j’ai installer un scanner OpticPro 4830P de Plustek sur une Sarge mais je n’arrive pas à la faire fonctionner.
/etc/sane.d/saned.conf
saned.conf
The contents of the saned.conf file is a list of host names, IP
addresses or IP subnets (CIDR notation) that are permitted to use local
SANE devices. IPv6 addresses must be enclosed in brackets, and should
always be specified in their compressed form.
The hostname matching is not case-sensitive.
#scan-client.somedomain.firm
#192.168.0.1
#192.168.0.1/29
#[2001:7a8:185e::42:12]
#[2001:7a8:185e::42:12]/64
NOTE: /etc/inetd.conf (or /etc/xinetd.conf) and
/etc/services must also be properly configured to start
the saned daemon as documented in saned(8), services(4)
and inetd.conf(4) (or xinetd.conf(5)).
#192.168.182.0/24
localhost
/etc/sane.d/dll.conf
/etc/sane.d/dll.conf - Configuration file for the SANE dynamic backend loader
On Debian systems, the dll backend will also look for pieces of configuration
in the /etc/sane.d/dll.d directory – packages providing backends should drop
a config file similar to dll.conf in this directory.
enable the next line if you want to allow access through the network:
net
abaton
agfafocus
apple
avision
artec
artec_eplus48u
as6e
bh
canon
canon630u
#canon_pp
coolscan
coolscan2
#dc25
#dc210
#dc240
dmc
epson
fujitsu
#gphoto2
gt68xx
hp
hpsj5s
hp5400
ibm
leo
ma1509
matsushita
microtek
microtek2
mustek
#mustek_pp
mustek_usb
nec
niash
pie
plustek
plustek_pp
#pnm
qcam
ricoh
s9036
sceptre
sharp
sm3600
snapscan
sp15c
#st400
tamarack
teco1
teco2
teco3
#test
u12
umax
#umax_pp
umax1220u
#v4l
The HP OfficeJet backend is not part of the SANE distribution
but is provided by the hpoj Debian package
hpoj
The hpaio backend (hplip package) supports HP multifunction
devices. It is intended as a replacement for hpoj, choose
whichever works best for you
hpaio
/etc/sane.d/plustek_pp.conf
Plustek-PP SANE Backend configuration file
For use with Plustek parallel-port scanners
user either [direct] or [kernel] to access the scanner
when using [kernel], device specifies the device-node, which is created
by the kernel-module loader (applies only to Linux)
when using [direct], device is used to set the parallel-port base address
or a device-name suitable for libieee1284, i.e. parport0
[direct]
device 0x378
leave the default values as specified in /etc/modules.conf
option warmup -1
option lOffOnEnd -1
option lampOff -1
model override switch, mostly for cosmetic changes, if the autodetection
does not work or could not work correctly
#option mov 7
example for accessing the scanner via libieee1284
#[direct]
#device parport0
device /dev/lp
example for accessing the scanner via the kernel module
#[kernel]
device /dev/pt_drv
#option warmup -1
#option lOffOnEnd -1
#option lampOff -1
pour les groupes
terciry:/home/falexis# id -nG falexis
falexis lp dialout cdrom floppy audio video plugdev scanner
