Ah ca y est il y a du nouveau.
Apres avoir telecharge ndiswrapper-utils et wireless-tools et les avoir installe… j’ai redemarre et j’ai obtenu le resultat suivannt (apres avoir configure mon ficheier /etc/network/interfaces correctement) :
[code]SERVER:/home/eric# iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
wmaster0 no wireless extensions.
wlan0 IEEE 802.11 ESSID:"XING-NUMERICABLE"
Mode:Managed Frequency:2.412 GHz Access Point: Not-Associated
Tx-Power=0 dBm
Retry min limit:7 RTS thr:off Fragment thr=2352 B
Encryption key:XXXX-XXXX-XX
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
SERVER:/home/eric# ifdown wlan0
Internet Systems Consortium DHCP Client V3.1.1
Copyright 2004-2008 Internet Systems Consortium.
All rights reserved.
For info, please visit http://www.isc.org/sw/dhcp/
wmaster0: unknown hardware address type 801
Listening on LPF/wlan0/00:08:d3:38:c5:b5
Sending on LPF/wlan0/00:08:d3:38:c5:b5
Sending on Socket/fallback
SERVER:/home/eric# ifup wlan0
SIOCSIFFLAGS: No such file or directory
receive_packet failed on wlan0: Network is down
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 6
send_packet: Network is down
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 15
^C
SERVER:/home/eric# wlist wlan0 scan
bash: wlist: command not found
SERVER:/home/eric# iwlist wlan0 scan
wlan0 Interface doesn’t support scanning : Network is down
SERVER:/home/eric# [/code]
J’ai regarde aussi pour recuperer les drivers windows du CD mais il n’y a aucun .cab, que des setup.exe…
