Voila ma carte grafique est une 7600GS j’ai installer les drivers nvidia beta, j’ai tester l’accélération 3d marche.
Donc voila j’essaye d’installé beryl donc :
voila j’ai télécharger et installer les packets suivant :
beryl-core_0.1.1-1_i…>
beryl-dev_0.1.1-1_i3…>
beryl-manager_0.1.1-…>
beryl-plugins-data_0…>
beryl-plugins_0.1.1-…>
beryl-settings_0.1.1…>
beryl_0.1.1-1_i386.deb
emerald-themes_0.1.1…>
emerald_0.1.1-1_i386…>
j’ai fait :
apt-get install libdrm2 libpng3 libxdamage1 libxcomposite1
j’ai modifier mon xorg le voici :
[code]# nvidia-xconfig: X configuration file generated by nvidia-xconfig
nvidia-xconfig: version 1.0 (buildmeister@builder3) Thu Sep 14 15:50:24 PDT 2006
/etc/X11/xorg.conf (xorg X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
(Type « man /etc/X11/xorg.conf » at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section « ServerLayout »
Identifier « Default Layout »
Screen « Default Screen » 0 0
InputDevice « Generic Keyboard »
InputDevice « Configured Mouse »
EndSection
Section « Files »
# path to defoma fonts
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/X11R6/lib/X11/fonts/misc"
FontPath "/usr/share/fonts/X11/cyrillic"
FontPath "/usr/X11R6/lib/X11/fonts/cyrillic"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath "/usr/X11R6/lib/X11/fonts/Type1"
FontPath "/usr/share/fonts/X11/100dpi"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi"
FontPath "/usr/share/fonts/X11/75dpi"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi"
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section « Module »
Load « i2c »
Load « bitmap »
Load « ddc »
Load « extmod »
Load « freetype »
Load « glx »
Load « int10 »
Load « type1 »
Load « vbe »
EndSection
Section « InputDevice »
Identifier « Generic Keyboard »
Driver « kbd »
Option « CoreKeyboard »
Option « XkbRules » « xorg »
Option « XkbModel » « pc105 »
Option « XkbLayout » « fr »
Option « XkbVariant » « latin9 »
EndSection
Identifier « Configured Mouse »
Driver « mouse »
Option « CorePointer »
Option « Device » « /dev/input/mice »
Option « Protocol » « ExplorerPS/2 »
Option « Emulate3Buttons » « true »
EndSection
Section « Monitor »
Identifier « QV773 »
Option « DPMS »
EndSection
Section « Device »
Identifier « NVIDIA Corporation NVIDIA Default Card »
Driver « nvidia »
EndSection
Section « Screen »
Identifier « Default Screen »
Device « NVIDIA Corporation NVIDIA Default Card »
Monitor « QV773 »
Option « AddARGBGLXVisuals » « True »
Option « DisableGLXRootClipping » « True »
DefaultDepth 24
SubSection « Display »
Depth 1
Modes « 1280x1024 » « 1024x768 » « 800x600 » « 720x400 » « 640x480 »
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section « Extensions »
Option « Composite » « Enable »
EndSection
j’ai fait :
beryl-manager
et j’ai sa :
donc voila si quelqu’un peut m’aider …
