Voici mon /var/log/messages d’aujourd’hui, je ne vois rien de plus que la dernière ligne d’étrange (désolé c’est un peu long, merci):
Dec 20 20:48:01 localhost syslogd 1.4.1#17: restart.
Dec 20 20:48:02 localhost kernel: klogd 1.4.1#17, log source = /proc/kmsg started.
Dec 20 20:48:02 localhost kernel: Inspecting /boot/System.map-2.4.27-2-386
Dec 20 20:48:02 localhost kernel: Loaded 18328 symbols from /boot/System.map-2.4.27-2-386.
Dec 20 20:48:02 localhost kernel: Symbols match kernel version 2.4.27.
Dec 20 20:48:02 localhost kernel: Loaded 1055 symbols from 28 modules.
Dec 20 20:48:02 localhost kernel: Linux version 2.4.27-2-386 (horms@tabatha.lab.ultramonkey.org) (gcc version 3.3.6 (Debian 1:3.3.6-8)) #1 Tue Aug 16 15:28:25 JST 2005
Dec 20 20:48:02 localhost kernel: BIOS-provided physical RAM map:
Dec 20 20:48:02 localhost kernel: BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
Dec 20 20:48:02 localhost kernel: BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
Dec 20 20:48:02 localhost kernel: BIOS-e820: 00000000000e8000 - 0000000000100000 (reserved)
Dec 20 20:48:02 localhost kernel: BIOS-e820: 0000000000100000 - 000000000eff0000 (usable)
Dec 20 20:48:02 localhost kernel: BIOS-e820: 000000000eff0000 - 000000000eff8000 (ACPI data)
Dec 20 20:48:02 localhost kernel: BIOS-e820: 000000000eff8000 - 000000000f000000 (ACPI NVS)
Dec 20 20:48:02 localhost kernel: BIOS-e820: 00000000ffef0000 - 00000000fff00000 (reserved)
Dec 20 20:48:02 localhost kernel: BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
Dec 20 20:48:02 localhost kernel: 239MB LOWMEM available.
Dec 20 20:48:02 localhost kernel: On node 0 totalpages: 61424
Dec 20 20:48:02 localhost kernel: zone(0): 4096 pages.
Dec 20 20:48:02 localhost kernel: zone(1): 57328 pages.
Dec 20 20:48:02 localhost kernel: zone(2): 0 pages.
Dec 20 20:48:02 localhost kernel: ACPI disabled because your bios is from 97 and too old
Dec 20 20:48:02 localhost kernel: You can enable it with acpi=force
Dec 20 20:48:02 localhost kernel: Kernel command line: root=/dev/hda6 ro
Dec 20 20:48:02 localhost kernel: Local APIC disabled by BIOS -- reenabling.
Dec 20 20:48:02 localhost kernel: Found and enabled local APIC!
Dec 20 20:48:02 localhost kernel: Initializing CPU#0
Dec 20 20:48:02 localhost kernel: Detected 1097.256 MHz processor.
Dec 20 20:48:02 localhost kernel: Console: colour VGA+ 80x25
Dec 20 20:48:02 localhost kernel: Calibrating delay loop... 2188.90 BogoMIPS
Dec 20 20:48:02 localhost kernel: Memory: 239424k/245696k available (1069k kernel code, 5884k reserved, 459k data, 96k init, 0k highmem)
Dec 20 20:48:02 localhost kernel: Dentry cache hash table entries: 32768 (order: 6, 262144 bytes)
Dec 20 20:48:02 localhost kernel: Inode cache hash table entries: 16384 (order: 5, 131072 bytes)
Dec 20 20:48:02 localhost kernel: Mount cache hash table entries: 512 (order: 0, 4096 bytes)
Dec 20 20:48:02 localhost kernel: Buffer cache hash table entries: 16384 (order: 4, 65536 bytes)
Dec 20 20:48:02 localhost kernel: Page-cache hash table entries: 65536 (order: 6, 262144 bytes)
Dec 20 20:48:02 localhost kernel: CPU: L1 I cache: 16K, L1 D cache: 16K
Dec 20 20:48:02 localhost kernel: CPU: L2 cache: 256K
Dec 20 20:48:02 localhost kernel: CPU serial number disabled.
Dec 20 20:48:02 localhost kernel: CPU: Intel Pentium III (Coppermine) stepping 0a
Dec 20 20:48:02 localhost kernel: Enabling fast FPU save and restore... done.
Dec 20 20:48:02 localhost kernel: Enabling unmasked SIMD FPU exception support... done.
Dec 20 20:48:02 localhost kernel: Checking 'hlt' instruction... OK.
Dec 20 20:48:02 localhost kernel: Checking for popad bug... OK.
Dec 20 20:48:02 localhost kernel: POSIX conformance testing by UNIFIX
Dec 20 20:48:02 localhost kernel: enabled ExtINT on CPU#0
Dec 20 20:48:02 localhost kernel: ESR value before enabling vector: 00000000
Dec 20 20:48:02 localhost kernel: ESR value after enabling vector: 00000000
Dec 20 20:48:02 localhost kernel: Using local APIC timer interrupts.
Dec 20 20:48:02 localhost kernel: calibrating APIC timer ...
Dec 20 20:48:02 localhost kernel: ..... CPU clock speed is 1097.2411 MHz.
Dec 20 20:48:02 localhost kernel: ..... host bus clock speed is 99.7491 MHz.
Dec 20 20:48:02 localhost kernel: cpu: 0, clocks: 997491, slice: 498745
Dec 20 20:48:02 localhost kernel: CPU0<T0:997488,T1:498736,D:7,S:498745,C:997491>
Dec 20 20:48:02 localhost kernel: ACPI: Subsystem revision 20040326
Dec 20 20:48:02 localhost kernel: ACPI: Interpreter disabled.
Dec 20 20:48:02 localhost kernel: PCI: PCI BIOS revision 2.10 entry at 0xfdb31, last bus=1
Dec 20 20:48:02 localhost kernel: PCI: Using configuration type 1
Dec 20 20:48:02 localhost kernel: PCI: Probing PCI hardware
Dec 20 20:48:02 localhost kernel: PCI: Probing PCI hardware (bus 00)
Dec 20 20:48:02 localhost kernel: PCI: Using IRQ router SIS5595 [1039/0008] at 00:01.0
Dec 20 20:48:02 localhost kernel: PCI: Found IRQ 11 for device 00:03.0
Dec 20 20:48:02 localhost kernel: PCI: Sharing IRQ 11 with 00:01.4
Dec 20 20:48:02 localhost kernel: Linux NET4.0 for Linux 2.4
Dec 20 20:48:02 localhost kernel: Based upon Swansea University Computer Society NET3.039
Dec 20 20:48:02 localhost kernel: Initializing RT netlink socket
Dec 20 20:48:02 localhost kernel: Starting kswapd
Dec 20 20:48:02 localhost kernel: VFS: Disk quotas vdquot_6.5.1
Dec 20 20:48:02 localhost kernel: devfs: v1.12c (20020818) Richard Gooch (rgooch@atnf.csiro.au)
Dec 20 20:48:02 localhost kernel: devfs: boot_options: 0x0
Dec 20 20:48:02 localhost kernel: pty: 256 Unix98 ptys configured
Dec 20 20:48:02 localhost kernel: Serial driver version 5.05c (2001-07-08) with HUB-6 MANY_PORTS MULTIPORT SHARE_IRQ SERIAL_PCI enabled
Dec 20 20:48:02 localhost kernel: PCI: Found IRQ 10 for device 00:01.6
Dec 20 20:48:02 localhost kernel: PCI: Sharing IRQ 10 with 00:01.1
Dec 20 20:48:02 localhost kernel: COMX: driver version 0.85 (C) 1995-1999 ITConsult-Pro Co. <info@itc.hu>
Dec 20 20:48:02 localhost kernel: RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
Dec 20 20:48:02 localhost kernel: Initializing Cryptographic API
Dec 20 20:48:02 localhost kernel: NET4: Linux TCP/IP 1.0 for NET4.0
Dec 20 20:48:02 localhost kernel: IP: routing cache hash table of 2048 buckets, 16Kbytes
Dec 20 20:48:02 localhost kernel: TCP: Hash tables configured (established 16384 bind 32768)
Dec 20 20:48:02 localhost kernel: Linux IP multicast router 0.06 plus PIM-SM
Dec 20 20:48:02 localhost kernel: RAMDISK: cramfs filesystem found at block 0
Dec 20 20:48:02 localhost kernel: RAMDISK: Loading 1316 blocks [1 disk] into ram disk... |^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^H\^H|^H/^H-^Hdone.
Dec 20 20:48:02 localhost kernel: Freeing initrd memory: 1316k freed
Dec 20 20:48:02 localhost kernel: VFS: Mounted root (cramfs filesystem).
Dec 20 20:48:02 localhost kernel: Freeing unused kernel memory: 96k freed
Dec 20 20:48:02 localhost kernel: NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
Dec 20 20:48:02 localhost kernel: Uniform Multi-Platform E-IDE driver Revision: 7.00beta4-2.4
Dec 20 20:48:02 localhost kernel: ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
Dec 20 20:48:02 localhost kernel: SIS5513: IDE controller at PCI slot 00:00.1
Dec 20 20:48:02 localhost kernel: SIS5513: chipset revision 208
Dec 20 20:48:02 localhost kernel: SIS5513: not 100%% native mode: will probe irqs later
Dec 20 20:48:02 localhost kernel: SIS5513: SiS630 ATA 100 (1st gen) controller
Dec 20 20:48:02 localhost kernel: ide0: BM-DMA at 0xff00-0xff07, BIOS settings: hda:DMA, hdb:DMA
Dec 20 20:48:02 localhost kernel: ide1: BM-DMA at 0xff08-0xff0f, BIOS settings: hdc:DMA, hdd:DMA
Dec 20 20:48:02 localhost kernel: hda: FUJITSU MHN2200AT, ATA DISK drive
Dec 20 20:48:02 localhost kernel: blk: queue cf825b60, I/O limit 4095Mb (mask 0xffffffff)
Dec 20 20:48:02 localhost kernel: hdc: UJDA710, ATAPI CD/DVD-ROM drive
Dec 20 20:48:02 localhost kernel: ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Dec 20 20:48:02 localhost kernel: ide1 at 0x170-0x177,0x376 on irq 15
Dec 20 20:48:02 localhost kernel: hda: attached ide-disk driver.
Dec 20 20:48:02 localhost kernel: hda: 39070080 sectors (20004 MB) w/2048KiB Cache, CHS=38760/16/63, UDMA(33)
Dec 20 20:48:02 localhost kernel: Partition check:
Dec 20 20:48:02 localhost kernel: /dev/ide/host0/bus0/target0/lun0: p1 p3 < p5 p6 >
Dec 20 20:48:02 localhost kernel: Journalled Block Device driver loaded
Dec 20 20:48:02 localhost kernel: kjournald starting. Commit interval 5 seconds
Dec 20 20:48:02 localhost kernel: EXT3-fs: mounted filesystem with ordered data mode.
Dec 20 20:48:02 localhost kernel: Adding Swap: 175856k swap-space (priority -1)
Dec 20 20:48:02 localhost kernel: EXT3 FS 2.4-0.9.19, 19 August 2002 on ide0(3,6), internal journal
Dec 20 20:48:02 localhost kernel: hdc: attached ide-cdrom driver.
Dec 20 20:48:02 localhost kernel: hdc: ATAPI 24X DVD-ROM CD-R/RW drive, 2048kB Cache, UDMA(33)
Dec 20 20:48:02 localhost kernel: Uniform CD-ROM driver Revision: 3.12
Dec 20 20:48:02 localhost kernel: usb.c: registered new driver usbdevfs
Dec 20 20:48:02 localhost kernel: usb.c: registered new driver hub
Dec 20 20:48:02 localhost kernel: ndiswrapper version 1.1 loaded (preempt=no,smp=no)
Dec 20 20:48:02 localhost kernel: SCSI subsystem driver Revision: 1.00
Dec 20 20:48:02 localhost kernel: Initializing USB Mass Storage driver...
Dec 20 20:48:02 localhost kernel: usb.c: registered new driver usb-storage
Dec 20 20:48:02 localhost kernel: USB Mass Storage support registered.
Dec 20 20:48:02 localhost kernel: Real Time Clock Driver v1.10f
Dec 20 20:48:02 localhost kernel: apm: BIOS not found.
Dec 20 20:48:02 localhost kernel: Linux agpgart interface v0.99 (c) Jeff Hartmann
Dec 20 20:48:02 localhost kernel: agpgart: Maximum main memory to use for agp memory: 189M
Dec 20 20:48:02 localhost kernel: agpgart: Detected SiS 630 chipset
Dec 20 20:48:02 localhost kernel: agpgart: AGP aperture is 64M @ 0xe0000000
Dec 20 20:48:02 localhost kernel: Linux Kernel Card Services 3.1.22
Dec 20 20:48:02 localhost kernel: options: [pci] [cardbus] [pm]
Dec 20 20:48:02 localhost kernel: Yenta ISA IRQ mask 0x00b8, PCI irq 11
Dec 20 20:48:02 localhost kernel: Socket status: 30000821
Dec 20 20:48:02 localhost kernel: sis900.c: v1.08.07 11/02/2003
Dec 20 20:48:02 localhost kernel: PCI: Found IRQ 10 for device 00:01.1
Dec 20 20:48:02 localhost kernel: PCI: Sharing IRQ 10 with 00:01.6
Dec 20 20:48:02 localhost kernel: 00:01.1: Realtek RTL8201 PHY transceiver found at address 1.
Dec 20 20:48:02 localhost kernel: 00:01.1: Using transceiver found at address 1 as default
Dec 20 20:48:02 localhost kernel: eth0: SiS 900 PCI Fast Ethernet at 0xd000, IRQ 10, 00:a0:cc:cc:43:3b.
Dec 20 20:48:02 localhost kernel: scsi0 : SCSI host adapter emulation for IDE ATAPI devices
Dec 20 20:48:02 localhost kernel: Trident 4DWave/SiS 7018/ALi 5451,Tvia CyberPro 5050 PCI Audio, version 0.14.10h, 15:45:38 Aug 16 2005
Dec 20 20:48:02 localhost kernel: PCI: Found IRQ 11 for device 00:01.4
Dec 20 20:48:02 localhost kernel: PCI: Sharing IRQ 11 with 00:03.0
Dec 20 20:48:02 localhost kernel: trident: SiS 7018 PCI Audio found at IO 0xd400, IRQ 11
Dec 20 20:48:02 localhost kernel: ac97_codec: AC97 Audio codec, id: ALG16 (ALC200/200P)
Dec 20 20:48:02 localhost kernel: ac97_codec: AC97 Modem codec, id: SIL34 (Silicon Laboratory Si3036)
Dec 20 20:48:02 localhost kernel: PCI: Found IRQ 9 for device 00:01.2
Dec 20 20:48:02 localhost kernel: PCI: Sharing IRQ 9 with 00:01.3
Dec 20 20:48:02 localhost kernel: usb-ohci.c: USB OHCI at membase 0xcf928000, IRQ 9
Dec 20 20:48:02 localhost kernel: usb-ohci.c: usb-00:01.2, Silicon Integrated Systems [SiS] USB 1.0 Controller
Dec 20 20:48:02 localhost kernel: usb.c: new USB bus registered, assigned bus number 1
Dec 20 20:48:02 localhost kernel: hub.c: USB hub found
Dec 20 20:48:02 localhost kernel: hub.c: 3 ports detected
Dec 20 20:48:02 localhost kernel: PCI: Found IRQ 9 for device 00:01.3
Dec 20 20:48:02 localhost kernel: PCI: Sharing IRQ 9 with 00:01.2
Dec 20 20:48:02 localhost kernel: usb-ohci.c: USB OHCI at membase 0xcf92a000, IRQ 9
Dec 20 20:48:02 localhost kernel: usb-ohci.c: usb-00:01.3, Silicon Integrated Systems [SiS] USB 1.0 Controller (#2)
Dec 20 20:48:02 localhost kernel: usb.c: new USB bus registered, assigned bus number 2
Dec 20 20:48:02 localhost kernel: hub.c: new USB device 00:01.2-1, assigned address 2
Dec 20 20:48:02 localhost kernel: usb.c: USB device 2 (vend/prod 0x44f/0xb303) is not claimed by any active driver.
Dec 20 20:48:02 localhost kernel: cs: cb_alloc(bus 2): vendor 0x11ab, device 0x1faa
Dec 20 20:48:02 localhost kernel: PCI: Enabling device 02:00.0 (0000 -> 0002)
Dec 20 20:48:02 localhost kernel: ndiswrapper: driver wg511v2 (NETGEAR,09/17/2004,3.1.0.19) loaded
Dec 20 20:48:02 localhost kernel: ndiswrapper: using irq 11
Dec 20 20:48:02 localhost kernel: wlan0: ndiswrapper ethernet device 00:0f:b5:4c:0c:d8 using driver wg511v2, configuration file 11AB:1FAA:1385:4E00.5.conf
Dec 20 20:48:02 localhost kernel: wlan0: encryption modes supported: WEP, WPA with TKIP
Dec 20 20:48:02 localhost kernel: cs: IO port probe 0x0100-0x04ff: excluding 0x378-0x37f 0x480-0x48f 0x4d0-0x4d7
Dec 20 20:48:02 localhost kernel: cs: IO port probe 0x0800-0x08ff: clean.
Dec 20 20:48:02 localhost kernel: cs: IO port probe 0x0c00-0x0cff: clean.
Dec 20 20:48:02 localhost kernel: cs: IO port probe 0x0a00-0x0aff: clean.
Dec 20 20:48:03 localhost lpd[890]: restarted
Dec 20 20:48:06 localhost Xprt_64: cat: /var/run/Xprt_0.pid: No such file or directory
Dec 20 20:48:11 localhost kernel: apm: BIOS not found.
Dec 20 20:48:14 localhost kernel: sisfb: Video ROM found and mapped to 0xc00c0000
Dec 20 20:48:14 localhost kernel: sisfb: Framebuffer at 0xd0000000, mapped to 0xcfa4b000, size 16384k
Dec 20 20:48:14 localhost kernel: sisfb: MMIO at 0xdfee0000, mapped to 0xd0a4c000, size 128k
Dec 20 20:48:14 localhost kernel: sisfb: Memory heap starting at 8192K, size 7672K
Dec 20 20:48:14 localhost kernel: [drm] AGP 0.99 Aperture @ 0xe0000000 64MB
Dec 20 20:48:14 localhost kernel: [drm] Initialized sis 1.0.0 20010503 on minor 0
Dec 20 20:48:41 localhost gconfd (gort-1227): démarrage (version 2.10.1), pid 1227 utilisateur « gort »
Dec 20 20:48:41 localhost gconfd (gort-1227): Adresse « xml:readonly:/etc/gconf/gconf.xml.mandatory » résolue vers une source de configuration en lecture seule à la position 0
Dec 20 20:48:41 localhost gconfd (gort-1227): Adresse « xml:readonly:/usr/share/gconf/local.mandatory » résolue vers une source de configuration en lecture seule à la position 1
Dec 20 20:48:41 localhost gconfd (gort-1227): Adresse « xml:readwrite:/home/gort/.gconf » résolue vers une source de configuration accessible en écriture à la position 2
Dec 20 20:48:41 localhost gconfd (gort-1227): Adresse « xml:readonly:/etc/gconf/gconf.xml.defaults » résolue vers une source de configuration en lecture seule à la position 3
Dec 20 20:48:41 localhost gconfd (gort-1227): Adresse « xml:readonly:/usr/share/gconf/local.defaults » résolue vers une source de configuration en lecture seule à la position 4
Dec 20 20:48:41 localhost gconfd (gort-1227): Adresse « xml:readonly:/usr/share/gconf/cdd.defaults » résolue vers une source de configuration en lecture seule à la position 5
Dec 20 20:48:41 localhost gconfd (gort-1227): Adresse « xml:readonly:/usr/share/gconf/debian.defaults » résolue vers une source de configuration en lecture seule à la position 6
Dec 20 20:48:41 localhost gconfd (gort-1227): Adresse « xml:readonly:/var/lib/gconf/defaults » résolue vers une source de configuration en lecture seule à la position 7
Dec 20 20:48:57 localhost gconfd (gort-1227): Adresse « xml:readwrite:/home/gort/.gconf » résolue vers une source de configuration accessible en écriture à la position 0
Dec 20 21:08:01 localhost -- MARK --
Dec 20 21:16:26 localhost kernel: ndiswrapper (set_essid:58): setting essid failed (C0000001)
