wicd devait savoir ce que j’attendais de lui, il a tout de suite planté ce matin… voila le contenu de /var/log/wicd/wicd.log:
2010/12/09 07:19:01 :: ---------------------------
2010/12/09 07:19:01 :: wicd initializing...
2010/12/09 07:19:01 :: wicd is version 1.7.0 552
2010/12/09 07:19:01 :: setting backend to external
2010/12/09 07:19:01 :: trying to load backend external
2010/12/09 07:19:01 :: successfully loaded backend external
2010/12/09 07:19:01 :: Couldn't detect a wireless interface.
2010/12/09 07:19:01 :: setting wireless interface wlan0
2010/12/09 07:19:01 :: automatically detected wired interface eth0
2010/12/09 07:19:01 :: setting wired interface eth0
2010/12/09 07:19:01 :: setting wpa driver wext
2010/12/09 07:19:01 :: setting use global dns to False
2010/12/09 07:19:01 :: setting global dns
2010/12/09 07:19:01 :: global dns servers are None None None
2010/12/09 07:19:01 :: domain is None
2010/12/09 07:19:01 :: search domain is None
2010/12/09 07:19:01 :: setting automatically reconnect when connection drops True
2010/12/09 07:19:01 :: Setting dhcp client to 0
2010/12/09 07:19:01 :: Wireless configuration file found...
2010/12/09 07:19:01 :: Wired configuration file found...
2010/12/09 07:19:01 :: chmoding configuration files 0600...
2010/12/09 07:19:01 :: chowning configuration files root:root...
2010/12/09 07:19:01 :: Using wireless interface...wlan0
2010/12/09 07:19:01 :: Using wired interface...eth0
2010/12/09 07:19:04 :: hidden
2010/12/09 07:19:09 :: Autoconnecting...
2010/12/09 07:19:09 :: No wired connection present, attempting to autoconnect to wireless network
2010/12/09 07:19:11 :: hidden
2010/12/09 07:19:11 :: trying to automatically connect to...fofifab
2010/12/09 07:19:11 :: Connecting to wireless network fofifab
2010/12/09 07:19:12 :: Putting interface down
2010/12/09 07:19:12 :: Releasing DHCP leases...
2010/12/09 07:19:12 :: Setting false IP...
2010/12/09 07:19:12 :: Stopping wpa_supplicant
2010/12/09 07:19:12 :: Flushing the routing table...
2010/12/09 07:19:12 :: Putting interface up...
2010/12/09 07:19:14 :: Generating psk...
2010/12/09 07:19:14 :: Attempting to authenticate...
2010/12/09 07:19:50 :: wpa_supplicant authentication may have failed.
2010/12/09 07:19:50 :: connect result is Failed
2010/12/09 07:19:50 :: exiting connection thread
2010/12/09 07:19:53 :: Sending connection attempt result bad_pass
2010/12/09 07:20:14 :: trying to load backend ioctl
2010/12/09 07:20:14 :: WARNING: python-iwscan not found, falling back to using iwlist scan.
2010/12/09 07:20:14 :: WARNING: python-wpactrl not found, falling back to using wpa_cli.
2010/12/09 07:20:14 :: trying to load backend external
2010/12/09 07:20:35 :: setting use global dns to 0
2010/12/09 07:20:35 :: setting global dns
2010/12/09 07:20:35 :: global dns servers are
2010/12/09 07:20:35 :: domain is
2010/12/09 07:20:35 :: search domain is
2010/12/09 07:20:35 :: setting wireless interface wlan0
2010/12/09 07:20:35 :: setting wired interface eth0
2010/12/09 07:20:35 :: setting wpa driver wext
2010/12/09 07:20:35 :: setting automatically reconnect when connection drops 1
2010/12/09 07:20:35 :: setting backend to external
2010/12/09 07:20:35 :: Setting dhcp client to 0
2010/12/09 07:20:39 :: hidden
2010/12/09 07:20:55 :: hidden
2010/12/09 07:21:04 :: hidden
2010/12/09 07:21:13 :: hidden
2010/12/09 07:21:23 :: Connecting to wireless network MonESSID
2010/12/09 07:21:23 :: Putting interface down
2010/12/09 07:21:23 :: Releasing DHCP leases...
2010/12/09 07:21:23 :: Setting false IP...
2010/12/09 07:21:23 :: Stopping wpa_supplicant
2010/12/09 07:21:23 :: Flushing the routing table...
2010/12/09 07:21:23 :: Putting interface up...
2010/12/09 07:21:25 :: Generating psk...
2010/12/09 07:21:25 :: Attempting to authenticate...
2010/12/09 07:22:01 :: wpa_supplicant authentication may have failed.
2010/12/09 07:22:01 :: connect result is Failed
2010/12/09 07:22:01 :: exiting connection thread
2010/12/09 07:22:01 :: Sending connection attempt result bad_pass
2010/12/09 07:23:19 :: Connecting to wireless network MonESSID
2010/12/09 07:23:20 :: Putting interface down
2010/12/09 07:23:20 :: Releasing DHCP leases...
2010/12/09 07:23:20 :: Setting false IP...
2010/12/09 07:23:20 :: Stopping wpa_supplicant
2010/12/09 07:23:20 :: Flushing the routing table...
2010/12/09 07:23:20 :: Putting interface up...
2010/12/09 07:23:22 :: Generating psk...
2010/12/09 07:23:22 :: Attempting to authenticate...
2010/12/09 07:23:23 :: Running DHCP with hostname mon-pc
2010/12/09 07:23:25 :: dhcpcd.sh: interface wlan0 has been configured with new IP=192.168.0.1
2010/12/09 07:23:25 :: DHCP connection successful
2010/12/09 07:23:25 :: not verifying
2010/12/09 07:23:25 :: Connecting thread exiting.
2010/12/09 07:23:25 :: Sending connection attempt result Success
2010/12/09 07:25:13 :: Autoconnecting...
2010/12/09 07:25:13 :: No wired connection present, attempting to autoconnect to wireless network
2010/12/09 07:25:15 :: hidden
2010/12/09 07:25:15 :: trying to automatically connect to...fofifab
2010/12/09 07:25:15 :: Connecting to wireless network fofifab
2010/12/09 07:25:16 :: Putting interface down
2010/12/09 07:25:16 :: Releasing DHCP leases...
2010/12/09 07:25:16 :: Setting false IP...
2010/12/09 07:25:16 :: Stopping wpa_supplicant
2010/12/09 07:25:16 :: Flushing the routing table...
2010/12/09 07:25:16 :: Putting interface up...
2010/12/09 07:25:18 :: Generating psk...
2010/12/09 07:25:18 :: Attempting to authenticate...
2010/12/09 07:25:53 :: wpa_supplicant authentication may have failed.
2010/12/09 07:25:53 :: connect result is Failed
2010/12/09 07:25:53 :: exiting connection thread
2010/12/09 07:25:57 :: Sending connection attempt result bad_pass
2010/12/09 07:25:57 :: Autoconnecting...
2010/12/09 07:25:57 :: No wired connection present, attempting to autoconnect to wireless network
2010/12/09 07:25:59 :: trying to automatically connect to...MonESSID
2010/12/09 07:25:59 :: Connecting to wireless network MonESSID
2010/12/09 07:25:59 :: Putting interface down
2010/12/09 07:25:59 :: Releasing DHCP leases...
2010/12/09 07:25:59 :: Setting false IP...
2010/12/09 07:26:00 :: Stopping wpa_supplicant
2010/12/09 07:26:00 :: Flushing the routing table...
2010/12/09 07:26:00 :: Putting interface up...
2010/12/09 07:26:02 :: Generating psk...
2010/12/09 07:26:02 :: Attempting to authenticate...
2010/12/09 07:26:03 :: Running DHCP with hostname mon-pc
2010/12/09 07:26:04 :: dhcpcd.sh: interface wlan0 has been configured with new IP=192.168.0.1
2010/12/09 07:26:04 :: DHCP connection successful
2010/12/09 07:26:04 :: not verifying
2010/12/09 07:26:04 :: Connecting thread exiting.
2010/12/09 07:26:07 :: Sending connection attempt result Success
Mon PC s’appelle mon-pc et ma freebox MonESSID…
J’ai remarqué 2 trucs étranges:
- des fois ma freebox est associée au canal 11, des fois au 6… (il me semblait avoir mis 11 dans la conf freebox, je vérifierai après, je tappe d’abord ça pendant que j’arrive à me connecter)
- quand ma freebox n’est plus vue lors d’une recherche wicd, un essid (que je ne connais pas (fofifab) a la case “se connecter auto” cochée avec mon mot de passe à l’intérieur !
Des idées ?
