Install lxml
Hello,
#The execution of the command :
apt-get install python3-lxml
#Genere
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 python3-lxml : Depends: python3 (< 3.5) but 3.7.2-1 is to be installed
E: Unable to correct problems, you have held broken packages.
Thanks,
La commande :
pip3 install  lxml
me génère :
Downloading/unpacking lxml
  Downloading lxml-4.3.1.tar.gz (4.4MB): 4.4MB downloaded
  Running setup.py (path:/tmp/pip-build-_qlo6zjf/lxml/setup.py) egg_info for package lxml
    Building lxml version 4.3.1.
    Building without Cython.
    Using build configuration of libxslt 1.1.28
    /tmp/pip-build-_qlo6zjf/lxml/setup.py:12: PkgResourcesDeprecationWarning: Parameters to load are deprecated.  Call .resolve and .require separately.
      sys.exit(1)
Installing collected packages: lxml
  Running setup.py install for lxml
    building 'lxml.etree' extension
    x86_64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DCYTHON_CLINE_IN_TRACEBACK=0 -I/usr/include/libxml2 -Isrc -Isrc/lxml/includes -I/usr/include/python3.7m -c src/lxml/etree.c -o build/temp.linux-x86_64-3.7/src/lxml/etree.o -w
    In file included from /usr/include/libxslt/xsltInternals.h:24,
                     from src/lxml/etree.c:718:
    /usr/include/libxslt/xsltlocale.h:19:10: fatal error: xlocale.h: No such file or directory
     #include <xlocale.h>
    compilation terminated.
    Compile failed: command 'x86_64-linux-gnu-gcc' failed with exit status 1
    cc -I/usr/include/libxml2 -I/usr/include/libxml2 -c /tmp/xmlXPathInitr9utwi5l.c -o tmp/xmlXPathInitr9utwi5l.o
    /tmp/xmlXPathInitr9utwi5l.c:2:1: warning: return type defaults to ‘int’ [-Wimplicit-int]
     main (int argc, char **argv) {
    cc tmp/xmlXPathInitr9utwi5l.o -lxml2 -o a.out
    error: command 'x86_64-linux-gnu-gcc' failed with exit status 1
    Complete output from command /usr/bin/python3 -c "import setuptools, tokenize;__file__='/tmp/pip-build-_qlo6zjf/lxml/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-39n98e9_-record/install-record.txt --single-version-externally-managed --compile:
running install
running build
running build_py
creating build
creating build/lib.linux-x86_64-3.7
creating build/lib.linux-x86_64-3.7/lxml
copying src/lxml/builder.py -> build/lib.linux-x86_64-3.7/lxml
copying src/lxml/__init__.py -> build/lib.linux-x86_64-3.7/lxml
copying src/lxml/sax.py -> build/lib.linux-x86_64-3.7/lxml
copying src/lxml/ElementInclude.py -> build/lib.linux-x86_64-3.7/lxml
copying src/lxml/cssselect.py -> build/lib.linux-x86_64-3.7/lxml
copying src/lxml/pyclasslookup.py -> build/lib.linux-x86_64-3.7/lxml
copying src/lxml/usedoctest.py -> build/lib.linux-x86_64-3.7/lxml
copying src/lxml/doctestcompare.py -> build/lib.linux-x86_64-3.7/lxml
copying src/lxml/_elementpath.py -> build/lib.linux-x86_64-3.7/lxml
creating build/lib.linux-x86_64-3.7/lxml/includes
copying src/lxml/includes/__init__.py -> build/lib.linux-x86_64-3.7/lxml/includes
creating build/lib.linux-x86_64-3.7/lxml/html
copying src/lxml/html/_html5builder.py -> build/lib.linux-x86_64-3.7/lxml/html
copying src/lxml/html/ElementSoup.py -> build/lib.linux-x86_64-3.7/lxml/html
copying src/lxml/html/builder.py -> build/lib.linux-x86_64-3.7/lxml/html
copying src/lxml/html/__init__.py -> build/lib.linux-x86_64-3.7/lxml/html
copying src/lxml/html/_diffcommand.py -> build/lib.linux-x86_64-3.7/lxml/html
copying src/lxml/html/soupparser.py -> build/lib.linux-x86_64-3.7/lxml/html
copying src/lxml/html/_setmixin.py -> build/lib.linux-x86_64-3.7/lxml/html
copying src/lxml/html/diff.py -> build/lib.linux-x86_64-3.7/lxml/html
copying src/lxml/html/clean.py -> build/lib.linux-x86_64-3.7/lxml/html
copying src/lxml/html/html5parser.py -> build/lib.linux-x86_64-3.7/lxml/html
copying src/lxml/html/usedoctest.py -> build/lib.linux-x86_64-3.7/lxml/html
copying src/lxml/html/formfill.py -> build/lib.linux-x86_64-3.7/lxml/html
copying src/lxml/html/defs.py -> build/lib.linux-x86_64-3.7/lxml/html
creating build/lib.linux-x86_64-3.7/lxml/isoschematron
copying src/lxml/isoschematron/__init__.py -> build/lib.linux-x86_64-3.7/lxml/isoschematron
copying src/lxml/etree.h -> build/lib.linux-x86_64-3.7/lxml
copying src/lxml/etree_api.h -> build/lib.linux-x86_64-3.7/lxml
copying src/lxml/lxml.etree.h -> build/lib.linux-x86_64-3.7/lxml
copying src/lxml/lxml.etree_api.h -> build/lib.linux-x86_64-3.7/lxml
copying src/lxml/includes/schematron.pxd -> build/lib.linux-x86_64-3.7/lxml/includes
copying src/lxml/includes/uri.pxd -> build/lib.linux-x86_64-3.7/lxml/includes
copying src/lxml/includes/config.pxd -> build/lib.linux-x86_64-3.7/lxml/includes
copying src/lxml/includes/xmlschema.pxd -> build/lib.linux-x86_64-3.7/lxml/includes
copying src/lxml/includes/etreepublic.pxd -> build/lib.linux-x86_64-3.7/lxml/includes
copying src/lxml/includes/c14n.pxd -> build/lib.linux-x86_64-3.7/lxml/includes
copying src/lxml/includes/__init__.pxd -> build/lib.linux-x86_64-3.7/lxml/includes
copying src/lxml/includes/xpath.pxd -> build/lib.linux-x86_64-3.7/lxml/includes
copying src/lxml/includes/xinclude.pxd -> build/lib.linux-x86_64-3.7/lxml/includes
copying src/lxml/includes/relaxng.pxd -> build/lib.linux-x86_64-3.7/lxml/includes
copying src/lxml/includes/xmlerror.pxd -> build/lib.linux-x86_64-3.7/lxml/includes
copying src/lxml/includes/dtdvalid.pxd -> build/lib.linux-x86_64-3.7/lxml/includes
copying src/lxml/includes/tree.pxd -> build/lib.linux-x86_64-3.7/lxml/includes
copying src/lxml/includes/xslt.pxd -> build/lib.linux-x86_64-3.7/lxml/includes
copying src/lxml/includes/xmlparser.pxd -> build/lib.linux-x86_64-3.7/lxml/includes
copying src/lxml/includes/htmlparser.pxd -> build/lib.linux-x86_64-3.7/lxml/includes
copying src/lxml/includes/etree_defs.h -> build/lib.linux-x86_64-3.7/lxml/includes
copying src/lxml/includes/lxml-version.h -> build/lib.linux-x86_64-3.7/lxml/includes
creating build/lib.linux-x86_64-3.7/lxml/isoschematron/resources
creating build/lib.linux-x86_64-3.7/lxml/isoschematron/resources/rng
copying src/lxml/isoschematron/resources/rng/iso-schematron.rng -> build/lib.linux-x86_64-3.7/lxml/isoschematron/resources/rng
creating build/lib.linux-x86_64-3.7/lxml/isoschematron/resources/xsl
copying src/lxml/isoschematron/resources/xsl/XSD2Schtrn.xsl -> build/lib.linux-x86_64-3.7/lxml/isoschematron/resources/xsl
copying src/lxml/isoschematron/resources/xsl/RNG2Schtrn.xsl -> build/lib.linux-x86_64-3.7/lxml/isoschematron/resources/xsl
creating build/lib.linux-x86_64-3.7/lxml/isoschematron/resources/xsl/iso-schematron-xslt1
copying src/lxml/isoschematron/resources/xsl/iso-schematron-xslt1/iso_abstract_expand.xsl -> build/lib.linux-x86_64-3.7/lxml/isoschematron/resources/xsl/iso-schematron-xslt1
copying src/lxml/isoschematron/resources/xsl/iso-schematron-xslt1/iso_schematron_skeleton_for_xslt1.xsl -> build/lib.linux-x86_64-3.7/lxml/isoschematron/resources/xsl/iso-schematron-xslt1
copying src/lxml/isoschematron/resources/xsl/iso-schematron-xslt1/iso_schematron_message.xsl -> build/lib.linux-x86_64-3.7/lxml/isoschematron/resources/xsl/iso-schematron-xslt1
copying src/lxml/isoschematron/resources/xsl/iso-schematron-xslt1/iso_dsdl_include.xsl -> build/lib.linux-x86_64-3.7/lxml/isoschematron/resources/xsl/iso-schematron-xslt1
copying src/lxml/isoschematron/resources/xsl/iso-schematron-xslt1/iso_svrl_for_xslt1.xsl -> build/lib.linux-x86_64-3.7/lxml/isoschematron/resources/xsl/iso-schematron-xslt1
copying src/lxml/isoschematron/resources/xsl/iso-schematron-xslt1/readme.txt -> build/lib.linux-x86_64-3.7/lxml/isoschematron/resources/xsl/iso-schematron-xslt1
running build_ext
creating build/temp.linux-x86_64-3.7
creating build/temp.linux-x86_64-3.7/src
creating build/temp.linux-x86_64-3.7/src/lxml
creating tmp
Cleaning up...
Command /usr/bin/python3 -c "import setuptools, tokenize;__file__='/tmp/pip-build-_qlo6zjf/lxml/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-39n98e9_-record/install-record.txt --single-version-externally-managed --compile failed with error code 1 in /tmp/pip-build-_qlo6zjf/lxml
Storing debug log for failure in /root/.pip/pip.log
Le paquet que tu cherche à installer est bien disponible et présent sur Stretch.
Quel est la version de ta Debian ?
Peux-tu fournir plus d’informations comme par exemple ton fichiers de sources en intégralité ?
Merci pour votre aide.
La commande :
dpkg -i python3-lxml_3.7.1-1_amd64.deb
Génère :
Selecting previously unselected package python3-lxml.
(Reading database ... 90313 files and directories currently installed.)
Preparing to unpack python3-lxml_3.7.1-1_amd64.deb ...
Unpacking python3-lxml (3.7.1-1) ...
dpkg: dependency problems prevent configuration of python3-lxml:
 python3-lxml depends on python3 (<< 3.6); however:
  Version of python3 on system is 3.7.2-1.
dpkg: error processing package python3-lxml (--install):
 dependency problems - leaving unconfigured
Errors were encountered while processing:
 python3-lxml
3.16.0-4-amd64 #1 SMP Debian 3.16.43-2+deb8u5 (2017-09-19) x86_64 GNU/Linux
Merci une autre fois
J’ai télécharger lxml-4.3.1
les commandes :
cd lxml-4.3.1
make
Donnent :
python setup.py  build_ext -i  --warnings --with-coverage
running build_ext
creating build
creating build/temp.linux-x86_64-2.7
creating build/temp.linux-x86_64-2.7/src
creating build/temp.linux-x86_64-2.7/src/lxml
x86_64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -fPIC -DCYTHON_TRACE_NOGIL=1 -DCYTHON_CLINE_IN_TRACEBACK=0 -I/usr/include/libxml2 -Isrc -Isrc/lxml/includes -I/usr/include/python2.7 -c src/lxml/etree.c -o build/temp.linux-x86_64-2.7/src/lxml/etree.o
creating tmp
cc -I/usr/include/libxml2 -I/usr/include/libxml2 -c /tmp/xmlXPathInitOvn8xW.c -o tmp/xmlXPathInitOvn8xW.o
/tmp/xmlXPathInitOvn8xW.c:2:1: warning: return type defaults to ‘int’ [-Wimplicit-int]
cc tmp/xmlXPathInitOvn8xW.o -lxml2 -o a.out
Makefile:26: recipe for target 'inplace' failed
make: *** [inplace] Error 1
