Installation wifi
Salut à tous,
j’ai un portable hp g62(-452eb), je voudrais faire fonctionner le wifi, mais sa marche pas.
Squeeze, 2.6.38-1 (j’ai garder le 2.6.32-5)
J’ai de installé: gnome-network-manager, firmware-ralink, wpasuppliant.
lspci:
00:00.0 Host bridge: Intel Corporation Core Processor DRAM Controller (rev 02) 00:02.0 VGA compatible controller: Intel Corporation Core Processor Integrated Graphics Controller (rev 02) 00:16.0 Communication controller: Intel Corporation 5 Series/3400 Series Chipset HECI Controller (rev 06) 00:1a.0 USB Controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 05) 00:1b.0 Audio device: Intel Corporation 5 Series/3400 Series Chipset High Definition Audio (rev 05) 00:1c.0 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 1 (rev 05) 00:1c.1 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 2 (rev 05) 00:1d.0 USB Controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 05) 00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev a5) 00:1f.0 ISA bridge: Intel Corporation Mobile 5 Series Chipset LPC Interface Controller (rev 05) 00:1f.2 SATA controller: Intel Corporation 5 Series/3400 Series Chipset 4 port SATA AHCI Controller (rev 05) 00:1f.3 SMBus: Intel Corporation 5 Series/3400 Series Chipset SMBus Controller (rev 05) 00:1f.6 Signal processing controller: Intel Corporation 5 Series/3400 Series Chipset Thermal Subsystem (rev 05) 02:00.0 Network controller: RaLink Device 5390 03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller (rev 02) ff:00.0 Host bridge: Intel Corporation Core Processor QuickPath Architecture Generic Non-core Registers (rev 02) ff:00.1 Host bridge: Intel Corporation Core Processor QuickPath Architecture System Address Decoder (rev 02) ff:02.0 Host bridge: Intel Corporation Core Processor QPI Link 0 (rev 02) ff:02.1 Host bridge: Intel Corporation Core Processor QPI Physical 0 (rev 02) ff:02.2 Host bridge: Intel Corporation Core Processor Reserved (rev 02) ff:02.3 Host bridge: Intel Corporation Core Processor Reserved (rev 02)
ifconfig:
[code]# ifconfig
eth0 Link encap:Ethernet HWaddr 98:4b:e1:93:6a:8c
inet adr:192.168.1.2 Bcast:192.168.1.255 Masque:255.255.255.0
adr inet6: fe80::9a4b:e1ff:fe93:6a1c/64 Scope:Lien
RX packets:698 errors:0 dropped:0 overruns:0 frame:0
TX packets:577 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:775014 (756.8 KiB) TX bytes:63298 (61.8 KiB)
Interruption:40 Adresse de base:0x6000
lo Link encap:Boucle locale
adr inet6: ::1/128 Scope:Hôte
RX packets:8 errors:0 dropped:0 overruns:0 frame:0
TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:560 (560.0 B) TX bytes:560 (560.0 B)[/code]
iwconfig:
[code]# iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
pan0 no wireless extensions.[/code]
Que faire ?
Ta carte wi-fi n’est peut-être pas compatible, j’ai eu le tour avec la mienne j’ai dû m’acheter une clé usb wi-fi.
Essaie de voir sur ce fil si cela peut t’aider :http://www.debian-fr.org/comment-faire-marcher-une-cle-usb-wifi-t31915.html
Et aussi : wiki.debian.org/ipw2200
En espérent que cela t’aide.
ta carte wifi est peut-être sur un port USB. Tape lsusb pour vérifier.
que donne iwconfig -a
# lsusb Bus 002 Device 004: ID 090c:37b0 Feiya Technology Corp. Bus 002 Device 003: ID 1532:0013 Razer USA, Ltd Bus 002 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 003: ID 0bda:0158 Realtek Semiconductor Corp. USB 2.0 multicard reader Bus 001 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
[code]# iwconfig
Je crois quelle n’est pas encore supporter, je vais l’installer manuellement.
tu as mal lu # iwconfig -a
# iwconfig -a -a No such device
En fouillant au pif suis tombé sur ce lien dans les forums côté Ubuntu…
http://forum.ubuntu-fr.org/viewtopic.php?id=444138&p=1
à voir…
il faut donc que tu récupère le pilote sur le site ralink qui est provisoirement indisponible :confused:
Le site n’est pas hors ligne, hier il fonctionnait d’ailleurs j’ai encore la dernière version de mon wifi sur l’ordi., aujourd’hui il est juste … hyper lent, mais il s’ouvre :smiley:
J’avais déjà lu et appliquer le lien que tu m’avais données hier, pour les ubuntueins sa fonctionne, mais moi sur debian sa me donnais toujours une erreur lors du “make”.
Mais aujourd’hui j’ai fais une recherche bien approfondie, j’ai rempli toute une feuille A4 avec des indices faire ceci, cela dans les site comme gento, arch, ect de même sur les liens que tu m’as données, après avoir bien rempli la feuille, j’ai trouver sur un tuto (espagnol ou italien que j’ai décrypter) qu’il expliquait de manière bien approfondie pour ubuntu/debian, après avoir lu le tuto la blague que j’ai eu, j’ai du entourer (presque tous les commandes) à peu prêt 90% de ma feuille en numérotant juste l’ordre des étapes :smiley: (j’avais donc bien chercher :smiley:).
Je penses être dans la bonne voie, à tester, je vous en re-dirais.
je sais plus où j’ai vu que pour debian il y a un patch a appliquer avant de faire le “make”
Exact !
Voila: lamaquinadiferencial.wordpress.c … an-hp-g62/
J’avais pas pu copier le lien sur ma feuille tellement il était long, j’ai copier le titre (qui n’est pas court non plus) et vive google :smiley:
Là je vais bientôt dormir, mais demain j’ai du boulot à faire:
  1. bidouillage pour fonctionnement wifi sur la config actuel.
  2. sauvegarde des données, compilation nouveau kernel, puis configuration wifi avec les bonnes méthodes.
Quelque chose me dit que je vais passer un bon moment à regarder la télé :smiley: au point 2.
Salut à tous, me revoilà.
J’ai pu installer ma carte wifi et il fonctionne, j’ai pas pu le faire sous debian pour une autre raison personnel, donc sa doit marcher (le tuto étant fait spécialement pour ubuntu et debian).
J’ai suivis ce tuto:
Conseil:
Utiliser google traduction pour suivre les instructions, et (fortement recommander) utiliser la page original pour copier/regarder les commandes à exécuter.
Pour ma part sous fedora, j’ai du à faire quelques changements au niveau de l’ajout rt5390… dans /etc/modules, car cela se passe un peu autrement).
(forums.fedora-fr.org/viewtopic.php?pid=453534)
Voilà, j’espère que sa servira au debianeux et ubuntieux, car en recherchant comment installer j’ai pu croiser une centaines de page qui n’ont pas pu l’installer.
:041 :041 :041 :041
