Savez-vous 'il y a moyen de lire des .ape sous nos debian? (idéalement avec xmms).
Merci.
Merci.
Trouvé ceci:
lea-linux.org/pho/read/20/311704
J’ai réussi à lire un .ape une seule fois, puis depuis impossible…:
"The filename “track01.ape” indicates that this file is of type “Monkey’s audio”. The contents of the file indicate that the file is of type “MP3 audio”. If you open this file, the file might present a security risk to your system.
Do not open the file unless you created the file yourself, or received the file from a trusted source. To open the file, rename the file to the correct extension for “MP3 audio”, then open the file normally. Alternatively, use the Open With menu to choose a specific application for the file. "
