salem alikoum
j’ai installé intermapper_5.2~b2-3.1-1_i386 avec dpkg; quant j’essaie de le lancer une erreur s’affiche :
[color=#0000FF]InterMapper is unable to locate the Java software on this system. Java is required to run InterMapper. We found a Java interpreter in /usr/bin/java, but it is a version of GCJ or OpenJDK, which is not supported. Please visit ‘java.com’ to download and install the Java Software, then re-run this program.
If you have installed Java in a non-standard location, please set the environment variable ‘INTERMAPPER_JAVA’ to the full path name of your ‘java’ executable, then re-run this program.[/color]
je ne sais pas quelle version de java qu’ilfaut telecharger et installer.
merci pour l’aide
Normalement l’aide devrait provenir du service commercial de cette société
