Bonjour à tous
Je suis un petit nouveau dans le monde linux (debian)
J’ai un serveur debian sarge qui va me servir de serveur web.
J’y ai installé plusieurs choses dont webmin.
Je veux y ajouter virtualmin (un module de webmin) mais pour cela il me faut postfix ou qmail.
Quand j’essaye d’installer Postfix (par exemple), il me met des erreurs car exim4 était installé sur le serveur…
Voici ce qu’il se passe quand je fais apt-get install postfix
bravo329:/# apt-get install postfix
Reading Package Lists... Done
Building Dependency Tree... Done
Suggested packages:
postfix-mysql postfix-pgsql postfix-ldap postfix-pcre
Recommended packages:
resolvconf
The following packages will be REMOVED:
clamav-exim4 exim4-base exim4-config exim4-daemon-heavy spamassassin-exim4
The following NEW packages will be installed:
postfix
0 upgraded, 1 newly installed, 5 to remove and 0 not upgraded.
Need to get 0B/802kB of archives.
After unpacking 1245kB disk space will be freed.
Do you want to continue? [Y/n] Y
Reading package fields... Done
Reading package status... Done
Retrieving bug reports... Done
Preconfiguring packages ...
(Reading database ... 50572 files and directories currently installed.)
Removing clamav-exim4 ...
Stopping MTA: exim4.
rm: cannot remove `/etc/exim4/conf.d/main/01_exim4-config_virusclamav': No such file or directory
dpkg: error processing clamav-exim4 (--remove):
subprocess post-removal script returned error exit status 1
Removing spamassassin-exim4 ...
rm: cannot remove `/etc/exim4/conf.d/router/850_exim4-config_spamcheck_router': No such file or directory
dpkg: error processing spamassassin-exim4 (--remove):
dpkg: exim4-base: dependency problems, but removing anyway as you request:
exim4-daemon-heavy depends on exim4-base (>= 4.50).
Removing exim4-base ...
Removing exim4-config ...
dpkg: exim4-daemon-heavy: dependency problems, but removing anyway as you request:
spamassassin-exim4 depends on exim4-daemon-light | exim4-daemon-heavy; however:
Package exim4-daemon-light is not installed.
Package exim4-daemon-heavy is to be removed.
clamav-exim4 depends on exim4-daemon-heavy.
mailx depends on exim4 | mail-transport-agent; however:
Package exim4 is not installed.
Package mail-transport-agent is not installed.
Package exim4-daemon-heavy which provides mail-transport-agent is to be removed.
Removing exim4-daemon-heavy ...
Errors were encountered while processing:
clamav-exim4
spamassassin-exim4
Après ça plus moyen de rien installer, il me demande de faire : apt-get -f install (et il réinstalle exim4!!)
J’ai cherché un peu partout sur le net mais je ne trouve pas le moyen de désinstaller exim4 sans qu’il me demande à chaque fois de refaire un apt-get -f install
(apt-get remove exim4, apt-get remove --purge exim*, … -> tout ça demande ensuite une réinstall d’exim
Pouvez-vous m’aider?
Bien à vous
