Installation curl sur debian6
Bonjour à tous
Lorsque j’essaie d’installer curl sur une debian 6/ispconfig3 j’obtiens:
[code]# aptitude install php5-curl curl
The following NEW packages will be installed:
php5-curl
The following packages will be upgraded:
php5-common
1 packages upgraded, 1 newly installed, 0 to remove and 85 not upgraded.
Need to get 580 kB of archives. After unpacking 127 kB will be used.
The following packages have unmet dependencies:
libapache2-mod-php5: Depends: php5-common (= 5.3.3-7+squeeze3) but 5.3.3-7+squeeze8 is to be installed.
php5-gd: Depends: php5-common (= 5.3.3-7+squeeze3) but 5.3.3-7+squeeze8 is to be installed.
php5-pspell: Depends: php5-common (= 5.3.3-7+squeeze3) but 5.3.3-7+squeeze8 is to be installed.
php5-mcrypt: Depends: php5-common (= 5.3.3-7+squeeze3) but 5.3.3-7+squeeze8 is to be installed.
php5-imap: Depends: php5-common (= 5.3.3-7+squeeze3) but 5.3.3-7+squeeze8 is to be installed.
php5-mysql: Depends: php5-common (= 5.3.3-7+squeeze3) but 5.3.3-7+squeeze8 is to be installed.
php5-cgi: Depends: php5-common (= 5.3.3-7+squeeze3) but 5.3.3-7+squeeze8 is to be installed.
php5-cli: Depends: php5-common (= 5.3.3-7+squeeze3) but 5.3.3-7+squeeze8 is to be installed.
The following actions will resolve these dependencies:
  Remove the following packages:
  1.  libapache2-mod-php5
  2.  libapache2-mod-suphp
  3.  php-auth
  4.  php-auth-sasl
  5.  php-mail-mime
  6.  php-mail-mimedecode
  7.  php-mdb2
  8.  php-mdb2-driver-mysql
  9.  php-net-smtp
  10. php-net-socket
  11. php-pear
  12. php5
  13. php5-cgi
  14. php5-cli
  15. php5-gd
  16. php5-imagick
  17. php5-imap
  18. php5-mcrypt
  19. php5-mysql
  20. php5-pspell
  21. php5-suhosin
  22. phpmyadmin
  23. roundcube
  24. roundcube-core
  25. roundcube-mysql
  26. suphp-common
    Keep the following packages at their current version:
  27. php5-curl [Not Installed]
    Leave the following dependencies unresolved:
  28. php-net-smtp recommends php-auth-sasl
  29. php5-common recommends php5-suhosin
  30. phpmyadmin recommends php5-gd
Je n’ose pas accepter cette solution. Merci pour vos suggestions
Avant d’installer de nouveaux paquets, tu devrais mettre à jour php avec la version de sécurité. Vérifie que tu as les dépôts security dans ton sources.list, puis :
Effectivement update, upgrade avaient résolu le problème.
