
PATH=/sbin:/usr/sbin:/bin:/usr/bin
DESC=“testprint"
NAME=testprint.py
DAEMON=/usr/bin/$NAME
DAEMON_ARGS=”"
PIDFILE=/var/run/$NAME.pid
SCRIPTNAME=/etc/init.d/$NAME
Exit if the package is not installed
[ -x “$DAEMON” ] || exit 0
Read configuration variable file if it is present
[ -r /etc/default/$NAME ] && . /etc/default/$NAME
Load the VERBOSE setting and other rcS variables
. /lib/init/vars.sh
Define LSB log_* functions.
Depend on lsb-base (>= 3.2-14) to ensure that this file is present
and status_of_proc is working.
. /lib/lsb/init-functions
Function that starts the daemon/service
do_start()
# Return
# 0 if daemon has been started
# 1 if daemon was already running
# 2 if daemon could not be started
start-stop-daemon --start --quiet --pidfile $PIDFILE --exec $DAEMON --test > /dev/null
|| return 1
start-stop-daemon --start --quiet --pidfile $PIDFILE --exec $DAEMON –
$DAEMON_ARGS
|| return 2
# Add code here, if necessary, that waits for the process to be ready
# to handle requests from services started subsequently which depend
# on this one. As a last resort, sleep for some time.
Function that stops the daemon/service
do_stop()
# Return
# 0 if daemon has been stopped
# 1 if daemon was already stopped
# 2 if daemon could not be stopped
# other if a failure occurred
start-stop-daemon --stop --quiet --retry=TERM/30/KILL/5 --pidfile $PIDFILE --name $NAME
RETVAL="$?"
[ “$RETVAL” = 2 ] && return 2
# Wait for children to finish too if this is a daemon that forks
# and if the daemon is only ever run from this initscript.
# If the above conditions are not satisfied then add some other code
# that waits for the process to drop all resources that could be
# needed by services started subsequently. A last resort is to
# sleep for some time.
start-stop-daemon --stop --quiet --oknodo --retry=0/30/KILL/5 --exec $DAEMON
[ "$?" = 2 ] && return 2
# Many daemons don't delete their pidfiles when they exit.
rm -f $PIDFILE
return "$RETVAL"
Function that sends a SIGHUP to the daemon/service
do_reload() {
# If the daemon can reload its configuration without
# restarting (for example, when it is sent a SIGHUP),
# then implement that here.
start-stop-daemon --stop --signal 1 --quiet --pidfile $PIDFILE --name $NAME
return 0
case “$1” in
start)
[ “$VERBOSE” != no ] && log_daemon_msg “Starting $DESC” "$NAME"
do_start
case “$?” in
0|1) [ “$VERBOSE” != no ] && log_end_msg 0 ;;
2) [ “$VERBOSE” != no ] && log_end_msg 1 ;;
esac
stop)
[ “$VERBOSE” != no ] && log_daemon_msg “Stopping $DESC” "$NAME"
do_stop
case “$?” in
esac
status)
status_of_proc “$DAEMON” “$NAME” && exit 0 || exit $?
#reload|force-reload)
# If do_reload() is not implemented then leave this commented out
# and leave ‘force-reload’ as an alias for ‘restart’.
#log_daemon_msg “Reloading $DESC” “$NAME”
#do_reload
#log_end_msg $?
restart|force-reload)
# If the “reload” option is implemented then remove the
# ‘force-reload’ alias
log_daemon_msg “Restarting $DESC” "$NAME"
do_stop
case “$?” in
0|1)
do_start
case “$?” in
0) log_end_msg 0 ;;
1) log_end_msg 1 ;; # Old process is still running
*) log_end_msg 1 ;; # Failed to start
esac
# Failed to stop
log_end_msg 1
esac
#echo “Usage: $SCRIPTNAME {start|stop|restart|reload|force-reload}” >&2
echo “Usage: $SCRIPTNAME {start|stop|status|restart|force-reload}” >&2
exit 3
esac
