Hello vv222,
je crois bien que gdm est “à moitié installé” et que kdm est installé.
En effet si je fais:
dpkg --status gdm
J’obtiens:
Package: gdm
Status: deinstall ok config-files
Priority: optional
Section: gnome
Installed-Size: 16548
Maintainer: Debian GNOME Maintainers <pkg-gnome-maintainers@lists.alioth.debian.org>
Architecture: amd64
Version: 2.20.11-4
Config-Version: 2.20.11-4
Provides: x-display-manager
Depends: libart-2.0-2 (>= 2.3.18), libatk1.0-0 (>= 1.29.3), libattr1 (>= 2.4.41-1), libaudit0, libc6 (>= 2.3), libcairo2 (>= 1.2.4), libdbus-1-3 (>= 1.0.2), libdbus-glib-1-2 (>= 0.78), libdmx1, libfontconfig1 (>= 2.8.0), libfreetype6 (>= 2.2.1), libglade2-0 (>= 1:2.6.1), libglib2.0-0 (>= 2.24.0), libgnomecanvas2-0 (>= 2.11.1), libgtk2.0-0 (>= 2.18.0), libpam0g (>= 0.99.7.1), libpango1.0-0 (>= 1.14.0), librsvg2-2 (>= 2.26.0), libselinux1 (>= 1.32), libwrap0 (>= 7.6-4~), libx11-6, libxau6, libxdmcp6, libxext6, libxi6, libxinerama1, libxml2 (>= 2.7.4), debconf (>= 0.5) | debconf-2.0, adduser, libpam-modules (>= 0.72-1), libpam-runtime (>= 0.76-13.1), gnome-session | x-session-manager | x-window-manager | x-terminal-emulator, gksu (>= 1.0.7), lsb-base (>= 3.2-14), librsvg2-common
Recommends: whiptail | dialog, zenity, gdm-themes, xserver-xephyr | xnest, xserver-xorg
Suggests: locales, pm-utils, libpam-gnome-keyring
Conflicts: fast-user-switch-applet (<< 2.17.4), gnome-panel (<< 2.19.2), gnome-screensaver (<< 2.17.7), gnome-session (<< 2.19.2)
Conffiles:
 /etc/init.d/gdm d655d8b37df0ab732a5c3aaad845fd98
 /etc/insserv.conf.d/gdm 82464ac174651f1589433a66fa57fa48
 /etc/gdm/PostLogin/Default.sample 2c3d901312c1bc31997ba6ba53b5f18a
 /etc/gdm/modules/AccessDwellMouseEvents b728f3702edc65820cba9a21ea238166
 /etc/gdm/modules/factory-AccessDwellMouseEvents b728f3702edc65820cba9a21ea238166
 /etc/gdm/modules/factory-AccessKeyMouseEvents 4bdb261d7e6ff1c5a9c109b4699ef5bd
 /etc/gdm/modules/AccessKeyMouseEvents 4bdb261d7e6ff1c5a9c109b4699ef5bd
 /etc/gdm/Init/Default 7ccbd175154c6ff73fbe4eff9711cc34
 /etc/gdm/XKeepsCrashing 707f1348da2ccd30f330cb0301adac54
 /etc/gdm/locale.conf 3a304ecef65088df6457a8443b2acee7
 /etc/gdm/PreSession/Default a1a563082a9fa5ad2510b04dcc94f355
 /etc/gdm/gdm.conf 5a344c36d142cad2a109e1892b5354bd
 /etc/gdm/PostSession/Default 08a7c64c8b7e2ca08faa132e63e3e584
 /etc/gdm/Xsession 25a9db180a5c9e0035a74789ef2073da
 /etc/pam.d/gdm af1bca30e47a53b61bf478b46a36913c
 /etc/pam.d/gdm-autologin b60183dee52f58dbe93973d1958817e4
Description: GNOME Display Manager
 gdm provides the equivalent of a "login:" prompt for X displays- it
 pops up a login window and starts an X session.
 It provides all the functionality of xdm, including XDMCP support for
 managing remote displays.
 The greeting window is written using the GNOME libraries and hence
 looks like a GNOME application- even to the extent of supporting
 themes! By default, the greeter is run as an unprivileged user for
 security.
Si je fais un:
dpkg --status kdm
J’obtiens:
Package: kdm
Status: install ok installed
Priority: optional
Section: x11
Installed-Size: 4046
Maintainer: Debian Qt/KDE Maintainers <debian-qt-kde@lists.debian.org>
Architecture: amd64
Source: kde-workspace
Version: 4:4.8.4-6
Replaces: kde-kdm-themes, kdmtheme
Depends: kde-runtime, libc6 (>= 2.11), libck-connector0 (>= 0.2.1), libdbus-1-3 (>= 1.0.2), libkdecore5 (>= 4:4.8), libkdeui5 (>= 4:4.8), libkio5 (>= 4:4.8), libknewstuff3-4 (>= 4:4.8), libkworkspace4abi1 (= 4:4.8.4-6), libpam0g (>= 0.99.7.1), libqimageblitz4 (>= 1:0.0.4), libqt4-svg (>= 4:4.5.3), libqt4-xml (>= 4:4.5.3), libqtcore4 (>= 4:4.7.0~beta1), libqtgui4 (>= 4:4.8.0), libstdc++6 (>= 4.1.1), libx11-6, libxau6, libxdmcp6, libxtst6, debconf (>= 0.5) | debconf-2.0, lsb-base (>= 3.2-14), consolekit, kde-workspace-kgreet-plugins (= 4:4.8.4-6), adduser, kde-wallpapers-default
Recommends: logrotate, xserver-xorg | xserver, kde-workspace | x-session-manager | x-window-manager, xterm | x-terminal-emulator
Suggests: kdepasswd, kde-wallpapers
Breaks: kde-kdm-themes, kdmtheme
Conffiles:
 /etc/logrotate.d/kdm 8c9e62d059711c10bff151ffb78f6228
 /etc/kde4/kdm/README e22153008a45ad278940020fc4594e70
 /etc/kde4/kdm/Xreset 514c4b4a0f42640916fac03574f843d9
 /etc/kde4/kdm/Xaccess 03b7b6cd8eacc152567b7f4a3ae9f537
 /etc/kde4/kdm/Xstartup ad83c25cc0bcc63293918b6e9dd0738d
 /etc/kde4/kdm/backgroundrc 6bc033893e97a0770f6f92c2efde55a8
 /etc/kde4/kdm/kdmrc a9b2ec03367c927f50cdcce2cb453985
 /etc/kde4/kdm/Xsession 9ae86149a17f326a256e338bd352e11d
 /etc/kde4/kdm/kdm.options 722b98e1bf38f59094ad1a5acb69261d
 /etc/kde4/kdm/Xsetup e2fe2d1f60e9775c8dd97f4a2773809e
 /etc/kde4/kdm/Xwilling ab97870cde0424d576375813874a304e
 /etc/init.d/kdm 72a2405cfa5c0dd45c30e98b7fc97491
 /etc/dbus-1/system.d/org.kde.kcontrol.kcmkdm.conf f3a5c84af8ce5582747f760c20308e45
 /etc/pam.d/kdm f8e043e7de6dd93d537ffe72a2fbae75
 /etc/pam.d/kdm-np 527a9b02acd0858ea7e061e29e3f127c
 /etc/insserv.conf.d/kdm d3a7ab4b48c90e2a0b609fcfa3b8b064
Description: KDE Display Manager for X11
 KDM manages a collection of X servers running on local or remote machines.
 It allows users to easily log into their preferred desktop environment, connect
 to a remote XDMCP server, or shut down the system.
 KDM supports custom themes and can display a list of users with icons.
 Additional user icons can be found in the 'kdepasswd' package.
 This package is part of the KDE base workspace module.
Homepage: http://www.kde.org/
Dois-je en conclure qu’il faut que je purge kdm et gdm avec les commandes:
apt-get autoremove --purge gdm
apt-get autoremove --purge kdm
(du coup j’enlève le statut corrigé du sujet en attendant une réponse.
Merci,
Vincent
