Voyez vous une raison à cela ?
Ces ip sont bloqués, soit par fail2ban soit par ModSecurity et pourtant iptstate me les affiches comme actives.
[quote]Aug 13 00:10:32 DOMAINE sshd[1278]: Did not receive identification string from 181.6.224.139
[Wed Aug 14 16:06:07 2013] [error] [client 65.55.52.111] ModSecurity: Access denied with code 403 (phase 2). Match of "rx …
Aug 15 20:20:10 DOMAINE sshd[9751]: warning: /etc/hosts.allow, line 14: host name/address mismatch: 221.143.48.185 != 221-143-48-185.tongkni.co.kr
Aug 15 20:20:10 DOMAINE sshd[9751]: Did not receive identification string from 221.143.48.185
Connexions Internet actives (serveurs et établies)
Proto Recv-Q Send-Q Adresse locale Adresse distante Etat User Inode PID/Program name
tcp 0 0 DOMAINE.com:domain *:* LISTEN bind 97929198 21760/named
tcp 0 0 *:munin *:* LISTEN root 10582 2792/munin-node
tcp 0 0 localhost.locald:domain *:* LISTEN root 4509 1747/pdnsd
tcp 0 0 *:ssh *:* LISTEN root 77366304 19760/sshd
tcp 0 0 *:3000 *:* LISTEN root 42848971 15549/ntop
tcp 0 0 localhost.localdoma:953 *:* LISTEN bind 97929201 21760/named
tcp 0 48 DOMAINE.com:ssh xxx.xxx.xxx.xxx-:43194 ESTABLISHED root 112988580 17429/sshd: USER
tcp6 0 0 [::]:domain [::]:* LISTEN bind 97929192 21760/named
tcp6 0 0 [::]:ssh [::]:* LISTEN root 77366306 19760/sshd
tcp6 0 0 ip6-localhost:953 [::]:* LISTEN bind 97929202 21760/named
udp 0 0 DOMAINE.com:domain *:* bind 97929197 21760/named
udp 0 0 localhost.locald:domain *:* root 4510 1747/pdnsd
udp 0 0 DOMAINE.com:ntp *:* root 8069 2596/ntpd
udp 0 0 localhost.localdoma:ntp *:* root 8068 2596/ntpd
udp 0 0 *:ntp *:* root 8061 2596/ntpd
udp 0 0 localhost.localdoma:921 *:* root 97929247 21787/lwresd
udp6 0 0 [::]:domain [::]:* bind 97929191 21760/named
udp6 0 0 fe80::222:4dff:fe7a:ntp [::]:* root 8072 2596/ntpd
udp6 0 0 ip6-localhost:ntp [::]:* root 8071 2596/ntpd
udp6 0 0 2001:41d0:8:7825::1:ntp [::]:* root 8070 2596/ntpd
udp6 0 0 [::]:ntp [::]:* root 8062 2596/ntpd
ps:
~ # uptime
11:05:32 up 134 days, 15:56, 1 user, load average: 0.18, 0.10, 0.05
