Je peux pas envoyé de mail ni en recevoir
Oui encore moi :mrgreen:
Voilà je vient de testé mon serveur mail et je peux pas en envoyé de mail ni en recevoir. J’utilise SquirrelMail comme logiciel.
Merci beaucoup de votre aide
Cordialement, Warranty
Avec tous les détails fournis, ça va être facile…
Quels détailles à tu besoin ?
Par exemple:
Messages d’erreurs dans squirrelmail
Les logs (pas tout s’il te plais, les dernières lignes après un essai d’envoi par exemple) - mail.err mail.warn pour commencer.
Voila,
mail.err
Apr 4 00:55:01 0001 postfix/smtpd[29409]: fatal: no SASL authentication mechanisms Apr 4 10:32:18 0001 dovecot: auth-worker(default): Warning: World-writable config file '/etc/mysql/my.cnf' is ignored Apr 4 12:17:45 0001 dovecot: auth-worker(default): Warning: World-writable config file '/etc/mysql/my.cnf' is ignored Apr 4 14:06:26 0001 dovecot: auth-worker(default): Warning: World-writable config file '/etc/mysql/my.cnf' is ignored Apr 5 00:10:02 0001 postfix/smtpd[7569]: fatal: no SASL authentication mechanisms Apr 5 11:14:46 0001 dovecot: auth-worker(default): Warning: World-writable config file '/etc/mysql/my.cnf' is ignored
mail.warn
Apr 4 14:06:26 0001 dovecot: auth-worker(default): Warning: World-writable config file '/etc/mysql/my.cnf' is ignored Apr 5 00:09:56 0001 dovecot: dovecot: Killed with signal 15 (by pid=7438 uid=0 code=kill) Apr 5 00:10:02 0001 postfix/smtpd[7569]: warning: SASL: Connect to private/auth failed: No such file or directory Apr 5 00:10:02 0001 postfix/smtpd[7569]: fatal: no SASL authentication mechanisms Apr 5 00:10:02 0001 postfix/postqueue[7603]: warning: close: Connection reset by peer Apr 5 11:14:46 0001 dovecot: auth-worker(default): Warning: World-writable config file '/etc/mysql/my.cnf' is ignored Apr 5 11:24:30 0001 postfix/local[19257]: warning: alias database loop for webmaster Apr 5 11:24:30 0001 postfix/local[19257]: warning: alias database loop for webmaster
Tu as utilisé quoi pour effectuer ton serveur de messagerie ?
J’ai utilisé se tutoriel howtoforge.com/perfect-serve … onfig-3-p5
A moins que tu parle du matériel ?
Re,
C’est postfix mysql et dovecot. Il vaudrait mieux répondre ça que de mettre un lien.
Pense à ceux qui veulent aider, s’ils doivent faire des recherches pour toi… t’imagine bien qu’ils vont fuir!
Donne tes conf, si un courageux passe par là il prendra peut-être la peine de chercher.
dovecot.conf
main.cf + master+cf
… :116 … tes “log” sont plutôt parlants … non ?
Est tu redevable envers ton FAI … ? … :033
Désolé de ne pas être clair dans mes messages, cela fait seulement 2 semaines que je suis sous Debian et je suis entièrement débutant sous ce système d’exploitation. Étant moi-même informaticien, mais uniquement sous Windows donc c’est un peu dure par moment à fournir les informations que vous demandez.
Sinon les fichiers
dovecot.conf
main.cf
master+cf
Je peux les trouver ou ?
Merci en tout cas de votre aide et votre patience.
Re,
Ce qui est sur, c’est que d’après les messages dans les logs, le fichier /etc/mysql/my.cnf ,n’a pas le bon chown
Ceci devrait régler l’affaire:
Pour le reste c’est plus “ardu”…
Les fichiers:
/etc/dovecot/devocot.conf
/etc/postfix/main.cf
/etc/postfix/master.cf
Tu es repassé sur le tuto et tu as vérifié tes fichiers ?
Edit… chmod et non chown. Désolé!
J’ai vérifié les fichiers en fonction du tuto et il son bien configuré.
Pour les fichiers:
devecot.conf
[code]## Dovecot configuration file
base_dir = /var/run/dovecot/
protocols = imap imaps pop3 pop3s
disable_plaintext_auth = no
log_timestamp = "%Y-%m-%d %H:%M:%S "
ssl_cert_file = /etc/ssl/.my-domain.tld/.my-domain.tld.crt
ssl_key_file = /etc/ssl/.my-domain.tld/.my-domain.tld.key
mail_privileged_group = mail
login_greeting = my-domain.tld IMAP server ready…
IMAP specific settings
protocol imap {
mail_executable = /usr/lib/dovecot/rawlog /usr/lib/dovecot/imap
mail_plugins = quota imap_quota
POP3 specific settings
protocol pop3 {
mail_executable = /usr/lib/dovecot/rawlog /usr/lib/dovecot/pop3
pop3_uidl_format = %08Xu%08Xv
LDA specific settings
protocol lda {
Address to use when sending rejection mails.
postmaster_address = postmaster@my-domain.tld
Support for dynamically loadable plugins. mail_plugins is a space separated
list of plugins to load.
mail_plugin_dir = /usr/lib/dovecot/modules/lda
UNIX socket path to master authentication server to find users.
auth_socket_path = /var/run/dovecot/auth-master
Enabling Sieve plugin for server-side mail filtering
mail_plugins = sieve quota
Plugin settings
plugin {
quota = maildir
sieve=/var/vmail/%d/%n/.sieve
Authentication processes
Executable location
#auth_executable = /usr/lib/dovecot/dovecot-auth
auth default {
mechanisms = plain login
SQL database <doc/wiki/AuthDatabase.SQL.txt>
passdb sql {
# Path for SQL configuration file
args = /etc/dovecot/dovecot-sql.conf
new quota support:
userdb prefetch {
userdb sql {
dovecot-lda specific settings
socket listen {
master {
mode = 0600
user = vmail # User running Dovecot LDA
#group = vmail # Or alternatively mode 0660 + LDA user in this group
client {
path = /var/spool/postfix/private/auth
mode = 0660
user = postfix
group = postfix
mail_location = maildir:/var/vmail/%d/%n/Maildir
mail_uid = 5000
mail_gid = 5000[/code]
main.cf
[code]# See /usr/share/postfix/main.cf.dist for a commented, more complete version
Debian specific: Specifying a file name will cause the first
line of that file to be used as the name. The Debian default
is /etc/mailname.
#myorigin = /etc/mailname
smtpd_banner = $myhostname ESMTP $mail_name (Debian/GNU)
biff = no
appending .domain is the MUA’s job.
append_dot_mydomain = no
Uncomment the next line to generate “delayed mail” warnings
#delay_warning_time = 4h
readme_directory = /usr/share/doc/postfix
TLS parameters
smtpd_tls_cert_file = /etc/postfix/smtpd.cert
smtpd_tls_key_file = /etc/postfix/smtpd.key
smtpd_use_tls = yes
smtpd_tls_session_cache_database = btree:${data_directory}/smtpd_scache
smtp_tls_session_cache_database = btree:${data_directory}/smtp_scache
See /usr/share/doc/postfix/TLS_README.gz in the postfix-doc package for
information on enabling SSL in the smtp client.
myhostname = 0001.lacibox.tk
alias_maps = hash:/etc/aliases
alias_database = hash:/etc/aliases
mydestination = 0001.lacibox.tk, localhost, localhost.localdomain
relayhost =
mynetworks = 127.0.0.0/8 [::1]/128
mailbox_command = procmail -a "$EXTENSION"
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = all
html_directory = /usr/share/doc/postfix/html
virtual_alias_domains =
virtual_alias_maps = proxy:mysql:/etc/postfix/mysql-virtual_forwardings.cf, mysql:/etc/postfix/mysql-virtual_email2email.cf
virtual_mailbox_domains = proxy:mysql:/etc/postfix/mysql-virtual_domains.cf
virtual_mailbox_maps = proxy:mysql:/etc/postfix/mysql-virtual_mailboxes.cf
virtual_mailbox_base = /var/vmail
virtual_uid_maps = static:5000
virtual_gid_maps = static:5000
smtpd_sasl_auth_enable = yes
broken_sasl_auth_clients = yes
smtpd_sasl_authenticated_header = yes
smtpd_recipient_restrictions = permit_mynetworks, permit_sasl_authenticated, check_recipient_access mysql:/etc/postfix/mysql-virtual_recipient.cf, reject_unauth_destination
smtpd_tls_security_level = may
transport_maps = proxy:mysql:/etc/postfix/mysql-virtual_transports.cf
relay_domains = mysql:/etc/postfix/mysql-virtual_relaydomains.cf
relay_recipient_maps = mysql:/etc/postfix/mysql-virtual_relayrecipientmaps.cf
virtual_create_maildirsize = yes
virtual_maildir_extended = yes
virtual_mailbox_limit_maps = proxy:mysql:/etc/postfix/mysql-virtual_mailbox_limit_maps.cf
virtual_mailbox_limit_override = yes
virtual_maildir_limit_message = "The user you are trying to reach is over quota."
virtual_overquota_bounce = yes
proxy_read_maps = $local_recipient_maps $mydestination $virtual_alias_maps $virtual_alias_domains $virtual_mailbox_maps $virtual_mailbox_domains $relay_recipient_maps $relay_domains $canonical_maps $sender_canonical_maps $recipient_canonical_maps $relocated_maps $transport_maps $mynetworks $virtual_mailbox_limit_maps
smtpd_sender_restrictions = check_sender_access mysql:/etc/postfix/mysql-virtual_sender.cf
smtpd_client_restrictions = check_client_access mysql:/etc/postfix/mysql-virtual_client.cf
maildrop_destination_concurrency_limit = 1
maildrop_destination_recipient_limit = 1
virtual_transport = dovecot
header_checks = regexp:/etc/postfix/header_checks
mime_header_checks = regexp:/etc/postfix/mime_header_checks
nested_header_checks = regexp:/etc/postfix/nested_header_checks
body_checks = regexp:/etc/postfix/body_checks
dovecot_destination_recipient_limit = 1
smtpd_sasl_type = dovecot
smtpd_sasl_path = private/auth
content_filter = amavis:[127.0.0.1]:10024
receive_override_options = no_address_mappings
message_size_limit = 0[/code]
master.cf
[code]
Postfix master process configuration file. For details on the format
of the file, see the master(5) manual page (command: “man 5 master”).
Do not forget to execute “postfix reload” after editing this file.
service type private unpriv chroot wakeup maxproc command + args
(yes) (yes) (yes) (never) (100)
smtp inet n - - - - smtpd
#submission inet n - - - - smtpd
-o smtpd_tls_security_level=encrypt
-o smtpd_sasl_auth_enable=yes
-o smtpd_client_restrictions=permit_sasl_authenticated,reject
-o milter_macro_daemon_name=ORIGINATING
#smtps inet n - - - - smtpd
-o smtpd_tls_wrappermode=yes
#628 inet n - - - - qmqpd
pickup fifo n - - 60 1 pickup
cleanup unix n - - - 0 cleanup
qmgr fifo n - n 300 1 qmgr
#qmgr fifo n - - 300 1 oqmgr
tlsmgr unix - - - 1000? 1 tlsmgr
rewrite unix - - - - - trivial-rewrite
bounce unix - - - - 0 bounce
defer unix - - - - 0 bounce
trace unix - - - - 0 bounce
verify unix - - - - 1 verify
flush unix n - - 1000? 0 flush
proxymap unix - - n - - proxymap
proxywrite unix - - n - 1 proxymap
smtp unix - - - - - smtp
When relaying mail as backup MX, disable fallback_relay to avoid MX loops
relay unix - - - - - smtp
-o smtp_fallback_relay=
-o smtp_helo_timeout=5 -o smtp_connect_timeout=5
showq unix n - - - - showq
error unix - - - - - error
retry unix - - - - - error
discard unix - - - - - discard
local unix - n n - - local
virtual unix - n n - - virtual
lmtp unix - - - - - lmtp
anvil unix - - - - 1 anvil
scache unix - - - - 1 scache
Interfaces to non-Postfix software. Be sure to examine the manual
pages of the non-Postfix software to find out what options it wants.
Many of the following services use the Postfix pipe(8) delivery
agent. See the pipe(8) man page for information about ${recipient}
and other message envelope options.
maildrop. See the Postfix MAILDROP_README file for details.
Also specify in main.cf: maildrop_destination_recipient_limit=1
maildrop unix - n n - - pipe
flags=DRhu user=vmail argv=/usr/bin/maildrop -d vmail ${extension} ${recipient} ${user} ${nexthop} ${sender}
Recent Cyrus versions can use the existing “lmtp” master.cf entry.
Specify in cyrus.conf:
lmtp cmd=“lmtpd -a” listen=“localhost:lmtp” proto=tcp4
Specify in main.cf one or more of the following:
mailbox_transport = lmtp:inet:localhost
virtual_transport = lmtp:inet:localhost
Cyrus 2.1.5 (Amos Gouaux)
Also specify in main.cf: cyrus_destination_recipient_limit=1
#cyrus unix - n n - - pipe
user=cyrus argv=/cyrus/bin/deliver -e -r ${sender} -m ${extension} ${user}
Old example of delivery via Cyrus.
#old-cyrus unix - n n - - pipe
flags=R user=cyrus argv=/cyrus/bin/deliver -e -m ${extension} ${user}
See the Postfix UUCP_README file for configuration details.
uucp unix - n n - - pipe
flags=Fqhu user=uucp argv=uux -r -n -z -a$sender - $nexthop!rmail ($recipient)
Other external delivery methods.
ifmail unix - n n - - pipe
flags=F user=ftn argv=/usr/lib/ifmail/ifmail -r $nexthop ($recipient)
bsmtp unix - n n - - pipe
flags=Fq. user=bsmtp argv=/usr/lib/bsmtp/bsmtp -t$nexthop -f$sender $recipient
scalemail-backend unix - n n - 2 pipe
flags=R user=scalemail argv=/usr/lib/scalemail/bin/scalemail-store ${nexthop} ${user} ${extension}
mailman unix - n n - - pipe
flags=FR user=list argv=/usr/lib/mailman/bin/postfix-to-mailman.py
${nexthop} ${user}
dovecot unix - n n - - pipe
flags=DRhu user=vmail:vmail argv=/usr/lib/dovecot/deliver -f ${sender} -d ${user}@${nexthop}
amavis unix - - - - 2 smtp
-o smtp_data_done_timeout=1200
-o smtp_send_xforward_command=yes
127.0.0.1:10025 inet n - - - - smtpd
-o content_filter=
-o local_recipient_maps=
-o relay_recipient_maps=
-o smtpd_restriction_classes=
-o smtpd_helo_restrictions=
-o smtpd_sender_restrictions=
-o smtpd_recipient_restrictions=permit_mynetworks,reject
-o mynetworks=127.0.0.0/8
-o strict_rfc821_envelopes=yes
-o receive_override_options=no_unknown_recipient_checks,no_header_body_checks
-o smtpd_bind_address=127.0.0.1[/code]
As-tu bien suivi la fin du tuto ?
Pas de problèmes particuliers à l’installation ?
Tu devrais essayer en désactivant smtpd_tls
