Le dmesg
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.3.0-0.bpo.1-amd64 (debian-kernel@lists.debian.org) (gcc version 4.9.2 (Debian 4.9.2-10) ) #1 SMP Debian 4.3.3-2~bpo8+1 (2015-12-23)
[ 0.000000] Command line: BOOT_IMAGE=/vmlinuz-4.3.0-0.bpo.1-amd64 root=/dev/mapper/rootvg-rootlv ro quiet
[ 0.000000] x86/fpu: xstate_offset[2]: 0240, xstate_sizes[2]: 0100
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x01: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x02: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x04: 'AVX registers'
[ 0.000000] x86/fpu: Enabled xstate features 0x7, context size is 0x340 bytes, using 'standard' format.
[ 0.000000] x86/fpu: Using 'eager' FPU context switches.
[ 0.000000] e820: BIOS-provided physical RAM map:
[ 0.000000] init_memory_mapping: [mem 0x00000000-0x000fffff]
[ 0.000000] [mem 0x00000000-0x000fffff] page 4k
[ 0.000000] BRK [0x01d38000, 0x01d38fff] PGTABLE
[ 0.000000] BRK [0x01d39000, 0x01d39fff] PGTABLE
[ 0.000000] BRK [0x01d3a000, 0x01d3afff] PGTABLE
[ 0.000000] init_memory_mapping: [mem 0x41ee00000-0x41effffff]
[ 0.000000] [mem 0x41ee00000-0x41effffff] page 2M
[ 0.000000] BRK [0x01d3b000, 0x01d3bfff] PGTABLE
[ 0.000000] init_memory_mapping: [mem 0x400000000-0x41edfffff]
[ 0.000000] [mem 0x400000000-0x41edfffff] page 2M
[ 0.000000] init_memory_mapping: [mem 0x3e0000000-0x3ffffffff]
[ 0.000000] [mem 0x3e0000000-0x3ffffffff] page 2M
[ 0.000000] BRK [0x01d3c000, 0x01d3cfff] PGTABLE
[ 0.000000] init_memory_mapping: [mem 0x00100000-0xdda1ffff]
[ 0.000000] [mem 0x00100000-0x001fffff] page 4k
[ 0.000000] [mem 0x00200000-0xdd9fffff] page 2M
[ 0.000000] [mem 0xdda00000-0xdda1ffff] page 4k
[ 0.000000] init_memory_mapping: [mem 0xde81c000-0xde81cfff]
[ 0.000000] [mem 0xde81c000-0xde81cfff] page 4k
[ 0.000000] BRK [0x01d3d000, 0x01d3dfff] PGTABLE
[ 0.000000] init_memory_mapping: [mem 0xde860000-0xdec7ffff]
[ 0.000000] [mem 0xde860000-0xde9fffff] page 4k
[ 0.000000] [mem 0xdea00000-0xdebfffff] page 2M
[ 0.000000] [mem 0xdec00000-0xdec7ffff] page 4k
[ 0.000000] init_memory_mapping: [mem 0xdeff4000-0xdeffffff]
[ 0.000000] [mem 0xdeff4000-0xdeffffff] page 4k
[ 0.000000] init_memory_mapping: [mem 0x100000000-0x3dfffffff]
[ 0.000000] [mem 0x100000000-0x3dfffffff] page 2M
[ 0.000000] RAMDISK: [mem 0x35e9c000-0x36f45fff]
[ 0.000000] ACPI: Early table checksum verification disabled
[ 0.000000] ACPI: RSDP 0x00000000000F0490 000024 (v02 ALASKA)
[ 0.000000] ACPI: XSDT 0x00000000DDC24078 00006C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FACP 0x00000000DDC2EC98 00010C (v05 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: DSDT 0x00000000DDC24180 00AB17 (v02 ALASKA A M I 00000022 INTL 20051117)
[ 0.000000] ACPI: FACS 0x00000000DDD4F080 000040
[ 0.000000] ACPI: APIC 0x00000000DDC2EDA8 000072 (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FPDT 0x00000000DDC2EE20 000044 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: MCFG 0x00000000DDC2EE68 00003C (v01 ALASKA A M I 01072009 MSFT 00000097)
[ 0.000000] ACPI: HPET 0x00000000DDC2EEA8 000038 (v01 ALASKA A M I 01072009 AMI. 00000005)
[ 0.000000] ACPI: SSDT 0x00000000DDC2EEE0 00036D (v01 SataRe SataTabl 00001000 INTL 20091112)
[ 0.000000] ACPI: SSDT 0x00000000DDC2F250 0009AA (v01 PmRef Cpu0Ist 00003000 INTL 20051117)
[ 0.000000] ACPI: SSDT 0x00000000DDC2FC00 000A92 (v01 PmRef CpuPm 00003000 INTL 20051117)
[ 0.000000] ACPI: BGRT 0x00000000DDC306F0 000038 (v00 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] No NUMA configuration found
[ 0.000000] Faking a node at [mem 0x0000000000000000-0x000000041effffff]
[ 0.000000] NODE_DATA(0) allocated [mem 0x41efeb000-0x41efeefff]
[ 0.000000] [ffffea0000000000-ffffea00107fffff] PMD -> [ffff88040e600000-ffff88041e5fffff] on node 0
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.000000] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x000000041effffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000001000-0x000000000009cfff]
[ 0.000000] node 0: [mem 0x0000000000100000-0x00000000dda1ffff]
[ 0.000000] node 0: [mem 0x00000000de81c000-0x00000000de81cfff]
[ 0.000000] node 0: [mem 0x00000000de860000-0x00000000dec7ffff]
[ 0.000000] node 0: [mem 0x00000000deff4000-0x00000000deffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000041effffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000041effffff]
[ 0.000000] On node 0 totalpages: 4181481
[ 0.000000] DMA zone: 64 pages used for memmap
[ 0.000000] DMA zone: 21 pages reserved
[ 0.000000] DMA zone: 3996 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 14138 pages used for memmap
[ 0.000000] DMA32 zone: 904781 pages, LIFO batch:31
[ 0.000000] Normal zone: 51136 pages used for memmap
[ 0.000000] Normal zone: 3272704 pages, LIFO batch:31
[ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.000000] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.000000] e820: [mem 0xdf000000-0xf7ffffff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.000000] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 32 pages/cpu @ffff88041ec00000 s94168 r8192 d28712 u524288
[ 0.000000] pcpu-alloc: s94168 r8192 d28712 u524288 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 0 1 2 3
[ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 4116122
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: BOOT_IMAGE=/vmlinuz-4.3.0-0.bpo.1-amd64 root=/dev/mapper/rootvg-rootlv ro quiet
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Calgary: detecting Calgary via BIOS EBDA area
[ 0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.000000] Memory: 16366172K/16725924K available (5674K kernel code, 1118K rwdata, 2792K rodata, 1300K init, 844K bss, 359752K reserved, 0K cma-reserved)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:33024 nr_irqs:456 16
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[ 0.000000] hpet clockevent registered
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 3409.949 MHz processor
[ 0.000024] Calibrating delay loop (skipped), value calculated using timer frequency.. 6819.89 BogoMIPS (lpj=13639796)
[ 0.000026] pid_max: default: 32768 minimum: 301
[ 0.000031] ACPI: Core revision 20150818
[ 0.004887] ACPI: 4 ACPI AML tables successfully acquired and loaded
[ 0.004914] Security Framework initialized
[ 0.004915] Yama: disabled by default; enable with sysctl kernel.yama.*
[ 0.004920] AppArmor: AppArmor disabled by boot time parameter
[ 0.005609] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.009295] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.011003] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.011016] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.011278] Initializing cgroup subsys io
[ 0.011283] Initializing cgroup subsys memory
[ 0.011287] Initializing cgroup subsys devices
[ 0.011289] Initializing cgroup subsys freezer
[ 0.011291] Initializing cgroup subsys net_cls
[ 0.011293] Initializing cgroup subsys perf_event
[ 0.011295] Initializing cgroup subsys net_prio
[ 0.011312] CPU: Physical Processor ID: 0
[ 0.011313] CPU: Processor Core ID: 0
[ 0.011316] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.011317] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[ 0.011576] mce: CPU supports 9 MCE banks
[ 0.011587] CPU0: Thermal monitoring enabled (TM1)
[ 0.011594] process: using mwait in idle threads
[ 0.011596] Last level iTLB entries: 4KB 512, 2MB 8, 4MB 8
[ 0.011597] Last level dTLB entries: 4KB 512, 2MB 32, 4MB 32, 1GB 0
[ 0.011895] Freeing SMP alternatives memory: 20K (ffffffff81c5e000 - ffffffff81c63000)
[ 0.015285] ftrace: allocating 23606 entries in 93 pages
[ 0.022866] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.062512] TSC deadline timer enabled
[ 0.062514] smpboot: CPU0: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz (family: 0x6, model: 0x3a, stepping: 0x9)
[ 0.062532] Performance Events: PEBS fmt1+, 16-deep LBR, IvyBridge events, full-width counters, Intel PMU driver.
[ 0.062546] ... version: 3
[ 0.062547] ... bit width: 48
[ 0.062547] ... generic registers: 8
[ 0.062548] ... value mask: 0000ffffffffffff
[ 0.062549] ... max period: 0000ffffffffffff
[ 0.062549] ... fixed-purpose events: 3
[ 0.062550] ... event mask: 00000007000000ff
[ 0.062915] x86: Booting SMP configuration:
[ 0.062916] .... node #0, CPUs: #1
[ 0.076294] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[ 0.076366] #2 #3
[ 0.103126] x86: Booted up 1 node, 4 CPUs
[ 0.103129] smpboot: Total of 4 processors activated (27279.59 BogoMIPS)
[ 0.105295] devtmpfs: initialized
[ 0.108218] PM: Registering ACPI NVS region [mem 0xddc31000-0xddd50fff] (1179648 bytes)
[ 0.108235] PM: Registering ACPI NVS region [mem 0xde81d000-0xde85ffff] (274432 bytes)
[ 0.108293] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.108351] pinctrl core: initialized pinctrl subsystem
[ 0.108458] NET: Registered protocol family 16
[ 0.121161] cpuidle: using governor ladder
[ 0.125682] cpuidle: using governor menu
[ 0.125762] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.125763] ACPI: bus type PCI registered
[ 0.125764] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.125824] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.125826] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.125831] pmd_set_huge: Cannot satisfy [mem 0xf8000000-0xf8200000] with a huge-page mapping due to MTRR override.
[ 0.125890] PCI: Using configuration type 1 for base access
[ 0.126215] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[ 0.126220] perf_event_intel: PMU erratum BJ122, BV98, HSD29 workaround disabled, HT off
[ 0.137943] ACPI: Added _OSI(Module Device)
[ 0.137944] ACPI: Added _OSI(Processor Device)
[ 0.137945] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.137946] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.139673] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.141560] ACPI: Dynamic OEM Table Load:
[ 0.141565] ACPI: SSDT 0xFFFF88040E0A0000 00083B (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
[ 0.141906] ACPI: Dynamic OEM Table Load:
[ 0.141909] ACPI: SSDT 0xFFFF88040C0C9800 000303 (v01 PmRef ApIst 00003000 INTL 20051117)
[ 0.142198] ACPI: Dynamic OEM Table Load:
[ 0.142201] ACPI: SSDT 0xFFFF88040C0BF800 000119 (v01 PmRef ApCst 00003000 INTL 20051117)
[ 0.142805] ACPI: Interpreter enabled
[ 0.142810] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S1_] (20150818/hwxface-580)
[ 0.142813] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S2_] (20150818/hwxface-580)
[ 0.142822] ACPI: (supports S0 S3 S4 S5)
[ 0.142823] ACPI: Using IOAPIC for interrupt routing
[ 0.142842] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.147232] ACPI: Power Resource [FN00] (off)
[ 0.147292] ACPI: Power Resource [FN01] (off)
[ 0.147350] ACPI: Power Resource [FN02] (off)
[ 0.147408] ACPI: Power Resource [FN03] (off)
[ 0.147465] ACPI: Power Resource [FN04] (off)
[ 0.147865] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[ 0.147869] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.148025] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug PME]
[ 0.148120] acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability]
[ 0.148121] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.148421] PCI host bridge to bus 0000:00
[ 0.148423] pci_bus 0000:00: root bus resource [bus 00-3e]
[ 0.148425] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.148426] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.148427] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.148428] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
[ 0.148429] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[ 0.148430] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[ 0.148431] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[ 0.148432] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
[ 0.148433] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
[ 0.148434] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xfeafffff window]
[ 0.148440] pci 0000:00:00.0: [8086:0150] type 00 class 0x060000
[ 0.148507] pci 0000:00:01.0: [8086:0151] type 01 class 0x060400
[ 0.148529] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.148561] pci 0000:00:01.0: System wakeup disabled by ACPI
[ 0.148610] pci 0000:00:14.0: [8086:1e31] type 00 class 0x0c0330
[ 0.148638] pci 0000:00:14.0: reg 0x10: [mem 0xf7f00000-0xf7f0ffff 64bit]
[ 0.148688] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.148722] pci 0000:00:14.0: System wakeup disabled by ACPI
[ 0.148752] pci 0000:00:16.0: [8086:1e3a] type 00 class 0x078000
[ 0.148780] pci 0000:00:16.0: reg 0x10: [mem 0xf7f1a000-0xf7f1a00f 64bit]
[ 0.148833] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 0.148901] pci 0000:00:1a.0: [8086:1e2d] type 00 class 0x0c0320
[ 0.148927] pci 0000:00:1a.0: reg 0x10: [mem 0xf7f18000-0xf7f183ff]
[ 0.148989] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 0.149033] pci 0000:00:1a.0: System wakeup disabled by ACPI
[ 0.149064] pci 0000:00:1b.0: [8086:1e20] type 00 class 0x040300
[ 0.149087] pci 0000:00:1b.0: reg 0x10: [mem 0xf7f10000-0xf7f13fff 64bit]
[ 0.149142] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.149181] pci 0000:00:1b.0: System wakeup disabled by ACPI
[ 0.149211] pci 0000:00:1c.0: [8086:1e10] type 01 class 0x060400
[ 0.149275] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.149311] pci 0000:00:1c.0: System wakeup disabled by ACPI
[ 0.149342] pci 0000:00:1c.4: [8086:1e18] type 01 class 0x060400
[ 0.149406] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[ 0.149443] pci 0000:00:1c.4: System wakeup disabled by ACPI
[ 0.149472] pci 0000:00:1c.5: [8086:244e] type 01 class 0x060401
[ 0.149535] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
[ 0.149573] pci 0000:00:1c.5: System wakeup disabled by ACPI
[ 0.149604] pci 0000:00:1d.0: [8086:1e26] type 00 class 0x0c0320
[ 0.149630] pci 0000:00:1d.0: reg 0x10: [mem 0xf7f17000-0xf7f173ff]
[ 0.149692] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.149735] pci 0000:00:1d.0: System wakeup disabled by ACPI
[ 0.149766] pci 0000:00:1f.0: [8086:1e44] type 00 class 0x060100
[ 0.149911] pci 0000:00:1f.2: [8086:1e02] type 00 class 0x010601
[ 0.149932] pci 0000:00:1f.2: reg 0x10: [io 0xf070-0xf077]
[ 0.149939] pci 0000:00:1f.2: reg 0x14: [io 0xf060-0xf063]
[ 0.149945] pci 0000:00:1f.2: reg 0x18: [io 0xf050-0xf057]
[ 0.149951] pci 0000:00:1f.2: reg 0x1c: [io 0xf040-0xf043]
[ 0.149958] pci 0000:00:1f.2: reg 0x20: [io 0xf020-0xf03f]
[ 0.149964] pci 0000:00:1f.2: reg 0x24: [mem 0xf7f16000-0xf7f167ff]
[ 0.149987] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.150044] pci 0000:00:1f.3: [8086:1e22] type 00 class 0x0c0500
[ 0.150058] pci 0000:00:1f.3: reg 0x10: [mem 0xf7f15000-0xf7f150ff 64bit]
[ 0.150077] pci 0000:00:1f.3: reg 0x20: [io 0xf000-0xf01f]
[ 0.150172] pci 0000:01:00.0: [1002:6898] type 00 class 0x030000
[ 0.150188] pci 0000:01:00.0: reg 0x10: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.150195] pci 0000:01:00.0: reg 0x18: [mem 0xf7e20000-0xf7e3ffff 64bit]
[ 0.150200] pci 0000:01:00.0: reg 0x20: [io 0xe000-0xe0ff]
[ 0.150208] pci 0000:01:00.0: reg 0x30: [mem 0xf7e00000-0xf7e1ffff pref]
[ 0.150223] pci 0000:01:00.0: supports D1 D2
[ 0.150253] pci 0000:01:00.1: [1002:aa50] type 00 class 0x040300
[ 0.150269] pci 0000:01:00.1: reg 0x10: [mem 0xf7e40000-0xf7e43fff 64bit]
[ 0.150301] pci 0000:01:00.1: supports D1 D2
[ 0.157148] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.157151] pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
[ 0.157155] pci 0000:00:01.0: bridge window [mem 0xf7e00000-0xf7efffff]
[ 0.157159] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.157217] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.157284] pci 0000:03:00.0: [10ec:8168] type 00 class 0x020000
[ 0.157330] pci 0000:03:00.0: reg 0x10: [io 0xd000-0xd0ff]
[ 0.157362] pci 0000:03:00.0: reg 0x18: [mem 0xf0004000-0xf0004fff 64bit pref]
[ 0.157382] pci 0000:03:00.0: reg 0x20: [mem 0xf0000000-0xf0003fff 64bit pref]
[ 0.157458] pci 0000:03:00.0: supports D1 D2
[ 0.157459] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.157492] pci 0000:03:00.0: System wakeup disabled by ACPI
[ 0.165148] pci 0000:00:1c.4: PCI bridge to [bus 03]
[ 0.165153] pci 0000:00:1c.4: bridge window [io 0xd000-0xdfff]
[ 0.165162] pci 0000:00:1c.4: bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.165232] pci 0000:04:00.0: [1b21:1080] type 01 class 0x060401
[ 0.165350] pci 0000:04:00.0: System wakeup disabled by ACPI
[ 0.165374] pci 0000:00:1c.5: PCI bridge to [bus 04-05] (subtractive decode)
[ 0.165379] pci 0000:00:1c.5: bridge window [mem 0xf7d00000-0xf7dfffff]
[ 0.165384] pci 0000:00:1c.5: bridge window [io 0x0000-0x0cf7 window] (subtractive decode)
[ 0.165385] pci 0000:00:1c.5: bridge window [io 0x0d00-0xffff window] (subtractive decode)
[ 0.165386] pci 0000:00:1c.5: bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[ 0.165387] pci 0000:00:1c.5: bridge window [mem 0x000d0000-0x000d3fff window] (subtractive decode)
[ 0.165388] pci 0000:00:1c.5: bridge window [mem 0x000d4000-0x000d7fff window] (subtractive decode)
[ 0.165389] pci 0000:00:1c.5: bridge window [mem 0x000d8000-0x000dbfff window] (subtractive decode)
[ 0.165390] pci 0000:00:1c.5: bridge window [mem 0x000dc000-0x000dffff window] (subtractive decode)
[ 0.165392] pci 0000:00:1c.5: bridge window [mem 0x000e0000-0x000e3fff window] (subtractive decode)
[ 0.165393] pci 0000:00:1c.5: bridge window [mem 0x000e4000-0x000e7fff window] (subtractive decode)
[ 0.165394] pci 0000:00:1c.5: bridge window [mem 0xe0000000-0xfeafffff window] (subtractive decode)
[ 0.165446] pci 0000:05:01.0: [168c:0013] type 00 class 0x020000
[ 0.165488] pci 0000:05:01.0: reg 0x10: [mem 0xf7d00000-0xf7d0ffff]
[ 0.165712] pci 0000:04:00.0: PCI bridge to [bus 05] (subtractive decode)
[ 0.165725] pci 0000:04:00.0: bridge window [mem 0xf7d00000-0xf7dfffff]
[ 0.165734] pci 0000:04:00.0: bridge window [mem 0xf7d00000-0xf7dfffff] (subtractive decode)
[ 0.165735] pci 0000:04:00.0: bridge window [io 0x0000-0x0cf7 window] (subtractive decode)
[ 0.165736] pci 0000:04:00.0: bridge window [io 0x0d00-0xffff window] (subtractive decode)
[ 0.165737] pci 0000:04:00.0: bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[ 0.165738] pci 0000:04:00.0: bridge window [mem 0x000d0000-0x000d3fff window] (subtractive decode)
[ 0.165739] pci 0000:04:00.0: bridge window [mem 0x000d4000-0x000d7fff window] (subtractive decode)
[ 0.165740] pci 0000:04:00.0: bridge window [mem 0x000d8000-0x000dbfff window] (subtractive decode)
[ 0.165741] pci 0000:04:00.0: bridge window [mem 0x000dc000-0x000dffff window] (subtractive decode)
[ 0.165743] pci 0000:04:00.0: bridge window [mem 0x000e0000-0x000e3fff window] (subtractive decode)
[ 0.165744] pci 0000:04:00.0: bridge window [mem 0x000e4000-0x000e7fff window] (subtractive decode)
[ 0.165745] pci 0000:04:00.0: bridge window [mem 0xe0000000-0xfeafffff window] (subtractive decode)
[ 0.166111] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.166149] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.166184] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.166218] ACPI: PCI Interrupt Link [LNKD] (IRQs *3 4 5 6 10 11 12 14 15)
[ 0.166253] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.166288] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 *5 6 10 11 12 14 15)
[ 0.166323] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.166357] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 *6 10 11 12 14 15)
[ 0.166532] ACPI: Enabled 4 GPEs in block 00 to 3F
[ 0.166604] vgaarb: setting as boot device: PCI:0000:01:00.0
[ 0.166605] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.166606] vgaarb: loaded
[ 0.166607] vgaarb: bridge control possible 0000:01:00.0
[ 0.166681] PCI: Using ACPI for IRQ routing
[ 0.168055] PCI: pci_cache_line_size set to 64 bytes
[ 0.168099] e820: reserve RAM buffer [mem 0x0009d800-0x0009ffff]
[ 0.168100] e820: reserve RAM buffer [mem 0xdda20000-0xdfffffff]
[ 0.168101] e820: reserve RAM buffer [mem 0xde81d000-0xdfffffff]
[ 0.168103] e820: reserve RAM buffer [mem 0xdec80000-0xdfffffff]
[ 0.168103] e820: reserve RAM buffer [mem 0xdf000000-0xdfffffff]
[ 0.168104] e820: reserve RAM buffer [mem 0x41f000000-0x41fffffff]
[ 0.168207] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.168211] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 0.170228] clocksource: Switched to clocksource hpet
[ 0.174027] pnp: PnP ACPI init
[ 0.174111] system 00:00: [mem 0xfed40000-0xfed44fff] has been reserved
[ 0.174114] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.174170] system 00:01: [io 0x0680-0x069f] has been reserved
[ 0.174172] system 00:01: [io 0x1000-0x100f] has been reserved
[ 0.174173] system 00:01: [io 0xffff] has been reserved
[ 0.174175] system 00:01: [io 0xffff] has been reserved
[ 0.174176] system 00:01: [io 0x0400-0x0453] could not be reserved
[ 0.174177] system 00:01: [io 0x0458-0x047f] has been reserved
[ 0.174178] system 00:01: [io 0x0500-0x057f] has been reserved
[ 0.174180] system 00:01: [io 0x164e-0x164f] has been reserved
[ 0.174181] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.174201] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.174249] system 00:03: [io 0x0454-0x0457] has been reserved
[ 0.174251] system 00:03: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.174312] system 00:04: [io 0x0290-0x029f] has been reserved
[ 0.174314] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.174349] system 00:05: [io 0x04d0-0x04d1] has been reserved
[ 0.174350] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.174501] pnp 00:06: [dma 0 disabled]
[ 0.174536] pnp 00:06: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.174684] system 00:07: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.174686] system 00:07: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.174687] system 00:07: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.174688] system 00:07: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.174690] system 00:07: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.174691] system 00:07: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.174692] system 00:07: [mem 0xfed90000-0xfed93fff] has been reserved
[ 0.174693] system 00:07: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.174695] system 00:07: [mem 0xff000000-0xffffffff] has been reserved
[ 0.174696] system 00:07: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.174697] system 00:07: [mem 0xf0100000-0xf0100fff] has been reserved
[ 0.174699] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.174783] pnp: PnP ACPI: found 8 devices
[ 0.180624] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.180666] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.180668] pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
[ 0.180670] pci 0000:00:01.0: bridge window [mem 0xf7e00000-0xf7efffff]
[ 0.180672] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.180674] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.180684] pci 0000:00:1c.4: PCI bridge to [bus 03]
[ 0.180686] pci 0000:00:1c.4: bridge window [io 0xd000-0xdfff]
[ 0.180691] pci 0000:00:1c.4: bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.180696] pci 0000:04:00.0: PCI bridge to [bus 05]
[ 0.180703] pci 0000:04:00.0: bridge window [mem 0xf7d00000-0xf7dfffff]
[ 0.180716] pci 0000:00:1c.5: PCI bridge to [bus 04-05]
[ 0.180720] pci 0000:00:1c.5: bridge window [mem 0xf7d00000-0xf7dfffff]
[ 0.180727] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.180728] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.180730] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.180731] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff window]
[ 0.180732] pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff window]
[ 0.180733] pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff window]
[ 0.180734] pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff window]
[ 0.180735] pci_bus 0000:00: resource 11 [mem 0x000e0000-0x000e3fff window]
[ 0.180736] pci_bus 0000:00: resource 12 [mem 0x000e4000-0x000e7fff window]
[ 0.180737] pci_bus 0000:00: resource 13 [mem 0xe0000000-0xfeafffff window]
[ 0.180738] pci_bus 0000:01: resource 0 [io 0xe000-0xefff]
[ 0.180739] pci_bus 0000:01: resource 1 [mem 0xf7e00000-0xf7efffff]
[ 0.180740] pci_bus 0000:01: resource 2 [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.180742] pci_bus 0000:03: resource 0 [io 0xd000-0xdfff]
[ 0.180743] pci_bus 0000:03: resource 2 [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.180744] pci_bus 0000:04: resource 1 [mem 0xf7d00000-0xf7dfffff]
[ 0.180745] pci_bus 0000:04: resource 4 [io 0x0000-0x0cf7 window]
[ 0.180746] pci_bus 0000:04: resource 5 [io 0x0d00-0xffff window]
[ 0.180747] pci_bus 0000:04: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.180748] pci_bus 0000:04: resource 7 [mem 0x000d0000-0x000d3fff window]
[ 0.180749] pci_bus 0000:04: resource 8 [mem 0x000d4000-0x000d7fff window]
[ 0.180750] pci_bus 0000:04: resource 9 [mem 0x000d8000-0x000dbfff window]
[ 0.180751] pci_bus 0000:04: resource 10 [mem 0x000dc000-0x000dffff window]
[ 0.180753] pci_bus 0000:04: resource 11 [mem 0x000e0000-0x000e3fff window]
[ 0.180754] pci_bus 0000:04: resource 12 [mem 0x000e4000-0x000e7fff window]
[ 0.180755] pci_bus 0000:04: resource 13 [mem 0xe0000000-0xfeafffff window]
[ 0.180756] pci_bus 0000:05: resource 1 [mem 0xf7d00000-0xf7dfffff]
[ 0.180757] pci_bus 0000:05: resource 4 [mem 0xf7d00000-0xf7dfffff]
[ 0.180758] pci_bus 0000:05: resource 5 [io 0x0000-0x0cf7 window]
[ 0.180759] pci_bus 0000:05: resource 6 [io 0x0d00-0xffff window]
[ 0.180760] pci_bus 0000:05: resource 7 [mem 0x000a0000-0x000bffff window]
[ 0.180761] pci_bus 0000:05: resource 8 [mem 0x000d0000-0x000d3fff window]
[ 0.180762] pci_bus 0000:05: resource 9 [mem 0x000d4000-0x000d7fff window]
[ 0.180763] pci_bus 0000:05: resource 10 [mem 0x000d8000-0x000dbfff window]
[ 0.180764] pci_bus 0000:05: resource 11 [mem 0x000dc000-0x000dffff window]
[ 0.180765] pci_bus 0000:05: resource 12 [mem 0x000e0000-0x000e3fff window]
[ 0.180766] pci_bus 0000:05: resource 13 [mem 0x000e4000-0x000e7fff window]
[ 0.180767] pci_bus 0000:05: resource 14 [mem 0xe0000000-0xfeafffff window]
[ 0.180810] NET: Registered protocol family 2
[ 0.180966] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.181205] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.181406] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.181434] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[ 0.181494] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[ 0.181582] NET: Registered protocol family 1
[ 0.222207] pci 0000:01:00.0: Video device with shadowed ROM
[ 0.222214] PCI: CLS mismatch (64 != 32), using 64 bytes
[ 0.222263] Unpacking initramfs...
[ 0.435566] Freeing initrd memory: 17064K (ffff880035e9c000 - ffff880036f46000)
[ 0.435587] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.435589] software IO TLB [mem 0xd9a20000-0xdda20000] (64MB) mapped at [ffff8800d9a20000-ffff8800dda1ffff]
[ 0.435637] RAPL PMU detected, API unit is 2^-32 Joules, 3 fixed counters 163840 ms ovfl timer
[ 0.435638] hw unit of domain pp0-core 2^-16 Joules
[ 0.435638] hw unit of domain package 2^-16 Joules
[ 0.435639] hw unit of domain pp1-gpu 2^-16 Joules
[ 0.435750] microcode: CPU0 sig=0x306a9, pf=0x2, revision=0x16
[ 0.435755] microcode: CPU1 sig=0x306a9, pf=0x2, revision=0x16
[ 0.435760] microcode: CPU2 sig=0x306a9, pf=0x2, revision=0x16
[ 0.435765] microcode: CPU3 sig=0x306a9, pf=0x2, revision=0x16
[ 0.435808] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 0.436017] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.436052] audit: initializing netlink subsys (disabled)
[ 0.436068] audit: type=2000 audit(1452278166.432:1): initialized
[ 0.436398] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.436414] zbud: loaded
[ 0.436497] VFS: Disk quotas dquot_6.6.0
[ 0.436509] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.436840] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.436865] io scheduler noop registered
[ 0.436868] io scheduler deadline registered
[ 0.436878] io scheduler cfq registered (default)
[ 0.437270] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.437275] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.437288] intel_idle: MWAIT substates: 0x1120
[ 0.437289] intel_idle: v0.4 model 0x3A
[ 0.437289] intel_idle: lapic_timer_reliable_states 0xffffffff
[ 0.437419] GHES: HEST is not enabled!
[ 0.437470] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.457858] 00:06: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 0.458272] Linux agpgart interface v0.103
[ 0.458311] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[ 0.458312] AMD IOMMUv2 functionality not available on this system
[ 0.458671] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 0.461053] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.461056] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.461194] mousedev: PS/2 mouse device common for all mice
[ 0.461229] rtc_cmos 00:02: RTC can wake from S4
[ 0.461365] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
[ 0.461387] rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 0.461394] Intel P-state driver initializing.
[ 0.461545] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.462510] NET: Registered protocol family 10
[ 0.462776] mip6: Mobile IPv6
[ 0.462780] NET: Registered protocol family 17
[ 0.462798] mpls_gso: MPLS GSO support
[ 0.463251] registered taskstats version 1
[ 0.463293] zswap: loaded using pool lzo/zbud
[ 0.463856] rtc_cmos 00:02: setting system clock to 2016-01-08 18:36:07 UTC (1452278167)
[ 0.463980] PM: Hibernation image not present or could not be loaded.
[ 0.464382] Freeing unused kernel memory: 1300K (ffffffff81b19000 - ffffffff81c5e000)
[ 0.464384] Write protecting the kernel read-only data: 10240k
[ 0.464681] Freeing unused kernel memory: 460K (ffff88000158d000 - ffff880001600000)
[ 0.464985] Freeing unused kernel memory: 1304K (ffff8800018ba000 - ffff880001a00000)
[ 0.508967] systemd-udevd[79]: starting version 215
[ 0.509266] random: systemd-udevd urandom read with 3 bits of entropy available
[ 0.524604] ACPI: bus type USB registered
[ 0.524634] usbcore: registered new interface driver usbfs
[ 0.524644] usbcore: registered new interface driver hub
[ 0.524660] usbcore: registered new device driver usb
[ 0.525241] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.525565] ehci-pci: EHCI PCI platform driver
[ 0.526323] SCSI subsystem initialized
[ 0.526545] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 0.526554] r8169 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 0.526658] ehci-pci 0000:00:1a.0: EHCI Host Controller
[ 0.526666] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 0.526682] ehci-pci 0000:00:1a.0: debug port 2
[ 0.529938] libata version 3.00 loaded.
[ 0.530171] r8169 0000:03:00.0 eth0: RTL8168evl/8111evl at 0xffffc900018b2000, 10:bf:48:bb:ed:b4, XID 0c900800 IRQ 25
[ 0.530174] r8169 0000:03:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[ 0.530571] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
[ 0.530731] ehci-pci 0000:00:1a.0: irq 23, io mem 0xf7f18000
[ 0.530855] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.530857] ACPI: Thermal Zone [TZ00] (28 C)
[ 0.531080] thermal LNXTHERM:01: registered as thermal_zone1
[ 0.531081] ACPI: Thermal Zone [TZ01] (30 C)
[ 0.541887] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 0.541929] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.541931] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.541932] usb usb1: Product: EHCI Host Controller
[ 0.541934] usb usb1: Manufacturer: Linux 4.3.0-0.bpo.1-amd64 ehci_hcd
[ 0.541935] usb usb1: SerialNumber: 0000:00:1a.0
[ 0.542063] hub 1-0:1.0: USB hub found
[ 0.542069] hub 1-0:1.0: 2 ports detected
[ 0.542305] ehci-pci 0000:00:1d.0: EHCI Host Controller
[ 0.542310] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 0.542322] ehci-pci 0000:00:1d.0: debug port 2
[ 0.546211] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
[ 0.546221] ehci-pci 0000:00:1d.0: irq 23, io mem 0xf7f17000
[ 0.557920] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 0.557965] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.557967] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.557969] usb usb2: Product: EHCI Host Controller
[ 0.557970] usb usb2: Manufacturer: Linux 4.3.0-0.bpo.1-amd64 ehci_hcd
[ 0.557971] usb usb2: SerialNumber: 0000:00:1d.0
[ 0.558169] hub 2-0:1.0: USB hub found
[ 0.558177] hub 2-0:1.0: 2 ports detected
[ 0.558430] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.558437] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[ 0.559509] xhci_hcd 0000:00:14.0: hcc params 0x20007181 hci version 0x100 quirks 0x0000b930
[ 0.559516] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 0.559657] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.559659] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.559661] usb usb3: Product: xHCI Host Controller
[ 0.559662] usb usb3: Manufacturer: Linux 4.3.0-0.bpo.1-amd64 xhci-hcd
[ 0.559663] usb usb3: SerialNumber: 0000:00:14.0
[ 0.559859] hub 3-0:1.0: USB hub found
[ 0.559870] hub 3-0:1.0: 4 ports detected
[ 0.560184] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.560188] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
[ 0.560217] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 0.560219] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.560220] usb usb4: Product: xHCI Host Controller
[ 0.560222] usb usb4: Manufacturer: Linux 4.3.0-0.bpo.1-amd64 xhci-hcd
[ 0.560223] usb usb4: SerialNumber: 0000:00:14.0
[ 0.560415] hub 4-0:1.0: USB hub found
[ 0.560428] hub 4-0:1.0: 4 ports detected
[ 0.560875] ahci 0000:00:1f.2: version 3.0
[ 0.573900] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0xc impl SATA mode
[ 0.573904] ahci 0000:00:1f.2: flags: 64bit ncq led clo pio slum part ems apst
[ 0.582596] scsi host0: ahci
[ 0.582810] scsi host1: ahci
[ 0.583016] scsi host2: ahci
[ 0.583147] scsi host3: ahci
[ 0.583286] scsi host4: ahci
[ 0.583405] scsi host5: ahci
[ 0.583454] ata1: DUMMY
[ 0.583456] ata2: DUMMY
[ 0.583458] ata3: SATA max UDMA/133 abar m2048@0xf7f16000 port 0xf7f16200 irq 27
[ 0.583460] ata4: SATA max UDMA/133 abar m2048@0xf7f16000 port 0xf7f16280 irq 27
[ 0.583461] ata5: DUMMY
[ 0.583462] ata6: DUMMY
[ 0.853607] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 0.869587] usb 2-1: new high-speed USB device number 2 using ehci-pci
[ 0.901564] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 0.901589] ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 0.901969] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20150818/psargs-359)
[ 0.901977] ACPI Error: Method parse/execution failed [\_SB.PCI0.SAT0.SPT2._GTF] (Node ffff88040e0b8f68), AE_NOT_FOUND (20150818/psparse-542)
[ 0.902365] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20150818/psargs-359)
[ 0.902372] ACPI Error: Method parse/execution failed [\_SB.PCI0.SAT0.SPT3._GTF] (Node ffff88040e0b8ef0), AE_NOT_FOUND (20150818/psparse-542)
[ 0.902518] ata3.00: ATA-9: SanDisk SDSSDHII960G, X31200RL, max UDMA/133
[ 0.902522] ata3.00: 1875385008 sectors, multi 1: LBA48 NCQ (depth 31/32), AA
[ 0.902798] ata4.00: ATA-9: ST3000DM001-1CH166, CC29, max UDMA/133
[ 0.902811] ata4.00: 5860533168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 0.903400] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20150818/psargs-359)
[ 0.903408] ACPI Error: Method parse/execution failed [\_SB.PCI0.SAT0.SPT3._GTF] (Node ffff88040e0b8ef0), AE_NOT_FOUND (20150818/psparse-542)
[ 0.903463] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20150818/psargs-359)
[ 0.903471] ACPI Error: Method parse/execution failed [\_SB.PCI0.SAT0.SPT2._GTF] (Node ffff88040e0b8f68), AE_NOT_FOUND (20150818/psparse-542)
[ 0.903793] ata4.00: configured for UDMA/133
[ 0.904466] ata3.00: configured for UDMA/133
[ 0.904651] scsi 2:0:0:0: Direct-Access ATA SanDisk SDSSDHII 00RL PQ: 0 ANSI: 5
[ 0.905061] scsi 3:0:0:0: Direct-Access ATA ST3000DM001-1CH1 CC29 PQ: 0 ANSI: 5
[ 0.907116] sd 2:0:0:0: [sda] 1875385008 512-byte logical blocks: (960 GB/894 GiB)
[ 0.907166] sd 3:0:0:0: [sdb] 5860533168 512-byte logical blocks: (3.00 TB/2.72 TiB)
[ 0.907169] sd 3:0:0:0: [sdb] 4096-byte physical blocks
[ 0.907241] sd 3:0:0:0: [sdb] Write Protect is off
[ 0.907244] sd 3:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 0.907271] sd 2:0:0:0: [sda] Write Protect is off
[ 0.907273] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 0.907280] sd 3:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 0.907305] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 0.907710] sda: sda1 sda2 sda3
[ 0.908116] sd 2:0:0:0: [sda] Attached SCSI disk
[ 0.917465] sd 3:0:0:0: [sdb] Attached SCSI disk
[ 0.918049] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 0.918165] sd 3:0:0:0: Attached scsi generic sg1 type 0
[ 0.976926] device-mapper: uevent: version 1.0.3
[ 0.977011] device-mapper: ioctl: 4.33.0-ioctl (2015-8-18) initialised: dm-devel@redhat.com
[ 0.985864] usb 1-1: New USB device found, idVendor=8087, idProduct=0024
[ 0.985868] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 0.986163] hub 1-1:1.0: USB hub found
[ 0.986204] hub 1-1:1.0: 6 ports detected
[ 1.001952] usb 2-1: New USB device found, idVendor=8087, idProduct=0024
[ 1.001966] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.002392] hub 2-1:1.0: USB hub found
[ 1.002610] hub 2-1:1.0: 8 ports detected
[ 1.038736] PM: Starting manual resume from disk
[ 1.038741] PM: Hibernation image partition 252:1 present
[ 1.038742] PM: Looking for hibernation image.
[ 1.038978] PM: Image not found (code -22)
[ 1.038981] PM: Hibernation image not present or could not be loaded.
[ 1.070648] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
[ 1.152005] systemd[1]: RTC configured in localtime, applying delta of 60 minutes to system time.
[ 1.257189] usb 1-1.5: new high-speed USB device number 3 using ehci-pci
[ 1.269941] systemd[1]: Found ordering cycle on basic.target/start
[ 1.269945] systemd[1]: Found dependency on paths.target/start
[ 1.269948] systemd[1]: Found dependency on cups.path/start
[ 1.269950] systemd[1]: Found dependency on sysinit.target/start
[ 1.269952] systemd[1]: Found dependency on rpcbind.service/start
[ 1.269954] systemd[1]: Found dependency on network-online.target/start
[ 1.269956] systemd[1]: Found dependency on network.target/start
[ 1.269957] systemd[1]: Found dependency on firewalld.service/start
[ 1.269959] systemd[1]: Found dependency on basic.target/start
[ 1.269961] systemd[1]: Breaking ordering cycle by deleting job paths.target/start
[ 1.269964] systemd[1]: Job paths.target/start deleted to break ordering cycle starting with basic.target/start
[ 1.270048] systemd[1]: Found ordering cycle on basic.target/start
[ 1.270050] systemd[1]: Found dependency on sysinit.target/start
[ 1.270052] systemd[1]: Found dependency on rpcbind.service/start
[ 1.270055] systemd[1]: Found dependency on network-online.target/start
[ 1.270057] systemd[1]: Found dependency on network.target/start
[ 1.270059] systemd[1]: Found dependency on firewalld.service/start
[ 1.270060] systemd[1]: Found dependency on basic.target/start
[ 1.270062] systemd[1]: Breaking ordering cycle by deleting job rpcbind.service/start
[ 1.270065] systemd[1]: Job rpcbind.service/start deleted to break ordering cycle starting with basic.target/start
[ 1.273173] usb 2-1.8: new full-speed USB device number 3 using ehci-pci
[ 1.297880] lp: driver loaded but no devices found
[ 1.299262] ppdev: user-space parallel port driver
[ 1.305177] fuse init (API version 7.23)
[ 1.314102] systemd-udevd[229]: starting version 215
[ 1.349727] usb 1-1.5: New USB device found, idVendor=1a40, idProduct=0101
[ 1.349732] usb 1-1.5: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.349735] usb 1-1.5: Product: USB 2.0 Hub
[ 1.350033] hub 1-1.5:1.0: USB hub found
[ 1.350093] hub 1-1.5:1.0: 4 ports detected
[ 1.370825] usb 2-1.8: New USB device found, idVendor=045e, idProduct=028e
[ 1.370828] usb 2-1.8: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.370830] usb 2-1.8: Product: Controller
[ 1.370831] usb 2-1.8: Manufacturer: ©Microsoft Corporation
[ 1.370832] usb 2-1.8: SerialNumber: 1A80BD3
[ 1.385206] EDAC MC: Ver: 3.0.0
[ 1.385421] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[ 1.385425] ACPI: Power Button [PWRB]
[ 1.385459] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 1.385461] ACPI: Power Button [PWRF]
[ 1.386146] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20150818/utaddress-254)
[ 1.386150] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 1.386153] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20150818/utaddress-254)
[ 1.386155] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 1.386156] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20150818/utaddress-254)
[ 1.386158] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 1.386158] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20150818/utaddress-254)
[ 1.386160] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 1.386161] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 1.389707] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 1.398852] wmi: Mapper loaded
[ 1.404990] EXT4-fs (dm-0): re-mounted. Opts: errors=remount-ro
[ 1.421038] usb 1-1.6: new high-speed USB device number 4 using ehci-pci
[ 1.433020] tsc: Refined TSC clocksource calibration: 3410.013 MHz
[ 1.433023] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x3127418e06e, max_idle_ns: 440795285561 ns
[ 1.453811] ACPI Warning: SystemIO range 0x000000000000F000-0x000000000000F01F conflicts with OpRegion 0x000000000000F000-0x000000000000F00F (\_SB_.PCI0.SBUS.SMBI) (20150818/utaddress-254)
[ 1.453816] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 1.454106] input: PC Speaker as /devices/platform/pcspkr/input/input4
[ 1.461949] snd_hda_intel 0000:01:00.1: Handle VGA-switcheroo audio client
[ 1.471078] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input6
[ 1.489304] AVX version of gcm_enc/dec engaged.
[ 1.489306] AES CTR mode by8 optimization enabled
[ 1.489910] iTCO_vendor_support: vendor-support=0
[ 1.493342] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 1.493372] iTCO_wdt: Found a Panther Point TCO device (Version=2, TCOBASE=0x0460)
[ 1.493457] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 1.496328] asus_wmi: ASUS WMI generic driver loaded
[ 1.497987] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC887-VD: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[ 1.497989] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 1.497991] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 1.497992] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 1.497993] snd_hda_codec_realtek hdaudioC0D0: dig-out=0x11/0x1e
[ 1.497993] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 1.497995] snd_hda_codec_realtek hdaudioC0D0: Front Mic=0x19
[ 1.497996] snd_hda_codec_realtek hdaudioC0D0: Rear Mic=0x18
[ 1.497997] snd_hda_codec_realtek hdaudioC0D0: Line=0x1a
[ 1.500387] asus_wmi: Initialization: 0x0
[ 1.500402] asus_wmi: BIOS WMI version: 0.9
[ 1.500424] asus_wmi: SFUN value: 0x0
[ 1.500610] input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input7
[ 1.500667] asus_wmi: Number of fans: 1
[ 1.509532] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 1.509578] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[ 1.509616] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 1.509654] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[ 1.509691] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[ 1.511224] sha256_ssse3: Using AVX optimized SHA-256 implementation
[ 1.515698] ath5k 0000:05:01.0: registered as 'phy0'
[ 1.532134] Adding 1998844k swap on /dev/mapper/rootvg-swaplv. Priority:-1 extents:1 across:1998844k SSFS
[ 1.538973] fglrx: module license 'Proprietary. (C) 2002 - ATI Technologies, Starnberg, GERMANY' taints kernel.
[ 1.538975] Disabling lock debugging due to kernel taint
[ 1.561800] cfg80211: World regulatory domain updated:
[ 1.561802] cfg80211: DFS Master region: unset
[ 1.561803] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 1.561804] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 1.561805] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 1.561806] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 1.561807] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 1.561808] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 1.561809] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 1.561810] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 1.561811] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 1.568887] <6>[fglrx] Maximum main memory to use for locked dma buffers: 15628 MBytes.
[ 1.568957] <6>[fglrx] vendor: 1002 device: 6898 revision: 0 count: 1
[ 1.569110] <6>[fglrx] ioport: bar 4, base 0xe000, size: 0x100
[ 1.569230] <6>[fglrx] Kernel PAT support is enabled
[ 1.569239] <6>[fglrx] module loaded - fglrx 15.20.3 [Sep 8 2015] with 1 minors
[ 1.638282] intel_rapl: Found RAPL domain package
[ 1.638285] intel_rapl: Found RAPL domain core
[ 2.111926] ath: EEPROM regdomain: 0x30
[ 2.111929] ath: EEPROM indicates we should expect a direct regpair map
[ 2.111931] ath: Country alpha2 being used: AM
[ 2.111932] ath: Regpair used: 0x30
[ 2.117632] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 2.117858] ath5k: phy0: Atheros AR2414 chip found (MAC: 0x79, PHY: 0x45)
[ 2.119125] cfg80211: Regulatory domain changed to country: AM
[ 2.119127] cfg80211: DFS Master region: ETSI
[ 2.119128] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 2.119129] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 2.119130] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 1800 mBm), (N/A)
[ 2.119131] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 1800 mBm), (0 s)
[ 2.432250] clocksource: Switched to clocksource tsc
[ 2.543882] input: Microsoft X-Box 360 pad as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.8/2-1.8:1.0/input/input13
[ 2.544010] usbcore: registered new interface driver xpad
[ 16.478376] usb 1-1.6: device descriptor read/64, error -110
[ 31.639613] usb 1-1.6: device descriptor read/64, error -110
[ 31.815460] usb 1-1.6: new high-speed USB device number 5 using ehci-pci
[ 46.872798] usb 1-1.6: device descriptor read/64, error -110
[ 62.034017] usb 1-1.6: device descriptor read/64, error -110
[ 62.209846] usb 1-1.6: new high-speed USB device number 6 using ehci-pci
[ 72.607719] usb 1-1.6: device not accepting address 6, error -110
[ 72.679652] usb 1-1.6: new high-speed USB device number 7 using ehci-pci
[ 83.077524] usb 1-1.6: device not accepting address 7, error -110
[ 83.077777] usb 1-1-port6: unable to enumerate USB device
[ 83.149459] usb 1-1.5.1: new full-speed USB device number 8 using ehci-pci
[ 83.245107] usb 1-1.5.1: New USB device found, idVendor=0b05, idProduct=17cb
[ 83.245112] usb 1-1.5.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 83.245114] usb 1-1.5.1: Product: BCM20702A0
[ 83.245116] usb 1-1.5.1: Manufacturer: Broadcom Corp
[ 83.245118] usb 1-1.5.1: SerialNumber: 5CF3706957FF
[ 83.317295] usb 1-1.5.4: new full-speed USB device number 9 using ehci-pci
[ 83.413198] usb 1-1.5.4: New USB device found, idVendor=046d, idProduct=c52b
[ 83.413211] usb 1-1.5.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 83.413214] usb 1-1.5.4: Product: USB Receiver
[ 83.413216] usb 1-1.5.4: Manufacturer: Logitech
[ 83.434443] hidraw: raw HID events driver (C) Jiri Kosina
[ 83.441319] usbcore: registered new interface driver usbhid
[ 83.441323] usbhid: USB HID core driver
[ 83.444830] Bluetooth: Core ver 2.20
[ 83.444845] NET: Registered protocol family 31
[ 83.444846] Bluetooth: HCI device and connection manager initialized
[ 83.444850] Bluetooth: HCI socket layer initialized
[ 83.444853] Bluetooth: L2CAP socket layer initialized
[ 83.444862] Bluetooth: SCO socket layer initialized
[ 83.445122] logitech-djreceiver 0003:046D:C52B.0003: hiddev0,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:1a.0-1.5.4/input2
[ 83.447446] usbcore: registered new interface driver btusb
[ 83.451793] Bluetooth: hci0: BCM: chip id 63
[ 83.452771] Bluetooth: hci0: BCM20702A1 (001.002.014) build 0000
[ 83.455102] bluetooth hci0: firmware: failed to load brcm/BCM20702A1-0b05-17cb.hcd (-2)
[ 83.455158] bluetooth hci0: Direct firmware load for brcm/BCM20702A1-0b05-17cb.hcd failed with error -2
[ 83.455161] Bluetooth: hci0: BCM: Patch brcm/BCM20702A1-0b05-17cb.hcd not found
[ 83.464747] random: nonblocking pool is initialized
[ 83.563756] input: Logitech M215 as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.5/1-1.5.4/1-1.5.4:1.2/0003:046D:C52B.0003/0003:046D:1020.0005/input/input14
[ 83.564073] logitech-hidpp-device 0003:046D:1020.0005: input,hidraw1: USB HID v1.11 Mouse [Logitech M215] on usb-0000:00:1a.0-1.5.4:2
[ 88.554955] input: Logitech K800 as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.5/1-1.5.4/1-1.5.4:1.2/0003:046D:C52B.0003/0003:046D:2010.0004/input/input15
[ 88.555327] logitech-hidpp-device 0003:046D:2010.0004: input,hidraw2: USB HID v1.11 Keyboard [Logitech K800] on usb-0000:00:1a.0-1.5.4:1
[ 89.118687] EXT4-fs (dm-5): mounting ext2 file system using the ext4 subsystem
[ 89.121934] EXT4-fs (dm-5): mounted filesystem without journal. Opts: (null)
[ 89.126167] EXT4-fs (dm-4): mounted filesystem with ordered data mode. Opts: (null)
[ 89.405724] EXT4-fs (dm-2): mounted filesystem with ordered data mode. Opts: (null)
[ 89.487952] EXT4-fs (dm-3): mounted filesystem with ordered data mode. Opts: (null)
[ 89.516013] systemd-journald[218]: Received request to flush runtime journal from PID 1
[ 89.948432] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 89.958419] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 89.963943] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 89.984297] Ebtables v2.0 registered
[ 89.989655] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 90.080118] vboxdrv: Found 4 processor cores
[ 90.098778] vboxdrv: TSC mode is Invariant, tentative frequency 3410000531 Hz
[ 90.098781] vboxdrv: Successfully loaded version 5.0.10_Debian (interface 0x00240000)
[ 90.105352] VBoxNetFlt: Successfully started.
[ 90.109716] VBoxNetAdp: Successfully started.
[ 90.114942] VBoxPciLinuxInit
[ 90.115849] vboxpci: IOMMU not found (not registered)
[ 90.138892] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 90.150444] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 90.180850] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 90.180969] r8169 0000:03:00.0: firmware: failed to load rtl_nic/rtl8168e-3.fw (-2)
[ 90.180971] r8169 0000:03:00.0: Direct firmware load for rtl_nic/rtl8168e-3.fw failed with error -2
[ 90.180974] r8169 0000:03:00.0 eth0: unable to load firmware patch rtl_nic/rtl8168e-3.fw (-2)
[ 90.186833] <6>[fglrx] Firegl kernel thread PID: 1047
[ 90.186886] <6>[fglrx] Firegl kernel thread PID: 1068
[ 90.186926] <6>[fglrx] Firegl kernel thread PID: 1069
[ 90.187009] <6>[fglrx] IRQ 31 Enabled
[ 90.196695] r8169 0000:03:00.0 eth0: link down
[ 90.196752] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 90.202338] r8169 0000:03:00.0 eth0: link down
[ 90.204951] <6>[fglrx] Reserved FB block: Shared offset:0, size:1000000
[ 90.204953] <6>[fglrx] Reserved FB block: Unshared offset:f7b4000, size:4000
[ 90.204954] <6>[fglrx] Reserved FB block: Unshared offset:f7b8000, size:548000
[ 90.204955] <6>[fglrx] Reserved FB block: Unshared offset:3fff3000, size:d000
[ 90.259377] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 91.896452] r8169 0000:03:00.0 eth0: link up
[ 91.896465] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Il y a des erreurs sur la clef bluetooth aussi, mais j’avais tenté de booter sans, j’avais quand même les erreurs usb.
