user@debian:/usr/share/applications$ install-debian
localuser:root being added to access control list
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
18:14:47 [2]: WARNING: Required settings.conf key disable-cancel is missing.
18:14:47 [2]: WARNING: Branding module-setting *windowExpanding* interpreted as "normal"
18:14:47 [2]: WARNING: the branding component "/etc/calamares/branding/debian" does not ship translations.
18:14:47 [2]: WARNING: RequirementsChecker entry 'internetCheckUrl' is undefined in welcome.conf,reverting to default (http://example.com).
18:14:47 [2]: WARNING: RequirementsChecker configuration map:
check : storage, ram, power, root
required : storage, ram, root
requiredRam : 1
requiredStorage : 10
18:14:47 [2]: WARNING: Partition-module setting *defaultFileSystemType* is missing, using ext4
18:15:15 [0]: blkid: unknown file system type "" on "/dev/sdc1"
18:15:18 [2]: WARNING: system is EFI but no EFI system partitions found.
18:15:18 [0]: QObject::setParent: Cannot set parent, new parent is in a different thread
18:15:18 [2]: WARNING: System is EFI but there's no EFI system partition, DISABLING alongside and replace features.
18:15:32 [2]: WARNING: system is EFI but no EFI system partitions found.
18:15:45 [2]: WARNING: system is EFI but no EFI system partitions found.
18:16:34 [2]: WARNING: system is EFI but no EFI system partitions found.
Segmentation fault
localuser:root being removed from access control list
Sep 2 16:19:43 localhost kernel: [ 4676.170923] BTRFS info (device sda1): disk space caching is enabled
Sep 2 16:19:43 localhost kernel: [ 4676.170926] BTRFS info (device sda1): has skinny extents
Sep 2 16:19:43 localhost kernel: [ 4676.180562] BTRFS info (device sda1): enabling ssd optimizations
Sep 2 16:19:43 localhost systemd[1080]: tmp-Calamares\x2diShJkZ.mount: Succeeded.
Sep 2 16:19:43 localhost systemd[1]: tmp-Calamares\x2diShJkZ.mount: Succeeded.
Sep 2 16:19:48 localhost systemd[1]: systemd-timedated.service: Succeeded.
Sep 2 16:20:05 localhost kernel: [ 4698.200664] calamares[6366]: segfault at 10 ip 00007f67d05490a6 sp 00007ffc655717a0 error 4 in libcalamares_viewmodule_partition.so[7f67d0507000+7d000]
Sep 2 16:20:05 localhost kernel: [ 4698.200675] Code: 44 24 48 31 c0 48 8b 47 30 4c 8d 64 24 30 4c 89 e7 48 8b 70 40 e8 5a e2 fb ff 48 8b 6c 24 40 4c 89 e6 48 89 ef e8 ba f2 fb ff <48> 8b 75 10 48 89 df 49 89 c4 e8 7b 1c fc ff 84 c0 0f 84 2b 01 00
