je n’arrive pas as installer FOG
[code]This script should be run by the root user on Fedora, or with sudo on Ubuntu.
Here are the settings FOG will use:
Distro: Ubuntu
Installation Type: Normal Server
Server IP Address: 192.168.1.203
DHCP router Address:
DHCP DNS Address:
Interface: eth0
Using FOG DHCP: 1
Internationalization: 0
Are you sure you wish to continue (Y/N) y
Installation Started…
Installing required packages, if this fails
make sure you have an active internet connection.
Preparing apt-get
Installing package: apache2
Installing package: php5
Installing package: php5-gd
Installing package: php5-cli
Installing package: php5-mysql
Installing package: php5-curl
Installing package: mysql-server
We are about to install MySQL Server on
this server, if MySQL isn’t installed already
you will be prompted for a root password. If
you don’t leave it blank you will need to change
it in the config.php file located at:/var/www/fog/commons/config.php
Press enter to acknowledge this message.
Lecture des listes de paquetsâ¦
Construction de l’arbre des dépendancesâ¦
Lecture des informations d’étatâ¦
mysql-server est déjà la plus récente version disponible.
Les paquets suivants ont été installés automatiquement et ne sont plus nécessaires :
apache2-mpm-prefork apache2.2-bin libdb5.1 libgd2-xpm libjpeg62 libt1-5 ttf-dejavu-core
Veuillez utiliser « apt-get autoremove » pour les supprimer.
0 mis à jour, 0 nouvellement installés, 0 à enlever et 8 non mis à jour.
- Installing package: mysql-client
- Installing package: isc-dhcp-server
- Installing package: tftpd-hpa
- Installing package: tftp-hpa
- Installing package: nfs-kernel-server
- Installing package: vsftpd
- Installing package: net-tools
- Installing package: wget
- Installing package: xinetd
- Installing package: sysv-rc-conf
- Installing package: tar
- Installing package: gzip
- Installing package: build-essential
- Installing package: cpp
- Installing package: gcc
- Installing package: g++
- Installing package: m4
- Installing package: htmldoc
- Installing package: perl
- Installing package: libcrypt-passwdmd5-perl
- Installing package: lftp
- Installing package: openssh-server
- Installing package: php-gettext
- Installing package: clamav-freshclam
Confirming package installation.
- Checking package: apache2…OK
- Checking package: php5…OK
- Checking package: php5-gd…OK
- Checking package: php5-cli…OK
- Checking package: php5-mysql…OK
- Checking package: php5-curl…OK
- Checking package: mysql-server…OK
- Checking package: mysql-client…OK
- Checking package: isc-dhcp-server…OK
- Checking package: tftpd-hpa…OK
- Checking package: tftp-hpa…OK
- Checking package: nfs-kernel-server…OK
- Checking package: vsftpd…OK
- Checking package: net-tools…OK
- Checking package: wget…OK
- Checking package: xinetd…OK
- Checking package: sysv-rc-conf…OK
- Checking package: tar…OK
- Checking package: gzip…OK
- Checking package: build-essential…OK
- Checking package: cpp…OK
- Checking package: gcc…OK
- Checking package: g++…OK
- Checking package: m4…OK
- Checking package: htmldoc…OK
- Checking package: perl…OK
- Checking package: libcrypt-passwdmd5-perl…OK
- Checking package: lftp…OK
- Checking package: openssh-server…OK
- Checking package: php-gettext…OK
- Checking package: clamav-freshclam…OK
Configuring services.
- Setting up fog user…Exists
- Setting up and starting MySql…Failed!
root@Host-456:/opt/fog_0.31/bin#[/code]
