salut à tous,
tout mes WM fonctionnent bien sauf Kde.
je passe kdm puis le paneau de démarrage qui se bloque à :
initialisations des servives systemes
comme message dans .xsession-errors j’ai ça.
startkde: Starting up…
QPixmap: Cannot create a QPixmap when no GUI is being used
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 16x16/stock/chart not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 16x16/stock/code not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 16x16/stock/data not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 16x16/stock/form not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 16x16/stock/image not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 16x16/stock/io not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 16x16/stock/media not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 16x16/stock/navigation not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 16x16/stock/net not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 16x16/stock/object not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 16x16/stock/table not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 16x16/stock/text not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 32x32/stock/chart not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 32x32/stock/code not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 32x32/stock/data not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 32x32/stock/form not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 32x32/stock/image not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 32x32/stock/io not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 32x32/stock/media not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 32x32/stock/navigation not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 32x32/stock/net not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 32x32/stock/object not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 32x32/stock/table not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 32x32/stock/text not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 36x36/stock/chart not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 36x36/stock/code not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 36x36/stock/data not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 36x36/stock/form not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 36x36/stock/image not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 36x36/stock/io not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 36x36/stock/media not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 36x36/stock/navigation not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 36x36/stock/net not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 36x36/stock/object not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 36x36/stock/table not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 36x36/stock/text not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 48x48/stock/chart not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 48x48/stock/code not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 48x48/stock/data not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 48x48/stock/form not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 48x48/stock/image not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 48x48/stock/io not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 48x48/stock/media not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 48x48/stock/navigation not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 48x48/stock/net not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 48x48/stock/object not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 48x48/stock/table not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 48x48/stock/text not valid.
ksplash: WARNING: KGenericFactory: instance requested but no instance name passed to the constructor!
klauncher: Exiting on signal 15 (la c’est normal j’ai tuer X) fatigué d’attendre.
y a quelqu’un qui a une solution ?
les répertoires d’icones indiqués sont vide
merci
Ignace
