Installation d'un lecteur
je possede un lecteur d’empreinte digitale AuthenTec et je n’arrive pas a l’installer :
Bus 007 Device 003: ID 0930:653d Toshiba Corp.
Bus 007 Device 001: ID 0000:0000
Bus 006 Device 001: ID 0000:0000
Bus 004 Device 001: ID 0000:0000
Bus 003 Device 003: ID 08ff:2580 AuthenTec, Inc.
Bus 003 Device 001: ID 0000:0000
Bus 001 Device 003: ID 03f0:171d Hewlett-Packard
Bus 001 Device 001: ID 0000:0000
Bus 002 Device 001: ID 0000:0000
Bus 005 Device 001: ID 0000:0000
Quand je fais la commande : sane-find-scanner, il ne me trouve rien :s
No SCSI scanners found. If you expected something different, make sure that
you have loaded a SCSI driver for your SCSI adapter.
Also you need support for SCSI Generic (sg) in your operating system.
If using Linux, try “modprobe sg”.
No USB scanners found. If you expected something different, make sure that
you have loaded a driver for your USB host controller and have installed a
kernel scanner module.
Not checking for parallel port scanners.
Most Scanners connected to the parallel port or other proprietary ports
can’t be detected by this program.
Distrib : Linux debian etch
Pc portable : Hp 6710B
Merci d’avance
Va voir là, tu trouveras le développement en cours:
http://gkall.hobby.nl/authentec.html
