Installer Webmin
Je suis sur debian squeeze 2.6.39.4, je voudrai installer webmin.
root@debian:~# apt-get install webmin Reading package lists... Done Building dependency tree Reading state information... Done E: Unable to locate package webmin root@debian:~#
root@debian:~# aptitude search webmin root@debian:~#
Le paquetage webmin est introuvable ?
Es ce que cela peut venir de mon source.list ?
Je l’installe depuis le site webmin
[code]root@debian:/home/serveur/Deb# wget http://prdownloads.sourceforge.net/webadmin/webmin_1.580_all.deb
–2012-06-19 10:12:31-- http://prdownloads.sourceforge.net/webadmin/webmin_1.580_all.deb
Resolving prdownloads.sourceforge.net… 216.34.181.59
Connecting to prdownloads.sourceforge.net|216.34.181.59|:80… connected.
HTTP request sent, awaiting response… 301 Moved Permanently
Location: http://downloads.sourceforge.net/project/webadmin/webmin/1.580/webmin_1.580_all.deb [following]
–2012-06-19 10:12:31-- http://downloads.sourceforge.net/project/webadmin/webmin/1.580/webmin_1.580_all.deb
Resolving downloads.sourceforge.net… 216.34.181.59
Reusing existing connection to prdownloads.sourceforge.net:80.
HTTP request sent, awaiting response… 302 Found
Location: http://freefr.dl.sourceforge.net/project/webadmin/webmin/1.580/webmin_1.580_all.deb [following]
–2012-06-19 10:12:31-- http://freefr.dl.sourceforge.net/project/webadmin/webmin/1.580/webmin_1.580_all.deb
Resolving freefr.dl.sourceforge.net… 158.255.96.7
Connecting to freefr.dl.sourceforge.net|158.255.96.7|:80… connected.
HTTP request sent, awaiting response… 200 OK
Length: 15756528 (15M) [application/octet-stream]
Saving to: `webmin_1.580_all.deb’
100%[==================================================================================================>] 15,756,528 1.36M/s in 13s
2012-06-19 10:12:45 (1.13 MB/s) - `webmin_1.580_all.deb’ saved [15756528/15756528]
root@debian:/home/serveur/Deb#[/code]
root@debian:/home/serveur/Deb# dpkg -i webmin_1.580_all.deb (Reading database ... 60602 files and directories currently installed.) Preparing to replace webmin 1.580 (using webmin_1.580_all.deb) ... Unpacking replacement webmin ... dpkg: dependency problems prevent configuration of webmin: webmin depends on libnet-ssleay-perl; however: Package libnet-ssleay-perl is not installed. webmin depends on libauthen-pam-perl; however: Package libauthen-pam-perl is not installed. webmin depends on libio-pty-perl; however: Package libio-pty-perl is not installed. webmin depends on apt-show-versions; however: Package apt-show-versions is not installed. dpkg: error processing webmin (--install): dependency problems - leaving unconfigured Errors were encountered while processing: webmin root@debian:/home/serveur/Deb#
Mais les dépendance ne s’intalle pas ?
Merci.
Webmin n’est plus dans les dépôts depuis un bon moment, il n’est pas considéré comme sûr.
Installes les paquets et ça va rouler :
En principe le paquet webmin a l’état cassé devrait être reconfiguré et opérationnel.
