Installation buster sur portable Dell : problème wifi
Tags: #<Tag:0x00007fb5bba66710> #<Tag:0x00007fb5bba66648> #<Tag:0x00007fb5bba66580>
@PengouinPdt Je confirme, ça ne marche pas :slight_smile:
root@lodoss:~# lspci | grep net
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (6) I219-LM (rev 30)
root@lodoss:~# dmesg | grep -i firmware
[    0.449368] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    2.156966] i915 0000:00:02.0: firmware: direct-loading firmware i915/kbl_dmc_ver1_04.bin
[    2.157348] [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
[    2.745611] amdgpu 0000:3b:00.0: firmware: direct-loading firmware amdgpu/polaris12_k_mc.bin
[    2.746697] amdgpu 0000:3b:00.0: firmware: direct-loading firmware amdgpu/polaris12_pfp_2.bin
[    2.746705] amdgpu 0000:3b:00.0: firmware: direct-loading firmware amdgpu/polaris12_me_2.bin
[    2.746711] amdgpu 0000:3b:00.0: firmware: direct-loading firmware amdgpu/polaris12_ce_2.bin
[    2.746720] amdgpu 0000:3b:00.0: firmware: direct-loading firmware amdgpu/polaris12_rlc.bin
[    2.746766] amdgpu 0000:3b:00.0: firmware: direct-loading firmware amdgpu/polaris12_mec_2.bin
[    2.746814] amdgpu 0000:3b:00.0: firmware: direct-loading firmware amdgpu/polaris12_mec2_2.bin
[    2.747776] amdgpu 0000:3b:00.0: firmware: direct-loading firmware amdgpu/polaris12_sdma.bin
[    2.747784] amdgpu 0000:3b:00.0: firmware: direct-loading firmware amdgpu/polaris12_sdma1.bin
[    2.747899] amdgpu 0000:3b:00.0: firmware: direct-loading firmware amdgpu/polaris12_uvd.bin
[    2.747900] [drm] Found UVD firmware Version: 1.130 Family ID: 16
[    2.749941] amdgpu 0000:3b:00.0: firmware: direct-loading firmware amdgpu/polaris12_vce.bin
[    2.749942] [drm] Found VCE firmware Version: 53.26 Binary ID: 3
[    2.750279] amdgpu 0000:3b:00.0: firmware: direct-loading firmware amdgpu/polaris12_k_smc.bin
[    5.744694] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[    5.746249] bluetooth hci0: firmware: direct-loading firmware intel/ibt-20-1-3.sfi
[    5.746252] Bluetooth: hci0: Found device firmware: intel/ibt-20-1-3.sfi
[   16.397087] Bluetooth: hci0: Failed to send firmware data (-110)
root@lodoss:~#
Bon, du coup soit Sid, soit noyau 5.1, et firmware Intel dans les deux cas.
Ya plus qu’a !
Merci :smiley:
Darckense
:wink:
ou comment perdre du temps à absolument testé une solution qui n’en est pas une alors qu’on est averti qu’elle ne l’est pas :stuck_out_tongue:
Bon courage.
PS : va écrire un petit article afin d’utiliser Debian Sid/Devuan Ceres
Je me demande, si elle existe, s’il ne faudrait pas tenter une mise à jour du BIOS
Tu auras les références nécessaires dans le retour de la ligne de commandes suivante,
lancée avec les privilèges du compte root
dmidecode -t baseboard; dmidecode -t bios
J’ai une bonne nouvelle, je vous écris depuis mon portable sous Debian en wifi ! :slight_smile: … mais je ne comprends pas pourquoi ça marche !
root@lodoss:~# uname -a
Linux lodoss 5.4.0-0.bpo.2-amd64 #1 SMP Debian 5.4.8-1~bpo10+1 (2020-01-07) x86_64 GNU/Linux
[    0.438667] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    1.754140] i915 0000:00:02.0: firmware: direct-loading firmware i915/kbl_dmc_ver1_04.bin
[    1.754765] [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
[    1.788332] amdgpu 0000:3b:00.0: firmware: direct-loading firmware amdgpu/polaris12_k_mc.bin
[    1.789005] amdgpu 0000:3b:00.0: firmware: direct-loading firmware amdgpu/polaris12_pfp_2.bin
[    1.789013] amdgpu 0000:3b:00.0: firmware: direct-loading firmware amdgpu/polaris12_me_2.bin
[    1.789019] amdgpu 0000:3b:00.0: firmware: direct-loading firmware amdgpu/polaris12_ce_2.bin
[    1.789026] amdgpu 0000:3b:00.0: firmware: direct-loading firmware amdgpu/polaris12_rlc.bin
[    1.789066] amdgpu 0000:3b:00.0: firmware: direct-loading firmware amdgpu/polaris12_mec_2.bin
[    1.789105] amdgpu 0000:3b:00.0: firmware: direct-loading firmware amdgpu/polaris12_mec2_2.bin
[    1.790098] amdgpu 0000:3b:00.0: firmware: direct-loading firmware amdgpu/polaris12_sdma.bin
[    1.790105] amdgpu 0000:3b:00.0: firmware: direct-loading firmware amdgpu/polaris12_sdma1.bin
[    1.790212] amdgpu 0000:3b:00.0: firmware: direct-loading firmware amdgpu/polaris12_uvd.bin
[    1.790213] [drm] Found UVD firmware Version: 1.130 Family ID: 16
[    1.792259] amdgpu 0000:3b:00.0: firmware: direct-loading firmware amdgpu/polaris12_vce.bin
[    1.792260] [drm] Found VCE firmware Version: 53.26 Binary ID: 3
[    1.792774] amdgpu 0000:3b:00.0: firmware: direct-loading firmware amdgpu/polaris12_k_smc.bin
[    3.537701] iwlwifi 0000:3c:00.0: firmware: failed to load iwlwifi-cc-a0-50.ucode (-2)
[    3.537721] firmware_class: See https://wiki.debian.org/Firmware for information about missing firmware
[    3.537739] iwlwifi 0000:3c:00.0: Direct firmware load for iwlwifi-cc-a0-50.ucode failed with error -2
[    3.537748] iwlwifi 0000:3c:00.0: firmware: failed to load iwlwifi-cc-a0-49.ucode (-2)
[    3.537764] iwlwifi 0000:3c:00.0: Direct firmware load for iwlwifi-cc-a0-49.ucode failed with error -2
[    3.539139] iwlwifi 0000:3c:00.0: firmware: direct-loading firmware iwlwifi-cc-a0-48.ucode
[    3.539268] iwlwifi 0000:3c:00.0: loaded firmware version 48.13675109.0 op_mode iwlmvm
[    3.668426] iwlwifi 0000:3c:00.0: Allocated 0x00400000 bytes for firmware monitor.
[    3.917958] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[    3.918975] bluetooth hci0: firmware: direct-loading firmware intel/ibt-20-1-3.sfi
[    3.918977] Bluetooth: hci0: Found device firmware: intel/ibt-20-1-3.sfi
[   14.262188] Bluetooth: hci0: Failed to send firmware data (-110)
J’ai installé le noyau 5.4 de backport car le 5.5 avait des dépendances non satisfaites et je ne voulais pas trop casser le système.
Après redémarrage, mon réseau wifi a été détecté automatiquement (automagiquement) par l’applet réseau du bureau KDE…
J’ai observé un comportement étrange en redémarrant justement. (Testé plusieurs fois et avec les deux noyaux, 5.4 et 4.19). Lorsque je redémarre le système, il se bloque juste après l’écran de Grub en affichant :
Chargement de linux XXXX (5.4 ou 4.19)
Chargement du disque mémoire initial
Par contre, si j’éteins complètement, j’attends une seconde et que je démarre, le système (5.4 ou 4.19) se charge normalement.
Etrange, non ? Vous pensez que c’est lié au Bios ? Normalement j’ai désactivé le Secure Boot.
Mais merci en tout cas, j’ai du réseau, c’est le principal ! :smiley:
Darckense
Pour le bios, j’ai justement fait une mise à jour (sous windows du coup), et il est à jour.
Super content que ton WiFi fonctionne :+1:
Merci beaucoup pour le retour. :grinning:
Très bien ! :stuck_out_tongue:
1/ parce que tu as installé un noyau > 5.1 - en l’occurence, un 5.4+
2/ parce que le firmware chargé est en version 48.13, or la version minimale est une v46.3 :stuck_out_tongue:
Par contre, que cela fonctionne avec le 4.19, c’est étonnant, mais soit !!!
une incidence liée à la màj Bios ? ça peut ; même si perso, je n’y crois pas.
Concernant Sid, j’ai créé ce mémoriel :
https://doc.huc.fr.eu.org/fr/sys/debian/unstable-sid/
