Interface ethernet invisible
Bonjour!
Je viens de remarquer un truc : l’interface ethernet de mon portable n’apparait plus, ni dans un ifconfig, ni dans un lspci.
J’ai peur de dire une bêtise, mais c’est sans doute depuis que les noyaux sont déblobbés.
Mon portable est un dell 1546.
Voici tout de même le retour de lspci, en espérant n’avoir rien débranché en enlevant la poussière des ventilos :
lspci 00:00.0 Host bridge: Advanced Micro Devices [AMD] RS780 Host Bridge 00:02.0 PCI bridge: Advanced Micro Devices [AMD] RS780 PCI to PCI bridge (ext gfx por t 0) 00:05.0 PCI bridge: Advanced Micro Devices [AMD] RS780 PCI to PCI bridge (PCIE port 1 ) 00:06.0 PCI bridge: Advanced Micro Devices [AMD] RS780 PCI to PCI bridge (PCIE port 2 ) 00:07.0 PCI bridge: Advanced Micro Devices [AMD] RS780 PCI to PCI bridge (PCIE port 3 ) 00:11.0 SATA controller: ATI Technologies Inc SB700/SB800 SATA Controller [IDE mode] 00:12.0 USB Controller: ATI Technologies Inc SB700/SB800 USB OHCI0 Controller 00:12.1 USB Controller: ATI Technologies Inc SB700 USB OHCI1 Controller 00:12.2 USB Controller: ATI Technologies Inc SB700/SB800 USB EHCI Controller 00:13.0 USB Controller: ATI Technologies Inc SB700/SB800 USB OHCI0 Controller 00:13.1 USB Controller: ATI Technologies Inc SB700 USB OHCI1 Controller 00:13.2 USB Controller: ATI Technologies Inc SB700/SB800 USB EHCI Controller 00:14.0 SMBus: ATI Technologies Inc SBx00 SMBus Controller (rev 3a) 00:14.2 Audio device: ATI Technologies Inc SBx00 Azalia (Intel HDA) 00:14.3 ISA bridge: ATI Technologies Inc SB700/SB800 LPC host controller 00:14.4 PCI bridge: ATI Technologies Inc SBx00 PCI to PCI Bridge 00:18.0 Host bridge: Advanced Micro Devices [AMD] Family 11h Processor HyperTransport Configuration (rev 40) 00:18.1 Host bridge: Advanced Micro Devices [AMD] Family 11h Processor Address Map 00:18.2 Host bridge: Advanced Micro Devices [AMD] Family 11h Processor DRAM Controlle r 00:18.3 Host bridge: Advanced Micro Devices [AMD] Family 11h Processor Miscellaneous Control 00:18.4 Host bridge: Advanced Micro Devices [AMD] Family 11h Processor Link Control 02:00.0 VGA compatible controller: ATI Technologies Inc M92 LP [Mobility Radeon HD 43 00 Series] 0b:00.0 Network controller: Broadcom Corporation BCM4312 802.11b/g LP-PHY (rev 01)
Où chercher? Car même si c’est un pilote qui manque, comme lspci ne me dit rien, je ne sais pas lequel chercher… :confused:
Même avec
ifconfig -a ?
Eh oui…
[code]# ifconfig -a
lo Link encap:Boucle locale
adr inet6: ::1/128 Scope:Hôte
RX packets:1761 errors:0 dropped:0 overruns:0 frame:0
TX packets:1761 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:208184 (203.3 KiB) TX bytes:208184 (203.3 KiB)
wlan0 Link encap:Ethernet HWaddr 70:1a:04:e7:79:dd
inet adr:192.168.0.11 Bcast:192.168.0.255 Masque:255.255.255.0
adr inet6: fe80::721a:4ff:fee7:79dd/64 Scope:Lien
RX packets:1407 errors:0 dropped:0 overruns:0 frame:0
TX packets:1435 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:459382 (448.6 KiB) TX bytes:178995 (174.7 KiB)
hum…
Pas dans lspci ni dans ifconfig -a…
Désactivée dans le bios ?
Sinon… elle ne pourrait pas être cramée ? Quand tu branche un câble ça réagit ?
Puisque tu supposes qu’un ancien noyau à blob était capable de le détecter et de le régler, démarres en un tout d’abord pour t’assurer que le circuit ethernet n’est pas désactivé par le BIOS et ensuite pour pouvoir comparer le retour de $ lspci, $lsmod, # ifconfig -a …
Si tu as viré tous tes anciens noyaux, démarres sur un bon vieux knoppix.
Avant de démarrer un ancien noyau, note les modules chargés par le noyau “déblobé”.
$ lsmod > modules_2.6.XX_sans_blob.txt
Puis noyau à blob démarré
$ lsmod > modules_2.6.YY_avec_blob.txt
Comparaisons
$ diff modules_2.6.XX_sans_blob.txt modules_2.6.YY_avec_blob.txt
$ diff /lib/modules/2.6.XX /lib/modules/2.6.YY
Au delà des modules
$ diff /boot/config-2.6.XX /boot/config-2.6.YY
Cramée? Hé ho, me fait pas peur hein :slightly_smiling:
Non, je n’ai pas d’option dans le bios de toute façon pour gérer l’ethernet.
Quelle réaction dois-je m’attendre quand je branche un cable? Parce que rien ne se passe tout simplement, l’interface n’est pas mieux détectée :slightly_smiling: .
Bon, c’est la matos qui est fichu on dirais. Je ne sais pas comment je pourrais le réparer, faut espérer que le wifi continue de fonctionner.
Je viens de tester avec le firmwares-linux-nonfree (qui contiennent les anciens blobs)… Ben pas mieux.
Re,
Manifestement la carte n’est pas alimentée…
Si tu as démarré sur un noyau “classique” et que tu ne vois pas plus ta carte, ce n’est pas bon signe quand même…
Je dirais que c’est matériel.
Je suis étonné que le bios ne propose rien pour activer ou désactiver les périphériques.
[quote=“lol”]Re,
Je suis étonné que le bios ne propose rien pour activer ou désactiver les périphériques.[/quote]
Le bios a des options pour le bluetooth, le wifi, l’usb… mais rien pour l’ethernet.
Bon, je vais ouvrir la machine et chercher l’ethernet voir comment il se porte.
Est elle listée ci dessous …
cat /etc/udev/rules.d/70-persistent-net.rules
As tu essayé avec un CD live tout bêtement (ou une clef USB boutable)
J’avais essayé avec un live cd plutot ancien (dynebolic), et toujours rien.
Bon, j’ai revérifié tous les branchements, ça a l’air d’aller. De plus, je n’ai pas senti le cramé.
Pour être sûr, j’ai fait une “réinitialisation du bios”, tout remis à defaut. Et devinez quoi… L’ethernet est détecté désormais!
Lol, tu avais raison visiblement. Je ne trouve toujours pas l’option du bios que j’ai pu désactiver (en même temps, le bios de dell… Un truc que tu gères à la souris, pouah!), mais c’était ça, la carte elle se porte bien.
Merci à tous !
Et désolé du dérangement…
