Je viens d’essayer Nexuiz, même tarif
En gros, tous mes jeux exploitant (apparament) le glx me font ça… donc ça ne vient pas d’une mauvaise config des jeux, ça pourrait venir de chez moi (sans blague…), aussi, voici mon fichier de conf pour xorg, des fois que vous trouviez une solution miracle
[quote]# xorg.conf (Xorg X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the xorg.conf manual page.
(Type “man xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following commands as root:
cp /etc/X11/xorg.conf /etc/X11/xorg.conf.custom
md5sum /etc/X11/xorg.conf >/var/lib/xfree86/xorg.conf.md5sum
dpkg-reconfigure xserver-xorg
Section "Files"
FontPath “unix/:7100” # local font server
# if the local font server has problems, we can fall back on these
FontPath "/usr/lib/X11/fonts/misc"
FontPath "/usr/lib/X11/fonts/cyrillic"
FontPath "/usr/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/Type1"
FontPath "/usr/lib/X11/fonts/CID"
FontPath "/usr/lib/X11/fonts/100dpi"
FontPath "/usr/lib/X11/fonts/75dpi"
EndSection
Section "Module"
Load "bitmap"
Load "dbe"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "record"
Load "type1"
Load "v4l"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "keyboard"
Option "CoreKeyboard"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/input/mice"
Option “Protocol” "ImPS/2"
Option “Emulate3Buttons” "true"
Option “ZAxisMapping” "4 5"
EndSection
Section "Device"
Identifier "ATI Technologies, Inc. Radeon R350 [Radeon 9800 Pro]"
Driver "fglrx"
EndSection
Section "Monitor"
Identifier "Écran générique"
Option "DPMS"
HorizSync 30-70
VertRefresh 50-160
EndSection
Section "Screen"
Identifier "Default Screen"
Device "ATI Technologies, Inc. Radeon R350 [Radeon 9800 Pro]"
Monitor "Écran générique"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes “1280x1024” “1024x768” “800x600” "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
EndSection
Section "DRI"
Mode 0666
EndSection[/quote]
Voici ce qu’un glxinfo me renvoit :
[quote]name of display: :0.0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_EXT_import_context, GLX_OML_swap_method, GLX_SGI_make_current_read,
GLX_SGIS_multisample, GLX_SGIX_fbconfig
client glx vendor string: ATI
client glx version string: 1.3
client glx extensions:
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context,
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_ATI_pixel_format_float,
GLX_ATI_render_texture
GLX extensions:
GLX_ARB_multisample
OpenGL vendor string: ATI Technologies Inc.
OpenGL renderer string: RADEON 9800 Pro Generic
OpenGL version string: 1.3.5519 (X4.3.0-8.20.8)
OpenGL extensions:
GL_ARB_multitexture, GL_EXT_texture_env_add, GL_EXT_compiled_vertex_array,
GL_S3_s3tc, GL_ARB_depth_texture, GL_ARB_fragment_program,
GL_ARB_fragment_program_shadow, GL_ARB_fragment_shader,
GL_ARB_multisample, GL_ARB_occlusion_query, GL_ARB_point_parameters,
GL_ARB_point_sprite, GL_ARB_shader_objects, GL_ARB_shading_language_100,
GL_ARB_shadow, GL_ARB_shadow_ambient, GL_ARB_texture_border_clamp,
GL_ARB_texture_compression, GL_ARB_texture_cube_map,
GL_ARB_texture_env_add, GL_ARB_texture_env_combine,
GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3,
GL_ARB_texture_mirrored_repeat, GL_ARB_transpose_matrix,
GL_ARB_vertex_blend, GL_ARB_vertex_buffer_object, GL_ARB_vertex_program,
GL_ARB_vertex_shader, GL_ARB_window_pos, GL_ARB_draw_buffers,
GL_ATI_draw_buffers, GL_ATI_element_array, GL_ATI_envmap_bumpmap,
GL_ATI_fragment_shader, GL_ATI_map_object_buffer, GL_ATI_separate_stencil,
GL_ATI_texture_env_combine3, GL_ATI_texture_float,
GL_ATI_texture_mirror_once, GL_ATI_vertex_array_object,
GL_ATI_vertex_attrib_array_object, GL_ATI_vertex_streams,
GL_ATIX_texture_env_combine3, GL_ATIX_texture_env_route,
GL_ATIX_vertex_shader_output_point_size, GL_EXT_abgr, GL_EXT_bgra,
GL_EXT_blend_color, GL_EXT_blend_func_separate, GL_EXT_blend_minmax,
GL_EXT_blend_subtract, GL_EXT_clip_volume_hint,
GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_framebuffer_object,
GL_EXT_multi_draw_arrays, GL_EXT_packed_pixels, GL_EXT_point_parameters,
GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_separate_specular_color, GL_EXT_shadow_funcs, GL_EXT_stencil_wrap,
GL_EXT_texgen_reflection, GL_EXT_texture3D,
GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map,
GL_EXT_texture_edge_clamp, GL_EXT_texture_env_combine,
GL_EXT_texture_env_dot3, GL_EXT_texture_filter_anisotropic,
GL_EXT_texture_lod_bias, GL_EXT_texture_mirror_clamp,
GL_EXT_texture_object, GL_EXT_texture_rectangle, GL_EXT_vertex_array,
GL_EXT_vertex_shader, GL_HP_occlusion_test, GL_NV_blend_square,
GL_NV_occlusion_query, GL_NV_texgen_reflection, GL_SGI_color_matrix,
GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp,
GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays
glu version: 1.3
glu extensions:
GLU_EXT_nurbs_tessellator, GLU_EXT_object_space_tess
visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat
0x23 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 1 0 None
0x24 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 1 0 None
0x25 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 1 0 None
0x26 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 1 0 None
0x27 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 1 0 None
0x28 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 1 0 None
0x29 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 1 0 None
0x2a 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 1 0 None
0x2b 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 1 0 None
0x2c 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 1 0 None
0x2d 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 1 0 None
0x2e 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 1 0 None
0x2f 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 2 1 None
0x30 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 2 1 None
0x31 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 2 1 None
0x32 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 2 1 None
0x33 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 1 0 None
0x34 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 1 0 None
0x35 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 1 0 None
0x36 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 1 0 None
0x37 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 4 1 None
0x38 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 4 1 None
0x39 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 4 1 None
0x3a 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 4 1 None
0x3b 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 1 0 None
0x3c 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 1 0 None
0x3d 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 1 0 None
0x3e 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 1 0 None
0x3f 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 6 1 None
0x40 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 6 1 None
0x41 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 6 1 None
0x42 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 6 1 None
0x43 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 1 0 None
0x44 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 1 0 None
0x45 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 1 0 None
0x46 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 1 0 None
0x47 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 1 0 None
0x48 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 1 0 None
0x49 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 1 0 None
0x4a 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 1 0 None
0x4b 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 1 0 None
0x4c 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 1 0 None
0x4d 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 1 0 None
0x4e 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 1 0 None
0x4f 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 2 1 None
0x50 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 2 1 None
0x51 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 2 1 None
0x52 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 2 1 None
0x53 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 1 0 None
0x54 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 1 0 None
0x55 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 1 0 None
0x56 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 1 0 None
0x57 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 4 1 None
0x58 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 4 1 None
0x59 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 4 1 None
0x5a 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 4 1 None
0x5b 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 1 0 None
0x5c 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 1 0 None
0x5d 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 1 0 None
0x5e 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 1 0 None
0x5f 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 6 1 None
0x60 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 6 1 None
0x61 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 6 1 None
0x62 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 6 1 None[/quote]
Pour les specs de mon écran voilà ce que ça donne (sinon il y a un lien plus complet dans un autre post du thread) :
[quote]Scanning Frequency Horizontal 31kHz ~ 80 kHz
Vertical 56~75Hz
Max. Resolution (Analog) 1280 x 1024 @ 75Hz
Recommended Resolution 1280 x 1024 @ 60Hz
Factory Preset Modes Analog 720 x 400 @ 70 Hz
640 x 480 @ 60/75 Hz
800 x 600 @ 60/75 Hz
1024 x 768 @ 60/70 Hz
1280 x 1024 @ 60/75 Hz[/quote]
