Débutant sur Linux et Debian (Je sais j’aurai dû commencer par Ubuntu), j’en suis à la fin de mon install de Genymotion. J’ai déjà installé VirtualBox.
Voici mon message d’erreur :
root@Adrien-debian:/# cd /opt
root@Adrien-debian:/opt# chmod +x genymotion-2.4.0_x64_debian.bin
root@Adrien-debian:/opt# ./genymotion-2.4.0_x64_debian.bin
Installing to folder [/opt/genymotion]. Are you sure [y/n] ? y
- Trying to find VirtualBox toolset … OK (Valid version of VirtualBox found: 4.3.26r98988)
- Extracting files … OK (Extract into: [/opt/genymotion])
Installation done successfully.
You can now use these tools from [/opt/genymotion]:
- genymotion
- genymotion-shell
root@Adrien-debian:/opt# cd genymotion
root@Adrien-debian:/opt/genymotion# ./genymotion
(process:30974): GConf-WARNING **: Client failed to connect to the D-BUS daemon:
Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Error while opening log file: /root/.Genymobile/genymotion.log: No such file or directory
Logging activities to file: /root/.Genymobile/genymotion.log
Abandon
Merci d’avance. Je suppose que vous avez besoin d’autres infos…
