merci mais ne fonctione toujour pas [list]
voiçi mon message de démarage
[quote]paulo@debian:~$ dmessg
bash: dmessg: command not found
paulo@debian:~$ dmesg
Linux version 2.6.18-4-686 (Debian 2.6.18.dfsg.1-12etch2) (dannf@debian.org) (gcc version 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)) #1 SMP Wed May 9 23:03:12 UTC 2007
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000e4000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000003ffc0000 (usable)
BIOS-e820: 000000003ffc0000 - 000000003ffd0000 (ACPI data)
BIOS-e820: 000000003ffd0000 - 0000000040000000 (ACPI NVS)
BIOS-e820: 00000000ff7c0000 - 0000000100000000 (reserved)
127MB HIGHMEM available.
896MB LOWMEM available.
found SMP MP-table at 000ff780
On node 0 totalpages: 262080
DMA zone: 4096 pages, LIFO batch:0
Normal zone: 225280 pages, LIFO batch:31
HighMem zone: 32704 pages, LIFO batch:7
DMI 2.3 present.
ACPI: RSDP (v000 ACPIAM ) @ 0x000fb230
ACPI: RSDT (v001 A M I OEMRSDT 0x09000507 MSFT 0x00000097) @ 0x3ffc0000
ACPI: FADT (v002 A M I OEMFACP 0x09000507 MSFT 0x00000097) @ 0x3ffc0200
ACPI: MADT (v001 A M I OEMAPIC 0x09000507 MSFT 0x00000097) @ 0x3ffc0390
ACPI: OEMB (v001 A M I AMI_OEM 0x09000507 MSFT 0x00000097) @ 0x3ffd0040
ACPI: DSDT (v001 A0211 A0211034 0x00000034 INTL 0x02002026) @ 0x00000000
ACPI: PM-Timer IO Port: 0x808
ACPI: Local APIC address 0xfee00000
ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
Processor #0 15:2 APIC version 20
ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
Processor #1 15:2 APIC version 20
ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 2, version 17, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
ACPI: IRQ0 used by override.
ACPI: IRQ2 used by override.
ACPI: IRQ9 used by override.
Enabling APIC mode: Flat. Using 1 I/O APICs
Using ACPI (MADT) for SMP configuration information
Allocating PCI resources starting at 50000000 (gap: 40000000:bf7c0000)
Detected 2860.159 MHz processor.
Built 1 zonelists. Total pages: 262080
Kernel command line: root=/dev/hdb8 ro
mapped APIC to ffffd000 (fee00000)
mapped IOAPIC to ffffc000 (fec00000)
Enabling fast FPU save and restore… done.
Enabling unmasked SIMD FPU exception support… done.
Initializing CPU#0
PID hash table entries: 4096 (order: 12, 16384 bytes)
Console: colour VGA+ 80x25
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 1031588k/1048320k available (1544k kernel code, 16116k reserved, 577k data, 196k init, 130816k highmem)
Checking if this processor honours the WP bit even in supervisor mode… Ok.
Calibrating delay using timer specific routine… 5723.87 BogoMIPS (lpj=11447749)Security Framework v1.0.0 initialized
SELinux: Disabled at boot.
Capability LSM initialized
Mount-cache hash table entries: 512
CPU: After generic identify, caps: bfebfbff 00000000 00000000 00000000 00004400 00000000 00000000
CPU: After vendor identify, caps: bfebfbff 00000000 00000000 00000000 00004400 00000000 00000000
CPU: Trace cache: 12K uops, L1 D cache: 8K
CPU: L2 cache: 512K
CPU: Physical Processor ID: 0
CPU: After all inits, caps: bfebfbff 00000000 00000000 00000080 00004400 00000000 00000000
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
CPU0: Intel P4/Xeon Extended MCE MSRs (12) available
CPU0: Thermal monitoring enabled
Compat vDSO mapped to ffffe000.
Checking ‘hlt’ instruction… OK.
SMP alternatives: switching to UP code
ACPI: Core revision 20060707
CPU0: Intel® Pentium® 4 CPU 2.60GHz stepping 09
SMP alternatives: switching to SMP code
Booting processor 1/1 eip 3000
Initializing CPU#1
Calibrating delay using timer specific routine… 5720.44 BogoMIPS (lpj=11440896)CPU: After generic identify, caps: bfebfbff 00000000 00000000 00000000 00004400 00000000 00000000
CPU: L2 cache: 512K
Intel machine check reporting enabled on CPU#1.
CPU1: Intel P4/Xeon Extended MCE MSRs (12) available
CPU1: Thermal monitoring enabled
CPU1: Intel® Pentium® 4 CPU 2.60GHz stepping 09
Total of 2 processors activated (11444.32 BogoMIPS).
ENABLING IO-APIC IRQs
…TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
checking TSC synchronization across 2 CPUs: passed.
Brought up 2 CPUs
migration_cost=137
checking if image is initramfs… it is
Freeing initrd memory: 4409k freed
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: PCI BIOS revision 2.10 entry at 0xf0031, last bus=1
PCI: Using configuration type 1
Setting up standard PCI resources
ACPI: Interpreter enabled
ACPI: Using IOAPIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
PCI: Ignoring BAR0-3 of IDE controller 0000:00:02.5
Boot video device is 0000:01:00.0
ACPI: PCI Interrupt Routing Table [_SB_.PCI0._PRT]
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 *10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 *10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 *5 7 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 *10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKG] (IRQs *3 4 5 7 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 *5 7 10 11 12 14 15)
Linux Plug and Play Support v0.97 © Adam Belay
pnp: PnP ACPI init
pnp: PnP ACPI: found 14 devices
PnPBIOS: Disabled by ACPI PNP
PCI: Using ACPI for IRQ routing
PCI: If a device doesn’t work, try “pci=routeirq”. If it helps, post a report
pnp: 00:07: ioport range 0x290-0x297 has been reserved
PCI: Bridge: 0000:00:01.0
IO window: e000-efff
MEM window: cff00000-cfffffff
PREFETCH window: d0000000-dfffffff
NET: Registered protocol family 2
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
audit: initializing netlink socket (disabled)
audit(1184336479.076:1): initialized
highmem bounce pool size: 64 pages
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
isapnp: Scanning for PnP cards…
isapnp: No Plug & Play device found
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
mice: PS/2 mouse device common for all mice
TCP bic registered
NET: Registered protocol family 17
NET: Registered protocol family 8
NET: Registered protocol family 20
Starting balanced_irq
Using IPI No-Shortcut mode
ACPI: (supports S0 S1 S3 S4 S5)
Freeing unused kernel memory: 196k freed
Time: tsc clocksource has been installed.
input: AT Translated Set 2 keyboard as /class/input/input0
ACPI: Processor [CPU1] (supports 8 throttling states)
ACPI: Processor [CPU2] (supports 8 throttling states)
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
SIS5513: IDE controller at PCI slot 0000:00:02.5
ACPI: PCI Interrupt 0000:00:02.5[A] -> GSI 16 (level, low) -> IRQ 169
SIS5513: chipset revision 1
SIS5513: not 100% native mode: will probe irqs later
SIS5513: SiS 962/963 MuTIOL IDE UDMA133 controller
ide0: BM-DMA at 0xffa0-0xffa7, BIOS settings: hda:DMA, hdb:DMA
ide1: BM-DMA at 0xffa8-0xffaf, BIOS settings: hdc:DMA, hdd:DMA
Probing IDE interface ide0…
usbcore: registered new driver usbfs
usbcore: registered new driver hub
ohci_hcd: 2005 April 22 USB 1.1 ‘Open’ Host Controller (OHCI) Driver (PCI)
sis900.c: v1.08.10 Apr. 2 2006
hda: Maxtor 6Y120L0, ATA DISK drive
hdb: Maxtor 6Y120P0, ATA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1…
hdc: HL-DT-STDVD-ROM GDR8162B, ATAPI CD/DVD-ROM drive
hdd: _NEC DVD_RW ND-1300A, ATAPI CD/DVD-ROM drive
ide1 at 0x170-0x177,0x376 on irq 15
ACPI: PCI Interrupt 0000:00:03.0[A] -> GSI 20 (level, low) -> IRQ 177
ohci_hcd 0000:00:03.0: OHCI Host Controller
ohci_hcd 0000:00:03.0: new USB bus registered, assigned bus number 1
ohci_hcd 0000:00:03.0: irq 177, io mem 0xcfefc000
hda: max request size: 128KiB
hda: 240121728 sectors (122942 MB) w/2048KiB Cache, CHS=65535/16/63, UDMA(33)
hda: cache flushes supported
hda: hda1 hda2 <<6>usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 3 ports detected
hda5 > hda3
hdb: max request size: 128KiB
hdb: 240121728 sectors (122942 MB) w/7936KiB Cache, CHS=65535/16/63, UDMA(33)
hdb: cache flushes supported
hdb: hdb1 < hdb5 hdb6 hdb7 hdb8 hdb9 hdb10 hdb11 hdb12 hdb13 >
ACPI: PCI Interrupt 0000:00:03.1[B] -> GSI 21 (level, low) -> IRQ 185
ohci_hcd 0000:00:03.1: OHCI Host Controller
ohci_hcd 0000:00:03.1: new USB bus registered, assigned bus number 2
ohci_hcd 0000:00:03.1: irq 185, io mem 0xcfefd000
hdc: ATAPI 48X DVD-ROM drive, 256kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
hdd: ATAPI 40X DVD-ROM DVD-R CD-R/RW drive, 2048kB Cache, UDMA(33)
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 3 ports detected
ACPI: PCI Interrupt 0000:00:03.2[C] -> GSI 22 (level, low) -> IRQ 193
ohci_hcd 0000:00:03.2: OHCI Host Controller
ohci_hcd 0000:00:03.2: new USB bus registered, assigned bus number 3
ohci_hcd 0000:00:03.2: irq 193, io mem 0xcfefe000
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
usb 1-2: new full speed USB device using ohci_hcd and address 2
ACPI: PCI Interrupt 0000:00:04.0[A] -> GSI 19 (level, low) -> IRQ 201
0000:00:04.0: Realtek RTL8201 PHY transceiver found at address 1.
0000:00:04.0: Using transceiver found at address 1 as default
eth0: SiS 900 PCI Fast Ethernet at 0xd000, IRQ 201, 00:15:f2:02:5e:25.
ACPI: PCI Interrupt 0000:00:03.3[D] -> GSI 23 (level, low) -> IRQ 209
ehci_hcd 0000:00:03.3: EHCI Host Controller
ehci_hcd 0000:00:03.3: new USB bus registered, assigned bus number 4
PCI: cache line size of 128 is not supported by device 0000:00:03.3
ehci_hcd 0000:00:03.3: irq 209, io mem 0xcfeff000
ehci_hcd 0000:00:03.3: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb4: configuration #1 chosen from 1 choice
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 8 ports detected
Attempting manual resume
kjournald starting. Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
usb 4-3: new high speed USB device using ehci_hcd and address 3
usb 4-3: configuration #1 chosen from 1 choice
usb 4-4: new high speed USB device using ehci_hcd and address 4
usb 4-4: configuration #1 chosen from 1 choice
hub 4-4:1.0: USB hub found
hub 4-4:1.0: 4 ports detected
ohci_hcd 0000:00:03.1: wakeup
usb 4-4.2: new low speed USB device using ehci_hcd and address 5
usb 4-4.2: configuration #1 chosen from 1 choice
usb 4-4.4: new full speed USB device using ehci_hcd and address 6
usb 4-4.4: configuration #1 chosen from 1 choice
usb 2-1: new full speed USB device using ohci_hcd and address 2
usb 2-1: configuration #1 chosen from 1 choice
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
Linux agpgart interface v0.101 © Dave Jones
Real Time Clock Driver v1.12ac
input: PC Speaker as /class/input/input1
shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Floppy drive(s): fd0 is 1.44M
FDC 0 is a post-1991 82077
agpgart: Detected SiS 661 chipset
agpgart: AGP aperture is 64M @ 0xe0000000
parport: PnPBIOS parport detected.
parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,EPP,ECP,DMA]
usbcore: registered new driver hiddev
input: Mega World USB 2-Axis 8-Button Gamepad as /class/input/input2
input: USB HID v1.00 Gamepad [Mega World USB 2-Axis 8-Button Gamepad] on usb-0000:00:03.3-4.2
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.6:USB HID core driver
drivers/usb/class/usblp.c: usblp0: USB Bidirectional printer dev 2 if 0 alt 0 proto 2 vid 0x03F0 pid 0x7504
usbcore: registered new driver usblp
drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
Linux video capture interface: v2.00
/home/paulo/Desktop/gspcav1-01.00.10/gspca_core.c: USB SPCA5XX camera found.(SPCA561A)
/home/paulo/Desktop/gspcav1-01.00.10/gspca_core.c: [spca5xx_probe:3930] Camera type S561
/home/paulo/Desktop/gspcav1-01.00.10/gspca_core.c: [spca5xx_getcapability:1170] maxw 352 maxh 288 minw 160 minh 120
usbcore: registered new driver gspca
/home/paulo/Desktop/gspcav1-01.00.10/gspca_core.c: gspca driver 01.00.10 registered
ACPI: PCI Interrupt 0000:00:02.7[C] -> GSI 18 (level, low) -> IRQ 217
intel8x0_measure_ac97_clock: measured 54796 usecs
intel8x0: clocking to 48000
input: ImPS/2 Generic Wheel Mouse as /class/input/input3
ts: Compaq touchscreen protocol output
Adding 1743012k swap on /dev/hdb11. Priority:-1 extents:1 across:1743012k
EXT3 FS on hdb8, internal journal
loop: loaded (max 8 devices)
device-mapper: ioctl: 4.7.0-ioctl (2006-06-24) initialised: dm-devel@redhat.com
EXT3 FS on hdb13, internal journal
EXT3 FS on hdb12, internal journal
EXT3 FS on hdb9, internal journal
EXT3 FS on hdb10, internal journal
eth0: Media Link On 100mbps full-duplex
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
ACPI: Power Button (FF) [PWRF]
ACPI: Power Button (CM) [PWRB]
lp0: using parport0 (interrupt-driven).
ppdev: user-space parallel port driver
[drm] Initialized drm 1.0.1 20051102
ACPI: PCI Interrupt 0000:01:00.0[A] -> GSI 16 (level, low) -> IRQ 169
[drm] Initialized radeon 1.25.0 20060524 on minor 0
mtrr: 0xd0000000,0x10000000 overlaps existing 0xd0000000,0x8000000
agpgart: Found an AGP 3.5 compliant device at 0000:00:00.0.
agpgart: Putting AGP V3 device at 0000:00:00.0 into 4x mode
agpgart: Putting AGP V3 device at 0000:01:00.0 into 4x mode
[drm] Setting GART location based on new memory map
[drm] Loading R200 Microcode
[drm] writeback test succeeded in 1 usecs
eth0: no IPv6 routers present
ISO 9660 Extensions: Microsoft Joliet Level 3
ISO 9660 Extensions: RRIP_1991A
merçi de votre aide
