[quote=“Triangle”]Mmmh, trop facile le nano xorg.conf
2 possibilités :
- Tu as sous la main un vieux xorg.conf qui marchait et il faut le copier dans /etc/X11[/quote]
J’en avais un qui traînait sur SD. À l’époque, je râlais car j’étais à 300FPS
J’y ai ajouté ta ligne, idem.
Le xorg.conf en question:
[code]Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
EndSection
Section "Module"
Load "bitmap"
Load "extmod"
Load "dri"
Load "dbe"
Load "ddc"
Load “record”
#Load “xtrap”
#Load "aiglx"
Load "glx"
Load "type1"
Load "freetype"
Load "int10"
Load "i2c"
Load "vbe"
EndSection
Section "Device"
Identifier "Intel Corporation Mobile 945GM/GMS, 943/940GML Express Integrated Graphics Controller"
Driver "intel"
Option “AccelMethod” "UXA"
Option “XAANoOffscreenPixmaps” "true"
Option “AllowGLXWithComposite” "True"
Option “TripleBuffer” “true”
#l’option DRI indique que l’on veut vraiment utiliser l’accélération 3D.
Option “DRI”
#EnablePageFlip augmente la vitesse d’affichage 3D, en principe.
Option “EnablePageFlip” “True”
#RenderAccel est une option pour l’activation de l’accélération 3D.
Option “RenderAccel” “true”
#Backingstore améliore la vraie transparence.
Option “backingstore” "true"
EndSection
Section "Monitor"
Identifier "Configured Monitor"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Intel Corporation Mobile 945GM/GMS, 943/940GML Express Integrated Graphics Controller"
Monitor "Configured Monitor"
DefaultDepth 24
SubSection "Display"
Viewport 0 0
Depth 24
Modes "1280x1024"
EndSubSection
EndSection
Section “ServerLayout”
#Option “AIGLX” "true"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
EndSection
Section "DRI"
Mode 0666
EndSection
Section "Extensions"
Option “Composite” "Enable"
Option “RENDER” "Enable"
Option “DAMAGE” "true"
EndSection[/code]
J’ai essayé, pas de changement. J’ai trouvé dans /etc/initramfs-tools/modules des bouts de mesa et de framebuffer qui traînaient, j’ai viré et j’ai laissé i915 modeset, mais toujours 20FPS!
Pour info, mon Xorg.0.log:
[code][ 3059.996]
X.Org X Server 1.10.2
Release Date: 2011-05-28
[ 3059.996] X Protocol Version 11, Revision 0
[ 3059.996] Build Operating System: Linux 2.6.32-5-686-bigmem i686 Debian
[ 3059.996] Current Operating System: Linux zeus 2.6.39-1-686-pae #1 SMP Fri May 20 20:40:05 UTC 2011 i686
[ 3059.996] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.39-1-686-pae root=UUID=fe5fdaa6-988e-457b-be33-3c8bb36e7ba5 ro quiet vga=794 i915.modeset=1
[ 3059.996] Build Date: 30 May 2011 12:03:58PM
[ 3059.996] xorg-server 2:1.10.2-1 (Cyril Brulebois kibi@debian.org)
[ 3059.996] Current version of pixman: 0.21.8
[ 3059.997] Before reporting problems, check http://wiki.x.org
[ 3059.997] Markers: (–) probed, () from config file, (==) default setting,
[ 3059.997] (==) Log file: “/var/log/Xorg.0.log”, Time: Sat Jun 4 10:49:32 2011
[ 3059.997] (==) Using config file: “/etc/X11/xorg.conf”
[ 3059.997] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 3059.998] (==) ServerLayout “Default Layout”
[ 3059.998] () |–>Screen “Default Screen” (0)
[ 3059.998] () | |–>Monitor “Configured Monitor”
[ 3059.999] () | |–>Device “Intel Corporation Mobile 945GM/GMS, 943/940GML Express Integrated Graphics Controller”
[ 3059.999] () |–>Input Device “Generic Keyboard”
[ 3059.999] () |–>Input Device “Configured Mouse”
[ 3059.999] (==) Automatically adding devices
[ 3059.999] (==) Automatically enabling devices
[ 3059.999] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 3059.999] Entry deleted from font path.
[ 3059.999] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType,
built-ins
[ 3059.999] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 3059.999] () Extension “Composite” is enabled
[ 3059.999] () Extension “RENDER” is enabled
[ 3059.999] (**) Extension “DAMAGE” is enabled
[ 3060.000] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 3060.000] (WW) Hotplugging is on, devices using drivers ‘kbd’, ‘mouse’ or ‘vmmouse’ will be disabled.
[ 3060.000] (WW) Disabling Generic Keyboard
[ 3060.000] (WW) Disabling Configured Mouse
[ 3060.000] (II) Loader magic: 0x8232ae0
[ 3060.000] (II) Module ABI versions:
[ 3060.000] X.Org ANSI C Emulation: 0.4
[ 3060.000] X.Org Video Driver: 10.0
[ 3060.000] X.Org XInput driver : 12.2
[ 3060.000] X.Org Server Extension : 5.0
[ 3060.002] (–) PCI:*(0:0:2:0) 8086:27ae:1043:1252 rev 3, Mem @ 0xfbe00000/524288, 0xd0000000/268435456, 0xfbdc0000/262144, I/O @ 0x0000dc80/8
[ 3060.002] (–) PCI: (0:0:2:1) 8086:27a6:1043:1252 rev 3, Mem @ 0xfbe80000/524288
[ 3060.002] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 3060.002] (II) “extmod” will be loaded. This was enabled by default and also specified in the config file.
[ 3060.002] (II) “dbe” will be loaded. This was enabled by default and also specified in the config file.
[ 3060.002] (II) “glx” will be loaded. This was enabled by default and also specified in the config file.
[ 3060.002] (II) “record” will be loaded. This was enabled by default and also specified in the config file.
[ 3060.002] (II) “dri” will be loaded. This was enabled by default and also specified in the config file.
[ 3060.002] (II) “dri2” will be loaded by default.
[ 3060.002] (II) LoadModule: “extmod”
[ 3060.003] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
[ 3060.004] (II) Module extmod: vendor=“X.Org Foundation”
[ 3060.004] compiled for 1.10.2, module version = 1.0.0
[ 3060.004] Module class: X.Org Server Extension
[ 3060.004] ABI class: X.Org Server Extension, version 5.0
[ 3060.004] (II) Loading extension SELinux
[ 3060.004] (II) Loading extension MIT-SCREEN-SAVER
[ 3060.005] (II) Loading extension XFree86-VidModeExtension
[ 3060.005] (II) Loading extension XFree86-DGA
[ 3060.005] (II) Loading extension DPMS
[ 3060.005] (II) Loading extension XVideo
[ 3060.005] (II) Loading extension XVideo-MotionCompensation
[ 3060.005] (II) Loading extension X-Resource
[ 3060.005] (II) LoadModule: “dri”
[ 3060.006] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
[ 3060.006] (II) Module dri: vendor=“X.Org Foundation”
[ 3060.006] compiled for 1.10.2, module version = 1.0.0
[ 3060.006] ABI class: X.Org Server Extension, version 5.0
[ 3060.006] (II) Loading extension XFree86-DRI
[ 3060.006] (II) LoadModule: “dbe”
[ 3060.007] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[ 3060.007] (II) Module dbe: vendor=“X.Org Foundation”
[ 3060.007] compiled for 1.10.2, module version = 1.0.0
[ 3060.007] Module class: X.Org Server Extension
[ 3060.007] ABI class: X.Org Server Extension, version 5.0
[ 3060.007] (II) Loading extension DOUBLE-BUFFER
[ 3060.007] (II) LoadModule: “ddc”
[ 3060.007] (II) Module “ddc” already built-in
[ 3060.007] (II) LoadModule: “record”
[ 3060.008] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so
[ 3060.008] (II) Module record: vendor=“X.Org Foundation”
[ 3060.009] compiled for 1.10.2, module version = 1.13.0
[ 3060.009] Module class: X.Org Server Extension
[ 3060.009] ABI class: X.Org Server Extension, version 5.0
[ 3060.009] (II) Loading extension RECORD
[ 3060.009] (II) LoadModule: “glx”
[ 3060.009] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 3060.010] (II) Module glx: vendor=“X.Org Foundation”
[ 3060.010] compiled for 1.10.2, module version = 1.0.0
[ 3060.010] ABI class: X.Org Server Extension, version 5.0
[ 3060.010] (==) AIGLX enabled
[ 3060.010] (II) Loading extension GLX
[ 3060.010] (II) LoadModule: “int10”
[ 3060.011] (II) Loading /usr/lib/xorg/modules/libint10.so
[ 3060.011] (II) Module int10: vendor=“X.Org Foundation”
[ 3060.011] compiled for 1.10.2, module version = 1.0.0
[ 3060.011] ABI class: X.Org Video Driver, version 10.0
[ 3060.011] (II) LoadModule: “i2c”
[ 3060.011] (II) Module “i2c” already built-in
[ 3060.011] (II) LoadModule: “vbe”
[ 3060.011] (II) Loading /usr/lib/xorg/modules/libvbe.so
[ 3060.012] (II) Module vbe: vendor=“X.Org Foundation”
[ 3060.012] compiled for 1.10.2, module version = 1.1.0
[ 3060.012] ABI class: X.Org Video Driver, version 10.0
[ 3060.012] (II) LoadModule: “dri2”
[ 3060.013] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[ 3060.013] (II) Module dri2: vendor=“X.Org Foundation”
[ 3060.013] compiled for 1.10.2, module version = 1.2.0
[ 3060.013] ABI class: X.Org Server Extension, version 5.0
[ 3060.013] (II) Loading extension DRI2
[ 3060.013] (II) LoadModule: “intel”
[ 3060.014] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[ 3060.014] (II) Module intel: vendor=“X.Org Foundation”
[ 3060.014] compiled for 1.10.1, module version = 2.15.0
[ 3060.014] Module class: X.Org Video Driver
[ 3060.014] ABI class: X.Org Video Driver, version 10.0
[ 3060.014] (II) intel: Driver for Intel Integrated Graphics Chipsets: i810,
i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G, 915G,
E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM, Pineview G,
965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33, GM45,
4 Series, G45/G43, Q45/Q43, G41, B43, B43, Clarkdale, Arrandale,
Sandybridge, Sandybridge, Sandybridge, Sandybridge, Sandybridge,
[ 3060.016] (++) using VT number 7
[ 3060.042] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[ 3060.043] drmOpenDevice: node name is /dev/dri/card0
[ 3060.043] drmOpenDevice: open result is 8, (OK)
[ 3060.043] drmOpenByBusid: Searching for BusID pci:0000:00:02.0
[ 3060.043] drmOpenByBusid: drmOpenMinor returns 8
[ 3060.043] drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
[ 3060.043] () intel(0): Depth 24, (–) framebuffer bpp 32
[ 3060.044] (==) intel(0): RGB weight 888
[ 3060.044] (==) intel(0): Default visual is TrueColor
[ 3060.044] () intel(0): Option “AccelMethod” “UXA”
[ 3060.044] () intel(0): Option “DRI”
[ 3060.044] (II) intel(0): Integrated Graphics Chipset: Intel® 945GME
[ 3060.044] (–) intel(0): Chipset: “945GME”
[ 3060.044] () intel(0): Relaxed fencing disabled
[ 3060.044] () intel(0): Framebuffer tiled
[ 3060.044] () intel(0): Pixmaps tiled
[ 3060.044] () intel(0): 3D buffers tiled
[ 3060.045] () intel(0): SwapBuffers wait enabled
[ 3060.045] (==) intel(0): video overlay key set to 0x101fe
[ 3060.220] (II) intel(0): Output VGA1 using monitor section Configured Monitor
[ 3060.357] (II) intel(0): Output DVI1 has no monitor section
[ 3060.516] (II) intel(0): EDID for output VGA1
[ 3060.516] (II) intel(0): Manufacturer: PKB Model: c2 Serial#: 2471564511
[ 3060.516] (II) intel(0): Year: 2009 Week: 35
[ 3060.516] (II) intel(0): EDID Version: 1.3
[ 3060.516] (II) intel(0): Analog Display Input, Input Voltage Level: 0.700/0.700 V
[ 3060.516] (II) intel(0): Sync: Separate
[ 3060.517] (II) intel(0): Max Image Size [cm]: horiz.: 44 vert.: 25
[ 3060.517] (II) intel(0): Gamma: 2.20
[ 3060.517] (II) intel(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
[ 3060.517] (II) intel(0): First detailed timing is preferred mode
[ 3060.517] (II) intel(0): redX: 0.650 redY: 0.335 greenX: 0.295 greenY: 0.605
[ 3060.517] (II) intel(0): blueX: 0.145 blueY: 0.075 whiteX: 0.313 whiteY: 0.329
[ 3060.517] (II) intel(0): Supported established timings:
[ 3060.517] (II) intel(0): 720x400@70Hz
[ 3060.517] (II) intel(0): 640x480@60Hz
[ 3060.517] (II) intel(0): 640x480@67Hz
[ 3060.517] (II) intel(0): 640x480@72Hz
[ 3060.518] (II) intel(0): 640x480@75Hz
[ 3060.518] (II) intel(0): 800x600@56Hz
[ 3060.518] (II) intel(0): 800x600@60Hz
[ 3060.518] (II) intel(0): 800x600@72Hz
[ 3060.518] (II) intel(0): 800x600@75Hz
[ 3060.518] (II) intel(0): 832x624@75Hz
[ 3060.518] (II) intel(0): 1024x768@60Hz
[ 3060.518] (II) intel(0): 1024x768@70Hz
[ 3060.518] (II) intel(0): 1024x768@75Hz
[ 3060.518] (II) intel(0): 1152x864@75Hz
[ 3060.518] (II) intel(0): Manufacturer’s mask: 0
[ 3060.518] (II) intel(0): Supported standard timings:
[ 3060.518] (II) intel(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 3060.518] (II) intel(0): #1: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 3060.519] (II) intel(0): #2: hsize: 1280 vsize 800 refresh: 60 vid: 129
[ 3060.519] (II) intel(0): Supported detailed timing:
[ 3060.519] (II) intel(0): clock: 118.2 MHz Image Size: 442 x 249 mm
[ 3060.519] (II) intel(0): h_active: 1600 h_sync: 1688 h_sync_end 1856 h_blank_end 2112 h_border: 0
[ 3060.519] (II) intel(0): v_active: 900 v_sync: 903 v_sync_end 908 v_blanking: 934 v_border: 0
[ 3060.519] (II) intel(0): Monitor name: Viseo 200Ws
[ 3060.519] (II) intel(0): Ranges: V min: 56 V max: 76 Hz, H min: 31 H max: 83 kHz, PixClock max 185 MHz
[ 3060.519] (II) intel(0): Serial No: D140C0044000
[ 3060.519] (II) intel(0): EDID (in hex):
[ 3060.519] (II) intel(0): 00ffffffffffff004162c200df145193
[ 3060.519] (II) intel(0): 23130103682c1978eab815a6554b9b25
[ 3060.520] (II) intel(0): 135054bfee80714f81c0810001010101
[ 3060.520] (II) intel(0): 010101010101312e40006284223058a8
[ 3060.520] (II) intel(0): 3500baf91000001c000000fc00566973
[ 3060.520] (II) intel(0): 656f2032303057730a20000000fd0038
[ 3060.520] (II) intel(0): 4c1f5312000a202020202020000000ff
[ 3060.520] (II) intel(0): 004431343043303034343030300a005f
[ 3060.520] (II) intel(0): EDID vendor “PKB”, prod id 194
[ 3060.520] (II) intel(0): Using EDID range info for horizontal sync
[ 3060.520] (II) intel(0): Using EDID range info for vertical refresh
[ 3060.521] (II) intel(0): Printing DDC gathered Modelines:
[ 3060.521] (II) intel(0): Modeline "1600x900"x0.0 118.25 1600 1688 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz)
[ 3060.521] (II) intel(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
[ 3060.521] (II) intel(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
[ 3060.521] (II) intel(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
[ 3060.521] (II) intel(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz)
[ 3060.521] (II) intel(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz)
[ 3060.521] (II) intel(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
[ 3060.521] (II) intel(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz)
[ 3060.522] (II) intel(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz)
[ 3060.522] (II) intel(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
[ 3060.522] (II) intel(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
[ 3060.522] (II) intel(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz)
[ 3060.522] (II) intel(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
[ 3060.522] (II) intel(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz)
[ 3060.522] (II) intel(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz)
[ 3060.522] (II) intel(0): Modeline "1280x720"x60.0 74.48 1280 1336 1472 1664 720 721 724 746 -hsync +vsync (44.8 kHz)
[ 3060.522] (II) intel(0): Modeline "1280x800"x0.0 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz)
[ 3060.523] (II) intel(0): Printing probed modes for output VGA1
[ 3060.523] (II) intel(0): Modeline "1600x900"x59.9 118.25 1600 1688 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz)
[ 3060.523] (II) intel(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 +hsync -vsync (49.7 kHz)
[ 3060.523] (II) intel(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz)
[ 3060.523] (II) intel(0): Modeline "1280x720"x60.0 74.44 1280 1336 1472 1664 720 721 724 746 -hsync +vsync (44.7 kHz)
[ 3060.523] (II) intel(0): Modeline "1024x768"x75.1 78.80 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.1 kHz)
[ 3060.523] (II) intel(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
[ 3060.523] (II) intel(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
[ 3060.523] (II) intel(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz)
[ 3060.524] (II) intel(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz)
[ 3060.524] (II) intel(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
[ 3060.524] (II) intel(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
[ 3060.524] (II) intel(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
[ 3060.524] (II) intel(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 491 520 -hsync -vsync (37.9 kHz)
[ 3060.524] (II) intel(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
[ 3060.524] (II) intel(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz)
[ 3060.524] (II) intel(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
[ 3060.524] (II) intel(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz)
[ 3060.659] (II) intel(0): EDID for output DVI1
[ 3060.659] (II) intel(0): Output VGA1 connected
[ 3060.659] (II) intel(0): Output DVI1 disconnected
[ 3060.659] (II) intel(0): Using exact sizes for initial modes
[ 3060.659] (II) intel(0): Output VGA1 using initial mode 1600x900
[ 3060.659] (II) intel(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[ 3060.660] (II) intel(0): Kernel page flipping support detected, enabling
[ 3060.660] () intel(0): Display dimensions: (440, 250) mm
[ 3060.660] () intel(0): DPI set to (92, 91)
[ 3060.660] (II) Loading sub module “fb”
[ 3060.660] (II) LoadModule: “fb”
[ 3060.660] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 3060.661] (II) Module fb: vendor=“X.Org Foundation”
[ 3060.661] compiled for 1.10.2, module version = 1.0.0
[ 3060.661] ABI class: X.Org ANSI C Emulation, version 0.4
[ 3060.661] (II) Loading sub module “dri2”
[ 3060.661] (II) LoadModule: “dri2”
[ 3060.662] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[ 3060.662] (II) Module dri2: vendor=“X.Org Foundation”
[ 3060.662] compiled for 1.10.2, module version = 1.2.0
[ 3060.662] ABI class: X.Org Server Extension, version 5.0
[ 3060.662] (==) Depth 24 pixmap format is 32 bpp
[ 3060.662] (II) intel(0): [DRI2] Setup complete
[ 3060.663] (II) intel(0): [DRI2] DRI driver: i915
[ 3060.663] (II) intel(0): Allocated new frame buffer 1600x900 stride 8192, tiled
[ 3060.663] (II) UXA(0): Driver registered support for the following operations:
[ 3060.663] (II) solid
[ 3060.663] (II) copy
[ 3060.663] (II) composite (RENDER acceleration)
[ 3060.663] (II) put_image
[ 3060.663] (II) get_image
[ 3060.663] () intel(0): Option “BackingStore” “true”
[ 3060.663] () intel(0): Backing store enabled
[ 3060.663] (==) intel(0): Silken mouse enabled
[ 3060.663] (II) intel(0): Initializing HW Cursor
[ 3060.696] (II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 3060.697] (==) intel(0): DPMS enabled
[ 3060.697] (II) intel(0): Set up textured video
[ 3060.697] (II) intel(0): Set up overlay video
[ 3060.697] (II) intel(0): direct rendering: DRI2 Enabled
[ 3060.697] (WW) intel(0): Option “XAANoOffscreenPixmaps” is not used
[ 3060.697] (WW) intel(0): Option “AllowGLXWithComposite” is not used
[ 3060.697] (WW) intel(0): Option “TripleBuffer” is not used
[ 3060.697] (WW) intel(0): Option “EnablePageFlip” is not used
[ 3060.697] (WW) intel(0): Option “RenderAccel” is not used
[ 3060.697] (==) intel(0): hotplug detection: “enabled”
[ 3060.698] (–) RandR disabled
[ 3060.698] (II) Initializing built-in extension Generic Event Extension
[ 3060.698] (II) Initializing built-in extension SHAPE
[ 3060.698] (II) Initializing built-in extension MIT-SHM
[ 3060.698] (II) Initializing built-in extension XInputExtension
[ 3060.698] (II) Initializing built-in extension XTEST
[ 3060.698] (II) Initializing built-in extension BIG-REQUESTS
[ 3060.698] (II) Initializing built-in extension SYNC
[ 3060.698] (II) Initializing built-in extension XKEYBOARD
[ 3060.699] (II) Initializing built-in extension XC-MISC
[ 3060.699] (II) Initializing built-in extension SECURITY
[ 3060.699] (II) Initializing built-in extension XINERAMA
[ 3060.699] (II) Initializing built-in extension XFIXES
[ 3060.699] (II) Initializing built-in extension RENDER
[ 3060.699] (II) Initializing built-in extension RANDR
[ 3060.699] (II) Initializing built-in extension COMPOSITE
[ 3060.699] (II) Initializing built-in extension DAMAGE
[ 3060.699] (II) SELinux: Disabled on system
[ 3060.739] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[ 3060.739] (II) AIGLX: enabled GLX_INTEL_swap_event
[ 3060.739] (II) AIGLX: enabled GLX_SGI_swap_control and GLX_MESA_swap_control
[ 3060.739] (II) AIGLX: enabled GLX_SGI_make_current_read
[ 3060.739] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
[ 3060.740] (II) AIGLX: Loaded and initialized /usr/lib/dri/i915_dri.so
[ 3060.740] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 3060.741] (II) intel(0): Setting screen physical size to 423 x 238
[ 3060.895] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 3060.895] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 3060.895] (II) LoadModule: “evdev”
[ 3060.896] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 3060.896] (II) Module evdev: vendor=“X.Org Foundation”
[ 3060.896] compiled for 1.10.1, module version = 2.6.0
[ 3060.896] Module class: X.Org XInput Driver
[ 3060.896] ABI class: X.Org XInput driver, version 12.2
[ 3060.896] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 3060.896] () Power Button: always reports core events
[ 3060.896] () Power Button: Device: “/dev/input/event1”
[ 3060.908] (–) Power Button: Found keys
[ 3060.908] (II) Power Button: Configuring as keyboard
[ 3060.908] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1”
[ 3060.908] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD)
[ 3060.908] () Option “xkb_rules” “evdev”
[ 3060.908] () Option “xkb_model” “pc105”
[ 3060.908] () Option “xkb_layout” “fr”
[ 3060.908] () Option “xkb_variant” “latin9”
[ 3060.908] () Option “xkb_options” “lv3:ralt_switch”
[ 3060.985] (II) config/udev: Adding input device Video Bus (/dev/input/event2)
[ 3060.985] () Video Bus: Applying InputClass “evdev keyboard catchall”
[ 3060.985] (II) Using input driver ‘evdev’ for ‘Video Bus’
[ 3060.985] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 3060.985] () Video Bus: always reports core events
[ 3060.986] () Video Bus: Device: “/dev/input/event2”
[ 3061.004] (–) Video Bus: Found keys
[ 3061.004] (II) Video Bus: Configuring as keyboard
[ 3061.004] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/device:00/PNP0A08:00/LNXVIDEO:00/input/input2/event2”
[ 3061.004] (II) XINPUT: Adding extended input device “Video Bus” (type: KEYBOARD)
[ 3061.004] () Option “xkb_rules” “evdev”
[ 3061.004] () Option “xkb_model” “pc105”
[ 3061.005] () Option “xkb_layout” “fr”
[ 3061.005] () Option “xkb_variant” “latin9”
[ 3061.005] () Option “xkb_options” “lv3:ralt_switch”
[ 3061.019] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 3061.019] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 3061.019] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 3061.019] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 3061.019] () Power Button: always reports core events
[ 3061.019] () Power Button: Device: “/dev/input/event0”
[ 3061.036] (–) Power Button: Found keys
[ 3061.036] (II) Power Button: Configuring as keyboard
[ 3061.036] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0/event0”
[ 3061.036] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD)
[ 3061.036] () Option “xkb_rules” “evdev”
[ 3061.036] () Option “xkb_model” “pc105”
[ 3061.036] () Option “xkb_layout” “fr”
[ 3061.037] () Option “xkb_variant” “latin9”
[ 3061.037] () Option “xkb_options” “lv3:ralt_switch”
[ 3061.046] (II) config/udev: Adding input device HDA Intel Headphone (/dev/input/event7)
[ 3061.046] (II) No input driver/identifier specified (ignoring)
[ 3061.051] (II) config/udev: Adding input device 123456789A123456789B123456789C123456789D123456 (/dev/input/event3)
[ 3061.051] () 123456789A123456789B123456789C123456789D123456: Applying InputClass “evdev pointer catchall”
[ 3061.051] () 123456789A123456789B123456789C123456789D123456: Applying InputClass “evdev keyboard catchall”
[ 3061.051] (II) Using input driver ‘evdev’ for ‘123456789A123456789B123456789C123456789D123456’
[ 3061.052] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 3061.052] () 123456789A123456789B123456789C123456789D123456: always reports core events
[ 3061.052] () 123456789A123456789B123456789C123456789D123456: Device: “/dev/input/event3”
[ 3061.052] (–) 123456789A123456789B123456789C123456789D123456: Found 12 mouse buttons
[ 3061.052] (–) 123456789A123456789B123456789C123456789D123456: Found scroll wheel(s)
[ 3061.052] (–) 123456789A123456789B123456789C123456789D123456: Found relative axes
[ 3061.052] (–) 123456789A123456789B123456789C123456789D123456: Found x and y relative axes
[ 3061.052] (–) 123456789A123456789B123456789C123456789D123456: Found absolute axes
[ 3061.052] (–) 123456789A123456789B123456789C123456789D123456: Found keys
[ 3061.052] (II) 123456789A123456789B123456789C123456789D123456: Configuring as mouse
[ 3061.052] (II) 123456789A123456789B123456789C123456789D123456: Configuring as keyboard
[ 3061.052] (II) 123456789A123456789B123456789C123456789D123456: Adding scrollwheel support
[ 3061.052] () 123456789A123456789B123456789C123456789D123456: YAxisMapping: buttons 4 and 5
[ 3061.052] () 123456789A123456789B123456789C123456789D123456: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 3061.052] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1:1.1/input/input3/event3”
[ 3061.053] (II) XINPUT: Adding extended input device “123456789A123456789B123456789C123456789D123456” (type: KEYBOARD)
[ 3061.053] () Option “xkb_rules” “evdev”
[ 3061.053] () Option “xkb_model” “pc105”
[ 3061.053] () Option “xkb_layout” “fr”
[ 3061.053] () Option “xkb_variant” “latin9”
[ 3061.053] () Option “xkb_options” “lv3:ralt_switch”
[ 3061.053] (II) 123456789A123456789B123456789C123456789D123456: initialized for relative axes.
[ 3061.053] (WW) 123456789A123456789B123456789C123456789D123456: ignoring absolute axes.
[ 3061.054] () 123456789A123456789B123456789C123456789D123456: (accel) keeping acceleration scheme 1
[ 3061.054] () 123456789A123456789B123456789C123456789D123456: (accel) acceleration profile 0
[ 3061.054] () 123456789A123456789B123456789C123456789D123456: (accel) acceleration factor: 2.000
[ 3061.054] () 123456789A123456789B123456789C123456789D123456: (accel) acceleration threshold: 4
[ 3061.055] (II) config/udev: Adding input device 123456789A123456789B123456789C123456789D123456 (/dev/input/mouse0)
[ 3061.055] (II) No input driver/identifier specified (ignoring)
[ 3061.059] (II) config/udev: Adding input device HID 1267:0103 (/dev/input/event4)
[ 3061.059] () HID 1267:0103: Applying InputClass “evdev keyboard catchall”
[ 3061.059] (II) Using input driver ‘evdev’ for ‘HID 1267:0103’
[ 3061.059] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 3061.059] () HID 1267:0103: always reports core events
[ 3061.059] () HID 1267:0103: Device: “/dev/input/event4”
[ 3061.072] (–) HID 1267:0103: Found keys
[ 3061.072] (II) HID 1267:0103: Configuring as keyboard
[ 3061.072] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-2/2-2:1.0/input/input4/event4”
[ 3061.072] (II) XINPUT: Adding extended input device “HID 1267:0103” (type: KEYBOARD)
[ 3061.072] () Option “xkb_rules” “evdev”
[ 3061.072] () Option “xkb_model” “pc105”
[ 3061.072] () Option “xkb_layout” “fr”
[ 3061.072] () Option “xkb_variant” “latin9”
[ 3061.073] () Option “xkb_options” “lv3:ralt_switch”
[ 3061.077] (II) config/udev: Adding input device HID 1267:0103 (/dev/input/event5)
[ 3061.077] () HID 1267:0103: Applying InputClass “evdev keyboard catchall”
[ 3061.077] (II) Using input driver ‘evdev’ for ‘HID 1267:0103’
[ 3061.077] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 3061.077] () HID 1267:0103: always reports core events
[ 3061.077] () HID 1267:0103: Device: “/dev/input/event5”
[ 3061.078] (–) HID 1267:0103: Found 1 mouse buttons
[ 3061.078] (–) HID 1267:0103: Found scroll wheel(s)
[ 3061.078] (–) HID 1267:0103: Found relative axes
[ 3061.078] (–) HID 1267:0103: Found absolute axes
[ 3061.078] (–) HID 1267:0103: Found keys
[ 3061.078] (II) HID 1267:0103: Configuring as mouse
[ 3061.078] (II) HID 1267:0103: Configuring as keyboard
[ 3061.078] (II) HID 1267:0103: Adding scrollwheel support
[ 3061.078] () HID 1267:0103: YAxisMapping: buttons 4 and 5
[ 3061.078] () HID 1267:0103: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 3061.079] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-2/2-2:1.1/input/input5/event5”
[ 3061.079] (II) XINPUT: Adding extended input device “HID 1267:0103” (type: KEYBOARD)
[ 3061.079] () Option “xkb_rules” “evdev”
[ 3061.079] () Option “xkb_model” “pc105”
[ 3061.079] () Option “xkb_layout” “fr”
[ 3061.079] () Option “xkb_variant” “latin9”
[ 3061.079] () Option “xkb_options” “lv3:ralt_switch”
[ 3061.080] (EE) HID 1267:0103: failed to initialize for relative axes.
[ 3061.081] (II) HID 1267:0103: initialized for absolute axes.
[ 3061.081] () HID 1267:0103: (accel) keeping acceleration scheme 1
[ 3061.081] () HID 1267:0103: (accel) acceleration profile 0
[ 3061.081] () HID 1267:0103: (accel) acceleration factor: 2.000
[ 3061.081] (**) HID 1267:0103: (accel) acceleration threshold: 4
[ 3061.097] (II) config/udev: Adding input device PC Speaker (/dev/input/event6)
[ 3061.097] (II) No input driver/identifier specified (ignoring)
[ 3072.748] (II) intel(0): EDID vendor “PKB”, prod id 194
[ 3072.748] (II) intel(0): Using hsync ranges from config file
[ 3072.748] (II) intel(0): Using vrefresh ranges from config file
[ 3072.748] (II) intel(0): Printing DDC gathered Modelines:
[ 3072.748] (II) intel(0): Modeline "1600x900"x0.0 118.25 1600 1688 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz)
[ 3072.748] (II) intel(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
[ 3072.748] (II) intel(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
[ 3072.748] (II) intel(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
[ 3072.749] (II) intel(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz)
[ 3072.749] (II) intel(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz)
[ 3072.749] (II) intel(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
[ 3072.749] (II) intel(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz)
[ 3072.749] (II) intel(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz)
[ 3072.749] (II) intel(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
[ 3072.749] (II) intel(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
[ 3072.749] (II) intel(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz)
[ 3072.749] (II) intel(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
[ 3072.749] (II) intel(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz)
[ 3072.749] (II) intel(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz)
[ 3072.749] (II) intel(0): Modeline "1280x720"x60.0 74.48 1280 1336 1472 1664 720 721 724 746 -hsync +vsync (44.8 kHz)
[ 3072.749] (II) intel(0): Modeline "1280x800"x0.0 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz)
[ 3085.340] (II) intel(0): EDID vendor “PKB”, prod id 194
[ 3085.340] (II) intel(0): Using hsync ranges from config file
[ 3085.340] (II) intel(0): Using vrefresh ranges from config file
[ 3085.340] (II) intel(0): Printing DDC gathered Modelines:
[ 3085.340] (II) intel(0): Modeline "1600x900"x0.0 118.25 1600 1688 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz)
[ 3085.340] (II) intel(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
[ 3085.340] (II) intel(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
[ 3085.340] (II) intel(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
[ 3085.341] (II) intel(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz)
[ 3085.341] (II) intel(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz)
[ 3085.341] (II) intel(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
[ 3085.341] (II) intel(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz)
[ 3085.341] (II) intel(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz)
[ 3085.341] (II) intel(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
[ 3085.341] (II) intel(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
[ 3085.341] (II) intel(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz)
[ 3085.341] (II) intel(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
[ 3085.341] (II) intel(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz)
[ 3085.341] (II) intel(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz)
[ 3085.341] (II) intel(0): Modeline "1280x720"x60.0 74.48 1280 1336 1472 1664 720 721 724 746 -hsync +vsync (44.8 kHz)
[ 3085.341] (II) intel(0): Modeline "1280x800"x0.0 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz)
Merci à toi en tous cas pour ton aide
