c’est bien tout ça
quel noyau?
uname --all
sinon préparer un
sudo tail -f /var/log/kern.log
et inserer un equipement usb
je suis sous xfce et j’ai
Applications -> Parametres -> Disques amovibles et medias
c’est bien tout ça
quel noyau?
uname --all
sinon préparer un
voila voila…
uname --all
Linux Emachines 3.2.0-0.bpo.4-amd64 #1 SMP Debian 3.2.68-1+deb7u6~bpo60+1 x86_64 GNU/Linux
May 21 21:54:14 Emachines kernel: [ 7898.395672] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
May 21 21:54:14 Emachines kernel: [ 7898.395682] usb 1-2: Product: Canon Digital Camera
May 21 21:54:14 Emachines kernel: [ 7898.395689] usb 1-2: Manufacturer: Canon Inc.
May 21 21:54:36 Emachines kernel: [ 7920.792907] usb 1-2: USB disconnect, device number 11
May 21 21:55:02 Emachines kernel: [ 7947.076351] usb 1-2: new high-speed USB device number 12 using ehci_hcd
May 21 21:55:02 Emachines kernel: [ 7947.211389] usb 1-2: New USB device found, idVendor=04a9, idProduct=3272
May 21 21:55:02 Emachines kernel: [ 7947.211404] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
May 21 21:55:02 Emachines kernel: [ 7947.211414] usb 1-2: Product: Canon Digital Camera
May 21 21:55:02 Emachines kernel: [ 7947.211421] usb 1-2: Manufacturer: Canon Inc.
May 21 21:55:12 Emachines kernel: [ 7956.610854] usb 1-2: USB disconnect, device number 12
May 21 21:57:12 Emachines kernel: [ 8076.664352] usb 1-1: new high-speed USB device number 13 using ehci_hcd
May 21 21:57:12 Emachines kernel: [ 8076.798185] usb 1-1: New USB device found, idVendor=0bc2, idProduct=2300
May 21 21:57:12 Emachines kernel: [ 8076.798200] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
May 21 21:57:12 Emachines kernel: [ 8076.798210] usb 1-1: Product: Portable
May 21 21:57:12 Emachines kernel: [ 8076.798217] usb 1-1: Manufacturer: Seagate
May 21 21:57:12 Emachines kernel: [ 8076.798223] usb 1-1: SerialNumber: 2GHWWCKJ
May 21 21:57:12 Emachines kernel: [ 8076.799734] scsi5 : usb-storage 1-1:1.0
May 21 21:57:13 Emachines kernel: [ 8077.800202] scsi 5:0:0:0: Direct-Access Seagate Portable 0130 PQ: 0 ANSI: 4
May 21 21:57:13 Emachines kernel: [ 8077.805119] sd 5:0:0:0: Attached scsi generic sg2 type 0
May 21 21:57:13 Emachines kernel: [ 8077.805474] sd 5:0:0:0: [sdb] 976773168 512-byte logical blocks: (500 GB/465 GiB)
May 21 21:57:13 Emachines kernel: [ 8077.806114] sd 5:0:0:0: [sdb] Write Protect is off
May 21 21:57:13 Emachines kernel: [ 8077.806132] sd 5:0:0:0: [sdb] Mode Sense: 2f 08 00 00
May 21 21:57:13 Emachines kernel: [ 8077.806820] sd 5:0:0:0: [sdb] No Caching mode page found
May 21 21:57:13 Emachines kernel: [ 8077.806832] sd 5:0:0:0: [sdb] Assuming drive cache: write through
May 21 21:57:13 Emachines kernel: [ 8077.813937] sd 5:0:0:0: [sdb] No Caching mode page found
May 21 21:57:13 Emachines kernel: [ 8077.813954] sd 5:0:0:0: [sdb] Assuming drive cache: write through
May 21 21:57:13 Emachines kernel: [ 8077.876065] sdb: sdb1
May 21 21:57:13 Emachines kernel: [ 8077.880224] sd 5:0:0:0: [sdb] No Caching mode page found
May 21 21:57:13 Emachines kernel: [ 8077.880242] sd 5:0:0:0: [sdb] Assuming drive cache: write through
May 21 21:57:13 Emachines kernel: [ 8077.880253] sd 5:0:0:0: [sdb] Attached SCSI disk
quand le disque est branché
sudo fdisk -l
df -h
ton noyau est ancien tu devrais avoir le 3.16 au moins
https://packages.debian.org/jessie/linux-image-amd64
`apt-cache policy linux-image*
verifie
sudo apt update
sudo apt full-upgrade
j’avais pas fait attention
Linux Emachines
je connais pas du tout ce matériel
sudo fdisk -l
Disk /dev/sda: 298,1 GiB, 320072933376 bytes, 625142448 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
Disk identifier: 0xa8364380
Device Boot Start End Sectors Size Id Type
/dev/sda1 2048 29362175 29360128 14G 27 Hidden NTFS WinRE
/dev/sda2 * 29362176 29566975 204800 100M 7 HPFS/NTFS/exFAT
/dev/sda3 29566976 224879475 195312500 93,1G 7 HPFS/NTFS/exFAT
/dev/sda4 224880638 625141759 400261122 190,9G 5 Extended
/dev/sda5 224880640 244410367 19529728 9,3G 83 Linux
/dev/sda6 244412416 251359231 6946816 3,3G 82 Linux swap / Solaris
/dev/sda7 251361280 625141759 373780480 178,2G 83 Linux
Partition 5 does not start on physical sector boundary.
Disk /dev/sdb: 465,8 GiB, 500107862016 bytes, 976773168 sectors
Disklabel type: dos
Disk identifier: 0x00030df9
/dev/sdb1 63 976768064 976768002 465,8G 7 HPFS/NTFS/exFAT
c’est normal ca ???
linux-image:
Installé : (aucun)
Candidat : (aucun)
Table de version :
je m’occupe des updates…
il manque *
pour voir si le disque sdb est monté
df -h
c’est bizare ca, dans synaptic je vois linux-image-3.2.0-0.bpo.4-amd64
Linux 3.2 for 64-bit PCs intsaté !?
sudo apt update
disent que tout est ok.
apt-cache policy linux-image-amd64
sudo cat /etc/apt/sources.list
tu dois seulement avoir ca
deb http://ftp.fr.debian.org/debian/ jessie non-free contrib main
deb http://security.debian.org/ jessie/updates main contrib non-free
deb http://ftp.fr.debian.org/debian/ jessie-updates main contrib non-free
deb http://ftp.debian.org/debian/ jessie-backports main contrib non-free
bon j’ai installé 3.16 (via synaptic) je l’ai vu demarrer après le reboot.
maintenant:
linux-image-amd64:
Installé : (aucun)
Candidat : 3.16+63
Table de version :
3.16+63 0
500 http://ftp.fr.debian.org/debian/ jessie/main amd64 Packages
j’ai ca:
deb http://ftp.fr.debian.org/debian/ jessie main contrib non-free
deb http://ftp.fr.debian.org/debian/ jessie-proposed-updates main contrib non-free
deb http://www.deb-multimedia.org jessie main non-free
je change ?
Bonne nouvelle, il y a du mieux: quand je monte mes disques USB, j’arrive a lire le contenu !!
Merci bien pour le dépannage, je respire déja mieux
par contre ils ne se montent pas tout seuls sur gdm. MP3 et Appareil photo non plus, et là je ne sais même pas comment faire pour les monter !?
questions subsidiaire: comment est-il possible que je sois passé de wheezy à jessie alors que mon noyau est resté en wheezy ?
voila le contenu de syslog quand je connecte un appareil photo (ne serait-ce pas ca mon soucis?):
May 22 09:14:45 Emachines kernel: [ 256.152262] usb 1-2: new high-speed USB device number 4 using ehci-pci
May 22 09:14:46 Emachines kernel: [ 256.288195] usb 1-2: New USB device found, idVendor=04a9, idProduct=3272
May 22 09:14:46 Emachines kernel: [ 256.288212] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
May 22 09:14:46 Emachines kernel: [ 256.288221] usb 1-2: Product: Canon Digital Camera
May 22 09:14:46 Emachines kernel: [ 256.288228] usb 1-2: Manufacturer: Canon Inc.
May 22 09:14:46 Emachines mtp-probe: checking bus 1, device 4: "/sys/devices/pci0000:00/0000:00:12.2/usb1/1-2"
May 22 09:14:46 Emachines mtp-probe: bus: 1, device: 4 was not an MTP device
May 22 09:14:46 Emachines systemd-udevd[2411]: failed to execute ‘/lib/udev/socket:@/org/freedesktop/hal/udev_event’ ‘socket:@/org/freedesktop/hal/udev_event’: No such file or directory
May 22 09:14:46 Emachines colord: Device added: sysfs-Canon_Inc.-Canon_Digital_Camera
May 22 09:14:46 Emachines systemd-udevd[2415]: failed to execute ‘/lib/udev/socket:@/org/freedesktop/hal/udev_event’ ‘socket:@/org/freedesktop/hal/udev_event’: No such file or directory
May 22 09:14:46 Emachines colord: Device added: sysfs-(null)
May 22 09:14:46 Emachines org.gtk.Private.GPhoto2VolumeMonitor[1870]: (process:1989): GVFS-GPhoto2-WARNING **: device (null) has no BUSNUM property, ignoring
May 22 09:15:19 Emachines kernel: [ 289.642514] usb 1-2: USB disconnect, device number 4
May 22 09:15:19 Emachines systemd-udevd[2433]: failed to execute ‘/lib/udev/socket:@/org/freedesktop/hal/udev_event’ ‘socket:@/org/freedesktop/hal/udev_event’: No such file or directory
May 22 09:15:19 Emachines colord: device removed: sysfs-(null)
May 22 09:15:19 Emachines systemd-udevd[2435]: failed to execute ‘/lib/udev/socket:@/org/freedesktop/hal/udev_event’ ‘socket:@/org/freedesktop/hal/udev_event’: No such file or directory
May 22 09:15:19 Emachines colord: device removed: sysfs-Canon_Inc.-Canon_Digital_Camera
ce depot n’est pas officiel et est connu pour provoquer des soucis de dépendances
Il faut monter ton noyau en Jessie
sudo apt-get install linux-headers-3.16.0-4-all linux-image-3.16.0-4-amd64 linux-headers-3.16.0-4-amd64
Nous ne pouvons pas répondre à cette question.
pour les equipements usb il faut ajouter le paquet mtp-tools
puis lorsqu’un appareil est connecté:
sudo mtp-detect
s’il n’est pas connu ajouté une règle dans /lib/udev/rules.d/69-libmtp.rules en fonction des identifiant vu par lsusb
Exemple mon appareil exotique connecté en PTP
@desktop:~$ lsusb
Bus 001 Device 015: ID 2717:0318
j’ai jouté la règle:
ATTR{idVendor}==“2717”, ATTR{idProduct}==“0318”, SYMLINK+=“libmtp-%k”, MODE=“660”, GROUP=“audio”, ENV{ID_MTP_DEVICE}=“1”, ENV{ID_MEDIA_PLAYER}=“1”
et redemarrer udev
sudo systemctl stop udev
sudo systemctl start udev
Et quand je le connecte en MTP:
lsusb
Bus 001 Device 016: ID 2717:0368
j’au aussi acces aux données par Thunar
qui l’ouvre à cette adresse
mtp://[usb:001,016]/Mémoire de stockage interne/
merci encore pour tout cette aide.
entre temps j’ai trouvé sur le net qu’il fallait virer le paquet HAL: depuis les mp3 sont detectés/montés automatiquement (pas encore les appareil photos).
je fais ce que vous me conseillez et je redonne des nouvelles…
A chaque fois je reprends espoir mais malhereusement a chaque fois je suis decu:
mtp-detect
Unable to open ~/.mtpz-data for reading, MTPZ disabled.
libmtp version: 1.1.8
Listing raw device(s)
No raw devices found.
quel appareil est branché?
que dit lsusb au meme moment.
c’est le canon:
lsusb
Bus 002 Device 002: ID 0402:7675 ALi Corp.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 009: ID 04a9:3272 Canon, Inc.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 04f3:0210 Elan Microelectronics Corp. Optical Mouse
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
