[quote=“bech”]Le démon snmpd existe dans /usr/sbin
Par contre, il n’y a rien pour lancer snmp dans /etc/init.d
[code][14:37:32] ~ # cat /etc/init.d/snmpd
#! /bin/sh -e
BEGIN INIT INFO
Provides: snmpd snmptrapd
Required-Start: $network $remote_fs $syslog
Required-Stop: $network $remote_fs $syslog
Default-Start: 2 3 4 5
Default-Stop: 0 1 6
Short-Description: SNMP agents
Description: NET SNMP (Simple Network Management Protocol) Agents
END INIT INFO
set -e
. /lib/lsb/init-functions
export PATH=/sbin:/usr/sbin:/bin:/usr/bin
test -x /usr/sbin/snmpd || exit 0
test -x /usr/sbin/snmptrapd || exit 0
Defaults
export MIBDIRS=/usr/share/mibs/site:/usr/share/snmp/mibs:/usr/share/mibs/iana:/usr/share/mibs/ietf:/usr/share/mibs/netsnmp
SNMPDRUN=yes
SNMPDOPTS=’-Lsd -Lf /dev/null -p /var/run/snmpd.pid’
TRAPDRUN=no
TRAPDOPTS=’-Lsd -p /var/run/snmptrapd.pid’
Reads config file (will override defaults above)
[ -r /etc/default/snmpd ] && . /etc/default/snmpd
Cd to / before starting any daemons.
cd /
Create compatibility link to old AgentX socket location
if [ “$SNMPDCOMPAT” = “yes” ] && [ “$1” != status ]; then
ln -sf /var/agentx/master /var/run/agentx
fi
case “$1” in
start)
echo -n “Starting network management services:”
if [ “$SNMPDRUN” = “yes” -a -f /etc/snmp/snmpd.conf ]; then
start-stop-daemon --quiet --start --oknodo --exec /usr/sbin/snmpd
– $SNMPDOPTS
echo -n " snmpd"
fi
if [ “$TRAPDRUN” = “yes” -a -f /etc/snmp/snmptrapd.conf ]; then
start-stop-daemon --quiet --start --oknodo --exec /usr/sbin/snmptrapd
– $TRAPDOPTS
echo -n " snmptrapd"
fi
echo “.”
stop)
echo -n “Stopping network management services:”
start-stop-daemon --quiet --stop --oknodo --exec /usr/sbin/snmpd
echo -n " snmpd"
start-stop-daemon --quiet --stop --oknodo --exec /usr/sbin/snmptrapd
echo “.”
restart)
echo -n “Restarting network management services:”
# Allow the daemons time to exit completely.
sleep 2
start-stop-daemon --quiet --start --exec /usr/sbin/snmpd – $SNMPDOPTS
echo -n " snmpd"
fi
# Allow snmpd time to start up.
sleep 1
start-stop-daemon --quiet --start --exec /usr/sbin/snmptrapd – $TRAPDOPTS
fi
echo “.”
reload|force-reload)
echo -n “Reloading network management services:”
start-stop-daemon --quiet --stop --signal 1
–pidfile /var/run/snmpd.pid --exec /usr/sbin/snmpd
echo -n " snmpd"
fi
echo “.”
status)
status=0
status_of_proc /usr/sbin/snmpd snmpd || status=$?
fi
status_of_proc /usr/sbin/snmptrapd snmptrapd || status=$?
fi
exit $status
echo “Usage: /etc/init.d/snmpd {start|stop|restart|reload|force-reload|status}”
exit 1
esac
exit 0
[14:37:38] ~ # [/code]
[quote]J’ai essayé de mettre dans /etc/init.d et /etc/rc?.d des shells snmp de Mandriva 2008, mais ils sont incompatibles.
Ce n’est plus les mains dans le cambouis ça, cela relèverait plutôt du suicide de ta Debian, hein …
Ne sois donc pas surpris de l’incompatibilité …
Option -s = simulation.
# aptitude remove -s --purge <le_paquet>
# aptitude search ~c
# aptitude purge ~c
# find / -iname "*le_paquet*"
SNMP ou la supervision d’équipements réseaux t’ouvrira la voie …
