sur le système décrit juste après, je n’ai pas d’interface graphique pour configurer l’affichage (dans Paramètres Système) : taille, luminosité, … et Gnome3 s’affiche en mode restreint.
La machine a un Celeron N2940 avec un Intel HD Graphics
[size=85][code]$ lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 7.7 (wheezy)
Release: 7.7
$ uname -a
Linux […] 3.2.0-4-amd64 #1 SMP Debian 3.2.63-2+deb7u1 x86_64 GNU/Linux
~$ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 8087:07e6 Intel Corp.
Bus 001 Device 003: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Bus 001 Device 004: ID 04f2:b47f Chicony Electronics Co., Ltd
Bus 001 Device 005: ID 04ca:300b Lite-On Technology Corp.
Bus 001 Device 006: ID 0bda:0129 Realtek Semiconductor Corp.
$ lspci
00:00.0 Host bridge: Intel Corporation ValleyView SSA-CUnit (rev 0e)
00:02.0 VGA compatible controller: Intel Corporation ValleyView Gen7 (rev 0e)
00:13.0 SATA controller: Intel Corporation ValleyView 6-Port SATA AHCI Controller (rev 0e)
00:14.0 USB controller: Intel Corporation ValleyView USB xHCI Host Controller (rev 0e)
00:1a.0 Encryption controller: Intel Corporation ValleyView SEC (rev 0e)
00:1b.0 Audio device: Intel Corporation ValleyView High Definition Audio Controller (rev 0e)
00:1c.0 PCI bridge: Intel Corporation ValleyView PCI Express Root Port (rev 0e)
00:1c.2 PCI bridge: Intel Corporation ValleyView PCI Express Root Port (rev 0e)
00:1c.3 PCI bridge: Intel Corporation ValleyView PCI Express Root Port (rev 0e)
00:1d.0 USB controller: Intel Corporation ValleyView USB Enhanced Host Controller (rev 0e)
00:1f.0 ISA bridge: Intel Corporation ValleyView Power Control Unit (rev 0e)
00:1f.3 SMBus: Intel Corporation ValleyView SMBus Controller (rev 0e)
02:00.0 Network controller: Atheros Communications Inc. AR9565 Wireless Network Adapter (rev 01)
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 0c)[/code][/size]
Comme piste de résolution, je pourrais installer un backport avec le bon pilote. Je pense au noyau Linux 3.16.2 (vu ici 01.org/linuxgraphics/downloads/ … ck-release) mais le ne vois pas dans Synaptic ?
J’espère ne pas être confus.
