K9copy pour Debian 7.4?
Apper ne trouve pas K9copy.
Ce soft existe pour Debian?
Oui.
$ apt-cache policy k9copy k9copy: Installé : (aucun) Candidat : 2.3.6-0.0 Table de version : 2.3.6-0.0 0 400 http://mirror.home-dn.net/debian-multimedia/ stable/main amd64 Packages
[quote=“wetaskiwin”]Bonjour,
Oui.
[mono]$ apt-cache policy k9copy
k9copy:
Installé : (aucun)
Table de version :
2.3.6-0.0 0
400 mirror.home-dn.net/debian-multimedia/ stable/main amd64 Packages[/mono][/quote]
:033 … ?
[mono][19:30:56]:~$ acp k9copy
k9copy:
Installé : (aucun)
Table de version :
2.3.6-0.0 0
500 deb-multimedia.org/ oldstable/main i386 Packages
[19:31:01]:~$[/mono]
[mono][19:33:47] ~ # version
Linux pc-2-loreleil 3.2.0-4-686-pae #1 SMP Debian 3.2.54-2 i686 GNU/Linux
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 7.4 (wheezy)
Release: 7.4
Codename: wheezy
[19:33:49] ~ #[/mono]
[mono][19:39:39]:~$ cat /etc/apt/sources.list
wheezy
deb ftp.fr.debian.org/debian/ stable main contrib non-free
#deb-src ftp.fr.debian.org/debian/ stable main contrib non-free
wheezy security
deb security.debian.org/ stable/updates main contrib non-free
#deb-src security.debian.org/ stable/updates main contrib non-free
wheezy update
deb ftp.fr.debian.org/debian/ wheezy-updates main contrib non-free
#deb-src ftp.fr.debian.org/debian/ oldstable-updates main contrib non-free
Blackports
deb ftp.debian.org/debian/ wheezy-backports main contrib non-free
wheezy multimedia
deb deb-multimedia.org stable main non-free
#deb-src debian-multimedia.org/ wheezy main
Squeeze
deb ftp.fr.debian.org/debian/ oldstable main contrib non-free
#deb-src ftp.fr.debian.org/debian/ oldstable main contrib non-free
stable security
deb security.debian.org/ oldstable/updates main contrib non-free
#deb-src security.debian.org/ oldstable/updates main contrib non-free
squeeze update
deb ftp.fr.debian.org/debian/ oldstable-updates main contrib non-free
backports
deb backports.debian.org/debian-backports squeeze-backports main contrib non-free
#deb mozilla.debian.net/ oldstable-backports iceweasel-release
stable multimedia
deb deb-multimedia.org oldstable main non-free
#deb-src debian-multimedia.org oldstable main non-free
Merci pour vos réponses mais je n’arrive toujours pas à obtenir K9copy.
$ apt-cache policy k9copy N: Impossible de trouver le paquet k9copy
J’ai installé dans Synaptic des dépôts que vous m’avez indiqués (pas tous, j’en avais d’ailleurs qui étaient déjà installés), ça ne donne rien.
Ceci dit je m’y prends peut être comme un manche.
dans ton sources.list il faut ajouter le dépôt oldstable pour deb-multimedia ,sauvegarder la modification et faire apt-get update et ensuite installer ton paquet k9copy
Je n’ai pas eu besoin du old-stable, mais j’ai été oblige de rajouter la seconde ligne ?
deb http://deb-multimedia.org/ stable main non-free deb http://mirror.home-dn.net/debian-multimedia/ stable main non-free
[quote=“ggoodluck47”]Salut,
deb http://deb-multimedia.org/ stable main non-free deb http://mirror.home-dn.net/debian-multimedia/ stable main non-free [/quote]
J’aurais du poster la partie de mon sources.list concerné par la question. La ligne [mono]deb mirror.home-dn.net/debian-multimedia/ stable main non-free[/mono] y était déjà.
[quote=“BelZéButh”] :033 … ?
k9copy:
Installé : (aucun)
Table de version :
2.3.6-0.0 0
[19:31:01]:~$[/quote]
Je te remercie mais j’ai arrêté de fumer. Je n’aurais peut-être pas dû parce, si ça se trouve, c’est à cause de ça que je comprends de moins en moins tes réponses. :017
Cela dit, la version de k9copy que tu trouves en oldstable (que je n’ai pas dans mon sources.list) est en i386 alors que j’en vois une en amd64.
Bon à priori seul
fonctionne pour moi=>
apt-cache policy k9copy k9copy: Installé : (aucun) Candidat : 2.3.6-0.0 Table de version : 2.3.6-0.0 0 500 http://mirror.home-dn.net/debian-multimedia/ stable/main amd64 Packages
A la fin du apt-get update j’ai=>
Lecture des listes de paquets... Fait W: Erreur de GPG : http://mirror.home-dn.net stable Release : Les signatures suivantes n'ont pas pu être vérifiées car la clé publique n'est pas disponible : NO_PUBKEY 07DC563D1F41B907
Et à l’installation j’ai un petit avertissement=>
Vous êtes sur le point d’installer des paquetages non signés qui risquent de compromettre votre système, car il est impossible de vérifier si les logiciels proviennent d’une source de confiance.
Voulez-vous vraiment poursuivre l’installation ?
En fait ça m’a refroidi.
Mais je risque quoi concrètement?
Bon ok pas de nouvelle = bonne nouvelle…
En fait j’ai installé k9copy par
après avoir installé k3b (soft intéressante aussi au demeurant) avec les même messages d’alerte.
La chance sourit au audacieux alors soyons fou.
Re merci à tous.
[quote=“Kodabess”]Bonjour,
Ce soft existe pour Debian?[/quote]
Ta bécane est super mais pourquoi une si petite CG?
Bonne question, que dis je excellente question.
En fait j’ai taper cette carte pour upgrader une ancienne bécane mais Debian ne fonctionnait plus avec (problème de PCI Express).
J’ai donc assemblé une nouvelle bécane et par soucis d’économie j’ai monter cette carte.
[quote=“Kodabess”]Bonne question, que dis je excellente question.
J’ai donc assemblé une nouvelle bécane et par soucis d’économie j’ai monter cette carte.[/quote]
Car si j’etais mauvaise langue je dirais que le core graphique de ton cpu est plus puissant que ta carte… :laughing:
De Dieux mais t’as raison??!
Tu m’étonnes avec cette config, une gf 210 pour passer pour un con c’est de première :030
Merci pour ta judicieuse remarque.
moi je trouve que les puces graphique de intel sont a la ramasse …
essaye avec la commande glxgears (paquet mesa-utils) avec et sans ta carte graphique
tu as installé le pilote proprio de Nvidia ?
[quote]tu as installé le pilote proprio de Nvidia ?
Non je crois pas, mais où se trouve les pilotes installés sur Debian?
Merci pour la commande mais comment ça marche, par exemple voici ce que ça donne avec ma carte.
4207 frames in 5.0 seconds = 841.362 FPS 4167 frames in 5.0 seconds = 833.377 FPS 4336 frames in 5.0 seconds = 867.154 FPS 4213 frames in 5.0 seconds = 842.541 FPS 4171 frames in 5.0 seconds = 834.090 FPS 4313 frames in 5.0 seconds = 862.598 FPS
Je suis incapable de lire ce résultat et je dois laisser tourner la commande combien de temps?
Pour le test sans la carte c’est compromis pour l’instant la DVI de ma carte mère donne un écran noir.
bin tu as affiché 4313 images 5.0 seconds = 862.598 FrameParSecondes
tu laisse tourner quelques secondes avec aucun programme d’ouvert
il faut que tu débranches ta carte nvidia
j’utilisais a l’époque le script SGFXI :075 pour installer les pilotes proprio je ne sais pas si c’est toujours d’actualité (il faut activer les dépôts non-free aussi il me semble)
smxi.org/site/install.htm#sgfxi
lance une recherche sur le forum et créer un autre sujet si tu as des difficultés
Merci bien.
