Installation carte graphique 8600 gts sur lenny 64
Bonjour à tous !
J’ai un petit soucis quant à l’installation de ma carte graphique… Une nvidia 8600 GTS.
J’ai tenter de suivre plusieurs “how to” pour installer cette carte mais sans succès.
un lspci me renvoi :
le fichier /etc/X11/xorg.conf:
[code]# nvidia-xconfig: X configuration file generated by nvidia-xconfig
nvidia-xconfig: version 1.0 (buildmeister@builder62) Mon Mar 2 15:57:24 PST 2009
Section "ServerLayout"
Identifier "Layout0"
screen 0 “Screen0” 0 0
Inputdevice “Keyboard0” "CoreKeyboard"
Inputdevice “Mouse0” "CorePointer"
EndSection
Section "Files"
Rgbpath "/usr/lib/X11/rgb"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load "type1"
Load "freetype"
Load "glx"
EndSection
Section “InputDevice”
# generated from default
Identifier	"Mouse0"
Driver		"mouse"
Option		"Protocol"	"auto"
Option		"Device"	"/dev/psaux"
Option		"Emulate3Buttons"	"no"
Option		"ZAxisMapping"	"4 5"
EndSection
Identifier	"Keyboard0"
Driver		"kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
Vendorname "Unknown"
Modelname "Unknown"
Horizsync 30.0 - 110.0
Vertrefresh 50.0 - 150.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nv"
Vendorname "NVIDIA Corporation"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
Defaultdepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Extensions"
EndSection[/code]
si je passe le driver “nv” en “nvidia” impossible de redemarer gnome, il plante…
voici le log de Xorg :
[code]X.Org X Server 1.4.2
Release Date: 11 June 2008
X Protocol Version 11, Revision 0
Build Operating System: Linux Debian (xorg-server 2:1.4.2-10)
Current Operating System: Linux debianpowa 2.6.26-1-amd64 #1 SMP Fri Mar 13 17:46:45 UTC 2009 x86_64
Build Date: 09 January 2009 02:16:05AM
    Before reporting problems, check http://wiki.x.org
Module Loader present
Markers: (–) probed, () from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.21.log”, Time: Fri Mar 27 23:06:11 2009
(==) Using config file: “/etc/X11/xorg.conf”
(==) ServerLayout “Layout0”
) |–>Screen “Screen0” (0)
() | |–>Monitor “Monitor0”
) | |–>Device “Device0”
() |–>Input Device “Keyboard0”
) |–>Input Device “Mouse0”
Merci de vos réponses :slightly_smiling:
Le tuto que l’on trouve dans trucs et astuces est celui-là.
Pour info, j’ai une 8600 GT et aucun problème en lenny.
Merci de ta réponse, j’ai suivi le tutoriel mais sans succès, il y à des erreurs… J’ai parcouru plusieurs tutoriels similaire mais toujours le même soucis, avec module-assistant…
Je tape la commande suivante :
m-a a-i nvidia il me répond :
La construction du paquet nvidia-kernel-source a échoué. │
│ Que souhaitez-vous faire ?
Je choisit d’examiner le fichier journal de la construction qui me dit :
Build log starting, file: ↑ │ /var/cache/modass/nvidia-kernel-source.buildlog.2.6.26-1-amd64.1238529745 ▮ │ Date: Tue, 31 Mar 2009 22:02:25 +0200
Et enfin avec la commande :
m-a a-i -i nvidia-kernel-source
Il me répond :
[code].
Données de 1 paquets mises à jour
Récupération des sources du noyau de la version : 2.6.26-1-amd64
En-têtes du noyau disponibles dans /lib/modules/2.6.26-1-amd64/build
apt-get-y install build-essential
Fait.
unpack
The source tarball could not be found!
Package nvidia-kernel-source not installed?
Running “m-a -f get nvidia-kernel-source” may help.
"/usr/share/modass/packages/default.sh" build KVERS=2.6.26-1-amd64 KSRC=/lib/modules/2.6.26-1-amd64/build KDREV=2.6.26-13lenny2 kdist_image
Donc je tente un : m-a -f get nvidia-kernel-source
Il fait son boulot mais me renvoi toujours bouler quand je retente : m-a a-i -i nvidia-kernel-source
grr !!
J’ai surement fait quelque bétises… Dans le tuto il dit de faire un :
find / -name “nvidia” -delete
Mais avec cette commande il ne voulai pas tout supprimer car il y avait des dossiers… Je l’ai ai donc joyeusement supprimer à la main ( la boulette ?!)
voila où j’en suit … Et je sent que le driver n’est pas prêt de tourner :frowning:
Souvent, ce sont les scories des tentatives précédentes : il faut donc commencer par virer tout ce qui reste concernant nvidia pour repartir d’un système propre.
Et bien justement… J’aimerai tout effacer mais … Je ne sait plus vraiment tout ce que j’ai fait donc cela va être délicat pour repartir sur une base propre :frowning: Une idée de solution ?!
tu as bien les dépôts contrib et non-free dans ton source.list ?
