sur le lenovo que je viens d’avoir, j’ai quelques difficultés à parametrer le wifi
je vais essayer d’être complet…
lsci -n (sur le site de kenshi muto )
PCI ID Supporté? Fabricant Matériel Pilote Noyau
80860104 Intel Corporation 2nd Generation Core Processor Family DRAM Controller
80860116 Oui Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller i915 v2.6.38-
80861e31 Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller
80861e3a Intel Corporation 7 Series/C210 Series Chipset Family MEI Controller #1
80861e2d Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #2
80861e20 Oui Intel Corporation 7 Series/C210 Series Chipset Family High Definition Audio Controller snd-hda-intel v3.0.0-
80861e10 Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 1
80861e12 Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 2
80861e16 Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 4
80861e26 Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #1
80861e57 Oui Intel Corporation HM77 Express Chipset LPC Controller iTCO_wdt v2.6.39-
80861e03 Oui Intel Corporation 7 Series Chipset Family 6-port SATA Controller [AHCI mode] ahci v2.6.39-
80861e22 Oui Intel Corporation 7 Series/C210 Series Chipset Family SMBus Controller i2c-i801 v3.0.0-
14e44727 Oui Broadcom Corporation BCM4313 802.11b/g/n Wireless LAN Controller brcmsmac v2.6.38-
10ec8168 Oui Realtek Semiconductor Co., Ltd. RTL8111/8168 PCI Express Gigabit Ethernet controller r8169 v2.6.25-
j’ai suivi ce tuto : http://wiki.debian-facile.org/manuel:wifi:detecter-le-materiel et celui ci http://wiki.debian.org/brcm80211
j’ai installé le paquet firmware-brcm80211
la sortie de ifconfig -a
[code] eth0 Link encap:Ethernet HWaddr 3c:97:0e:75:0e:dc
inet adr:192.168.0.23 Bcast:192.168.0.255 Masque:255.255.255.0
adr inet6: fe80::3e97:eff:fe75:edc/64 Scope:Lien
RX packets:794 errors:0 dropped:0 overruns:0 frame:0
TX packets:429 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:199986 (195.2 KiB) TX bytes:44863 (43.8 KiB)
Interruption:40 Adresse de base:0xc000
lo Link encap:Boucle locale
adr inet6: ::1/128 Scope:Hôte
wlan0 Link encap:Ethernet HWaddr a4:17:31:bb:f6:85
BROADCAST MULTICAST MTU:1500 Metric:1
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)[/code]
et le fichier /etc/network/interfaces
j’utilise également wicd
merci d’avance ![]()
