Merci de m’ avoir répondu alors,
j ai regardé en long large et en travers j y comprend rien j ai trouve ce fil qui parle du même
problème enfin de ce que j en ai compris car moi et l anglais :smt003
http://archives.free.net.ph/thread/20090819.214656.a788e2f0.fr.html
j’ ai installer le dernier noyau 2.6.31-1-686 le problème reste le même flood de mon syslog et messages
sauf quil dit plus pareil enfin bref voici la sortie de certaine commande si vous avez une idée car la
suis un peu paumé merci.
cat /proc/interrupts
CPU0 CPU1
0: 46 0 IO-APIC-edge timer
1: 3132 0 IO-APIC-edge i8042
4: 2 0 IO-APIC-edge
7: 0 0 IO-APIC-edge parport0
8: 2 0 IO-APIC-edge rtc0
9: 0 0 IO-APIC-fasteoi acpi
14: 0 0 IO-APIC-edge ide0
15: 0 0 IO-APIC-edge ide1
17: 25593 0 IO-APIC-fasteoi HDA Intel
19: 6845 0 IO-APIC-fasteoi eth0
20: 0 0 IO-APIC-fasteoi uhci_hcd:usb1
21: 17198 0 IO-APIC-fasteoi sata_via, uhci_hcd:usb3, ehci_hcd:usb5
22: 49911 0 IO-APIC-fasteoi uhci_hcd:usb2
23: 0 0 IO-APIC-fasteoi uhci_hcd:usb4
48: 0 0 PCI-MSI-edge aerdrv
NMI: 0 0 Non-maskable interrupts
LOC: 272830 387832 Local timer interrupts
SPU: 0 0 Spurious interrupts
CNT: 0 0 Performance counter interrupts
PND: 0 0 Performance pending work
RES: 2820 4494 Rescheduling interrupts
CAL: 22 153 Function call interrupts
TLB: 14266 15061 TLB shootdowns
TRM: 0 0 Thermal event interrupts
THR: 0 0 Threshold APIC interrupts
MCE: 0 0 Machine check exceptions
MCP: 10 10 Machine check polls
ERR: 0
MIS: 0
lspci -v:
[code]00:00.0 Host bridge: VIA Technologies, Inc. PT880 Ultra/PT894 Host Bridge
Subsystem: ASRock Incorporation Device 0308
Flags: bus master, medium devsel, latency 8
Memory at f8000000 (32-bit, prefetchable) [size=64M]
Capabilities: [80] AGP version 3.5
Capabilities: [50] Power Management version 2
Kernel driver in use: agpgart-via
Kernel modules: via-agp
00:00.1 Host bridge: VIA Technologies, Inc. PT894 Host Bridge
Subsystem: ASRock Incorporation Device 1308
Flags: bus master, medium devsel, latency 0
00:00.2 Host bridge: VIA Technologies, Inc. PT894 Host Bridge
Subsystem: ASRock Incorporation Device 2308
00:00.3 Host bridge: VIA Technologies, Inc. PT890 Host Bridge
00:00.4 Host bridge: VIA Technologies, Inc. PT894 Host Bridge
Subsystem: ASRock Incorporation Device 4308
00:00.5 PIC: VIA Technologies, Inc. PT894 I/O APIC Interrupt Controller (prog-if 20 [IO(X)-APIC])
Subsystem: ASRock Incorporation Device 5308
Flags: bus master, fast devsel, latency 0
00:00.7 Host bridge: VIA Technologies, Inc. PT894 Host Bridge
00:01.0 PCI bridge: VIA Technologies, Inc. VT8237/VX700 PCI Bridge (prog-if 00 [Normal decode])
Flags: bus master, 66MHz, medium devsel, latency 0
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
Memory behind bridge: ff300000-ff3fffff
Capabilities: [70] Power Management version 2
Kernel modules: shpchp
00:02.0 PCI bridge: VIA Technologies, Inc. PT890 PCI to PCI Bridge Controller (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 0000a000-0000cfff
Memory behind bridge: ff400000-ff4fffff
Prefetchable memory behind bridge: bff00000-dfefffff
Capabilities: [40] Express Root Port (Slot+), MSI 00
Capabilities: [68] Power Management version 2
Capabilities: [70] Message Signalled Interrupts: Mask+ 64bit+ Queue=0/0 Enable+
Capabilities: [100] Advanced Error Reporting <?>
Capabilities: [140] Virtual Channel <?>
Kernel driver in use: pcieport-driver
00:0b.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8169 Gigabit Ethernet (rev 10)
Subsystem: Realtek Semiconductor Co., Ltd. RTL-8169 Gigabit Ethernet
Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 19
I/O ports at ee00 [size=256]
Memory at ff6ff400 (32-bit, non-prefetchable) [size=256]
Expansion ROM at ff6c0000 [disabled] [size=128K]
Capabilities: [dc] Power Management version 2
Kernel driver in use: r8169
Kernel modules: r8169
00:0f.0 IDE interface: VIA Technologies, Inc. VT8237A SATA 2-Port Controller (rev 80) (prog-if 8f [Master SecP SecO PriP PriO])
Subsystem: ASRock Incorporation Device 0591
Flags: bus master, medium devsel, latency 32, IRQ 21
I/O ports at e000 [size=8]
I/O ports at dc00 [size=4]
I/O ports at d880 [size=8]
I/O ports at d800 [size=4]
I/O ports at d480 [size=16]
I/O ports at d000 [size=256]
Capabilities: [c0] Power Management version 2
Kernel driver in use: sata_via
Kernel modules: sata_via
00:0f.1 IDE interface: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE (rev 07) (prog-if 8a [Master SecP PriP])
Subsystem: ASRock Incorporation K7VT2/K7VT6 motherboard
[virtual] Memory at 000001f0 (32-bit, non-prefetchable) [disabled] [size=8]
[virtual] Memory at 000003f0 (type 3, non-prefetchable) [disabled] [size=1]
[virtual] Memory at 00000170 (32-bit, non-prefetchable) [disabled] [size=8]
[virtual] Memory at 00000370 (type 3, non-prefetchable) [disabled] [size=1]
I/O ports at fc00 [size=16]
Kernel driver in use: VIA_IDE
Kernel modules: via82cxxx
00:10.0 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev a0) (prog-if 00 [UHCI])
Subsystem: ASRock Incorporation K7VT6
Flags: bus master, medium devsel, latency 32, IRQ 20
I/O ports at e080 [size=32]
Capabilities: [80] Power Management version 2
Kernel driver in use: uhci_hcd
Kernel modules: uhci-hcd
00:10.1 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev a0) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 32, IRQ 22
I/O ports at e400 [size=32]
00:10.2 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev a0) (prog-if 00 [UHCI])
I/O ports at e480 [size=32]
00:10.3 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev a0) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 32, IRQ 23
I/O ports at ec00 [size=32]
00:10.4 USB Controller: VIA Technologies, Inc. USB 2.0 (rev 86) (prog-if 20 [EHCI])
Subsystem: ASRock Incorporation K7VT6 motherboard
Memory at ff6ff800 (32-bit, non-prefetchable) [size=256]
Kernel driver in use: ehci_hcd
Kernel modules: ehci-hcd
00:11.0 ISA bridge: VIA Technologies, Inc. VT8237A PCI to ISA Bridge
Subsystem: ASRock Incorporation Device 3337
Flags: medium devsel
Kernel modules: i2c-viapro
00:11.7 Host bridge: VIA Technologies, Inc. VT8251 Ultra VLINK Controller
Subsystem: VIA Technologies, Inc. Device 337e
Capabilities: [58] HyperTransport: Interrupt Discovery and Configuration
00:12.0 Ethernet controller: VIA Technologies, Inc. VT6102 [Rhine-II] (rev 7c)
I/O ports at e800 [size=256]
Memory at ff6ffc00 (32-bit, non-prefetchable) [size=256]
Capabilities: [40] Power Management version 2
Kernel driver in use: via-rhine
Kernel modules: via-rhine
00:13.0 Host bridge: VIA Technologies, Inc. VT8237A Host Bridge
02:00.0 VGA compatible controller: ATI Technologies Inc RV515 [Radeon X1300] (prog-if 00 [VGA controller])
Subsystem: Info-Tek Corp. Device 1972
Flags: bus master, fast devsel, latency 0, IRQ 10
Memory at c0000000 (64-bit, prefetchable) [size=256M]
Memory at ff4f0000 (64-bit, non-prefetchable) [size=64K]
I/O ports at c000 [size=256]
Expansion ROM at ff4c0000 [disabled] [size=128K]
Capabilities: [58] Express Endpoint, MSI 00
Capabilities: [80] Message Signalled Interrupts: Mask- 64bit+ Queue=0/0 Enable-
02:00.1 Display controller: ATI Technologies Inc RV515 [Radeon X1300] (Secondary)
Subsystem: Info-Tek Corp. Device 1973
Memory at ff4e0000 (64-bit, non-prefetchable) [size=64K]
80:01.0 Audio device: VIA Technologies, Inc. VT1708/A [Azalia HDAC] (VIA High Definition Audio Controller) (rev 10)
Subsystem: ASRock Incorporation Device 0888
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at ff5fc000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [60] Message Signalled Interrupts: Mask- 64bit+ Queue=0/0 Enable-
Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [100] #1106
Kernel driver in use: HDA Intel
Kernel modules: snd-hda-intel[/code]
fichier messages
Nov 24 09:19:26 hera kernel: imklog 3.18.6, log source = /proc/kmsg started.
Nov 24 09:19:26 hera kernel: [ 0.000000] Initializing cgroup subsys cpuset
Nov 24 09:19:26 hera kernel: [ 0.000000] Linux version 2.6.31-1-686 (Debian 2.6.31-2) (ben@decadent.org.uk) (gcc version 4.3.4 (Debian 4.3.4-6) ) #1 SMP Sun Nov 15 20:39:33 UTC 2009
Nov 24 09:19:26 hera kernel: [ 0.000000] KERNEL supported cpus:
Nov 24 09:19:26 hera kernel: [ 0.000000] Intel GenuineIntel
Nov 24 09:19:26 hera kernel: [ 0.000000] AMD AuthenticAMD
Nov 24 09:19:26 hera kernel: [ 0.000000] NSC Geode by NSC
Nov 24 09:19:26 hera kernel: [ 0.000000] Cyrix CyrixInstead
Nov 24 09:19:26 hera kernel: [ 0.000000] Centaur CentaurHauls
Nov 24 09:19:26 hera kernel: [ 0.000000] Transmeta GenuineTMx86
Nov 24 09:19:26 hera kernel: [ 0.000000] Transmeta TransmetaCPU
Nov 24 09:19:26 hera kernel: [ 0.000000] UMC UMC UMC UMC
Nov 24 09:19:26 hera kernel: [ 0.000000] BIOS-provided physical RAM map:
Nov 24 09:19:26 hera kernel: [ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
Nov 24 09:19:26 hera kernel: [ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
Nov 24 09:19:26 hera kernel: [ 0.000000] BIOS-e820: 00000000000e2000 - 0000000000100000 (reserved)
Nov 24 09:19:26 hera kernel: [ 0.000000] BIOS-e820: 0000000000100000 - 000000007ffb0000 (usable)
Nov 24 09:19:26 hera kernel: [ 0.000000] BIOS-e820: 000000007ffb0000 - 000000007ffc0000 (ACPI data)
Nov 24 09:19:26 hera kernel: [ 0.000000] BIOS-e820: 000000007ffc0000 - 000000007fff0000 (ACPI NVS)
Nov 24 09:19:26 hera kernel: [ 0.000000] BIOS-e820: 000000007fff0000 - 0000000080000000 (reserved)
Nov 24 09:19:26 hera kernel: [ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
Nov 24 09:19:26 hera kernel: [ 0.000000] BIOS-e820: 00000000ff780000 - 0000000100000000 (reserved)
Nov 24 09:19:26 hera kernel: [ 0.000000] DMI present.
Nov 24 09:19:26 hera kernel: [ 0.000000] AMI BIOS detected: BIOS may corrupt low RAM, working around it.
Nov 24 09:19:26 hera kernel: [ 0.000000] last_pfn = 0x7ffb0 max_arch_pfn = 0x100000
Nov 24 09:19:26 hera kernel: [ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
Nov 24 09:19:26 hera kernel: [ 0.000000] init_memory_mapping: 0000000000000000-00000000373fe000
Nov 24 09:19:26 hera kernel: [ 0.000000] RAMDISK: 37d18000 - 37fef29c
Nov 24 09:19:26 hera kernel: [ 0.000000] Allocated new RAMDISK: 00100000 - 003d729c
Nov 24 09:19:26 hera kernel: [ 0.000000] Move RAMDISK from 0000000037d18000 - 0000000037fef29b to 00100000 - 003d729b
Nov 24 09:19:26 hera kernel: [ 0.000000] ACPI: RSDP 000f7e20 00014 (v00 ACPIAM)
Nov 24 09:19:26 hera kernel: [ 0.000000] ACPI: RSDT 7ffb0000 00034 (v01 A M I OEMRSDT 09000717 MSFT 00000097)
Nov 24 09:19:26 hera kernel: [ 0.000000] ACPI: FACP 7ffb0200 00084 (v02 A M I OEMFACP 09000717 MSFT 00000097)
Nov 24 09:19:26 hera kernel: [ 0.000000] ACPI: DSDT 7ffb0450 04AED (v01 75D8U 75D8U291 00000291 INTL 02002026)
Nov 24 09:19:26 hera kernel: [ 0.000000] ACPI: FACS 7ffc0000 00040
Nov 24 09:19:26 hera kernel: [ 0.000000] ACPI: APIC 7ffb0390 00078 (v01 A M I OEMAPIC 09000717 MSFT 00000097)
Nov 24 09:19:26 hera kernel: [ 0.000000] ACPI: MCFG 7ffb0410 0003C (v01 A M I OEMMCFG 09000717 MSFT 00000097)
Nov 24 09:19:26 hera kernel: [ 0.000000] ACPI: OEMB 7ffc0040 00051 (v01 A M I AMI_OEM 09000717 MSFT 00000097)
Nov 24 09:19:26 hera kernel: [ 0.000000] 1163MB HIGHMEM available.
Nov 24 09:19:26 hera kernel: [ 0.000000] 883MB LOWMEM available.
Nov 24 09:19:26 hera kernel: [ 0.000000] mapped low ram: 0 - 373fe000
Nov 24 09:19:26 hera kernel: [ 0.000000] low ram: 0 - 373fe000
Nov 24 09:19:26 hera kernel: [ 0.000000] node 0 low ram: 00000000 - 373fe000
Nov 24 09:19:26 hera kernel: [ 0.000000] node 0 bootmap 00012000 - 00018e80
Nov 24 09:19:26 hera kernel: [ 0.000000] (9 early reservations) ==> bootmem [0000000000 - 00373fe000]
Nov 24 09:19:26 hera kernel: [ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
Nov 24 09:19:26 hera kernel: [ 0.000000] #1 [0000001000 - 0000002000] EX TRAMPOLINE ==> [0000001000 - 0000002000]
Nov 24 09:19:26 hera kernel: [ 0.000000] #2 [0000006000 - 0000007000] TRAMPOLINE ==> [0000006000 - 0000007000]
Nov 24 09:19:26 hera kernel: [ 0.000000] #3 [0001000000 - 00014fcd58] TEXT DATA BSS ==> [0001000000 - 00014fcd58]
Nov 24 09:19:26 hera kernel: [ 0.000000] #4 [000009fc00 - 0000100000] BIOS reserved ==> [000009fc00 - 0000100000]
Nov 24 09:19:26 hera kernel: [ 0.000000] #5 [00014fd000 - 0001503123] BRK ==> [00014fd000 - 0001503123]
Nov 24 09:19:26 hera kernel: [ 0.000000] #6 [0000010000 - 0000012000] PGTABLE ==> [0000010000 - 0000012000]
Nov 24 09:19:26 hera kernel: [ 0.000000] #7 [0000100000 - 00003d729c] NEW RAMDISK ==> [0000100000 - 00003d729c]
Nov 24 09:19:26 hera kernel: [ 0.000000] #8 [0000012000 - 0000019000] BOOTMAP ==> [0000012000 - 0000019000]
Nov 24 09:19:26 hera kernel: [ 0.000000] found SMP MP-table at [c00ff780] ff780
Nov 24 09:19:26 hera kernel: [ 0.000000] Zone PFN ranges:
Nov 24 09:19:26 hera kernel: [ 0.000000] DMA 0x00000010 -> 0x00001000
Nov 24 09:19:26 hera kernel: [ 0.000000] Normal 0x00001000 -> 0x000373fe
Nov 24 09:19:26 hera kernel: [ 0.000000] HighMem 0x000373fe -> 0x0007ffb0
Nov 24 09:19:26 hera kernel: [ 0.000000] Movable zone start PFN for each node
Nov 24 09:19:26 hera kernel: [ 0.000000] early_node_map[2] active PFN ranges
Nov 24 09:19:26 hera kernel: [ 0.000000] 0: 0x00000010 -> 0x0000009f
Nov 24 09:19:26 hera kernel: [ 0.000000] 0: 0x00000100 -> 0x0007ffb0
Nov 24 09:19:26 hera kernel: [ 0.000000] Using APIC driver default
Nov 24 09:19:26 hera kernel: [ 0.000000] ACPI: PM-Timer IO Port: 0x808
Nov 24 09:19:26 hera kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
Nov 24 09:19:26 hera kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
Nov 24 09:19:26 hera kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x82] disabled)
Nov 24 09:19:26 hera kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x83] disabled)
Nov 24 09:19:26 hera kernel: [ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
Nov 24 09:19:26 hera kernel: [ 0.000000] IOAPIC[0]: apic_id 2, version 3, address 0xfec00000, GSI 0-23
Nov 24 09:19:26 hera kernel: [ 0.000000] ACPI: IOAPIC (id[0x03] address[0xfecc0000] gsi_base[24])
Nov 24 09:19:26 hera kernel: [ 0.000000] IOAPIC[1]: apic_id 3, version 3, address 0xfecc0000, GSI 24-47
Nov 24 09:19:26 hera kernel: [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Nov 24 09:19:26 hera kernel: [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
Nov 24 09:19:26 hera kernel: [ 0.000000] Enabling APIC mode: Flat. Using 2 I/O APICs
Nov 24 09:19:26 hera kernel: [ 0.000000] Using ACPI (MADT) for SMP configuration information
Nov 24 09:19:26 hera kernel: [ 0.000000] SMP: Allowing 4 CPUs, 2 hotplug CPUs
Nov 24 09:19:26 hera kernel: [ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
Nov 24 09:19:26 hera kernel: [ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e2000
Nov 24 09:19:26 hera kernel: [ 0.000000] PM: Registered nosave memory: 00000000000e2000 - 0000000000100000
Nov 24 09:19:26 hera kernel: [ 0.000000] Allocating PCI resources starting at 80000000 (gap: 80000000:7ee00000)
Nov 24 09:19:26 hera kernel: [ 0.000000] NR_CPUS:32 nr_cpumask_bits:32 nr_cpu_ids:4 nr_node_ids:1
Nov 24 09:19:26 hera kernel: [ 0.000000] PERCPU: Embedded 13 pages at c250e000, static data 31868 bytes
Nov 24 09:19:26 hera kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 519999
Nov 24 09:19:26 hera kernel: [ 0.000000] Kernel command line: root=/dev/sda3 ro
Nov 24 09:19:26 hera kernel: [ 0.000000] PID hash table entries: 4096 (order: 12, 16384 bytes)
Nov 24 09:19:26 hera kernel: [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Nov 24 09:19:26 hera kernel: [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Nov 24 09:19:26 hera kernel: [ 0.000000] Enabling fast FPU save and restore... done.
Nov 24 09:19:26 hera kernel: [ 0.000000] Enabling unmasked SIMD FPU exception support... done.
Nov 24 09:19:26 hera kernel: [ 0.000000] Initializing CPU#0
Nov 24 09:19:26 hera kernel: [ 0.000000] Initializing HighMem for node 0 (000373fe:0007ffb0)
Nov 24 09:19:26 hera kernel: [ 0.000000] Memory: 2069936k/2096832k available (2823k kernel code, 25496k reserved, 1217k data, 376k init, 1191624k highmem)
Nov 24 09:19:26 hera kernel: [ 0.000000] virtual kernel memory layout:
Nov 24 09:19:26 hera kernel: [ 0.000000] fixmap : 0xffd56000 - 0xfffff000 (2724 kB)
Nov 24 09:19:26 hera kernel: [ 0.000000] pkmap : 0xff400000 - 0xff800000 (4096 kB)
Nov 24 09:19:26 hera kernel: [ 0.000000] vmalloc : 0xf7bfe000 - 0xff3fe000 ( 120 MB)
Nov 24 09:19:26 hera kernel: [ 0.000000] lowmem : 0xc0000000 - 0xf73fe000 ( 883 MB)
Nov 24 09:19:26 hera kernel: [ 0.000000] .init : 0xc13f3000 - 0xc1451000 ( 376 kB)
Nov 24 09:19:26 hera kernel: [ 0.000000] .data : 0xc12c1ef4 - 0xc13f2498 (1217 kB)
Nov 24 09:19:26 hera kernel: [ 0.000000] .text : 0xc1000000 - 0xc12c1ef4 (2823 kB)
Nov 24 09:19:26 hera kernel: [ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
Nov 24 09:19:26 hera kernel: [ 0.000000] NR_IRQS:1280
Nov 24 09:19:26 hera kernel: [ 0.000000] Fast TSC calibration using PIT
Nov 24 09:19:26 hera kernel: [ 0.000000] Detected 1794.085 MHz processor.
Nov 24 09:19:26 hera kernel: [ 0.001293] Console: colour VGA+ 80x25
Nov 24 09:19:26 hera kernel: [ 0.001297] console [tty0] enabled
Nov 24 09:19:26 hera kernel: [ 0.004014] Calibrating delay loop (skipped), value calculated using timer frequency.. 3588.17 BogoMIPS (lpj=7176340)
Nov 24 09:19:26 hera kernel: [ 0.004171] Security Framework initialized
Nov 24 09:19:26 hera kernel: [ 0.004231] SELinux: Disabled at boot.
Nov 24 09:19:26 hera kernel: [ 0.004305] Mount-cache hash table entries: 512
Nov 24 09:19:26 hera kernel: [ 0.004518] Initializing cgroup subsys ns
Nov 24 09:19:26 hera kernel: [ 0.004578] Initializing cgroup subsys cpuacct
Nov 24 09:19:26 hera kernel: [ 0.004636] Initializing cgroup subsys devices
Nov 24 09:19:26 hera kernel: [ 0.004692] Initializing cgroup subsys freezer
Nov 24 09:19:26 hera kernel: [ 0.004749] Initializing cgroup subsys net_cls
Nov 24 09:19:26 hera kernel: [ 0.004828] CPU: L1 I cache: 32K, L1 D cache: 32K
Nov 24 09:19:26 hera kernel: [ 0.004931] CPU: L2 cache: 2048K
Nov 24 09:19:26 hera kernel: [ 0.004986] CPU: Physical Processor ID: 0
Nov 24 09:19:26 hera kernel: [ 0.005041] CPU: Processor Core ID: 0
Nov 24 09:19:26 hera kernel: [ 0.005099] mce: CPU supports 6 MCE banks
Nov 24 09:19:26 hera kernel: [ 0.005164] CPU0: Thermal monitoring enabled (TM1)
Nov 24 09:19:26 hera kernel: [ 0.005223] using mwait in idle threads.
Nov 24 09:19:26 hera kernel: [ 0.005285] Performance Counters: Core2 events, Intel PMU driver.
Nov 24 09:19:26 hera kernel: [ 0.005441] ... version: 2
Nov 24 09:19:26 hera kernel: [ 0.005496] ... bit width: 40
Nov 24 09:19:26 hera kernel: [ 0.005551] ... generic counters: 2
Nov 24 09:19:26 hera kernel: [ 0.005607] ... value mask: 000000ffffffffff
Nov 24 09:19:26 hera kernel: [ 0.005663] ... max period: 000000007fffffff
Nov 24 09:19:26 hera kernel: [ 0.005719] ... fixed-purpose counters: 3
Nov 24 09:19:26 hera kernel: [ 0.005774] ... counter mask: 0000000700000003
Nov 24 09:19:26 hera kernel: [ 0.005833] Checking 'hlt' instruction... OK.
Nov 24 09:19:26 hera kernel: [ 0.021281] ACPI: Core revision 20090521
Nov 24 09:19:26 hera kernel: [ 0.032562] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
Nov 24 09:19:26 hera kernel: [ 0.073919] CPU0: Intel(R) Core(TM)2 CPU 6300 @ 1.86GHz stepping 06
Nov 24 09:19:26 hera kernel: [ 0.076001] Booting processor 1 APIC 0x1 ip 0x6000
Nov 24 09:19:26 hera kernel: [ 0.004000] Initializing CPU#1
Nov 24 09:19:26 hera kernel: [ 0.004000] Calibrating delay using timer specific routine.. 3587.70 BogoMIPS (lpj=7175413)
Nov 24 09:19:26 hera kernel: [ 0.004000] CPU: L1 I cache: 32K, L1 D cache: 32K
Nov 24 09:19:26 hera kernel: [ 0.004000] CPU: L2 cache: 2048K
Nov 24 09:19:26 hera kernel: [ 0.004000] CPU: Physical Processor ID: 0
Nov 24 09:19:26 hera kernel: [ 0.004000] CPU: Processor Core ID: 1
Nov 24 09:19:26 hera kernel: [ 0.004000] mce: CPU supports 6 MCE banks
Nov 24 09:19:26 hera kernel: [ 0.004000] CPU1: Thermal monitoring enabled (TM1)
Nov 24 09:19:26 hera kernel: [ 0.004000] x86 PAT enabled: cpu 1, old 0x7040600070406, new 0x7010600070106
Nov 24 09:19:26 hera kernel: [ 0.161970] CPU1: Intel(R) Core(TM)2 CPU 6300 @ 1.86GHz stepping 06
Nov 24 09:19:26 hera kernel: [ 0.162621] checking TSC synchronization [CPU#0 -> CPU#1]: passed.
Nov 24 09:19:26 hera kernel: [ 0.164079] Brought up 2 CPUs
Nov 24 09:19:26 hera kernel: [ 0.164137] Total of 2 processors activated (7175.87 BogoMIPS).
Nov 24 09:19:26 hera kernel: [ 0.164356] Booting paravirtualized kernel on bare hardware
Nov 24 09:19:26 hera kernel: [ 0.164356] regulator: core version 0.5
Nov 24 09:19:26 hera kernel: [ 0.164356] NET: Registered protocol family 16
Nov 24 09:19:26 hera kernel: [ 0.164356] ACPI: bus type pci registered
Nov 24 09:19:26 hera kernel: [ 0.168066] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 255
Nov 24 09:19:26 hera kernel: [ 0.168125] PCI: Not using MMCONFIG.
Nov 24 09:19:26 hera kernel: [ 0.168312] PCI: PCI BIOS revision 3.00 entry at 0xf0031, last bus=128
Nov 24 09:19:26 hera kernel: [ 0.168370] PCI: Using configuration type 1 for base access
Nov 24 09:19:26 hera kernel: [ 0.168802] bio: create slab <bio-0> at 0
Nov 24 09:19:26 hera kernel: [ 0.177503] ACPI: Interpreter enabled
Nov 24 09:19:26 hera kernel: [ 0.177565] ACPI: (supports S0 S1 S3 S4 S5)
Nov 24 09:19:26 hera kernel: [ 0.177877] ACPI: Using IOAPIC for interrupt routing
Nov 24 09:19:26 hera kernel: [ 0.177990] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 255
Nov 24 09:19:26 hera kernel: [ 0.183404] PCI: MCFG area at e0000000 reserved in ACPI motherboard resources
Nov 24 09:19:26 hera kernel: [ 0.183463] PCI: Using MMCONFIG for extended config space
Nov 24 09:19:26 hera kernel: [ 0.191011] ACPI Warning: Incorrect checksum in table [OEMB] - BC, should be B7 20090521 tbutils-246
Nov 24 09:19:26 hera kernel: [ 0.191286] ACPI: No dock devices found.
Nov 24 09:19:26 hera kernel: [ 0.191693] ACPI: PCI Root Bridge [PCI0] (0000:00)
Nov 24 09:19:26 hera kernel: [ 0.192361] pci 0000:00:02.0: PME# supported from D0 D3hot D3cold
Nov 24 09:19:26 hera kernel: [ 0.192421] pci 0000:00:02.0: PME# disabled
Nov 24 09:19:26 hera kernel: [ 0.192599] pci 0000:00:0b.0: PME# supported from D1 D2 D3hot
Nov 24 09:19:26 hera kernel: [ 0.192658] pci 0000:00:0b.0: PME# disabled
Nov 24 09:19:26 hera kernel: [ 0.193027] pci 0000:00:10.0: PME# supported from D0 D1 D2 D3hot D3cold
Nov 24 09:19:26 hera kernel: [ 0.193087] pci 0000:00:10.0: PME# disabled
Nov 24 09:19:26 hera kernel: [ 0.193236] pci 0000:00:10.1: PME# supported from D0 D1 D2 D3hot D3cold
Nov 24 09:19:26 hera kernel: [ 0.193296] pci 0000:00:10.1: PME# disabled
Nov 24 09:19:26 hera kernel: [ 0.193445] pci 0000:00:10.2: PME# supported from D0 D1 D2 D3hot D3cold
Nov 24 09:19:26 hera kernel: [ 0.194156] pci 0000:00:10.2: PME# disabled
Nov 24 09:19:26 hera kernel: [ 0.194305] pci 0000:00:10.3: PME# supported from D0 D1 D2 D3hot D3cold
Nov 24 09:19:26 hera kernel: [ 0.194365] pci 0000:00:10.3: PME# disabled
Nov 24 09:19:26 hera kernel: [ 0.194515] pci 0000:00:10.4: PME# supported from D0 D1 D2 D3hot D3cold
Nov 24 09:19:26 hera kernel: [ 0.194575] pci 0000:00:10.4: PME# disabled
Nov 24 09:19:26 hera kernel: [ 0.194903] pci 0000:00:12.0: PME# supported from D0 D1 D2 D3hot D3cold
Nov 24 09:19:26 hera kernel: [ 0.194963] pci 0000:00:12.0: PME# disabled
Nov 24 09:19:26 hera kernel: [ 0.208832] ACPI: PCI Root Bridge [PCI1] (0000:80)
Nov 24 09:19:26 hera kernel: [ 0.209012] pci 0000:80:01.0: PME# supported from D0 D3hot D3cold
Nov 24 09:19:26 hera kernel: [ 0.209072] pci 0000:80:01.0: PME# disabled
Nov 24 09:19:26 hera kernel: [ 0.209390] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12 14 15)
Nov 24 09:19:26 hera kernel: [ 0.210129] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 *6 7 10 11 12 14 15)
Nov 24 09:19:26 hera kernel: [ 0.210868] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 7 10 11 12 14 15)
Nov 24 09:19:26 hera kernel: [ 0.211605] ACPI: PCI Interrupt Link [LNKD] (IRQs *3 4 5 6 7 10 11 12 14 15)
Nov 24 09:19:26 hera kernel: [ 0.212311] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
Nov 24 09:19:26 hera kernel: [ 0.213146] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
Nov 24 09:19:26 hera kernel: [ 0.213982] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
Nov 24 09:19:26 hera kernel: [ 0.214819] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 *10 11 12 14 15)
Nov 24 09:19:26 hera kernel: [ 0.215531] PCI: Using ACPI for IRQ routing
Nov 24 09:19:26 hera kernel: [ 0.244006] pnp: PnP ACPI init
Nov 24 09:19:26 hera kernel: [ 0.244070] ACPI: bus type pnp registered
Nov 24 09:19:26 hera kernel: [ 0.248713] pnp: PnP ACPI: found 13 devices
Nov 24 09:19:26 hera kernel: [ 0.248769] ACPI: ACPI bus type pnp unregistered
Nov 24 09:19:26 hera kernel: [ 0.248827] PnPBIOS: Disabled by ACPI PNP
Nov 24 09:19:26 hera kernel: [ 0.248894] system 00:06: ioport range 0x295-0x296 has been reserved
Nov 24 09:19:26 hera kernel: [ 0.248953] system 00:06: ioport range 0x3e0-0x3e7 has been reserved
Nov 24 09:19:26 hera kernel: [ 0.249011] system 00:06: ioport range 0x4d0-0x4d1 has been reserved
Nov 24 09:19:26 hera kernel: [ 0.249069] system 00:06: ioport range 0x800-0x87f has been reserved
Nov 24 09:19:26 hera kernel: [ 0.249127] system 00:06: ioport range 0x400-0x41f has been reserved
Nov 24 09:19:26 hera kernel: [ 0.249186] system 00:06: iomem range 0xff5fc000-0xff5fffff has been reserved
Nov 24 09:19:26 hera kernel: [ 0.249244] system 00:06: iomem range 0xffb80000-0xffbfffff has been reserved
Nov 24 09:19:26 hera kernel: [ 0.249307] system 00:07: iomem range 0xfec00000-0xfec00fff could not be reserved
Nov 24 09:19:26 hera kernel: [ 0.249370] system 00:07: iomem range 0xfee00000-0xfee00fff has been reserved
Nov 24 09:19:26 hera kernel: [ 0.249433] system 00:0a: iomem range 0xe0000000-0xefffffff has been reserved
Nov 24 09:19:26 hera kernel: [ 0.249495] system 00:0b: iomem range 0x0-0x9ffff could not be reserved
Nov 24 09:19:26 hera kernel: [ 0.249553] system 00:0b: iomem range 0xc0000-0xcffff could not be reserved
Nov 24 09:19:26 hera kernel: [ 0.249612] system 00:0b: iomem range 0xe0000-0xfffff could not be reserved
Nov 24 09:19:26 hera kernel: [ 0.249670] system 00:0b: iomem range 0x100000-0x7fffffff could not be reserved
Nov 24 09:19:26 hera kernel: [ 0.249733] system 00:0b: iomem range 0xfff80000-0xffffffff has been reserved
Nov 24 09:19:26 hera kernel: [ 0.284577] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
Nov 24 09:19:26 hera kernel: [ 0.284634] pci 0000:00:01.0: IO window: disabled
Nov 24 09:19:26 hera kernel: [ 0.284695] pci 0000:00:01.0: MEM window: 0xff300000-0xff3fffff
Nov 24 09:19:26 hera kernel: [ 0.284754] pci 0000:00:01.0: PREFETCH window: disabled
Nov 24 09:19:26 hera kernel: [ 0.284813] pci 0000:00:02.0: PCI bridge, secondary bus 0000:02
Nov 24 09:19:26 hera kernel: [ 0.284872] pci 0000:00:02.0: IO window: 0xa000-0xcfff
Nov 24 09:19:26 hera kernel: [ 0.284932] pci 0000:00:02.0: MEM window: 0xff400000-0xff4fffff
Nov 24 09:19:26 hera kernel: [ 0.284992] pci 0000:00:02.0: PREFETCH window: 0xbff00000-0xdfefffff
Nov 24 09:19:26 hera kernel: [ 0.285074] pci 0000:00:02.0: PCI INT A -> GSI 27 (level, low) -> IRQ 27
Nov 24 09:19:26 hera kernel: [ 0.285219] NET: Registered protocol family 2
Nov 24 09:19:26 hera kernel: [ 0.285381] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
Nov 24 09:19:26 hera kernel: [ 0.285788] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
Nov 24 09:19:26 hera kernel: [ 0.286414] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
Nov 24 09:19:26 hera kernel: [ 0.286760] TCP: Hash tables configured (established 131072 bind 65536)
Nov 24 09:19:26 hera kernel: [ 0.286818] TCP reno registered
Nov 24 09:19:26 hera kernel: [ 0.286985] NET: Registered protocol family 1
Nov 24 09:19:26 hera kernel: [ 0.287118] Unpacking initramfs...
Nov 24 09:19:26 hera kernel: [ 0.373858] Freeing initrd memory: 2908k freed
Nov 24 09:19:26 hera kernel: [ 0.375948] audit: initializing netlink socket (disabled)
Nov 24 09:19:26 hera kernel: [ 0.376073] type=2000 audit(1259054352.376:1): initialized
Nov 24 09:19:26 hera kernel: [ 0.376517] highmem bounce pool size: 64 pages
Nov 24 09:19:26 hera kernel: [ 0.376578] HugeTLB registered 4 MB page size, pre-allocated 0 pages
Nov 24 09:19:26 hera kernel: [ 0.376751] VFS: Disk quotas dquot_6.5.2
Nov 24 09:19:26 hera kernel: [ 0.376843] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Nov 24 09:19:26 hera kernel: [ 0.376963] msgmni has been set to 1722
Nov 24 09:19:26 hera kernel: [ 0.377236] alg: No test for stdrng (krng)
Nov 24 09:19:26 hera kernel: [ 0.377328] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
Nov 24 09:19:26 hera kernel: [ 0.377393] io scheduler noop registered
Nov 24 09:19:26 hera kernel: [ 0.377448] io scheduler anticipatory registered
Nov 24 09:19:26 hera kernel: [ 0.377504] io scheduler deadline registered
Nov 24 09:19:26 hera kernel: [ 0.377575] io scheduler cfq registered (default)
Nov 24 09:19:26 hera kernel: [ 0.377654] pci 0000:00:01.0: disabling DAC on VIA PCI bridge
Nov 24 09:19:26 hera kernel: [ 0.378514] isapnp: Scanning for PnP cards...
Nov 24 09:19:26 hera kernel: [ 0.732638] isapnp: No Plug & Play device found
Nov 24 09:19:26 hera kernel: [ 0.733966] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
Nov 24 09:19:26 hera kernel: [ 0.734124] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Nov 24 09:19:26 hera kernel: [ 0.734576] 00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Nov 24 09:19:26 hera kernel: [ 0.734818] PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
Nov 24 09:19:26 hera kernel: [ 0.734875] PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Nov 24 09:19:26 hera kernel: [ 0.735055] serio: i8042 KBD port at 0x60,0x64 irq 1
Nov 24 09:19:26 hera kernel: [ 0.735162] mice: PS/2 mouse device common for all mice
Nov 24 09:19:26 hera kernel: [ 0.735274] rtc_cmos 00:02: RTC can wake from S4
Nov 24 09:19:26 hera kernel: [ 0.735359] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
Nov 24 09:19:26 hera kernel: [ 0.735449] rtc0: alarms up to one year, y3k, 114 bytes nvram
Nov 24 09:19:26 hera kernel: [ 0.735525] cpuidle: using governor ladder
Nov 24 09:19:26 hera kernel: [ 0.735581] cpuidle: using governor menu
Nov 24 09:19:26 hera kernel: [ 0.735640] No iBFT detected.
Nov 24 09:19:26 hera kernel: [ 0.736065] TCP cubic registered
Nov 24 09:19:26 hera kernel: [ 0.736169] NET: Registered protocol family 10
Nov 24 09:19:26 hera kernel: [ 0.736711] lo: Disabled Privacy Extensions
Nov 24 09:19:26 hera kernel: [ 0.737095] Mobile IPv6
Nov 24 09:19:26 hera kernel: [ 0.737151] NET: Registered protocol family 17
Nov 24 09:19:26 hera kernel: [ 0.737226] Using IPI No-Shortcut mode
Nov 24 09:19:26 hera kernel: [ 0.737348] registered taskstats version 1
Nov 24 09:19:26 hera kernel: [ 0.737582] rtc_cmos 00:02: setting system clock to 2009-11-24 09:19:13 UTC (1259054353)
Nov 24 09:19:26 hera kernel: [ 0.737709] Freeing unused kernel memory: 376k freed
Nov 24 09:19:26 hera kernel: [ 0.737993] Write protecting the kernel text: 2824k
Nov 24 09:19:26 hera kernel: [ 0.738070] Write protecting the kernel read-only data: 828k
Nov 24 09:19:26 hera kernel: [ 0.760394] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
Nov 24 09:19:26 hera kernel: [ 0.793968] SCSI subsystem initialized
Nov 24 09:19:26 hera kernel: [ 0.814811] sata_via 0000:00:0f.0: PCI INT B -> GSI 21 (level, low) -> IRQ 21
Nov 24 09:19:26 hera kernel: [ 0.814898] sata_via 0000:00:0f.0: routed to hard irq line 6
Nov 24 09:19:26 hera kernel: [ 0.815015] scsi0 : sata_via
Nov 24 09:19:26 hera kernel: [ 0.815158] scsi1 : sata_via
Nov 24 09:19:26 hera kernel: [ 0.816952] ata1: SATA max UDMA/133 cmd 0xe000 ctl 0xdc00 bmdma 0xd480 irq 21
Nov 24 09:19:26 hera kernel: [ 0.817012] ata2: SATA max UDMA/133 cmd 0xd880 ctl 0xd800 bmdma 0xd488 irq 21
Nov 24 09:19:26 hera kernel: [ 1.020010] ata1: SATA link down 1.5 Gbps (SStatus 0 SControl 300)
Nov 24 09:19:26 hera kernel: [ 1.232009] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Nov 24 09:19:26 hera kernel: [ 1.397213] ata2.00: ATA-7: Maxtor 6V080E0, VA111630, max UDMA/133
Nov 24 09:19:26 hera kernel: [ 1.397271] ata2.00: 160086528 sectors, multi 16: LBA48 NCQ (depth 0/32)
Nov 24 09:19:26 hera kernel: [ 1.413228] ata2.00: configured for UDMA/133
Nov 24 09:19:26 hera kernel: [ 1.413396] scsi 1:0:0:0: Direct-Access ATA Maxtor 6V080E0 VA11 PQ: 0 ANSI: 5
Nov 24 09:19:26 hera kernel: [ 1.427784] Uniform Multi-Platform E-IDE driver
Nov 24 09:19:26 hera kernel: [ 1.588381] sd 1:0:0:0: [sda] 160086528 512-byte logical blocks: (81.9 GB/76.3 GiB)
Nov 24 09:19:26 hera kernel: [ 1.588500] sd 1:0:0:0: [sda] Write Protect is off
Nov 24 09:19:26 hera kernel: [ 1.588587] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Nov 24 09:19:26 hera kernel: [ 1.588795] sda: sda1 sda2 sda3 sda4 < sda5 sda6 sda7 sda8 sda9 sda10 sda11 >
Nov 24 09:19:26 hera kernel: [ 1.678034] sd 1:0:0:0: [sda] Attached SCSI disk
Nov 24 09:19:26 hera kernel: [ 2.158952] PM: Starting manual resume from disk
Nov 24 09:19:26 hera kernel: [ 2.214677] kjournald starting. Commit interval 5 seconds
Nov 24 09:19:26 hera kernel: [ 2.214686] EXT3-fs: mounted filesystem with ordered data mode.
Nov 24 09:19:26 hera kernel: [ 3.304156] udevd version 125 started
Nov 24 09:19:26 hera kernel: [ 3.785155] Linux agpgart interface v0.103
Nov 24 09:19:26 hera kernel: [ 3.798227] agpgart: Detected VIA PT880 Ultra chipset
Nov 24 09:19:26 hera kernel: [ 3.802068] agpgart-via 0000:00:00.0: AGP aperture is 64M @ 0xf8000000
Nov 24 09:19:26 hera kernel: [ 3.997051] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
Nov 24 09:19:26 hera kernel: [ 3.997134] r8169 0000:00:0b.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
Nov 24 09:19:26 hera kernel: [ 3.997213] r8169 0000:00:0b.0: no PCI Express capability
Nov 24 09:19:26 hera kernel: [ 3.997929] eth0: RTL8169sb/8110sb at 0xf7c42400, 00:b0:c2:03:08:f7, XID 10000000 IRQ 19
Nov 24 09:19:26 hera kernel: [ 4.010876] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
Nov 24 09:19:26 hera kernel: [ 4.022056] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Nov 24 09:19:26 hera kernel: [ 4.376258] usbcore: registered new interface driver usbfs
Nov 24 09:19:26 hera kernel: [ 4.376349] usbcore: registered new interface driver hub
Nov 24 09:19:26 hera kernel: [ 4.386355] usbcore: registered new device driver usb
Nov 24 09:19:26 hera kernel: [ 4.398528] via-rhine.c:v1.10-LK1.4.3 2007-03-06 Written by Donald Becker
Nov 24 09:19:26 hera kernel: [ 4.398634] via-rhine 0000:00:12.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
Nov 24 09:19:26 hera kernel: [ 4.399459] eth1: VIA Rhine II at 0x1e800, 00:13:8f:ac:a8:a3, IRQ 23.
Nov 24 09:19:26 hera kernel: [ 4.400235] eth1: MII PHY found at address 1, status 0x7849 advertising 05e1 Link 0000.
Nov 24 09:19:26 hera kernel: [ 4.506475] uhci_hcd: USB Universal Host Controller Interface driver
Nov 24 09:19:26 hera kernel: [ 4.506593] uhci_hcd 0000:00:10.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
Nov 24 09:19:26 hera kernel: [ 4.506658] uhci_hcd 0000:00:10.0: UHCI Host Controller
Nov 24 09:19:26 hera kernel: [ 4.506742] uhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 1
Nov 24 09:19:26 hera kernel: [ 4.506837] uhci_hcd 0000:00:10.0: irq 20, io base 0x0000e080
Nov 24 09:19:26 hera kernel: [ 4.506933] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
Nov 24 09:19:26 hera kernel: [ 4.506991] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Nov 24 09:19:26 hera kernel: [ 4.507724] usb usb1: Product: UHCI Host Controller
Nov 24 09:19:26 hera kernel: [ 4.507783] usb usb1: Manufacturer: Linux 2.6.31-1-686 uhci_hcd
Nov 24 09:19:26 hera kernel: [ 4.507842] usb usb1: SerialNumber: 0000:00:10.0
Nov 24 09:19:26 hera kernel: [ 4.507974] usb usb1: configuration #1 chosen from 1 choice
Nov 24 09:19:26 hera kernel: [ 4.508085] hub 1-0:1.0: USB hub found
Nov 24 09:19:26 hera kernel: [ 4.508147] hub 1-0:1.0: 2 ports detected
Nov 24 09:19:26 hera kernel: [ 4.508259] uhci_hcd 0000:00:10.1: PCI INT B -> GSI 22 (level, low) -> IRQ 22
Nov 24 09:19:26 hera kernel: [ 4.508322] uhci_hcd 0000:00:10.1: UHCI Host Controller
Nov 24 09:19:26 hera kernel: [ 4.508386] uhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 2
Nov 24 09:19:26 hera kernel: [ 4.508475] uhci_hcd 0000:00:10.1: irq 22, io base 0x0000e400
Nov 24 09:19:26 hera kernel: [ 4.508562] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
Nov 24 09:19:26 hera kernel: [ 4.508620] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Nov 24 09:19:26 hera kernel: [ 4.508682] usb usb2: Product: UHCI Host Controller
Nov 24 09:19:26 hera kernel: [ 4.508738] usb usb2: Manufacturer: Linux 2.6.31-1-686 uhci_hcd
Nov 24 09:19:26 hera kernel: [ 4.508795] usb usb2: SerialNumber: 0000:00:10.1
Nov 24 09:19:26 hera kernel: [ 4.508902] usb usb2: configuration #1 chosen from 1 choice
Nov 24 09:19:26 hera kernel: [ 4.508990] hub 2-0:1.0: USB hub found
Nov 24 09:19:26 hera kernel: [ 4.509051] hub 2-0:1.0: 2 ports detected
Nov 24 09:19:26 hera kernel: [ 4.509156] uhci_hcd 0000:00:10.2: PCI INT C -> GSI 21 (level, low) -> IRQ 21
Nov 24 09:19:26 hera kernel: [ 4.509219] uhci_hcd 0000:00:10.2: UHCI Host Controller
Nov 24 09:19:26 hera kernel: [ 4.509283] uhci_hcd 0000:00:10.2: new USB bus registered, assigned bus number 3
Nov 24 09:19:26 hera kernel: [ 4.509365] uhci_hcd 0000:00:10.2: irq 21, io base 0x0000e480
Nov 24 09:19:26 hera kernel: [ 4.509451] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
Nov 24 09:19:26 hera kernel: [ 4.509509] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Nov 24 09:19:26 hera kernel: [ 4.509571] usb usb3: Product: UHCI Host Controller
Nov 24 09:19:26 hera kernel: [ 4.509627] usb usb3: Manufacturer: Linux 2.6.31-1-686 uhci_hcd
Nov 24 09:19:26 hera kernel: [ 4.509684] usb usb3: SerialNumber: 0000:00:10.2
Nov 24 09:19:26 hera kernel: [ 4.509791] usb usb3: configuration #1 chosen from 1 choice
Nov 24 09:19:26 hera kernel: [ 4.509877] hub 3-0:1.0: USB hub found
Nov 24 09:19:26 hera kernel: [ 4.509938] hub 3-0:1.0: 2 ports detected
Nov 24 09:19:26 hera kernel: [ 4.510042] uhci_hcd 0000:00:10.3: PCI INT D -> GSI 23 (level, low) -> IRQ 23
Nov 24 09:19:26 hera kernel: [ 4.510104] uhci_hcd 0000:00:10.3: UHCI Host Controller
Nov 24 09:19:26 hera kernel: [ 4.510168] uhci_hcd 0000:00:10.3: new USB bus registered, assigned bus number 4
Nov 24 09:19:26 hera kernel: [ 4.510256] uhci_hcd 0000:00:10.3: irq 23, io base 0x0000ec00
Nov 24 09:19:26 hera kernel: [ 4.510343] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
Nov 24 09:19:26 hera kernel: [ 4.510401] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Nov 24 09:19:26 hera kernel: [ 4.510463] usb usb4: Product: UHCI Host Controller
Nov 24 09:19:26 hera kernel: [ 4.510520] usb usb4: Manufacturer: Linux 2.6.31-1-686 uhci_hcd
Nov 24 09:19:26 hera kernel: [ 4.510577] usb usb4: SerialNumber: 0000:00:10.3
Nov 24 09:19:26 hera kernel: [ 4.510685] usb usb4: configuration #1 chosen from 1 choice
Nov 24 09:19:26 hera kernel: [ 4.510772] hub 4-0:1.0: USB hub found
Nov 24 09:19:26 hera kernel: [ 4.510832] hub 4-0:1.0: 2 ports detected
Nov 24 09:19:26 hera kernel: [ 4.518781] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Nov 24 09:19:26 hera kernel: [ 4.518843] Warning! ehci_hcd should always be loaded before uhci_hcd and ohci_hcd, not after
Nov 24 09:19:26 hera kernel: [ 4.518935] ehci_hcd 0000:00:10.4: PCI INT C -> GSI 21 (level, low) -> IRQ 21
Nov 24 09:19:26 hera kernel: [ 4.519009] ehci_hcd 0000:00:10.4: EHCI Host Controller
Nov 24 09:19:26 hera kernel: [ 4.519078] ehci_hcd 0000:00:10.4: new USB bus registered, assigned bus number 5
Nov 24 09:19:26 hera kernel: [ 4.519171] ehci_hcd 0000:00:10.4: irq 21, io mem 0xff6ff800
Nov 24 09:19:26 hera kernel: [ 4.520567] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
Nov 24 09:19:26 hera kernel: [ 4.520636] ACPI: Power Button [PWRF]
Nov 24 09:19:26 hera kernel: [ 4.520778] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input2
Nov 24 09:19:26 hera kernel: [ 4.520842] ACPI: Power Button [PWRB]
Nov 24 09:19:26 hera kernel: [ 4.528524] ehci_hcd 0000:00:10.4: USB 2.0 started, EHCI 1.00
Nov 24 09:19:26 hera kernel: [ 4.528621] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
Nov 24 09:19:26 hera kernel: [ 4.528679] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Nov 24 09:19:26 hera kernel: [ 4.528742] usb usb5: Product: EHCI Host Controller
Nov 24 09:19:26 hera kernel: [ 4.528798] usb usb5: Manufacturer: Linux 2.6.31-1-686 ehci_hcd
Nov 24 09:19:26 hera kernel: [ 4.528855] usb usb5: SerialNumber: 0000:00:10.4
Nov 24 09:19:26 hera kernel: [ 4.529000] usb usb5: configuration #1 chosen from 1 choice
Nov 24 09:19:26 hera kernel: [ 4.529095] hub 5-0:1.0: USB hub found
Nov 24 09:19:26 hera kernel: [ 4.529158] hub 5-0:1.0: 8 ports detected
Nov 24 09:19:26 hera kernel: [ 4.548481] processor LNXCPU:00: registered as cooling_device0
Nov 24 09:19:26 hera kernel: [ 4.548867] processor LNXCPU:01: registered as cooling_device1
Nov 24 09:19:26 hera kernel: [ 4.639848] via82cxxx 0000:00:0f.1: VIA vt8237a (rev 00) IDE UDMA133
Nov 24 09:19:26 hera kernel: [ 4.639912] via82cxxx 0000:00:0f.1: IDE controller (0x1106:0x0571 rev 0x07)
Nov 24 09:19:26 hera kernel: [ 4.640018] via82cxxx 0000:00:0f.1: not 100% native mode: will probe irqs later
Nov 24 09:19:26 hera kernel: [ 4.640085] ide0: BM-DMA at 0xfc00-0xfc07
Nov 24 09:19:26 hera kernel: [ 4.640156] ide1: BM-DMA at 0xfc08-0xfc0f
Nov 24 09:19:26 hera kernel: [ 4.907065] parport_pc 00:05: reported by Plug and Play ACPI
Nov 24 09:19:26 hera kernel: [ 4.907234] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE,EPP]
Nov 24 09:19:26 hera kernel: [ 4.956464] input: PC Speaker as /devices/platform/pcspkr/input/input3
Nov 24 09:19:26 hera kernel: [ 4.990027] HDA Intel 0000:80:01.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
Nov 24 09:19:26 hera kernel: [ 4.990147] HDA Intel 0000:80:01.0: PCI: Disallowing DAC for device
Nov 24 09:19:26 hera kernel: [ 5.104023] usb 2-2: new low speed USB device using uhci_hcd and address 2
Nov 24 09:19:26 hera kernel: [ 5.278410] usb 2-2: New USB device found, idVendor=046d, idProduct=c408
Nov 24 09:19:26 hera kernel: [ 5.278474] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Nov 24 09:19:26 hera kernel: [ 5.278533] usb 2-2: Product: USB Trackball
Nov 24 09:19:26 hera kernel: [ 5.278589] usb 2-2: Manufacturer: Logitech
Nov 24 09:19:26 hera kernel: [ 5.278742] usb 2-2: configuration #1 chosen from 1 choice
Nov 24 09:19:26 hera kernel: [ 5.324279] hda_codec: Unknown model for ALC888, trying auto-probe from BIOS...
Nov 24 09:19:26 hera kernel: [ 5.324521] input: HDA Digital PCBeep as /devices/pci0000:80/0000:80:01.0/input/input4
Nov 24 09:19:26 hera kernel: [ 5.776083] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Nov 24 09:19:26 hera kernel: [ 5.776248] ide1 at 0x170-0x177,0x376 on irq 15
Nov 24 09:19:26 hera kernel: [ 5.787286] usbcore: registered new interface driver hiddev
Nov 24 09:19:26 hera kernel: [ 5.802638] input: Logitech USB Trackball as /devices/pci0000:00/0000:00:10.1/usb2/2-2/2-2:1.0/input/input5
Nov 24 09:19:26 hera kernel: [ 5.802819] generic-usb 0003:046D:C408.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech USB Trackball] on usb-0000:00:10.1-2/input0
Nov 24 09:19:26 hera kernel: [ 5.802906] usbcore: registered new interface driver usbhid
Nov 24 09:19:26 hera kernel: [ 5.802964] usbhid: v2.6:USB HID core driver
Nov 24 09:19:26 hera kernel: [ 7.022934] Adding 489940k swap on /dev/sda1. Priority:-1 extents:1 across:489940k
Nov 24 09:19:26 hera kernel: [ 7.166072] EXT3 FS on sda3, internal journal
Nov 24 09:19:26 hera kernel: [ 8.085767] loop: module loaded
Nov 24 09:19:26 hera kernel: [ 9.986847] kjournald starting. Commit interval 5 seconds
Nov 24 09:19:26 hera kernel: [ 9.987035] EXT3 FS on sda2, internal journal
Nov 24 09:19:26 hera kernel: [ 9.987140] EXT3-fs: mounted filesystem with ordered data mode.
Nov 24 09:19:26 hera kernel: [ 10.042039] kjournald starting. Commit interval 5 seconds
Nov 24 09:19:26 hera kernel: [ 10.042284] EXT3 FS on sda10, internal journal
Nov 24 09:19:26 hera kernel: [ 10.042404] EXT3-fs: mounted filesystem with ordered data mode.
Nov 24 09:19:26 hera kernel: [ 10.104946] kjournald starting. Commit interval 5 seconds
Nov 24 09:19:26 hera kernel: [ 10.105140] EXT3 FS on sda11, internal journal
Nov 24 09:19:26 hera kernel: [ 10.105244] EXT3-fs: mounted filesystem with ordered data mode.
Nov 24 09:19:26 hera kernel: [ 10.157405] kjournald starting. Commit interval 5 seconds
Nov 24 09:19:26 hera kernel: [ 10.157607] EXT3 FS on sda5, internal journal
Nov 24 09:19:26 hera kernel: [ 10.157711] EXT3-fs: mounted filesystem with ordered data mode.
Nov 24 09:19:26 hera kernel: [ 10.215472] kjournald starting. Commit interval 5 seconds
Nov 24 09:19:26 hera kernel: [ 10.215673] EXT3 FS on sda9, internal journal
Nov 24 09:19:26 hera kernel: [ 10.215777] EXT3-fs: mounted filesystem with ordered data mode.
Nov 24 09:19:26 hera kernel: [ 10.270012] kjournald starting. Commit interval 5 seconds
Nov 24 09:19:26 hera kernel: [ 10.270205] EXT3 FS on sda6, internal journal
Nov 24 09:19:26 hera kernel: [ 10.270309] EXT3-fs: mounted filesystem with ordered data mode.
Nov 24 09:19:26 hera kernel: [ 10.325244] kjournald starting. Commit interval 5 seconds
Nov 24 09:19:26 hera kernel: [ 10.325440] EXT3 FS on sda8, internal journal
Nov 24 09:19:26 hera kernel: [ 10.325544] EXT3-fs: mounted filesystem with ordered data mode.
Nov 24 09:19:26 hera kernel: [ 10.374186] kjournald starting. Commit interval 5 seconds
Nov 24 09:19:26 hera kernel: [ 10.374380] EXT3 FS on sda7, internal journal
Nov 24 09:19:26 hera kernel: [ 10.374484] EXT3-fs: mounted filesystem with ordered data mode.
Nov 24 09:19:26 hera kernel: [ 12.047421] r8169: eth0: link up
Nov 24 09:19:26 hera rsyslogd: [origin software="rsyslogd" swVersion="3.18.6" x-pid="1562" x-info="http://www.rsyslog.com"] restart
Nov 24 09:19:29 hera dhcpd: Internet Systems Consortium DHCP Server V3.1.1
Nov 24 09:19:29 hera dhcpd: Copyright 2004-2008 Internet Systems Consortium.
Nov 24 09:19:29 hera dhcpd: All rights reserved.
Nov 24 09:19:29 hera dhcpd: For info, please visit http://www.isc.org/sw/dhcp/
Nov 24 09:19:29 hera dhcpd: Wrote 1 leases to leases file.
Nov 24 09:19:47 hera kernel: [ 34.572747] __ratelimit: 44 callbacks suppressed
Nov 24 09:19:53 hera kernel: [ 40.630102] __ratelimit: 10 callbacks suppressed
Nov 24 09:20:02 hera kernel: [ 49.841071] __ratelimit: 344 callbacks suppressed
Nov 24 09:20:08 hera kernel: [ 54.956858] __ratelimit: 10 callbacks suppressed
Nov 24 09:20:13 hera kernel: [ 60.020273] __ratelimit: 146 callbacks suppressed
Nov 24 09:20:18 hera kernel: [ 65.228245] __ratelimit: 87 callbacks suppressed
Nov 24 09:20:23 hera kernel: [ 70.250332] __ratelimit: 235 callbacks suppressed
Nov 24 09:20:41 hera kernel: [ 88.301477] __ratelimit: 511 callbacks suppressed
Nov 24 09:20:46 hera kernel: [ 93.560959] __ratelimit: 405 callbacks suppressed
Nov 24 09:20:56 hera kernel: [ 103.578183] __ratelimit: 32 callbacks suppressed
Nov 24 09:21:02 hera kernel: [ 108.977329] __ratelimit: 144 callbacks suppressed
Nov 24 09:21:07 hera kernel: [ 114.503354] __ratelimit: 108 callbacks suppressed
Nov 24 09:21:13 hera kernel: [ 120.250057] __ratelimit: 3 callbacks suppressed
Nov 24 09:21:28 hera kernel: [ 135.094505] __ratelimit: 196 callbacks suppressed
Nov 24 09:21:37 hera kernel: [ 144.262140] __ratelimit: 99 callbacks suppressed
Nov 24 09:22:36 hera kernel: [ 203.222475] __ratelimit: 99 callbacks suppressed
Nov 24 09:22:42 hera kernel: [ 209.221034] __ratelimit: 85 callbacks suppressed
Nov 24 09:22:49 hera kernel: [ 216.382091] __ratelimit: 150 callbacks suppressed
Nov 24 09:22:54 hera kernel: [ 221.661276] __ratelimit: 149 callbacks suppressed
Nov 24 09:23:00 hera kernel: [ 227.289378] __ratelimit: 226 callbacks suppressed
Nov 24 09:23:06 hera kernel: [ 233.688743] __ratelimit: 96 callbacks suppressed
Nov 24 09:23:12 hera kernel: [ 239.805100] __ratelimit: 93 callbacks suppressed
Nov 24 09:23:31 hera kernel: [ 258.914841] __ratelimit: 23 callbacks suppressed
Nov 24 09:23:37 hera kernel: [ 264.008979] __ratelimit: 26 callbacks suppressed
Nov 24 09:23:48 hera kernel: [ 275.455431] __ratelimit: 296 callbacks suppressed
Nov 24 09:23:54 hera kernel: [ 281.375943] __ratelimit: 420 callbacks suppressed
Nov 24 09:23:59 hera kernel: [ 286.832103] __ratelimit: 211 callbacks suppressed
Nov 24 09:24:05 hera kernel: [ 292.048403] __ratelimit: 63 callbacks suppressed
Nov 24 09:24:10 hera kernel: [ 297.054302] __ratelimit: 315 callbacks suppressed
et enfin un bout du syslog
Nov 24 09:46:22 hera kernel: [ 1629.235066] do_IRQ: 0.83 No irq handler for vector (irq -1)
Nov 24 09:46:22 hera kernel: [ 1629.502946] do_IRQ: 0.83 No irq handler for vector (irq -1)
Nov 24 09:46:29 hera kernel: [ 1636.347251] __ratelimit: 57 callbacks suppressed
Nov 24 09:46:29 hera kernel: [ 1636.347257] do_IRQ: 0.83 No irq handler for vector (irq -1)
Nov 24 09:46:29 hera kernel: [ 1636.368495] do_IRQ: 0.83 No irq handler for vector (irq -1)
Nov 24 09:46:29 hera kernel: [ 1636.392087] do_IRQ: 0.83 No irq handler for vector (irq -1)
Nov 24 09:46:29 hera kernel: [ 1636.392145] do_IRQ: 0.83 No irq handler for vector (irq -1)
Nov 24 09:46:29 hera kernel: [ 1636.414778] do_IRQ: 0.83 No irq handler for vector (irq -1)
Nov 24 09:46:29 hera kernel: [ 1636.433454] do_IRQ: 0.83 No irq handler for vector (irq -1)
Nov 24 09:46:29 hera kernel: [ 1636.433598] do_IRQ: 0.83 No irq handler for vector (irq -1)
Nov 24 09:46:29 hera kernel: [ 1636.448977] do_IRQ: 0.83 No irq handler for vector (irq -1)
Nov 24 09:46:29 hera kernel: [ 1636.465081] do_IRQ: 0.83 No irq handler for vector (irq -1)
Nov 24 09:46:29 hera kernel: [ 1636.486172] do_IRQ: 0.83 No irq handler for vector (irq -1)
Nov 24 09:46:34 hera kernel: [ 1641.739592] __ratelimit: 173 callbacks suppressed
Nov 24 09:46:34 hera kernel: [ 1641.739599] do_IRQ: 0.83 No irq handler for vector (irq -1)
Nov 24 09:46:34 hera kernel: [ 1641.783688] do_IRQ: 0.83 No irq handler for vector (irq -1)
Nov 24 09:46:34 hera kernel: [ 1641.864671] do_IRQ: 0.83 No irq handler for vector (irq -1)
Nov 24 09:46:34 hera kernel: [ 1641.864816] do_IRQ: 0.83 No irq handler for vector (irq -1)
Nov 24 09:46:34 hera kernel: [ 1641.864820] do_IRQ: 0.83 No irq handler for vector (irq -1)
Nov 24 09:46:34 hera kernel: [ 1641.896234] do_IRQ: 0.83 No irq handler for vector (irq -1)
Nov 24 09:46:35 hera kernel: [ 1642.095635] do_IRQ: 0.83 No irq handler for vector (irq -1)
Nov 24 09:46:35 hera kernel: [ 1642.098570] do_IRQ: 0.83 No irq handler for vector (irq -1)
Nov 24 09:46:35 hera kernel: [ 1642.098687] do_IRQ: 0.83 No irq handler for vector (irq -1)
Nov 24 09:46:35 hera kernel: [ 1642.101352] do_IRQ: 0.83 No irq handler for vector (irq -1)
Voila s’il vous faut autre chose faites signe
en attendant vos idée géniale j y retourne
