Install tablette wacom volito 2
bonjour
j’essaye d’installer ma tablette graphique , une wacom volito 2.
après des recherches sur internet , j’en suis arrivé là , mais sans résultats pour l’instant .
j’ai essayé avec le pilote wacom.ko fourni avec debian etch et en copiant le 0.7.6.4 du site linux wacom , sans succès , pour l’instant je n’arrive meme pas a bouger le stylet .
les modifs sont en vert et les infos en bleu .
[quote]# /etc/X11/xorg.conf (xorg X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
(Type “man /etc/X11/xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/X11R6/lib/X11/fonts/misc"
FontPath "/usr/share/fonts/X11/cyrillic"
FontPath "/usr/X11R6/lib/X11/fonts/cyrillic"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath "/usr/X11R6/lib/X11/fonts/Type1"
FontPath "/usr/share/fonts/X11/100dpi"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi"
FontPath "/usr/share/fonts/X11/75dpi"
FontPath “/usr/X11R6/lib/X11/fonts/75dpi”
# path to defoma fonts
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/input/mice"
Option “Protocol” "ImPS/2"
Option “Emulate3Buttons” "true"
EndSection
[color=green]Section "InputDevice"
Identifier "stylus"
Driver "wacom"
Option “Device” "/dev/input/event3"
Option “Type” "stylus"
Option “USB” "on"
Option “ForceDevice” "ISDV4"
EndSection
Identifier "eraser"
Driver "wacom"
Option “Type” "eraser"
Option “USB” "on"
EndSection
Identifier "cursor"
Driver "wacom"
Option “Type” "cursor"
Option “USB” "on"
EndSection
[/color]
Section "Device"
Identifier "nVidia Corporation NV44A [GeForce 6200]"
Driver "nvidia"
BusID "PCI:1:0:0"
EndSection
Section "Monitor"
Identifier "B101920"
Option "DPMS"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "nVidia Corporation NV44A [GeForce 6200]"
Monitor "B101920"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes “1280x1024” “1152x864” “1024x768” “832x624” “800x600” “720x400” "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice “Configured Mouse”
InputDevice “stylus” "SendCoreEvents"
InputDevice “eraser” "SendCoreEvents"
InputDevice “cursor” "SendCoreEvents"
EndSection
Section "DRI"
Mode 0666
EndSection
debian-bureau:/home/franck# lsusb
Bus 005 Device 002: ID 050d:0234 Belkin Components F5U234 USB 2.0 4-Port Hub
Bus 005 Device 001: ID 0000:0000
Bus 003 Device 003: ID 046d:08d7 Logitech, Inc.
Bus 003 Device 001: ID 0000:0000
Bus 004 Device 001: ID 0000:0000
Bus 002 Device 001: ID 0000:0000
Bus 001 Device 002: ID 056a:0062 Wacom Co., Ltd
Bus 001 Device 001: ID 0000:0000
debian-bureau:/home/franck# cd /dev/input
debian-bureau:/dev/input# ls
by-id event0 event2 mice mouse1 ts0 wacom
by-path event1 event3 mouse0 tablet-volito2-4x5 ts1
debian-bureau:/dev/input# exit
exit
franck@debian-bureau:~$ su
Password:
debian-bureau:/home/franck#cat /proc/bus/input/devices
I: Bus=0011 Vendor=0001 Product=0001 Version=ab41
N: Name="AT Translated Set 2 keyboard"
P: Phys=isa0060/serio0/input0
S: Sysfs=/class/input/input0
H: Handlers=kbd event0
B: EV=120013
B: KEY=4 2000000 3802078 f840d001 feffffdf ffefffff ffffffff fffffffe
B: MSC=10
B: LED=7
I: Bus=0010 Vendor=001f Product=0001 Version=0100
N: Name="PC Speaker"
P: Phys=isa0061/input0
S: Sysfs=/class/input/input1
H: Handlers=kbd event1
B: EV=40001
B: SND=6
I: Bus=0011 Vendor=0002 Product=0002 Version=000f
N: Name="PS2++ Logitech MX Mouse"
P: Phys=isa0060/serio1/input0
S: Sysfs=/class/input/input2
H: Handlers=mouse0 event2 ts0
B: EV=7
B: KEY=ff0000 0 0 0 0 0 0 0 0
B: REL=143
I: Bus=0003 Vendor=056a Product=0062 Version=0200
N: Name="Wacom Volito2 4x5"
P: Phys=
S: Sysfs=/class/input/input3
H: Handlers=mouse1 event3 ts1
B: EV=f
B: KEY=1c43 0 70000 0 0 0 0 0 0 0 0
B: REL=100
B: ABS=100 3000003
merci
tu peux faire un ls -l de /dev/input STP ?
Pourquoi tu prends event3, et pas /dev/input/wacom ou même /dev/input/tablet-volito2-4x5, comme entrée ? tu as essayé ?
Sinon, pas d’idée particulière.
bonjour
oui , je l’ai tous essayé , sans detection , mais hier je n’avais que
[quote]event0 event1event2 mice mouse0 mouse1
[/quote]j’ai eu le reste en redémarrant ce matin .
[quote]franck@debian-bureau:~$ su
Password:
debian-bureau:/home/franck# ls -l de /dev/input
ls: de: Aucun fichier ou répertoire de ce type
/dev/input:
total 0
drwxr-xr-x 2 root root 60 2007-06-01 09:37 by-id
drwxr-xr-x 2 root root 140 2007-06-01 09:37 by-path
crw-rw---- 1 root root 13, 64 2007-06-01 09:37 event0
crw-rw---- 1 root root 13, 65 2007-06-01 09:37 event1
crw-rw---- 1 root root 13, 66 2007-06-01 09:37 event2
crw-rw---- 1 root root 13, 67 2007-06-01 09:37 event3
crw-rw---- 1 root root 13, 63 2007-06-01 09:37 mice
crw-rw---- 1 root root 13, 32 2007-06-01 09:37 mouse0
crw-rw---- 1 root root 13, 33 2007-06-01 09:37 mouse1
lrwxrwxrwx 1 root root 6 2007-06-01 09:37 tablet-volito2-4x5 -> event3
crw-rw---- 1 root root 13, 128 2007-06-01 09:37 ts0
crw-rw---- 1 root root 13, 129 2007-06-01 09:37 ts1
lrwxrwxrwx 1 root root 6 2007-06-01 09:37 wacom -> event3
debian-bureau:/home/franck#[/quote]
merci
en nlisant ça:
linuxwacom.sourceforge.net/index … o/inputdev
je vois que l’option “ForceDevice” “ISDV4” est réservée aux tabletpc. Tu as essayé sans ?
Tu pourrais donner le contenu de ton xorg.conf (expurgé des trucs vraiment inutiles, si tu en as le courage).
C’est pour voir si le resultat est comparable à ça:
linuxwacom.sourceforge.net/index … o/restartx
merci
ma tablette est bien une tablette pc
my-volito.com/volito/intro.asp?lang=fr
elle fonctionne sous ubuntu feisty :wink: , je comparerais les fichiers .
c’est a dire ?
je retesterais ce soir où ce week-end , la , je dois aller bosser.
merci pour tes reponses .
[quote=“fran”]merci
(…)[/quote]Je crois que tu confonds tablette pour PC et Tablet-PC (un portable avec le pad intègré). Dans le man, de toutes façons, il est dit que cette option concerne un dispositif serie, ce qui n’est pas ton cas.
As tu au moins essayé sans ?
Sinon, je voulais parler de X.0.log, pas de xorg.conf, j’ai ecrit un peu vite.
Que disent tes logs, donc.
je m’étais servis de ça pour installer ma wacom graphire :wink:
doc.ubuntu-fr.org/wacom
doc.ubuntu-fr.org/tutoriel/comme … _avec_gimp
edit : je te file mon xorg du laptopk7 si ça peux t’aider , pense a installer ça
[code]# xorg.conf (xorg X Window System server configuration file)
Edit this file with caution, and see the xorg.conf manual page.
(Type “man xorg.conf” at the shell prompt.)
package.
InputDevice "Configured Mouse"
InputDevice "Synaptics Touchpad"
InputDevice “cursor” “SendCoreEvents” # pour les tablettes non lcd seulement
InputDevice “pad” # pour tablettes Intuos3/Cintiq 21UX/Graphire4 et ne doit pas envoyer d’evenement noyau
EndSection
Section "Files"
EndSection
Section “Module”
#Load "bitmap"
Load “ddc”
#Load "dri"
Load "extmod"
Load “freetype”
#Load "glx"
Load "int10"
Load "vbe"
Load "GLcore"
Load “dbe”
#Load "record"
Load "speedo"
Load "type1"
Load "synaptics"
Load "wacom"
EndSection
Driver "wacom"
Identifier “stylus”
#Option “Device” “/dev/ttyS0” # Tablette SERIE
Option “Device” “/dev/input/wacom” # Tablette USB
Option “Type” “stylus” # Stylet pointe ecriture
Option “USB” “on” # Tablette USB
Option “Mode” “absolute” # Position sur la tablette
#Option “ForceDevice” “ISDV4” # Tablet PC ONLY
#Option “HistorySize” “64” # Taille buffer
Option “Tilt” “on” # Inclinaison
#Option “TiltInvert” “on” # Invertion de l’inclinaison
Option “Threshold” “5” # sensibilité à la pression
EndSection
Driver "wacom"
Identifier “eraser”
Option “Type” “eraser” # stylet pointe gomme
EndSection
Driver "wacom"
Identifier “cursor”
EndSection
Driver "wacom"
Identifier “pad”
Option “Type” "pad"
EndSection
Driver "kbd"
EndSection
Driver "mouse"
Option “Device” "/dev/input/mouse0"
EndSection
Identifier "Synaptics Touchpad"
Driver "synaptics"
Option “SendCoreEvents” "true"
Option “Device” "/dev/psaux"
Option “Protocol” "auto-dev"
Option “HorizScrollDelta” "0"
EndSection
Section "Device"
Identifier "S3 Inc. ProSavage PN133 [Twister P]"
Driver "savage"
BusID "PCI:1:0:0"
EndSection
Section "Monitor"
Identifier "Écran générique"
Option "DPMS"
HorizSync 30-60
VertRefresh 50-75
EndSection
Section "Screen"
Device "S3 Inc. ProSavage PN133 [Twister P]"
Monitor "Écran générique"
DefaultDepth 24
Depth 1
Modes "1024x768"
EndSubSection
Depth 4
Modes "1024x768"
EndSubSection
Depth 8
Modes "1024x768"
EndSubSection
Depth 15
Modes "1024x768"
EndSubSection
Depth 16
Modes "1024x768"
EndSubSection
Depth 24
Modes "1024x768"
EndSubSection
EndSection
bonsoir
merci pour vos reponses
je viens de tester sans l’option “ForceDevice” "ISDV4"
sans résultat .
j’ai mis /dev/input/tablet-volito2-4x5 comme entée .
sans resultat
xserver-xorg-input-wacom wacom-tools sont installés
par contre le paquet wacom-kernel-sources(je sais pas si il doit etre installé)me retourne une erreur
enregistrersous.com/images/1 … 223537.jpg
j’ai copier le wacom.ko 0.7.6.4 qui est pour linux 2.6.18
je continues a chercher
c’est pas comme ça qu’on utilise les wacom-kernel-sources.
Si tu veux te fabriquer un module wacom “sur mesure” pour ton noyau actuel (ça peut etre interressant), c’est simple, en root:
aptitude install module-assistant m-a a-i wacom-kernel-sourcesaprés, tu rebootes, et tu testes (sans l’option, même si ça ne change rien, c’est sûr qu’elle ne concerne pas une tablette usb, c’est marqué dans le man).
bonsoir
je retesterais plus tard , je viens de planter X (j’avais fait une sauvegarde, heureusement)
il ne me trouvais plus l’event 3 au demarrage .
alors que
[quote]debian-bureau:/home/franck# cd /dev/input
by-path event1 event3 mouse0 tablet-volito2-4x5 ts1[/quote]
j’ai tout retesté , aucune detection ??
bonjour
je n’arrive toujours a rien avec ma tablette
avec
by-path event1 event3 mouse0 tablet-volito2-4x5 ts1 [/quote]
je n’ai aucune detection du stylet
tu as regardé ça avant ?
[quote]Commencez par ouvrir un terminal et tapez:
cd /dev/input ls
quelque chose de ce genre devrait s’afficher :
event0 event1 event2 event3 mice mouse0 mouse1 ts0 ts1
Bien, nous devons maintenant repérer sous quel “eventX” se trouve la tablette (chez moi c’est event3), pour ce faire, il faut taper:
Ensuite, bougez le stylet sur la tablette. Si plein de chiffres s’affichent à chaque fois que vous déplacez le stylet, c’est bon, vous avez trouvé, sinon réessayez avec un autre “event” (appuyez sur Ctrl + c pour arrêter le système de détection et regagner le contrôle du terminal). Effectuez la même opération pour les “mouse”, le but étant de trouver votre souris. C’est probablement mouse0.
Quand vous avez trouvé sous quel event se trouvait la tablette et sous quelle mouse se trouvait la souris, passez à la suite.[/quote]
oui , c’est ce dont je parle dans mon post précédent (Posté le: Dim Juin 03, 2007 4:12 pm )
j’ai suivi tes liens , mais je ne detecte rien pour le stylet en testant avec
je trouve le clavier , la souris mais pas le stylet .
ça fonctionnait avec ubuntu , je detectais le stylet sur l’event 3 .
mais là rien.
il doit manqué qque chose ?
et ça c’est quoi ? :laughing:
su cat wacom | od
ou
[quote=“scorpio81”]et ça c’est quoi ? :laughing:
su cat wacom | od
ou
bonne question :smiley:
j’ai testé les entrées tablet-volito2-4x5 et wacom que tu indiques comme le reste , sans succés .
:cry:
tu promènes le stylet dessus la tablette au moins
:laughing:
oui ,faut pas abuser , merci
et j’ai déjà fait la manip sous ubuntu .
je sais je deconne , mais on sait jamais hu hu :laughing:
tu as essayé de redémarrer le server X avec la tablette branchée et de refaire des tests
sur mes machines , si je la branche une fois sur le bureau , ben ça marche pas ,ok apres avoir relançé le serveur x
la tablette est branchée en permanence , j’ai relancé X plusieurs fois , redemarré ,sans succés .
je testerais d’autre port usb , sinon je l’utiliserais avec ubuntu.
merci :frowning:
j’ai testé d’autres port usb , sans resultat.
je viens de la tester sur mon portable , sous ubuntu feisty , je branche , ça fonctionne , et je la detecte avec cat event3 | od en 2 minutes .
j’ai recupéré le pilote wacom.ko de feisty que j’ai copier sous debian
toujours rien , relance de X , redémarrage , rien.
il doit manquer quelque chose.
ce pc tournait sous ubuntu avant et la tablette fonctionnait!
