Je veux creer une base de données sous OO et au lancement il me dit qu’il manque un JRE (Java) et que je dois en installer un ?!
est ce que ça veut dire que je n’ai pas de java ?
Oui. Mais tu as l’embarras du choix pour en installer un:console@emeraude:~$ apt-cache search java runtime
gij-3.4 - The GNU Java bytecode interpreter
kaffe-pthreads-profile - A POSIX threads and profiling enabled version of the Kaffe VM
libgcj5 - Java runtime library for use with gcj
libgcj5-common - Java runtime library for use with gcj (jar files)
libopenvrml4 - runtime shared library for VRML
apache - versatile, high-performance HTTP server
apache-perl - versatile, high-performance HTTP server with Perl support
apache-ssl - versatile, high-performance HTTP server with SSL support
gij-4.0 - The GNU Java bytecode interpreter
ikvm - Java virtual machine/compiler implemented in .NET (Mono)
jamvm - virtual machine which conforms to JVM specification 2
kaffe-jthreads - A green threads enabled version of the Kaffe VM
kaffe-pthreads - A POSIX threads enabled version of the Kaffe VM
libcommons-logging-java - commmon wrapper interface for several logging APIs
libentity-dev - XML-based GUI builder for GTK+ (core library development files)
libentity0 - XML-based GUI builder for GTK+ (core library)
libgcj-common - Java runtime library (common files)
libgcj6 - Java runtime library for use with gcj
libgcj6-common - Java runtime library for use with gcj (jar files)
libikvm-native - Native library for IKVM Java virtual machine for .NET (Mono)
liblog4j1.2-java - Logging library for java
libxsltc-java - XSL Transformations (XSLT) compiler from Xalan-Java
mono-jay - LALR(1) parser generator oriented to Java/.NET
pnet-compiler - DotGNU Portable.NET C# compiler & tools
sablevm - Free implementation of Java Virtual Machine (JVM) second edition
java-package - utility for building Java(TM) 2 related Debian packages
classpath-doc - free Java API documentation
gij - The GNU Java bytecode interpreter
java-gcj-compat - Java runtime environment using GIJ
java-gcj-compat-dev - Java runtime environment with GCJ
libjmagick6-jni - A java interface to ImageMagick - native library
libopenvrml5 - runtime shared library for VRML
libzip-ocaml - ocaml compression libraries
openoffice.org - OpenOffice.org Office suite version 2.0
xjed - editor for programmers (x11 version)
filler - simple game where two players try to capture half the board
libsidl-dev - Scientific Interface Definition Language (SIDL) C(++)/FORTRAN runtime devel
libsidl0.10.2 - Scientific Interface Definition Language (SIDL) C(++)/FORTRAN runtime
libsidl0.10.2-java - Scientific Interface Definition Language (SIDL) Java runtime
python2.4-babel - Scientific Interface Definition Language (SIDL) python runtime
j2re1.4 - Blackdown Java(TM) 2 Runtime Environment, Standard Edition
libgcj4 - Java runtime library for use with gcj
gij-3.3 - The GNU Java bytecode interpreter
libgcj4-common - Java runtime library for use with gcj (jar files)
merci pour les infos.
Je dois avoir une sources.list completement naze car j’ai tout juste la moitié de l’apt-cache …
bon je dois refaire la sources.list et tout ira mieux
[quote=“franck91”]merci pour les infos.
merci pour les infos[/quote]
Non, mais j’ai toutes les sources (sarge/etch/sid), avec des priorités…
je viens de voir qu’il y avait un paquet openfoffice, mais je peux pas faire un apt-get install openofice-machin truc si ?
il va pas essayer de m’installer encore une fois un openoffice ?
[quote=“franck91”]je viens de voir qu’il y avait un paquet openfoffice, mais je peux pas faire un apt-get install openofice-machin truc si ?
il va pas essayer de m’installer encore une fois un openoffice ?[/quote]
Si, forcément…
C’est pour ca que si tu l’as installé depuis les sources, il faut faire un “make uninstall” (avec un peu de chance, ca devrait nettoyer ce que tu as installé).
Si ca ne marche pas, il faut trouver et supprimmer toutes traces de l’Oo que tu as installé.
Par ailleurs, je te signales que la version en paquet dans la sarge est une version Oo 1, pas Oo 2, donc c’est un choix. (il y en a un en version 2 dans la sid, et je crois aussi en etch).
oui en effet dans sarge c’est Oo1.1.x pour passer en Oo2 j’ai pris la bidouille trouvée sur cet (excellent) forum.
