Salut à tous, cela fait maintenant une semaine que j’ai du mal installer et activer Curl sur mon serveur.
N.B : Je suis débutant en Linux(Debian)…
Voici le message d’erreur quand j’essaie d’installer :
root@staaf:~# aptitude install php5-curl curl
The following NEW packages will be installed:
curl libcurl3{a} libssh2-1{a} php5-curl
0 packages upgraded, 4 newly installed, 0 to remove and 0 not upgraded.
Need to get 77.2 kB/613 kB of archives. After unpacking 1212 kB will be used.
Do you want to continue? [Y/n/?]
WARNING: untrusted versions of the following packages will be installed!
Untrusted packages could compromise your system’s security.
You should only proceed with the installation if you are certain that
this is what you want to do.
libssh2-1
Do you want to ignore this warning and proceed anyway?
To continue, enter “Yes”; to abort, enter “No”: Yes
Err http://ftp.debian.org/debian/ squeeze/main libssh2-1 i386 1.2.6-1
404 Not Found [IP: 2001:610:1908:b000::148:12 80]
E: Failed to fetch http://ftp.debian.org/debian/pool/main/libs/libssh2/libssh2-1_1.2.6-1_i386.deb: 404 Not Found [IP: 2001:610:1908:b000::148:12 80]
root@staaf:~#
Aidez moi svp…
