voila a l’instalation du de l’annuaire il m’est imposible de redémarer corectemnt le slapd.
Starting OpenLDAP: slapd - failed.
The operation failed but no output was produced. For hints on what went
wrong please refer to the system’s logfiles (e.g. /var/log/syslog) or
try running the daemon in Debug mode like via “slapd -d 16383” (warning:
this will create copious output).
Below, you can find the command line options used by this script to
run slapd. Do not forget to specify those options if you
want to look to debugging output:
slapd -h 'ldap://127.0.0.1:389 ldaps://192.168.0.16:636’ -g openldap -u openldap -f /etc/ldap/slapd.conf
je vais fournir les fichier de configuraiton et le tuto
le probléme survien à la fin du " 1.3 Support SSL"
