Bonjour, J’ai upgradé de Squeeze à Wheezy hier, ai changé d’environnement de bureau (Gnome => XFCE) mais j’ai perdu mon wifi au passage :
$ ifconfig -a
Could not find the database of available applications, run update-
command-not-found as root to fix this
Command 'ifconfig' is available in '/sbin/ifconfig'
The command could not be located because '/sbin' is not included in
the PATH environment variable.
This is most likely caused by the lack of administrative priviledges
associated with your user account.
ifconfig: command not found
Mon matériel semble reconnu
[code]$ cat /etc/network/interfaces
This file describes the network interfaces available on your system
auto lo
iface lo inet loopback
The primary network interface
allow-hotplug eth0
#NetworkManager#iface eth0 inet dhcp
$ lspci
00:00.0 Host bridge: Intel Corporation Core Processor DRAM Controller
(rev 02)
00:02.0 VGA compatible controller: Intel Corporation Core Processor
Integrated Graphics Controller (rev 02)
00:16.0 Communication controller: Intel Corporation 5 Series/3400
Series Chipset HECI Controller (rev 06)
00:1a.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset
USB2 Enhanced Host Controller (rev 05)
00:1b.0 Audio device: Intel Corporation 5 Series/3400 Series Chipset
High Definition Audio (rev 05)
00:1c.0 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI
Express Root Port 1 (rev 05)
00:1c.1 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI
Express Root Port 2 (rev 05)
00:1c.2 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI
Express Root Port 3 (rev 05)
00:1c.3 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI
Express Root Port 4 (rev 05)
00:1c.4 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI
Express Root Port 5 (rev 05)
00:1c.5 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI
Express Root Port 6 (rev 05)
00:1d.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev a5)
00:1f.0 ISA bridge: Intel Corporation Mobile 5 Series Chipset LPC
Interface Controller (rev 05)
00:1f.2 SATA controller: Intel Corporation 5 Series/3400 Series
Chipset 4 port SATA AHCI Controller (rev 05)
00:1f.3 SMBus: Intel Corporation 5 Series/3400 Series Chipset SMBus
Controller (rev 05)
00:1f.6 Signal processing controller: Intel Corporation 5 Series/3400
Series Chipset Thermal Subsystem (rev 05)
04:00.0 Network controller: Ralink corp. RT3090 Wireless 802.11n 1T/1R
PCIe
06:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd.
RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 03)
3f:00.0 Host bridge: Intel Corporation Core Processor QuickPath
Architecture Generic Non-core Registers (rev 02)
3f:00.1 Host bridge: Intel Corporation Core Processor QuickPath
Architecture System Address Decoder (rev 02)
3f:02.0 Host bridge: Intel Corporation Core Processor QPI Link 0 (rev
02)
3f:02.1 Host bridge: Intel Corporation Core Processor QPI Physical 0
(rev 02)
3f:02.2 Host bridge: Intel Corporation Core Processor Reserved (rev
02)
3f:02.3 Host bridge: Intel Corporation Core Processor Reserved (rev
02)
J’accède à ma freebox via windows. Comment pourrais-je installer ifconfig, ifup et wicd tout en étant hors_ligne sous Debian ou via windows?
