Sur un Debian 8.0 j’essaye de suivre le tuto area51.fr/2010/09/06/suexec-suphp-apache2/
mais je bloque sur l’installation de suPHP.
lors de la commande apt-get install libapache2-mod-suphp j’obtiens le message:
Reading package lists… Done
Building dependency tree
Reading state information… Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libapache2-mod-suphp : Depends: suphp-common (= 0.7.1-1) but it is not going to be installed
Depends: apache2.2-common but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Pour info mon fichier sources.list contient les lignes suivantes:
deb security.debian.org/ squeeze/updates main contrib non-free
deb-src security.debian.org/ squeeze/updates main contrib non-free
Debian.org:
deb ftp.debian.org/debian/ squeeze main contrib non-free
deb-src ftp.debian.org/debian/ squeeze main contrib non-free
Au paravent le fichier de source contenait les lignes:
deb debian.mirrors.ovh.net/debian/ wheezy main
deb-src debian.mirrors.ovh.net/debian/ wheezy main
deb security.debian.org/ wheezy/updates main
deb-src security.debian.org/ wheezy/updates main
deb packages.dotdeb.org wheezy-php55 all
deb-src packages.dotdeb.org wheezy-php55 all
deb ftp.fr.debian.org/debian/ sid main
Et avec ces sources le message d’erreur était un peu différent:
Package libapache2-mod-suphp is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package ‘libapache2-mod-suphp’ has no installation candidate
(je précise que j’ai fait les apt-get update et upgrade avant)
Pouvez-vous m’aider s’il vous plait?
merci
cyril
