Bonsoir à tous,
Après moultes recherches et installations de dépendances, je viens vous voir car imposible d’installer kodi ! J’ai du très probablement supprimé des dépendances indispensables à celui ci en installant d’autre programmes car je viens de formater et je ne me souvient pas avoir eu de difficultées à l’installer lors de la précédante installation .
Bref toujours utile que un classique apt-get install donne ceci :
Reading package lists… Done
Building dependency tree
Reading state information… Done
You might want to run ‘apt --fix-broken install’ to correct these.
The following packages have unmet dependencies:
kodi : Depends: kodi-bin (>= 2:17.5-1~stretch) but 2:17.3+dfsg1-5 is to be installed
Depends: mesa-utils but it is not going to be installed
Depends: python-bluez but it is not going to be installed or
python-lightblue but it is not going to be installed
Depends: libbluray1 but it is not going to be installed
Depends: libshairplay0 but it is not installable
Depends: libyajl2 but it is not going to be installed
kodi-bin : Depends: libcrossguid0 (>= 0.0+git200150803) but it is not going to be installed
Depends: libmariadbclient18 (>= 10.1.28) but 10.1.26-1 is to be installed
Depends: libmicrohttpd12 (>= 0.9.50) but it is not going to be installed
Depends: libpcrecpp0v5 (>= 7.7) but it is not going to be installed
Depends: libtinyxml2.6.2v5 but it is not going to be installed
Depends: libyajl2 (>= 2.0.4) but it is not going to be installed
E: Unmet dependencies. Try ‘apt --fix-broken install’ with no packages (or specify a solution).
J’ai essayé de trouver et d’installer toutes les dépendances à la main mais sans succès, rien que le premier kodi-bin me renvoie ceci :
Selecting previously unselected package kodi-bin:amd64.
(Reading database … 332303 files and directories currently installed.)
Preparing to unpack kodi-bin_17.3+dfsg1-5_amd64.deb …
Unpacking kodi-bin:amd64 (2:17.3+dfsg1-5) …
dpkg: dependency problems prevent configuration of kodi-bin:amd64:
kodi-bin:amd64 depends on libcrossguid0 (>= 0.0+git200150803); however:
Package libcrossguid0 is not installed.
kodi-bin:amd64 depends on libmariadbclient18 (>= 10.1.28); however:
Version of libmariadbclient18:amd64 on system is 10.1.26-1.
kodi-bin:amd64 depends on libmicrohttpd12 (>= 0.9.50); however:
Package libmicrohttpd12 is not installed.
kodi-bin:amd64 depends on libpcrecpp0v5 (>= 7.7); however:
Package libpcrecpp0v5 is not installed.
kodi-bin:amd64 depends on libtinyxml2.6.2v5; however:
Package libtinyxml2.6.2v5 is not installed.
kodi-bin:amd64 depends on libyajl2 (>= 2.0.4); however:
Package libyajl2 is not installed.
dpkg: error processing package kodi-bin:amd64 (–install):
dependency problems - leaving unconfigured
Processing triggers for libc-bin (2.24-17) …
Processing triggers for man-db (2.7.6.1-2) …
Errors were encountered while processing:
kodi-bin:amd64
En plus des dépendances installé manuellement j’ai essayé de suivre des tutos ici et là, comme celui là http://kodi.wiki/view/HOW-TO_compile_XBMC_for_Linux_on_Debian/Ubuntu même si j’ai conscience qu’il date un peu mais bon …
Voilà en gros j’y suis depuis plus de une heure et impossible de l’installer ! Le plus bizarre c’est qu’avant je n’avais eu aucun problème particulier … :\
En vous remerciant d’avance à tous
strictement rien de top secret, j’en et peur , je n’ai pas la prétention de me considérer comme étant assez important pour détenir “des choses” pour pouvant posséder un tel qualificatif ! Non j’avoue que comme sa tu me prend un peu au dépourvu, les choses en question doivent être wine, ou virtualbox très honnetement c’est les deux seuls choses pour lequel j’ai du y toucher, et encore que maintenant j’ai constater avant hier, que ça n’était même plus utile pour virtualbox !
