voila ce gui bug :
X Window System Version 1.3.0
Release Date: 19 April 2007
X Protocol Version 11, Revision 0, Release 1.3
Build Operating System: Linux Debian (xorg-server 2:1.3.0.0.dfsg-12)
Current Operating System: Linux ordidetib 2.6.22.7.070924 #1 Mon Sep 24 16:58:16 CEST 2007 i686
Build Date: 09 August 2007
Before reporting problems, check wiki.x.org
Module Loader present
Markers: (–) probed, () from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Tue Sep 25 11:23:28 2007
(==) Using config file: “/etc/X11/xorg.conf”
(==) ServerLayout “Default Layout”
() |–>Screen “Default Screen” (0)
() | |–>Monitor “CM1555NEL”
() | |–>Device “ATI Technologies Inc Radeon RV250 If [Radeon 9000]”
() |–>Input Device “Generic Keyboard”
() |–>Input Device “Configured Mouse”
(WW) The directory “/usr/X11R6/lib/X11/fonts/misc” does not exist.
Entry deleted from font path.
(WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/cyrillic” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/100dpi/” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/75dpi/” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/Type1” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/100dpi” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/75dpi” does not exist.
(WW) The directory “/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType” does not exist.
(WW) Including the default font path /usr/share/fonts/X11/misc,/usr/share/fonts/X11/cyrillic,/usr/share/fonts/X11/100dpi/:unscaled,/usr/share/fonts/X11/75dpi/:unscaled,/usr/share/fonts/X11/Type1,/usr/share/fonts/X11/100dpi,/usr/share/fonts/X11/75dpi,/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType.
() FontPath set to:
(==) RgbPath set to “/etc/X11/rgb”
(==) ModulePath set to “/usr/lib/xorg/modules”
() Extension “Composite” is disabled
(**) Extension “RENDER” is enabled
(II) Open ACPI successful (/var/run/acpid.socket)
(II) Loader magic: 0x81e5140
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 1.2
X.Org XInput driver : 0.7
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: “pcidata”
(II) Loading /usr/lib/xorg/modules//libpcidata.so
(II) Module pcidata: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 1.0.0
ABI class: X.Org Video Driver, version 1.2
(++) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 10de,01e0 card 147b,1c02 rev c1 class 06,00,00 hdr 80
(II) PCI: 00:00:1: chip 10de,01eb card 10de,0c17 rev c1 class 05,00,00 hdr 80
(II) PCI: 00:00:2: chip 10de,01ee card 10de,0c17 rev c1 class 05,00,00 hdr 80
(II) PCI: 00:00:3: chip 10de,01ed card 10de,0c17 rev c1 class 05,00,00 hdr 80
(II) PCI: 00:00:4: chip 10de,01ec card 10de,0c17 rev c1 class 05,00,00 hdr 80
(II) PCI: 00:00:5: chip 10de,01ef card 10de,0c17 rev c1 class 05,00,00 hdr 80
(II) PCI: 00:01:0: chip 10de,0060 card 147b,1c02 rev a4 class 06,01,00 hdr 80
(II) PCI: 00:01:1: chip 10de,0064 card 147b,1c02 rev a2 class 0c,05,00 hdr 80
(II) PCI: 00:02:0: chip 10de,0067 card 147b,1c02 rev a4 class 0c,03,10 hdr 80
(II) PCI: 00:02:1: chip 10de,0067 card 147b,1c02 rev a4 class 0c,03,10 hdr 80
(II) PCI: 00:02:2: chip 10de,0068 card 147b,1c02 rev a4 class 0c,03,20 hdr 80
(II) PCI: 00:04:0: chip 10de,0066 card 147b,1c02 rev a1 class 02,00,00 hdr 00
(II) PCI: 00:06:0: chip 10de,006a card 147b,1c02 rev a1 class 04,01,00 hdr 00
(II) PCI: 00:08:0: chip 10de,006c card 0000,0000 rev a3 class 06,04,00 hdr 01
(II) PCI: 00:09:0: chip 10de,0065 card 147b,1c02 rev a2 class 01,01,8a hdr 00
(II) PCI: 00:1e:0: chip 10de,01e8 card 0000,0000 rev c1 class 06,04,00 hdr 01
(II) PCI: 02:00:0: chip 1002,4966 card 174b,7197 rev 01 class 03,00,00 hdr 80
(II) PCI: 02:00:1: chip 1002,496e card 174b,7196 rev 01 class 03,80,00 hdr 00
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,2), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:1:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:8:0), (0,1,1), BCTRL: 0x0202 (VGA_EN is cleared)
(II) Bus 2: bridge is at (0:30:0), (0,2,2), BCTRL: 0x000a (VGA_EN is set)
(II) Bus 2 I/O range:
[0] -1 0 0x0000c000 - 0x0000cfff (0x1000) IX[B]
(II) Bus 2 non-prefetchable memory range:
[0] -1 0 0xd8000000 - 0xd9ffffff (0x2000000) MX[B]
(II) Bus 2 prefetchable memory range:
[0] -1 0 0xd0000000 - 0xd7ffffff (0x8000000) MX[B]
(–) PCI:*(2:0:0) ATI Technologies Inc Radeon RV250 If [Radeon 9000] rev 1, Mem @ 0xd0000000/26, 0xd9000000/16, I/O @ 0xc000/8
(–) PCI: (2:0:1) ATI Technologies Inc Radeon RV250 [Radeon 9000] (Secondary) rev 1, Mem @ 0xd4000000/26, 0xd9010000/16
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) PCI Memory resource overlap reduced 0xc0000000 from 0xcfffffff to 0xbfffffff
(II) Active PCI resource ranges:
[0] -1 0 0xda002000 - 0xda002fff (0x1000) MX[B]
[1] -1 0 0xda001000 - 0xda001fff (0x1000) MX[B]
[2] -1 0 0xda000000 - 0xda0000ff (0x100) MX[B]
[3] -1 0 0xda005000 - 0xda005fff (0x1000) MX[B]
[4] -1 0 0xda004000 - 0xda004fff (0x1000) MX[B]
[5] -1 0 0xc0000000 - 0xbfffffff (0x0) MX[B]O
[6] -1 0 0xd9000000 - 0xd900ffff (0x10000) MXB
[7] -1 0 0xd0000000 - 0xd3ffffff (0x4000000) MXB
[8] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[9] -1 0 0x0000d800 - 0x0000d87f (0x80) IX[B]
[10] -1 0 0x0000d400 - 0x0000d4ff (0x100) IX[B]
[11] -1 0 0x0000d000 - 0x0000d007 (0x8) IX[B]
[12] -1 0 0x0000e400 - 0x0000e41f (0x20) IX[B]
[13] -1 0 0x0000c000 - 0x0000c0ff (0x100) IXB
(II) Inactive PCI resource ranges:
[0] -1 0 0xd9010000 - 0xd901ffff (0x10000) MXB
[1] -1 0 0xd4000000 - 0xd7ffffff (0x4000000) MXB
(II) Active PCI resource ranges after removing overlaps:
(II) Inactive PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[4] -1 0 0xda002000 - 0xda002fff (0x1000) MX[B]
[5] -1 0 0xda001000 - 0xda001fff (0x1000) MX[B]
[6] -1 0 0xda000000 - 0xda0000ff (0x100) MX[B]
[7] -1 0 0xda005000 - 0xda005fff (0x1000) MX[B]
[8] -1 0 0xda004000 - 0xda004fff (0x1000) MX[B]
[9] -1 0 0xc0000000 - 0xbfffffff (0x0) MX[B]O
[10] -1 0 0xd9000000 - 0xd900ffff (0x10000) MXB
[11] -1 0 0xd0000000 - 0xd3ffffff (0x4000000) MXB
[12] -1 0 0xd9010000 - 0xd901ffff (0x10000) MXB
[13] -1 0 0xd4000000 - 0xd7ffffff (0x4000000) MXB
[14] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[15] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[16] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[17] -1 0 0x0000d800 - 0x0000d87f (0x80) IX[B]
[18] -1 0 0x0000d400 - 0x0000d4ff (0x100) IX[B]
[19] -1 0 0x0000d000 - 0x0000d007 (0x8) IX[B]
[20] -1 0 0x0000e400 - 0x0000e41f (0x20) IX[B]
[21] -1 0 0x0000c000 - 0x0000c0ff (0x100) IXB
(II) LoadModule: “i2c”(II) Module already built-in
(II) LoadModule: “ddc”(II) Module already built-in
(II) LoadModule: “dri”
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
(II) Module dri: vendor="X.Org Foundation"
ABI class: X.Org Server Extension, version 0.3
(II) Loading extension XFree86-DRI
(II) LoadModule: “extmod”
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
Module class: X.Org Server Extension
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: “freetype”
(II) Loading /usr/lib/xorg/modules//fonts/libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
compiled for 1.3.0, module version = 2.1.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.5
(II) Loading font FreeType
(II) LoadModule: “glx”
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(II) Module glx: vendor="X.Org Foundation"
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: “int10”
(II) Loading /usr/lib/xorg/modules//libint10.so
(II) Module int10: vendor="X.Org Foundation"
(II) LoadModule: “vbe”
(II) Loading /usr/lib/xorg/modules//libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 1.1.0
(II) LoadModule: “dbe”
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: “record”
(II) Loading /usr/lib/xorg/modules/extensions//librecord.so
(II) Module record: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: “fglrx”
(II) Loading /usr/lib/xorg/modules/drivers//fglrx_drv.so
(II) Module fglrx: vendor="FireGL - ATI Technologies Inc."
compiled for 7.1.0, module version = 8.38.6
Module class: X.Org Video Driver
ABI class: X.Org Video Driver, version 1.0
(II) LoadModule: “kbd”
(II) Loading /usr/lib/xorg/modules/input//kbd_drv.so
(II) Module kbd: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 1.2.1
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 0.7
(II) LoadModule: “mouse”
(II) Loading /usr/lib/xorg/modules/input//mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 1.2.2
(II) Primary Device is: PCI 02:00:0
(II) ATI Proprietary Linux Driver Version Identifier:8.38.6
(II) ATI Proprietary Linux Driver Release Identifier: LGDr8.38g1
(II) ATI Proprietary Linux Driver Build Date: Jun 22 2007 13:10:21
(II) ATI Proprietary Linux Driver Build Information: autobuild-rel-r6-8.38.1.1.2.3-driver-lnx-x86-x86_64-351593
(WW) fglrx: No matching Device section for instance (BusID PCI:2:0:1) found
(EE) No devices detected.
Fatal server error:
no screens found
