A la fin de installation de virtualbox 4.3 sous Wheezy j’ai ce message d’erreur :
Stopping VirtualBox kernel modules ...done.
Uninstalling old VirtualBox DKMS kernel modules ...done.
Trying to register the VirtualBox kernel modules using DKMSError! Your kernel headers for kernel 2.6.32-5-686 cannot be found.
Please install the linux-headers-2.6.32-5-686 package,
or use the --kernelsourcedir option to tell DKMS where it's located
...failed!
(Failed, trying without DKMS)
Recompiling VirtualBox kernel modules ...failed!
(Look at /var/log/vbox-install.log to find out what went wrong)
J’ai donc été voir dans le fichier log cité :
[code]Uninstalling modules from DKMS
removing old DKMS module vboxhost version 4.3.16
Deleting module version: 4.3.16
completely from the DKMS tree.
Done.
Attempting to install using DKMS
Creating symlink /var/lib/dkms/vboxhost/4.3.16/source ->
/usr/src/vboxhost-4.3.16
DKMS: add completed.
Failed to install using DKMS, attempting to install without
Makefile:183: *** Error: unable to find the sources of your current Linux kernel. Specify KERN_DIR= and run Make again. Arrêt.[/code]
Avez vous une idée du problème car je me tire les cheveux depuis ce matin.
Merci beaucoup
