voila un modprobe ipw2200 , ce qui est drole
[code WARNING: Error inserting ieee80211_crypt (/lib/modules/2.6.16-1-686/net/ieee80211/ieee80211_crypt.ko): Invalid module format
WARNING: Error inserting ieee80211 (/lib/modules/2.6.16-1-686/net/ieee80211/ieee80211.ko): Invalid module format
FATAL: Error inserting ipw2200 (/lib/modules/2.6.16-1-686/kernel/drivers/net/wireless/ipw2200.ko): Invalid module format[/code]
un dmesg
fd8
ACPI: MCFG (v001 HP 309E 0x06040000 LOHR 0x0000005f) @ 0x3feeaf9c
ACPI: SSDT (v001 HP 309E 0x00003000 INTL 0x20030224) @ 0x3fee56d3
ACPI: SSDT (v001 HP 309E 0x00003001 INTL 0x20030224) @ 0x3fee54fb
ACPI: SSDT (v001 HP 309E 0x00003000 INTL 0x20030224) @ 0x3fee53e7
ACPI: SSDT (v001 HP 309E 0x00000001 INTL 0x20030224) @ 0x3fee52bb
ACPI: DSDT (v001 HP 309E 0x06040000 MSFT 0x0100000e) @ 0x00000000
ACPI: PM-Timer IO Port: 0x1008
ACPI: Local APIC address 0xfee00000
ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
Processor #0 6:13 APIC version 20
ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] disabled)
ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
ACPI: IRQ0 used by override.
ACPI: IRQ2 used by override.
ACPI: IRQ9 used by override.
Enabling APIC mode: Flat. Using 1 I/O APICs
Using ACPI (MADT) for SMP configuration information
Allocating PCI resources starting at 50000000 (gap: 40000000:a0000000)
Built 1 zonelists
Kernel command line: root=/dev/hda3 ro
mapped APIC to ffffd000 (fee00000)
mapped IOAPIC to ffffc000 (fec00000)
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Initializing CPU#0
PID hash table entries: 4096 (order: 12, 65536 bytes)
Detected 1729.608 MHz processor.
Using pmtmr for high-res timesource
Console: colour VGA+ 80x25
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 1034440k/1047424k available (1408k kernel code, 12424k reserved, 527k data, 144k init, 0k highmem)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
Calibrating delay using timer specific routine.. 3465.30 BogoMIPS (lpj=1732653)
Security Framework v1.0.0 initialized
SELinux: Disabled at boot.
Capability LSM initialized
Mount-cache hash table entries: 512
CPU: After generic identify, caps: afe9fbff 00100000 00000000 00000000 00000180 00000000 00000000
CPU: After vendor identify, caps: afe9fbff 00100000 00000000 00000000 00000180 00000000 00000000
CPU: L1 I cache: 32K, L1 D cache: 32K
CPU: L2 cache: 2048K
CPU: After all inits, caps: afe9fbff 00100000 00000000 00000040 00000180 00000000 00000000
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
CPU: Intel(R) Pentium(R) M processor 1.73GHz stepping 08
Checking 'hlt' instruction... OK.
ENABLING IO-APIC IRQs
..TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
checking if image is initramfs... it is
Freeing initrd memory: 1028k freed
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: PCI BIOS revision 2.10 entry at 0xfd860, last bus=7
PCI: Using MMCONFIG
ACPI: Subsystem revision 20060127
ACPI: Interpreter enabled
ACPI: Using IOAPIC for interrupt routing
ACPI Error (nsxfeval-0242): Handle is NULL and Pathname is relative [20060127]
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
PCI quirk: region 1000-107f claimed by ICH6 ACPI/GPIO/TCO
PCI quirk: region 1180-11bf claimed by ICH6 GPIO
PCI: Ignoring BAR0-3 of IDE controller 0000:00:1f.1
Boot video device is 0000:01:00.0
PCI: Transparent bridge - 0000:00:1e.0
PCI: Bus #07 (-#0a) may be hidden behind transparent bridge #06 (-#07) (try 'pci=assign-busses')
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEGP._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP01._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCIB._PRT]
ACPI: PCI Interrupt Link [LNKA] (IRQs 1 3 4 5 6 7 10 12 14 15) *11
ACPI: PCI Interrupt Link [LNKB] (IRQs 1 3 4 5 6 7 11 12 14 15) *10
ACPI: PCI Interrupt Link [LNKC] (IRQs 1 3 4 5 6 7 *10 12 14 15)
ACPI: PCI Interrupt Link [LNKD] (IRQs 1 3 4 5 6 7 11 12 14 15) *10
ACPI: PCI Interrupt Link [LNKE] (IRQs 1 3 4 5 6 7 10 12 14 15) *11
ACPI: PCI Interrupt Link [LNKF] (IRQs 1 3 4 5 6 7 *11 12 14 15)
ACPI: PCI Interrupt Link [LNKG] (IRQs 1 3 4 5 6 7 *10 12 14 15)
ACPI: PCI Interrupt Link [LNKH] (IRQs 1 3 4 5 6 7 *11 12 14 15)
ACPI: Embedded Controller [EC0] (gpe 27) interrupt mode.
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI init
pnp: PnP ACPI: found 8 devices
PnPBIOS: Disabled by ACPI PNP
PCI: Using ACPI for IRQ routing
PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
PCI: Cannot allocate resource region 7 of bridge 0000:00:1c.0
PCI: Cannot allocate resource region 8 of bridge 0000:00:1c.0
PCI: Cannot allocate resource region 9 of bridge 0000:00:1c.0
PCI: Bridge: 0000:00:01.0
IO window: 3000-3fff
MEM window: c8100000-c81fffff
PREFETCH window: d0000000-d7ffffff
PCI: Bridge: 0000:00:1c.0
IO window: disabled.
MEM window: disabled.
PREFETCH window: disabled.
PCI: Bus 7, cardbus bridge: 0000:06:06.0
IO window: 00004400-000044ff
IO window: 00004800-000048ff
PREFETCH window: 50000000-51ffffff
MEM window: 52000000-53ffffff
PCI: Bridge: 0000:00:1e.0
IO window: 4000-4fff
MEM window: c8200000-c82fffff
ACPI: PCI Interrupt 0000:00:01.0[A] -> GSI 16 (level, low) -> IRQ 169
PCI: Setting latency timer of device 0000:00:01.0 to 64
ACPI: PCI Interrupt 0000:00:1c.0[A] -> GSI 17 (level, low) -> IRQ 177
PCI: Setting latency timer of device 0000:00:1c.0 to 64
PCI: Setting latency timer of device 0000:00:1e.0 to 64
ACPI: PCI Interrupt 0000:06:06.0[A] -> GSI 22 (level, low) -> IRQ 185
PCI: Setting latency timer of device 0000:06:06.0 to 64
Simple Boot Flag at 0x36 set to 0x1
audit: initializing netlink socket (disabled)
audit(1144421892.841:1): initialized
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler deadline registered
io scheduler cfq registered
assign_interrupt_mode Found MSI capability
Allocate Port Service[0000:00:01.0:pcie00]
Allocate Port Service[0000:00:01.0:pcie03]
Allocate Port Service[0000:00:1c.0:pcie00]
Allocate Port Service[0000:00:1c.0:pcie02]
Allocate Port Service[0000:00:1c.0:pcie03]
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
i8042.c: Detected active multiplexing controller, rev 1.1.
serio: i8042 AUX0 port at 0x60,0x64 irq 12
serio: i8042 AUX1 port at 0x60,0x64 irq 12
serio: i8042 AUX2 port at 0x60,0x64 irq 12
serio: i8042 AUX3 port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
ACPI: PCI Interrupt 0000:00:1e.3[B] -> GSI 20 (level, low) -> IRQ 217
ACPI: PCI interrupt for device 0000:00:1e.3 disabled
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
NET: Registered protocol family 2
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 7, 524288 bytes)
TCP bind hash table entries: 65536 (order: 6, 262144 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
TCP bic registered
NET: Registered protocol family 17
NET: Registered protocol family 8
NET: Registered protocol family 20
Using IPI Shortcut mode
ACPI wakeup devices:
LID0 RP01 LANC PS2K PS2M
ACPI: (supports S0 S3 S4 S5)
Freeing unused kernel memory: 144k freed
mice: PS/2 mouse device common for all mice
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
ICH6: IDE controller at PCI slot 0000:00:1f.1
ACPI: PCI Interrupt 0000:00:1f.1[A] -> GSI 18 (level, low) -> IRQ 225
ICH6: chipset revision 4
ICH6: not 100% native mode: will probe irqs later
ide0: BM-DMA at 0x18c0-0x18c7, BIOS settings: hda:DMA, hdb:DMA
Probing IDE interface ide0...
hda: TOSHIBA MK1031GAS, ATA DISK drive
hdb: MATSHITAUJ-840D, ATAPI CD/DVD-ROM drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
hda: max request size: 128KiB
hda: 195371568 sectors (100030 MB), CHS=65535/16/63, UDMA(100)
hda: cache flushes supported
hda: hda1 hda2 < hda5 hda6 > hda3
kjournald starting. Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
input: AT Translated Set 2 keyboard as /class/input/input0
input: AT Translated Set 2 keyboard as /class/input/input1
Adding 329292k swap on /dev/hda6. Priority:-1 extents:1 across:329292k
EXT3 FS on hda3, internal journal
Real Time Clock Driver v1.12ac
Generic RTC Driver v1.07
hdb: ATAPI 24X DVD-ROM DVD-R CD-R/RW drive, 2048kB Cache, (U)DMA
Uniform CD-ROM driver Revision: 3.20
ieee80211_crypt: version magic '2.6.16-1-686 686 gcc-3.3' should be '2.6.16-1-686 686 gcc-4.0'
ieee80211: version magic '2.6.16-1-686 686 gcc-3.3' should be '2.6.16-1-686 686 gcc-4.0'
ipw2200: version magic '2.6.16-1-686 686 gcc-3.3' should be '2.6.16-1-686 686 gcc-4.0'
input: PS/2 Mouse as /class/input/input2
input: AlpsPS/2 ALPS GlidePoint as /class/input/input3
8139too Fast Ethernet driver 0.9.27
ACPI: PCI Interrupt 0000:06:07.0[A] -> GSI 20 (level, low) -> IRQ 217
eth0: RealTek RTL8139 at 0x4000, 00:0a:e4:d7:3b:fc, IRQ 217
eth0: Identified 8139 chip type 'RTL-8100B/8139D'
usbcore: registered new driver usbfs
usbcore: registered new driver hub
USB Universal Host Controller Interface driver v2.3
ACPI: PCI Interrupt 0000:00:1d.0[A] -> GSI 23 (level, low) -> IRQ 233
PCI: Setting latency timer of device 0000:00:1d.0 to 64
uhci_hcd 0000:00:1d.0: UHCI Host Controller
uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1
uhci_hcd 0000:00:1d.0: irq 233, io base 0x00001800
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:1d.1[B] -> GSI 19 (level, low) -> IRQ 50
PCI: Setting latency timer of device 0000:00:1d.1 to 64
uhci_hcd 0000:00:1d.1: UHCI Host Controller
uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 2
uhci_hcd 0000:00:1d.1: irq 50, io base 0x00001820
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:1d.2[C] -> GSI 18 (level, low) -> IRQ 225
PCI: Setting latency timer of device 0000:00:1d.2 to 64
uhci_hcd 0000:00:1d.2: UHCI Host Controller
uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 3
uhci_hcd 0000:00:1d.2: irq 225, io base 0x00001840
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:1d.3[D] -> GSI 16 (level, low) -> IRQ 169
PCI: Setting latency timer of device 0000:00:1d.3 to 64
uhci_hcd 0000:00:1d.3: UHCI Host Controller
uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 4
uhci_hcd 0000:00:1d.3: irq 169, io base 0x00001860
usb usb4: configuration #1 chosen from 1 choice
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
Linux agpgart interface v0.101 (c) Dave Jones
agpgart: Detected an Intel 915GM Chipset.
agpgart: AGP aperture is 256M @ 0x0
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
ACPI: PCI Interrupt 0000:00:1d.7[A] -> GSI 23 (level, low) -> IRQ 233
PCI: Setting latency timer of device 0000:00:1d.7 to 64
ehci_hcd 0000:00:1d.7: EHCI Host Controller
ehci_hcd 0000:00:1d.7: debug port 1
PCI: cache line size of 32 is not supported by device 0000:00:1d.7
ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 5
ehci_hcd 0000:00:1d.7: irq 233, io mem 0xc8000000
ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb5: configuration #1 chosen from 1 choice
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 8 ports detected
hw_random hardware driver 1.0.0 loaded
ACPI: PCI Interrupt 0000:00:1e.2[A] -> GSI 17 (level, low) -> IRQ 177
PCI: Setting latency timer of device 0000:00:1e.2 to 64
intel8x0_measure_ac97_clock: measured 50521 usecs
intel8x0: clocking to 48000
PCI: Setting latency timer of device 0000:00:1e.3 to 64
Yenta: CardBus bridge found at 0000:06:06.0 [103c:309d]
Yenta: Enabling burst memory read transactions
Yenta: Using CSCINT to route CSC interrupts to PCI
Yenta: Routing CardBus interrupts to PCI
Yenta TI: socket 0000:06:06.0, mfunc 0x01aa1b02, devctl 0x64
Yenta: ISA IRQ mask 0x0cf8, PCI irq 185
Socket status: 30000006
pcmcia: parent PCI bridge I/O window: 0x4000 - 0x4fff
cs: IO port probe 0x4000-0x4fff: clean.
pcmcia: parent PCI bridge Memory window: 0xc8200000 - 0xc82fffff
pcmcia: parent PCI bridge Memory window: 0x50000000 - 0x51ffffff
ieee1394: Initialized config rom entry `ip1394'
ACPI: PCI Interrupt 0000:06:06.2[C] -> GSI 21 (level, low) -> IRQ 58
ohci1394: fw-host0: OHCI-1394 1.1 (PCI): IRQ=[58] MMIO=[c8208000-c82087ff] Max Packet=[2048] IR/IT contexts=[4/8]
ieee1394: Host added: ID:BUS[0-00:1023] GUID[05e40a00bc215035]
8139cp: 10/100 PCI Ethernet driver v1.2 (Mar 22, 2004)
ts: Compaq touchscreen protocol output
eth0: link up, 100Mbps, full-duplex, lpa 0x41E1
ACPI: Battery Slot [BAT0] (battery present)
ACPI: AC Adapter [AC] (on-line)
ACPI: CPU0 (power states: C1[C1] C2[C2] C3[C3] C4[C3])
ACPI: Power Button (FF) [PWRF]
ACPI: Lid Switch [LID0]
ACPI: Sleep Button (CM) [SLPB]
ACPI: Power Button (CM) [PWB]
ACPI: Thermal Zone [THR0] (61 C)
ACPI: Thermal Zone [THR1] (56 C)
pcmcia: Detected deprecated PCMCIA ioctl usage.
pcmcia: This interface will soon be removed from the kernel; please expect breakage unless you upgrade to new tools.
pcmcia: see http://www.kernel.org/pub/linux/utils/kernel/pcmcia/pcmcia.html for details.
cs: IO port probe 0x100-0x4ff: excluding 0x200-0x20f 0x4d0-0x4d7
cs: IO port probe 0x800-0x8ff: excluding 0x800-0x80f
cs: IO port probe 0xc00-0xcff: excluding 0xcf8-0xcff
cs: IO port probe 0xa00-0xaff: clean.
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
eth0: no IPv6 routers present
un ifconfig -a
[code]eth0 Link encap:Ethernet HWaddr 00:03:C9:EA:1F:D2
inet addr:192.168.25.26 Bcast:192.168.255.255 Mask:255.255.0.0
inet6 addr: fe80::203:c9ff:feea:1fd2/64 Scope:Link
RX packets:4726 errors:0 dropped:0 overruns:0 frame:0
TX packets:2855 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:5593914 (5.3 MiB) TX bytes:316888 (309.4 KiB)
Interrupt:217 Base address:0x4000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
RX packets:81 errors:0 dropped:0 overruns:0 frame:0
TX packets:81 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:5456 (5.3 KiB) TX bytes:5456 (5.3 KiB)
sit0 Link encap:IPv6-in-IPv4
NOARP MTU:1480 Metric:1
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
