Installer le daemon Mochad
Bonsoir,
J’ai installé le programme Mochad (Multiple Online Controllers for Home Automation Daemon) version 0.1.16 qui est un deamon. Je suis sur Debian wheezy 3.0.4.
Doc ici ----> sourceforge.net/apps/mediawiki/m … =Main_Page
J’ai installé la librairie pour l’usb.
root@debian:~# apt-get install libusb-1.0-0-dev Reading package lists... Done Building dependency tree Reading state information... Done The following NEW packages will be installed: libusb-1.0-0-dev 0 upgraded, 1 newly installed, 0 to remove and 3 not upgraded. Need to get 186 kB of archives. After this operation, 964 kB of additional disk space will be used. Get:1 http://ftp.fr.debian.org/debian/ stable/main libusb-1.0-0-dev armel 2:1.0.11-1 [186 kB] Fetched 186 kB in 0s (683 kB/s) perl: warning: Setting locale failed. perl: warning: Please check that your locale settings: LANGUAGE = (unset), LC_ALL = (unset), LANG = "fr_FR.UTF-8" are supported and installed on your system. perl: warning: Falling back to the standard locale ("C"). locale: Cannot set LC_CTYPE to default locale: No such file or directory locale: Cannot set LC_MESSAGES to default locale: No such file or directory locale: Cannot set LC_ALL to default locale: No such file or directory Selecting previously unselected package libusb-1.0-0-dev. (Reading database ... 17063 files and directories currently installed.) Unpacking libusb-1.0-0-dev (from .../libusb-1.0-0-dev_2%3a1.0.11-1_armel.deb) ... Setting up libusb-1.0-0-dev (2:1.0.11-1) ... root@debian:~#
Désarchivage de l’archive téléchargé
root@debian:/home/serveur/Pilotes# tar xvzf mochad-0.1.16.tar.gz mochad-0.1.16/ mochad-0.1.16/README mochad-0.1.16/x10_write.h mochad-0.1.16/aclocal.m4 mochad-0.1.16/decode.h mochad-0.1.16/mochad.c mochad-0.1.16/ChangeLog mochad-0.1.16/Makefile.in mochad-0.1.16/apps/ mochad-0.1.16/apps/mochamon.pl mochad-0.1.16/apps/simplemon.pl mochad-0.1.16/apps/bash.sh mochad-0.1.16/apps/rfsectopl3.pl mochad-0.1.16/apps/mochad.scr mochad-0.1.16/apps/x10-tk.py mochad-0.1.16/global.c mochad-0.1.16/Makefile.am mochad-0.1.16/cgi/ mochad-0.1.16/cgi/netcat.pl mochad-0.1.16/cgi/getsensors.pl mochad-0.1.16/cgi/x10.pl mochad-0.1.16/cgi/cgi-lib.pl mochad-0.1.16/configure mochad-0.1.16/hotplug2/ mochad-0.1.16/hotplug2/20-usb-x10 mochad-0.1.16/hotplug2/mochad mochad-0.1.16/decode.c mochad-0.1.16/udev/ mochad-0.1.16/udev/91-usb-x10-controllers.rules mochad-0.1.16/x10state.c mochad-0.1.16/configure.ac mochad-0.1.16/encode.c mochad-0.1.16/missing mochad-0.1.16/x10_write.c mochad-0.1.16/COPYING mochad-0.1.16/encode.h mochad-0.1.16/INSTALL mochad-0.1.16/depcomp mochad-0.1.16/install-sh mochad-0.1.16/global.h mochad-0.1.16/NEWS mochad-0.1.16/x10state.h root@debian:/home/serveur/Pilotes#
Installation du deamon Mochad
root@debian:/home/serveur/Pilotes# cd mochad-* root@debian:/home/serveur/Pilotes/mochad-0.1.16# ./configure checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for a thread-safe mkdir -p... /bin/mkdir -p checking for gawk... no checking for mawk... mawk checking whether make sets $(MAKE)... yes checking for gcc... gcc checking whether the C compiler works... yes checking for C compiler default output file name... a.out checking for suffix of executables... checking whether we are cross compiling... no checking for suffix of object files... o checking whether we are using the GNU C compiler... yes checking whether gcc accepts -g... yes checking for gcc option to accept ISO C89... none needed checking for style of include used by make... GNU checking dependency style of gcc... gcc3 checking whether make sets $(MAKE)... (cached) yes checking for library containing libusb_init... -lusb-1.0 checking how to run the C preprocessor... gcc -E checking for grep that handles long lines and -e... /bin/grep checking for egrep... /bin/grep -E checking for ANSI C header files... yes checking for sys/types.h... yes checking for sys/stat.h... yes checking for stdlib.h... yes checking for string.h... yes checking for memory.h... yes checking for strings.h... yes checking for inttypes.h... yes checking for stdint.h... yes checking for unistd.h... yes checking fcntl.h usability... yes checking fcntl.h presence... yes checking for fcntl.h... yes checking netinet/in.h usability... yes checking netinet/in.h presence... yes checking for netinet/in.h... yes checking for stdlib.h... (cached) yes checking for string.h... (cached) yes checking sys/socket.h usability... yes checking sys/socket.h presence... yes checking for sys/socket.h... yes checking syslog.h usability... yes checking syslog.h presence... yes checking for syslog.h... yes checking for unistd.h... (cached) yes checking for pid_t... yes checking for size_t... yes checking for uint16_t... yes checking for uint8_t... yes checking vfork.h usability... no checking vfork.h presence... no checking for vfork.h... no checking for fork... yes checking for vfork... yes checking for working fork... yes checking for working vfork... (cached) yes checking for stdlib.h... (cached) yes checking for GNU libc compatible malloc... yes checking for alarm... yes checking for memset... yes checking for select... yes checking for socket... yes checking for strerror... yes checking for strtol... yes checking for strtoul... yes configure: creating ./config.status config.status: creating Makefile config.status: executing depfiles commands root@debian:/home/serveur/Pilotes/mochad-0.1.16# make gcc -DPACKAGE_NAME=\"mochad\" -DPACKAGE_TARNAME=\"mochad\" -DPACKAGE_VERSION=\"0.1.16\" -DPACKAGE_STRING=\"mochad\ 0.1.16\" -DPACKAGE_BUGREPORT=\"mmauka@users.sourceforge.net\" -DPACKAGE_URL=\"\" -DPACKAGE=\"mochad\" -DVERSION=\"0.1.16\" -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_FCNTL_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_SYS_SOCKET_H=1 -DHAVE_SYSLOG_H=1 -DHAVE_UNISTD_H=1 -DHAVE_FORK=1 -DHAVE_VFORK=1 -DHAVE_WORKING_VFORK=1 -DHAVE_WORKING_FORK=1 -DHAVE_STDLIB_H=1 -DHAVE_MALLOC=1 -DHAVE_ALARM=1 -DHAVE_MEMSET=1 -DHAVE_SELECT=1 -DHAVE_SOCKET=1 -DHAVE_STRERROR=1 -DHAVE_STRTOL=1 -DHAVE_STRTOUL=1 -I. -O2 -Wall -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wreturn-type -Wcast-align -g -O2 -MT mochad.o -MD -MP -MF .deps/mochad.Tpo -c -o mochad.o mochad.c mv -f .deps/mochad.Tpo .deps/mochad.Po gcc -DPACKAGE_NAME=\"mochad\" -DPACKAGE_TARNAME=\"mochad\" -DPACKAGE_VERSION=\"0.1.16\" -DPACKAGE_STRING=\"mochad\ 0.1.16\" -DPACKAGE_BUGREPORT=\"mmauka@users.sourceforge.net\" -DPACKAGE_URL=\"\" -DPACKAGE=\"mochad\" -DVERSION=\"0.1.16\" -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_FCNTL_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_SYS_SOCKET_H=1 -DHAVE_SYSLOG_H=1 -DHAVE_UNISTD_H=1 -DHAVE_FORK=1 -DHAVE_VFORK=1 -DHAVE_WORKING_VFORK=1 -DHAVE_WORKING_FORK=1 -DHAVE_STDLIB_H=1 -DHAVE_MALLOC=1 -DHAVE_ALARM=1 -DHAVE_MEMSET=1 -DHAVE_SELECT=1 -DHAVE_SOCKET=1 -DHAVE_STRERROR=1 -DHAVE_STRTOL=1 -DHAVE_STRTOUL=1 -I. -O2 -Wall -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wreturn-type -Wcast-align -g -O2 -MT decode.o -MD -MP -MF .deps/decode.Tpo -c -o decode.o decode.c mv -f .deps/decode.Tpo .deps/decode.Po gcc -DPACKAGE_NAME=\"mochad\" -DPACKAGE_TARNAME=\"mochad\" -DPACKAGE_VERSION=\"0.1.16\" -DPACKAGE_STRING=\"mochad\ 0.1.16\" -DPACKAGE_BUGREPORT=\"mmauka@users.sourceforge.net\" -DPACKAGE_URL=\"\" -DPACKAGE=\"mochad\" -DVERSION=\"0.1.16\" -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_FCNTL_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_SYS_SOCKET_H=1 -DHAVE_SYSLOG_H=1 -DHAVE_UNISTD_H=1 -DHAVE_FORK=1 -DHAVE_VFORK=1 -DHAVE_WORKING_VFORK=1 -DHAVE_WORKING_FORK=1 -DHAVE_STDLIB_H=1 -DHAVE_MALLOC=1 -DHAVE_ALARM=1 -DHAVE_MEMSET=1 -DHAVE_SELECT=1 -DHAVE_SOCKET=1 -DHAVE_STRERROR=1 -DHAVE_STRTOL=1 -DHAVE_STRTOUL=1 -I. -O2 -Wall -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wreturn-type -Wcast-align -g -O2 -MT encode.o -MD -MP -MF .deps/encode.Tpo -c -o encode.o encode.c mv -f .deps/encode.Tpo .deps/encode.Po gcc -DPACKAGE_NAME=\"mochad\" -DPACKAGE_TARNAME=\"mochad\" -DPACKAGE_VERSION=\"0.1.16\" -DPACKAGE_STRING=\"mochad\ 0.1.16\" -DPACKAGE_BUGREPORT=\"mmauka@users.sourceforge.net\" -DPACKAGE_URL=\"\" -DPACKAGE=\"mochad\" -DVERSION=\"0.1.16\" -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_FCNTL_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_SYS_SOCKET_H=1 -DHAVE_SYSLOG_H=1 -DHAVE_UNISTD_H=1 -DHAVE_FORK=1 -DHAVE_VFORK=1 -DHAVE_WORKING_VFORK=1 -DHAVE_WORKING_FORK=1 -DHAVE_STDLIB_H=1 -DHAVE_MALLOC=1 -DHAVE_ALARM=1 -DHAVE_MEMSET=1 -DHAVE_SELECT=1 -DHAVE_SOCKET=1 -DHAVE_STRERROR=1 -DHAVE_STRTOL=1 -DHAVE_STRTOUL=1 -I. -O2 -Wall -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wreturn-type -Wcast-align -g -O2 -MT global.o -MD -MP -MF .deps/global.Tpo -c -o global.o global.c global.c: In function '_dbprintf': global.c:40:9: warning: variable 'buflen' set but not used [-Wunused-but-set-variable] mv -f .deps/global.Tpo .deps/global.Po gcc -DPACKAGE_NAME=\"mochad\" -DPACKAGE_TARNAME=\"mochad\" -DPACKAGE_VERSION=\"0.1.16\" -DPACKAGE_STRING=\"mochad\ 0.1.16\" -DPACKAGE_BUGREPORT=\"mmauka@users.sourceforge.net\" -DPACKAGE_URL=\"\" -DPACKAGE=\"mochad\" -DVERSION=\"0.1.16\" -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_FCNTL_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_SYS_SOCKET_H=1 -DHAVE_SYSLOG_H=1 -DHAVE_UNISTD_H=1 -DHAVE_FORK=1 -DHAVE_VFORK=1 -DHAVE_WORKING_VFORK=1 -DHAVE_WORKING_FORK=1 -DHAVE_STDLIB_H=1 -DHAVE_MALLOC=1 -DHAVE_ALARM=1 -DHAVE_MEMSET=1 -DHAVE_SELECT=1 -DHAVE_SOCKET=1 -DHAVE_STRERROR=1 -DHAVE_STRTOL=1 -DHAVE_STRTOUL=1 -I. -O2 -Wall -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wreturn-type -Wcast-align -g -O2 -MT x10state.o -MD -MP -MF .deps/x10state.Tpo -c -o x10state.o x10state.c x10state.c:113:13: warning: 'hua_dbprint' defined but not used [-Wunused-function] mv -f .deps/x10state.Tpo .deps/x10state.Po gcc -DPACKAGE_NAME=\"mochad\" -DPACKAGE_TARNAME=\"mochad\" -DPACKAGE_VERSION=\"0.1.16\" -DPACKAGE_STRING=\"mochad\ 0.1.16\" -DPACKAGE_BUGREPORT=\"mmauka@users.sourceforge.net\" -DPACKAGE_URL=\"\" -DPACKAGE=\"mochad\" -DVERSION=\"0.1.16\" -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_FCNTL_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_SYS_SOCKET_H=1 -DHAVE_SYSLOG_H=1 -DHAVE_UNISTD_H=1 -DHAVE_FORK=1 -DHAVE_VFORK=1 -DHAVE_WORKING_VFORK=1 -DHAVE_WORKING_FORK=1 -DHAVE_STDLIB_H=1 -DHAVE_MALLOC=1 -DHAVE_ALARM=1 -DHAVE_MEMSET=1 -DHAVE_SELECT=1 -DHAVE_SOCKET=1 -DHAVE_STRERROR=1 -DHAVE_STRTOL=1 -DHAVE_STRTOUL=1 -I. -O2 -Wall -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wreturn-type -Wcast-align -g -O2 -MT x10_write.o -MD -MP -MF .deps/x10_write.Tpo -c -o x10_write.o x10_write.c mv -f .deps/x10_write.Tpo .deps/x10_write.Po gcc -O2 -Wall -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wreturn-type -Wcast-align -g -O2 -o mochad mochad.o decode.o encode.o global.o x10state.o x10_write.o -lusb-1.0 root@debian:/home/serveur/Pilotes/mochad-0.1.16# make install make[1]: Entering directory `/home/serveur/Pilotes/mochad-0.1.16' test -z "/usr/local/bin" || /bin/mkdir -p "/usr/local/bin" /usr/bin/install -c mochad '/usr/local/bin' make install-exec-hook make[2]: Entering directory `/home/serveur/Pilotes/mochad-0.1.16' if test -d /etc/udev/rules.d ; then \ cp /home/serveur/Pilotes/mochad-0.1.16/udev/91-usb-x10-controllers.rules /etc/udev/rules.d ; \ fi ; if test -d /etc/hotplug.d/usb ; then \ cp /home/serveur/Pilotes/mochad-0.1.16/hotplug2/20-usb-x10 /etc/hotplug.d/usb ; \ cp /home/serveur/Pilotes/mochad-0.1.16/hotplug2/mochad /etc/init.d ; \ fi ; make[2]: Leaving directory `/home/serveur/Pilotes/mochad-0.1.16' make[1]: Nothing to be done for `install-data-am'. make[1]: Leaving directory `/home/serveur/Pilotes/mochad-0.1.16' root@debian:/home/serveur/Pilotes/mochad-0.1.16# cd ~ root@debian:~#
Mochad est maintenant installé, mais quand j’execute le deamon sur mon serveur “mochad” j’ai une message failed ?
Détails :
[code]serveur@debian:~$ mochad
serveur@debian:~$
Message from syslogd@debian at Jun 16 17:14:45 …
mochad[4184]: libusb_open_device_with_vid_pid failed
mochad[4184]: Could not find/open CM15A/CM19A -5
serveur@debian:~$[/code]
Extrait lsusb
Le cm15A est bien reconnu via l’usb.
Comment résoudre le problème ?
Pour éventuellement y désinstaller, je ne sais pas comment procéder ?
Merci ?
Les étapes de compilation / installation / désinstallation sont propres à chaque projet.
Tu n’as pas eu à taper “make install”, qui d’habitude se charge d’installer l’application pour le système (et non pas pour l’utilisateur simple).
Donc on rentre dans un cas «atypique».
Le readme du projet indique peut-être une façon de nettoyer les fichiers, la procédure peut être incluse dans le make, genre “make uninstall” (à ne pas confondre avec “make clean” qui vire simplement le résultat de la compilation).
Quant à ton erreur, je ne connais pas ce type d’équipement, ni le logiciel, mais vu la nature des erreurs, je ne serais pas étonné que tu trouves plus d’infos auprès de la communauté mochad.
lsusb n’indique pas qu’un périphérique est «reconnu» mais indique qu’il est «présent». Il se peut fortement que tout en l’ayant branché, il ne soit pas fonctionnel faute à un driver/firmware manquant.
Le readme ne dit pas grand chose.
code.empreintesduweb.com/6189.html
Je cherchais juste à désinstaller le deamon mochad, voila pourquoi l’origine de ce poste.
C’est du matériel domotique norme x10 (Marmitek cm15 Pro)
Donc ceci n’est pas non plus causé par un manque de paquet/librairie ou de la distrib debian.
Merci.
